587,180 active members*
5,208 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > Rotating H200 rotary table using 4th axis
Results 1 to 9 of 9
    Jun 2008
    9
    Hey guys,
    We just installed a H200 rotary table on our VMX24. I need to install the Jergens Ball locks on all 4 sides to use for mounting fixtures. Simple question. How to I rotate the table 90 degrees on the A axis?
    Where do I put that information in the programs. We generally use subprograms at the bottom of the program and call them up at the top of the program. I know that A0 is the starting plane. then A90 would rotate to 90 degrees and A180 and so on. At least that is what I have been told.
    I am unclear as to where to place this information. We don't use conversational programming at all. Below is the program I would like to use.
    (Jergens FACEMOUNT RECEIVER BUSHING)
    (Program #1 of 1)
    ( Material
    ( Home : X,Y=O UL)
    ( Z=O Top)
    ( Note's : USING G52'S FOR LOCATIONS, SO ADJUSTING ONE THING)
    ( LIKE CB SIZE WILL ADJUST THEM ALL)
    ( Compendsation Required on all EM's)
    ( Tool #1 .625 DRILL)
    ( Tool #2 .500 EM---1.350 LOC---)
    ( Tool #3 .250 SPOT)
    ( Tool #4 .152 DRILL)
    ( Tool #5 8-32 ROLL TAP)
    G90G80G40
    N901G0T1M6( .625 DRILL)
    S2140M3
    G0Z1.000
    M8
    G54( Fixture Offset,number One)
    G52X0.750 Y-1.125
    G65 P1
    G52X0.750 Y-4.875
    G65 P1
    G52X12.000 Y-4.875
    G65 P1
    G52X12.000 Y-1.125
    G65 P1
    G52X23.250 Y-1.125
    G65 P1
    G52X23.250 Y-4.875
    G65 P1
    G52X0.Y0.
    M9
    G0Z1.000M5
    N902T2M6( .500 EM)
    S12100M3
    G0Z1.000
    M8
    G52X0.750 Y-1.125
    G65 P2 Z-.333
    G65 P2 Z-.666
    G65 P2 Z-1.000
    G65 P2 Z-1.000
    G65 P3 Z-.469
    G52X0.750 Y-4.875
    G65 P2 Z-.333
    G65 P2 Z-.666
    G65 P2 Z-1.000
    G65 P2 Z-1.000
    G65 P3 Z-.469
    G52X12.000 Y-4.875
    G65 P2 Z-.333
    G65 P2 Z-.666
    G65 P2 Z-1.000
    G65 P2 Z-1.000
    G65 P3 Z-.469
    G52X12.000 Y-1.125
    G65 P2 Z-.333
    G65 P2 Z-.666
    G65 P2 Z-1.000
    G65 P2 Z-1.000
    G65 P3 Z-.469
    G52X23.250 Y-1.125
    G65 P2 Z-.333
    G65 P2 Z-.666
    G65 P2 Z-1.000
    G65 P2 Z-1.000
    G65 P3 Z-.469
    G52X23.250 Y-4.875
    G65 P2 Z-.333
    G65 P2 Z-.666
    G65 P2 Z-1.000
    G65 P2 Z-1.000
    G65 P3 Z-.469
    G52X0.Y0.
    M9
    G0Z1.000
    G0X5.000Y8.000Z10.000
    M00
    S12100M3
    G0Z1.000
    M8
    G52X0.750 Y-1.125
    G65 P4 Z-.469
    G52X0.750 Y-4.875
    G65 P4 Z-.469
    G52X12.000 Y-4.875
    G65 P4 Z-.469
    G52X12.000 Y-1.125
    G65 P4 Z-.469
    G52X23.250 Y-1.125
    G65 P4 Z-.469
    G52X23.250 Y-4.875
    G65 P4 Z-.469
    G52X0.Y0.
    M9
    G0Z1.000
    M00
    G0Z11.000M5
    N903T3M6( .250 SPOT)
    S12100M3
    G0Z1.000
    M8
    G52X0.750 Y-1.125
    G65 P7
    G65 P8
    G65 P10
    G52X0.750 Y-4.875
    G65 P7
    G65 P8
    G65 P10
    G52X12.000 Y-4.875
    G65 P7
    G65 P8
    G65 P10
    G52X12.000 Y-1.125
    G65 P7
    G65 P8
    G65 P10
    G52X23.250 Y-1.125
    G65 P7
    G65 P8
    G65 P10
    G52X23.250 Y-4.875
    G65 P7
    G65 P8
    G65 P10
    G52X0.Y0.
    M9
    G0Z1.000M5
    N904T4M6( .152 DRILL)
    S8000M3
    G0Z1.000
    M8
    G52X0.750 Y-1.125
    G65 P11
    G52X0.750 Y-4.875
    G65 P11
    G52X12.000 Y-4.875
    G65 P11
    G52X12.000 Y-1.125
    G65 P11
    G52X23.250 Y-1.125
    G65 P11
    G52X23.250 Y-4.875
    G65 P11
    G52X0.Y0.
    M9
    G0Z1.000M5
    N905T5M6( 8-32 TAP)
    S2000M3
    G0Z1.000
    M8
    G52X0.750 Y-1.125
    G65 P12
    G52X0.750 Y-4.875
    G65 P12
    G52X12.000 Y-4.875
    G65 P12
    G52X12.000 Y-1.125
    G65 P12
    G52X23.250 Y-1.125
    G65 P12
    G52X23.250 Y-4.875
    G65 P12
    G52X0.Y0.
    M9
    G0Z1.000M5
    N901T1M6( .625 DRILL)
    N920G0X-5.150Y18.100Z15.000(CHANGE X,Y,Z TO GET GOOD MACHINE HOME)
    M30( ===========End of Program =========)
    O1
    N1G0X0.Y0.Z.100( .625 DRILL )
    G81 Z-1.000 R.100 F23.
    N1G0Z.100
    M99
    O2
    N2G0X0.Y0.Z.100( .500 EM, Z-1.000, .687 HOLE)
    G1 Z#26 F50.
    G1 X0.0938 F10.
    G3 X0.0938 Y0. I-0.0938 J0.
    G1 X0.
    N2G0Z.100
    M99
    O3
    N3G0X0.Y0.Z.100( .500 EM, Z-.469, 1.345, ROUGH SIZE)
    G1 Z#26 F50.
    G1 X0.4225 F10.
    G3 X0.4225 Y0. I-0.4225 J0.
    G1 X0.
    N3G0Z.100
    M99
    O4
    N4G0X0.Y0.Z.100( .500 EM, Z-.469, 1.375 +0./-.0004 HOLE)
    G1 Z#26 F50.
    G1 X0.4375 F10.
    G3 X0.4375 Y0. I-0.4375 J0.
    G1 X0.
    N4G0Z.100
    M99
    O7
    N7G0X0.Y0.Z.100( .187 SPOT, DEBURR DEEP)
    G1 Z-.544 F50.
    G1 X0.2688 F10.
    G3 X0.2688 Y0. I-0.2688 J0.
    G1 X0.
    N7G0Z.100
    M99
    O8
    N8G0X0.Y0.Z.100( .187 SPOT, DEBURR TOP)
    G1 Z-.075 F50.
    G1 X0.6125 F10.
    G3 X0.6125 Y0. I-0.6125 J0.
    G1 X0.
    N8G0Z.100
    M99
    O10
    N10G0X0.492Y0.Z.100( .187 SPOT)
    G81 Z-.551 R.100 F25.
    X-0.246 Y-0.4261
    X-0.246 Y0.4261
    N10G0Z.100
    M99
    O11
    N11G0X0.492Y0.Z.100( .152 DRILL)
    G81 Z-.869 R.100 F25.
    X-0.246 Y-0.4261
    X-0.246 Y0.4261
    N11G0Z.100
    M99
    O12
    N12G0X0.492Y0.Z.100( 8-32 TAP)
    M29
    G84 Z-.840 R.100 P0. F62.50
    X-0.246 Y-0.4261
    X-0.246 Y0.4261
    N12G0Z.100
    M99
    E
    Jun 2008
    9
    Re: Rotating H200 rotary table using 4th axis
    Just one more thing, we will be using this more as an indexer rather than true 4th axis. We will machine parts at 0, the rotate to 90 and machine those parts and so on.
    Jul 2010
    492
    here is one of my programs for using our 4th axis.... this is all stationary work, not any rotating while milling.......
    Code:
    (PROGRAM NAME -  1118812 4TH AXIS )
    (DATE=DD-MM-YY -  03-06-14  TIME=HH:MM -  16:30 )
    N10 G0 G17 G40 G80 G90
    (  1/2 FLAT ENDMILL   TOOL - 20  DIA. OFF. - 20  LEN. - 20  DIA. - .5 )
    N11 T20 M6
    N12 G43 H20
    N13 G0 G90 G54 X.785 Y-.18 S9000 M3
    N14 M33
    N15 G0 G90 A-30.
    N16 M32
    N17 Z.25
    N18 Z.1
    N19 G1 Z0. F500.
    N20 Y.21 Z-.0328 F250.
    N21 X.58 Z-.05
    N22 Y-.18 Z-.0828
    N23 X.785 Z-.1
    N24 Y.21 Z-.1328
    N25 X.58 Z-.15
    N26 Y-.18 Z-.1828
    N27 X.785 Z-.2
    N28 Y.21 Z-.2328
    N29 X.58 Z-.25
    N30 Y-.18 Z-.2828
    N31 X.785 Z-.3
    N32 Y.21 Z-.3328
    N33 X.58 Z-.35
    N34 Y-.18 Z-.3828
    N35 X.785 Z-.4
    N36 Y.21 Z-.4328
    N37 X.58 Z-.45
    N38 Y-.18 Z-.4828
    N39 X.785 Z-.5
    N40 Y.21 Z-.5328
    N41 X.58 Z-.55
    N42 Y-.18 Z-.5828
    N43 X.785 Z-.6
    N44 Y.21 Z-.6328
    N45 X.58 Z-.65
    N46 Y-.18 Z-.6828
    N47 X.785 Z-.7
    N48 Y.21 Z-.7328
    N49 X.58 Z-.75
    N50 Y-.18 Z-.7828
    N51 X.785 Z-.8
    N52 Y.21 Z-.8328
    N53 X.58 Z-.85
    N54 Y-.18 Z-.8828
    N55 X.785 Z-.9
    N56 Y.21 Z-.9328
    N57 X.58 Z-.95
    N58 Y-.18 Z-.9828
    N59 X.785 Z-1.
    N60 Y.21
    N61 X.58
    N62 Y-.18
    N63 X.785
    N64 G0 Z.25
    N65 X.985 Y-.38
    N66 Z.1
    N67 G1 Z0. F500.
    N68 Y.41 Z-.0283 F250.
    N69 X.38 Z-.05
    N70 Y-.38 Z-.0783
    N71 X.985 Z-.1
    N72 Y.41 Z-.1283
    N73 X.38 Z-.15
    N74 Y-.38 Z-.1783
    N75 X.985 Z-.2
    N76 Y.41 Z-.2283
    N77 X.38 Z-.25
    N78 Y-.38 Z-.2783
    N79 X.985 Z-.3
    N80 Y.41 Z-.3283
    N81 X.38 Z-.35
    N82 Y-.38 Z-.3783
    N83 X.985 Z-.4
    N84 Y.41 Z-.4283
    N85 X.38 Z-.45
    N86 Y-.38 Z-.4783
    N87 X.985 Z-.5
    N88 Y.41 Z-.5283
    N89 X.38 Z-.55
    N90 Y-.38 Z-.5783
    N91 X.985 Z-.6
    N92 Y.41 Z-.6283
    N93 X.38 Z-.65
    N94 Y-.38 Z-.6783
    N95 X.985 Z-.7
    N96 Y.41 Z-.7283
    N97 X.38 Z-.75
    N98 Y-.38 Z-.7783
    N99 X.985 Z-.8
    N100 Y.41 Z-.8283
    N101 X.38 Z-.85
    N102 Y-.38 Z-.8783
    N103 X.985 Z-.9
    N104 Y.41 Z-.9283
    N105 X.38 Z-.95
    N106 Y-.38 Z-.9783
    N107 X.985 Z-1.
    N108 Y.41
    N109 X.38
    N110 Y-.38
    N111 X.985
    N112 G0 Z.25
    N113 M5
    N114 G91 G28 Z0.
    N115 M01
    (  1/4 FLAT ENDMILL   TOOL - 5  DIA. OFF. - 5  LEN. - 5  DIA. - .25 )
    N116 T5 M6
    N117 G43 H5
    N118 G0 G90 G54 X1.12 Y-.39 S9000 M3
    N119 M33
    N120 G0 G90 A-30.
    N121 M32
    N122 Z.25
    N123 Z.1
    N124 G1 Z0. F500.
    N125 Y.42 Z-.0055 F250.
    N126 G3 X.995 Y.545 Z-.0069 I-.125
    N127 G1 X.37 Z-.0112
    N128 G3 X.245 Y.42 Z-.0125 J-.125
    N129 G1 Y-.39 Z-.018
    N130 G3 X.37 Y-.515 Z-.0194 I.125
    N131 G1 X.995 Z-.0237
    N132 G3 X1.12 Y-.39 Z-.025 J.125
    N133 G1 Y.42 Z-.0305
    N134 G3 X.995 Y.545 Z-.0319 I-.125
    N135 G1 X.37 Z-.0362
    N136 G3 X.245 Y.42 Z-.0375 J-.125
    N137 G1 Y-.39 Z-.043
    N138 G3 X.37 Y-.515 Z-.0444 I.125
    N139 G1 X.995 Z-.0487
    N140 G3 X1.12 Y-.39 Z-.05 J.125
    N141 G1 Y.42 Z-.0555
    N142 G3 X.995 Y.545 Z-.0569 I-.125
    N143 G1 X.37 Z-.0612
    N144 G3 X.245 Y.42 Z-.0625 J-.125
    N145 G1 Y-.39 Z-.068
    N146 G3 X.37 Y-.515 Z-.0694 I.125
    N147 G1 X.995 Z-.0737
    N148 G3 X1.12 Y-.39 Z-.075 J.125
    N149 G1 Y.42 Z-.0805
    N150 G3 X.995 Y.545 Z-.0819 I-.125
    N151 G1 X.37 Z-.0862
    N152 G3 X.245 Y.42 Z-.0875 J-.125
    N153 G1 Y-.39 Z-.093
    N154 G3 X.37 Y-.515 Z-.0944 I.125
    N155 G1 X.995 Z-.0987
    N156 G3 X1.12 Y-.39 Z-.1 J.125
    N157 G1 Y.42 Z-.1055
    N158 G3 X.995 Y.545 Z-.1069 I-.125
    N159 G1 X.37 Z-.1112
    N160 G3 X.245 Y.42 Z-.1125 J-.125
    N161 G1 Y-.39 Z-.118
    N162 G3 X.37 Y-.515 Z-.1194 I.125
    N163 G1 X.995 Z-.1237
    N164 G3 X1.12 Y-.39 Z-.125 J.125
    N165 G1 Y.42 Z-.1305
    N166 G3 X.995 Y.545 Z-.1319 I-.125
    N167 G1 X.37 Z-.1362
    N168 G3 X.245 Y.42 Z-.1375 J-.125
    N169 G1 Y-.39 Z-.143
    N170 G3 X.37 Y-.515 Z-.1444 I.125
    N171 G1 X.995 Z-.1487
    N172 G3 X1.12 Y-.39 Z-.15 J.125
    N173 G1 Y.42 Z-.1555
    N174 G3 X.995 Y.545 Z-.1569 I-.125
    N175 G1 X.37 Z-.1612
    N176 G3 X.245 Y.42 Z-.1625 J-.125
    N177 G1 Y-.39 Z-.168
    N178 G3 X.37 Y-.515 Z-.1694 I.125
    N179 G1 X.995 Z-.1737
    N180 G3 X1.12 Y-.39 Z-.175 J.125
    N181 G1 Y.42 Z-.1805
    N182 G3 X.995 Y.545 Z-.1819 I-.125
    N183 G1 X.37 Z-.1862
    N184 G3 X.245 Y.42 Z-.1875 J-.125
    N185 G1 Y-.39 Z-.193
    N186 G3 X.37 Y-.515 Z-.1944 I.125
    N187 G1 X.995 Z-.1987
    N188 G3 X1.12 Y-.39 Z-.2 J.125
    N189 G1 Y.42 Z-.2055
    N190 G3 X.995 Y.545 Z-.2069 I-.125
    N191 G1 X.37 Z-.2112
    N192 G3 X.245 Y.42 Z-.2125 J-.125
    N193 G1 Y-.39 Z-.218
    N194 G3 X.37 Y-.515 Z-.2194 I.125
    N195 G1 X.995 Z-.2237
    N196 G3 X1.12 Y-.39 Z-.225 J.125
    N197 G1 Y.42 Z-.2305
    N198 G3 X.995 Y.545 Z-.2319 I-.125
    N199 G1 X.37 Z-.2362
    N200 G3 X.245 Y.42 Z-.2375 J-.125
    N201 G1 Y-.39 Z-.243
    N202 G3 X.37 Y-.515 Z-.2444 I.125
    N203 G1 X.995 Z-.2487
    N204 G3 X1.12 Y-.39 Z-.25 J.125
    N205 G1 Y.42 Z-.2555
    N206 G3 X.995 Y.545 Z-.2569 I-.125
    N207 G1 X.37 Z-.2612
    N208 G3 X.245 Y.42 Z-.2625 J-.125
    N209 G1 Y-.39 Z-.268
    N210 G3 X.37 Y-.515 Z-.2694 I.125
    N211 G1 X.995 Z-.2737
    N212 G3 X1.12 Y-.39 Z-.275 J.125
    N213 G1 Y.42 Z-.2805
    N214 G3 X.995 Y.545 Z-.2819 I-.125
    N215 G1 X.37 Z-.2862
    N216 G3 X.245 Y.42 Z-.2875 J-.125
    N217 G1 Y-.39 Z-.293
    N218 G3 X.37 Y-.515 Z-.2944 I.125
    N219 G1 X.995 Z-.2987
    N220 G3 X1.12 Y-.39 Z-.3 J.125
    N221 G1 Y.42 Z-.3055
    N222 G3 X.995 Y.545 Z-.3069 I-.125
    N223 G1 X.37 Z-.3112
    N224 G3 X.245 Y.42 Z-.3125 J-.125
    N225 G1 Y-.39 Z-.318
    N226 G3 X.37 Y-.515 Z-.3194 I.125
    N227 G1 X.995 Z-.3237
    N228 G3 X1.12 Y-.39 Z-.325 J.125
    N229 G1 Y.42 Z-.3305
    N230 G3 X.995 Y.545 Z-.3319 I-.125
    N231 G1 X.37 Z-.3362
    N232 G3 X.245 Y.42 Z-.3375 J-.125
    N233 G1 Y-.39 Z-.343
    N234 G3 X.37 Y-.515 Z-.3444 I.125
    N235 G1 X.995 Z-.3487
    N236 G3 X1.12 Y-.39 Z-.35 J.125
    N237 G1 Y.42 Z-.3555
    N238 G3 X.995 Y.545 Z-.3569 I-.125
    N239 G1 X.37 Z-.3612
    N240 G3 X.245 Y.42 Z-.3625 J-.125
    N241 G1 Y-.39 Z-.368
    N242 G3 X.37 Y-.515 Z-.3694 I.125
    N243 G1 X.995 Z-.3737
    N244 G3 X1.12 Y-.39 Z-.375 J.125
    N245 G1 Y.42 Z-.3805
    N246 G3 X.995 Y.545 Z-.3819 I-.125
    N247 G1 X.37 Z-.3862
    N248 G3 X.245 Y.42 Z-.3875 J-.125
    N249 G1 Y-.39 Z-.393
    N250 G3 X.37 Y-.515 Z-.3944 I.125
    N251 G1 X.995 Z-.3987
    N252 G3 X1.12 Y-.39 Z-.4 J.125
    N253 G1 Y.42 Z-.4055
    N254 G3 X.995 Y.545 Z-.4069 I-.125
    N255 G1 X.37 Z-.4112
    N256 G3 X.245 Y.42 Z-.4125 J-.125
    N257 G1 Y-.39 Z-.418
    N258 G3 X.37 Y-.515 Z-.4194 I.125
    N259 G1 X.995 Z-.4237
    N260 G3 X1.12 Y-.39 Z-.425 J.125
    N261 G1 Y.42 Z-.4305
    N262 G3 X.995 Y.545 Z-.4319 I-.125
    N263 G1 X.37 Z-.4362
    N264 G3 X.245 Y.42 Z-.4375 J-.125
    N265 G1 Y-.39 Z-.443
    N266 G3 X.37 Y-.515 Z-.4444 I.125
    N267 G1 X.995 Z-.4487
    N268 G3 X1.12 Y-.39 Z-.45 J.125
    N269 G1 Y.42 Z-.4555
    N270 G3 X.995 Y.545 Z-.4569 I-.125
    N271 G1 X.37 Z-.4612
    N272 G3 X.245 Y.42 Z-.4625 J-.125
    N273 G1 Y-.39 Z-.468
    N274 G3 X.37 Y-.515 Z-.4694 I.125
    N275 G1 X.995 Z-.4737
    N276 G3 X1.12 Y-.39 Z-.475 J.125
    N277 G1 Y.42 Z-.4805
    N278 G3 X.995 Y.545 Z-.4819 I-.125
    N279 G1 X.37 Z-.4862
    N280 G3 X.245 Y.42 Z-.4875 J-.125
    N281 G1 Y-.39 Z-.493
    N282 G3 X.37 Y-.515 Z-.4944 I.125
    N283 G1 X.995 Z-.4987
    N284 G3 X1.12 Y-.39 Z-.5 J.125
    N285 G1 Y.42 Z-.5055
    N286 G3 X.995 Y.545 Z-.5069 I-.125
    N287 G1 X.37 Z-.5112
    N288 G3 X.245 Y.42 Z-.5125 J-.125
    N289 G1 Y-.39 Z-.518
    N290 G3 X.37 Y-.515 Z-.5194 I.125
    N291 G1 X.995 Z-.5237
    N292 G3 X1.12 Y-.39 Z-.525 J.125
    N293 G1 Y.42 Z-.5305
    N294 G3 X.995 Y.545 Z-.5319 I-.125
    N295 G1 X.37 Z-.5362
    N296 G3 X.245 Y.42 Z-.5375 J-.125
    N297 G1 Y-.39 Z-.543
    N298 G3 X.37 Y-.515 Z-.5444 I.125
    N299 G1 X.995 Z-.5487
    N300 G3 X1.12 Y-.39 Z-.55 J.125
    N301 G1 Y.42 Z-.5555
    N302 G3 X.995 Y.545 Z-.5569 I-.125
    N303 G1 X.37 Z-.5612
    N304 G3 X.245 Y.42 Z-.5625 J-.125
    N305 G1 Y-.39 Z-.568
    N306 G3 X.37 Y-.515 Z-.5694 I.125
    N307 G1 X.995 Z-.5737
    N308 G3 X1.12 Y-.39 Z-.575 J.125
    N309 G1 Y.42 Z-.5805
    N310 G3 X.995 Y.545 Z-.5819 I-.125
    N311 G1 X.37 Z-.5862
    N312 G3 X.245 Y.42 Z-.5875 J-.125
    N313 G1 Y-.39 Z-.593
    N314 G3 X.37 Y-.515 Z-.5944 I.125
    N315 G1 X.995 Z-.5987
    N316 G3 X1.12 Y-.39 Z-.6 J.125
    N317 G1 Y.42 Z-.6055
    N318 G3 X.995 Y.545 Z-.6069 I-.125
    N319 G1 X.37 Z-.6112
    N320 G3 X.245 Y.42 Z-.6125 J-.125
    N321 G1 Y-.39 Z-.618
    N322 G3 X.37 Y-.515 Z-.6194 I.125
    N323 G1 X.995 Z-.6237
    N324 G3 X1.12 Y-.39 Z-.625 J.125
    N325 G1 Y.42 Z-.6305
    N326 G3 X.995 Y.545 Z-.6319 I-.125
    N327 G1 X.37 Z-.6362
    N328 G3 X.245 Y.42 Z-.6375 J-.125
    N329 G1 Y-.39 Z-.643
    N330 G3 X.37 Y-.515 Z-.6444 I.125
    N331 G1 X.995 Z-.6487
    N332 G3 X1.12 Y-.39 Z-.65 J.125
    N333 G1 Y.42 Z-.6555
    N334 G3 X.995 Y.545 Z-.6569 I-.125
    N335 G1 X.37 Z-.6612
    N336 G3 X.245 Y.42 Z-.6625 J-.125
    N337 G1 Y-.39 Z-.668
    N338 G3 X.37 Y-.515 Z-.6694 I.125
    N339 G1 X.995 Z-.6737
    N340 G3 X1.12 Y-.39 Z-.675 J.125
    N341 G1 Y.42 Z-.6805
    N342 G3 X.995 Y.545 Z-.6819 I-.125
    N343 G1 X.37 Z-.6862
    N344 G3 X.245 Y.42 Z-.6875 J-.125
    N345 G1 Y-.39 Z-.693
    N346 G3 X.37 Y-.515 Z-.6944 I.125
    N347 G1 X.995 Z-.6987
    N348 G3 X1.12 Y-.39 Z-.7 J.125
    N349 G1 Y.42 Z-.7055
    N350 G3 X.995 Y.545 Z-.7069 I-.125
    N351 G1 X.37 Z-.7112
    N352 G3 X.245 Y.42 Z-.7125 J-.125
    N353 G1 Y-.39 Z-.718
    N354 G3 X.37 Y-.515 Z-.7194 I.125
    N355 G1 X.995 Z-.7237
    N356 G3 X1.12 Y-.39 Z-.725 J.125
    N357 G1 Y.42 Z-.7305
    N358 G3 X.995 Y.545 Z-.7319 I-.125
    N359 G1 X.37 Z-.7362
    N360 G3 X.245 Y.42 Z-.7375 J-.125
    N361 G1 Y-.39 Z-.743
    N362 G3 X.37 Y-.515 Z-.7444 I.125
    N363 G1 X.995 Z-.7487
    N364 G3 X1.12 Y-.39 Z-.75 J.125
    N365 G1 Y.42 Z-.7555
    N366 G3 X.995 Y.545 Z-.7569 I-.125
    N367 G1 X.37 Z-.7612
    N368 G3 X.245 Y.42 Z-.7625 J-.125
    N369 G1 Y-.39 Z-.768
    N370 G3 X.37 Y-.515 Z-.7694 I.125
    N371 G1 X.995 Z-.7737
    N372 G3 X1.12 Y-.39 Z-.775 J.125
    N373 G1 Y.42 Z-.7805
    N374 G3 X.995 Y.545 Z-.7819 I-.125
    N375 G1 X.37 Z-.7862
    N376 G3 X.245 Y.42 Z-.7875 J-.125
    N377 G1 Y-.39 Z-.793
    N378 G3 X.37 Y-.515 Z-.7944 I.125
    N379 G1 X.995 Z-.7987
    N380 G3 X1.12 Y-.39 Z-.8 J.125
    N381 G1 Y.42 Z-.8055
    N382 G3 X.995 Y.545 Z-.8069 I-.125
    N383 G1 X.37 Z-.8112
    N384 G3 X.245 Y.42 Z-.8125 J-.125
    N385 G1 Y-.39 Z-.818
    N386 G3 X.37 Y-.515 Z-.8194 I.125
    N387 G1 X.995 Z-.8237
    N388 G3 X1.12 Y-.39 Z-.825 J.125
    N389 G1 Y.42 Z-.8305
    N390 G3 X.995 Y.545 Z-.8319 I-.125
    N391 G1 X.37 Z-.8362
    N392 G3 X.245 Y.42 Z-.8375 J-.125
    N393 G1 Y-.39 Z-.843
    N394 G3 X.37 Y-.515 Z-.8444 I.125
    N395 G1 X.995 Z-.8487
    N396 G3 X1.12 Y-.39 Z-.85 J.125
    N397 G1 Y.42 Z-.8555
    N398 G3 X.995 Y.545 Z-.8569 I-.125
    N399 G1 X.37 Z-.8612
    N400 G3 X.245 Y.42 Z-.8625 J-.125
    N401 G1 Y-.39 Z-.868
    N402 G3 X.37 Y-.515 Z-.8694 I.125
    N403 G1 X.995 Z-.8737
    N404 G3 X1.12 Y-.39 Z-.875 J.125
    N405 G1 Y.42 Z-.8805
    N406 G3 X.995 Y.545 Z-.8819 I-.125
    N407 G1 X.37 Z-.8862
    N408 G3 X.245 Y.42 Z-.8875 J-.125
    N409 G1 Y-.39 Z-.893
    N410 G3 X.37 Y-.515 Z-.8944 I.125
    N411 G1 X.995 Z-.8987
    N412 G3 X1.12 Y-.39 Z-.9 J.125
    N413 G1 Y.42 Z-.9055
    N414 G3 X.995 Y.545 Z-.9069 I-.125
    N415 G1 X.37 Z-.9112
    N416 G3 X.245 Y.42 Z-.9125 J-.125
    N417 G1 Y-.39 Z-.918
    N418 G3 X.37 Y-.515 Z-.9194 I.125
    N419 G1 X.995 Z-.9237
    N420 G3 X1.12 Y-.39 Z-.925 J.125
    N421 G1 Y.42 Z-.9305
    N422 G3 X.995 Y.545 Z-.9319 I-.125
    N423 G1 X.37 Z-.9362
    N424 G3 X.245 Y.42 Z-.9375 J-.125
    N425 G1 Y-.39 Z-.943
    N426 G3 X.37 Y-.515 Z-.9444 I.125
    N427 G1 X.995 Z-.9487
    N428 G3 X1.12 Y-.39 Z-.95 J.125
    N429 G1 Y.42 Z-.9555
    N430 G3 X.995 Y.545 Z-.9569 I-.125
    N431 G1 X.37 Z-.9612
    N432 G3 X.245 Y.42 Z-.9625 J-.125
    N433 G1 Y-.39 Z-.968
    N434 G3 X.37 Y-.515 Z-.9694 I.125
    N435 G1 X.995 Z-.9737
    N436 G3 X1.12 Y-.39 Z-.975 J.125
    N437 G1 Y.42 Z-.9805
    N438 G3 X.995 Y.545 Z-.9819 I-.125
    N439 G1 X.37 Z-.9862
    N440 G3 X.245 Y.42 Z-.9875 J-.125
    N441 G1 Y-.39 Z-.993
    N442 G3 X.37 Y-.515 Z-.9944 I.125
    N443 G1 X.995 Z-.9987
    N444 G3 X1.12 Y-.39 Z-1. J.125
    N445 G1 Y.42
    N446 G3 X.995 Y.545 I-.125
    N447 G1 X.37
    N448 G3 X.245 Y.42 J-.125
    N449 G1 Y-.39
    N450 G3 X.37 Y-.515 I.125
    N451 G1 X.995
    N452 G3 X1.12 Y-.39 J.125
    N453 G0 Z.25
    N454 M5
    N455 G91 G28 Z0.
    N456 M01
    N457 T20 M6
    N458 G43 H20
    N459 G0 G90 G54 X.785 Y-.21 S9000 M3
    N460 M33
    N461 G0 G90 A-150.
    N462 M32
    N463 Z.25
    N464 Z.1
    N465 G1 Z0. F500.
    N466 Y.18 Z-.0328 F250.
    N467 X.58 Z-.05
    N468 Y-.21 Z-.0828
    N469 X.785 Z-.1
    N470 Y.18 Z-.1328
    N471 X.58 Z-.15
    N472 Y-.21 Z-.1828
    N473 X.785 Z-.2
    N474 Y.18 Z-.2328
    N475 X.58 Z-.25
    N476 Y-.21 Z-.2828
    N477 X.785 Z-.3
    N478 Y.18 Z-.3328
    N479 X.58 Z-.35
    N480 Y-.21 Z-.3828
    N481 X.785 Z-.4
    N482 Y.18 Z-.4328
    N483 X.58 Z-.45
    N484 Y-.21 Z-.4828
    N485 X.785 Z-.5
    N486 Y.18 Z-.5328
    N487 X.58 Z-.55
    N488 Y-.21 Z-.5828
    N489 X.785 Z-.6
    N490 Y.18 Z-.6328
    N491 X.58 Z-.65
    N492 Y-.21 Z-.6828
    N493 X.785 Z-.7
    N494 Y.18 Z-.7328
    N495 X.58 Z-.75
    N496 Y-.21 Z-.7828
    N497 X.785 Z-.8
    N498 Y.18 Z-.8328
    N499 X.58 Z-.85
    N500 Y-.21 Z-.8828
    N501 X.785 Z-.9
    N502 Y.18 Z-.9328
    N503 X.58 Z-.95
    N504 Y-.21 Z-.9828
    N505 X.785 Z-1.
    N506 Y.18
    N507 X.58
    N508 Y-.21
    N509 X.785
    N510 G0 Z.25
    N511 X.985 Y-.41
    N512 Z.1
    N513 G1 Z0. F500.
    N514 Y.38 Z-.0283 F250.
    N515 X.38 Z-.05
    N516 Y-.41 Z-.0783
    N517 X.985 Z-.1
    N518 Y.38 Z-.1283
    N519 X.38 Z-.15
    N520 Y-.41 Z-.1783
    N521 X.985 Z-.2
    N522 Y.38 Z-.2283
    N523 X.38 Z-.25
    N524 Y-.41 Z-.2783
    N525 X.985 Z-.3
    N526 Y.38 Z-.3283
    N527 X.38 Z-.35
    N528 Y-.41 Z-.3783
    N529 X.985 Z-.4
    N530 Y.38 Z-.4283
    N531 X.38 Z-.45
    N532 Y-.41 Z-.4783
    N533 X.985 Z-.5
    N534 Y.38 Z-.5283
    N535 X.38 Z-.55
    N536 Y-.41 Z-.5783
    N537 X.985 Z-.6
    N538 Y.38 Z-.6283
    N539 X.38 Z-.65
    N540 Y-.41 Z-.6783
    N541 X.985 Z-.7
    N542 Y.38 Z-.7283
    N543 X.38 Z-.75
    N544 Y-.41 Z-.7783
    N545 X.985 Z-.8
    N546 Y.38 Z-.8283
    N547 X.38 Z-.85
    N548 Y-.41 Z-.8783
    N549 X.985 Z-.9
    N550 Y.38 Z-.9283
    N551 X.38 Z-.95
    N552 Y-.41 Z-.9783
    N553 X.985 Z-1.
    N554 Y.38
    N555 X.38
    N556 Y-.41
    N557 X.985
    N558 G0 Z.25
    N559 M5
    N560 G91 G28 Z0.
    N561 M01
    N562 T5 M6
    N563 G43 H5
    N564 G0 G90 G54 X1.12 Y-.42 S9000 M3
    N565 M33
    N566 G0 G90 A-150.
    N567 M32
    N568 Z.25
    N569 Z.1
    N570 G1 Z0. F500.
    N571 Y.39 Z-.0055 F250.
    N572 G3 X.995 Y.515 Z-.0069 I-.125
    N573 G1 X.37 Z-.0112
    N574 G3 X.245 Y.39 Z-.0125 J-.125
    N575 G1 Y-.42 Z-.018
    N576 G3 X.37 Y-.545 Z-.0194 I.125
    N577 G1 X.995 Z-.0237
    N578 G3 X1.12 Y-.42 Z-.025 J.125
    N579 G1 Y.39 Z-.0305
    N580 G3 X.995 Y.515 Z-.0319 I-.125
    N581 G1 X.37 Z-.0362
    N582 G3 X.245 Y.39 Z-.0375 J-.125
    N583 G1 Y-.42 Z-.043
    N584 G3 X.37 Y-.545 Z-.0444 I.125
    N585 G1 X.995 Z-.0487
    N586 G3 X1.12 Y-.42 Z-.05 J.125
    N587 G1 Y.39 Z-.0555
    N588 G3 X.995 Y.515 Z-.0569 I-.125
    N589 G1 X.37 Z-.0612
    N590 G3 X.245 Y.39 Z-.0625 J-.125
    N591 G1 Y-.42 Z-.068
    N592 G3 X.37 Y-.545 Z-.0694 I.125
    N593 G1 X.995 Z-.0737
    N594 G3 X1.12 Y-.42 Z-.075 J.125
    N595 G1 Y.39 Z-.0805
    N596 G3 X.995 Y.515 Z-.0819 I-.125
    N597 G1 X.37 Z-.0862
    N598 G3 X.245 Y.39 Z-.0875 J-.125
    N599 G1 Y-.42 Z-.093
    N600 G3 X.37 Y-.545 Z-.0944 I.125
    N601 G1 X.995 Z-.0987
    N602 G3 X1.12 Y-.42 Z-.1 J.125
    N603 G1 Y.39 Z-.1055
    N604 G3 X.995 Y.515 Z-.1069 I-.125
    N605 G1 X.37 Z-.1112
    N606 G3 X.245 Y.39 Z-.1125 J-.125
    N607 G1 Y-.42 Z-.118
    N608 G3 X.37 Y-.545 Z-.1194 I.125
    N609 G1 X.995 Z-.1237
    N610 G3 X1.12 Y-.42 Z-.125 J.125
    N611 G1 Y.39 Z-.1305
    N612 G3 X.995 Y.515 Z-.1319 I-.125
    N613 G1 X.37 Z-.1362
    N614 G3 X.245 Y.39 Z-.1375 J-.125
    N615 G1 Y-.42 Z-.143
    N616 G3 X.37 Y-.545 Z-.1444 I.125
    N617 G1 X.995 Z-.1487
    N618 G3 X1.12 Y-.42 Z-.15 J.125
    N619 G1 Y.39 Z-.1555
    N620 G3 X.995 Y.515 Z-.1569 I-.125
    N621 G1 X.37 Z-.1612
    N622 G3 X.245 Y.39 Z-.1625 J-.125
    N623 G1 Y-.42 Z-.168
    N624 G3 X.37 Y-.545 Z-.1694 I.125
    N625 G1 X.995 Z-.1737
    N626 G3 X1.12 Y-.42 Z-.175 J.125
    N627 G1 Y.39 Z-.1805
    N628 G3 X.995 Y.515 Z-.1819 I-.125
    N629 G1 X.37 Z-.1862
    N630 G3 X.245 Y.39 Z-.1875 J-.125
    N631 G1 Y-.42 Z-.193
    N632 G3 X.37 Y-.545 Z-.1944 I.125
    N633 G1 X.995 Z-.1987
    N634 G3 X1.12 Y-.42 Z-.2 J.125
    N635 G1 Y.39 Z-.2055
    N636 G3 X.995 Y.515 Z-.2069 I-.125
    N637 G1 X.37 Z-.2112
    N638 G3 X.245 Y.39 Z-.2125 J-.125
    N639 G1 Y-.42 Z-.218
    N640 G3 X.37 Y-.545 Z-.2194 I.125
    N641 G1 X.995 Z-.2237
    N642 G3 X1.12 Y-.42 Z-.225 J.125
    N643 G1 Y.39 Z-.2305
    N644 G3 X.995 Y.515 Z-.2319 I-.125
    N645 G1 X.37 Z-.2362
    N646 G3 X.245 Y.39 Z-.2375 J-.125
    N647 G1 Y-.42 Z-.243
    N648 G3 X.37 Y-.545 Z-.2444 I.125
    N649 G1 X.995 Z-.2487
    N650 G3 X1.12 Y-.42 Z-.25 J.125
    N651 G1 Y.39 Z-.2555
    N652 G3 X.995 Y.515 Z-.2569 I-.125
    N653 G1 X.37 Z-.2612
    N654 G3 X.245 Y.39 Z-.2625 J-.125
    N655 G1 Y-.42 Z-.268
    N656 G3 X.37 Y-.545 Z-.2694 I.125
    N657 G1 X.995 Z-.2737
    N658 G3 X1.12 Y-.42 Z-.275 J.125
    N659 G1 Y.39 Z-.2805
    N660 G3 X.995 Y.515 Z-.2819 I-.125
    N661 G1 X.37 Z-.2862
    N662 G3 X.245 Y.39 Z-.2875 J-.125
    N663 G1 Y-.42 Z-.293
    N664 G3 X.37 Y-.545 Z-.2944 I.125
    N665 G1 X.995 Z-.2987
    N666 G3 X1.12 Y-.42 Z-.3 J.125
    N667 G1 Y.39 Z-.3055
    N668 G3 X.995 Y.515 Z-.3069 I-.125
    N669 G1 X.37 Z-.3112
    N670 G3 X.245 Y.39 Z-.3125 J-.125
    N671 G1 Y-.42 Z-.318
    N672 G3 X.37 Y-.545 Z-.3194 I.125
    N673 G1 X.995 Z-.3237
    N674 G3 X1.12 Y-.42 Z-.325 J.125
    N675 G1 Y.39 Z-.3305
    N676 G3 X.995 Y.515 Z-.3319 I-.125
    N677 G1 X.37 Z-.3362
    N678 G3 X.245 Y.39 Z-.3375 J-.125
    N679 G1 Y-.42 Z-.343
    N680 G3 X.37 Y-.545 Z-.3444 I.125
    N681 G1 X.995 Z-.3487
    N682 G3 X1.12 Y-.42 Z-.35 J.125
    N683 G1 Y.39 Z-.3555
    N684 G3 X.995 Y.515 Z-.3569 I-.125
    N685 G1 X.37 Z-.3612
    N686 G3 X.245 Y.39 Z-.3625 J-.125
    N687 G1 Y-.42 Z-.368
    N688 G3 X.37 Y-.545 Z-.3694 I.125
    N689 G1 X.995 Z-.3737
    N690 G3 X1.12 Y-.42 Z-.375 J.125
    N691 G1 Y.39 Z-.3805
    N692 G3 X.995 Y.515 Z-.3819 I-.125
    N693 G1 X.37 Z-.3862
    N694 G3 X.245 Y.39 Z-.3875 J-.125
    N695 G1 Y-.42 Z-.393
    N696 G3 X.37 Y-.545 Z-.3944 I.125
    N697 G1 X.995 Z-.3987
    N698 G3 X1.12 Y-.42 Z-.4 J.125
    N699 G1 Y.39 Z-.4055
    N700 G3 X.995 Y.515 Z-.4069 I-.125
    N701 G1 X.37 Z-.4112
    N702 G3 X.245 Y.39 Z-.4125 J-.125
    N703 G1 Y-.42 Z-.418
    N704 G3 X.37 Y-.545 Z-.4194 I.125
    N705 G1 X.995 Z-.4237
    N706 G3 X1.12 Y-.42 Z-.425 J.125
    N707 G1 Y.39 Z-.4305
    N708 G3 X.995 Y.515 Z-.4319 I-.125
    N709 G1 X.37 Z-.4362
    N710 G3 X.245 Y.39 Z-.4375 J-.125
    N711 G1 Y-.42 Z-.443
    N712 G3 X.37 Y-.545 Z-.4444 I.125
    N713 G1 X.995 Z-.4487
    N714 G3 X1.12 Y-.42 Z-.45 J.125
    N715 G1 Y.39 Z-.4555
    N716 G3 X.995 Y.515 Z-.4569 I-.125
    N717 G1 X.37 Z-.4612
    N718 G3 X.245 Y.39 Z-.4625 J-.125
    N719 G1 Y-.42 Z-.468
    N720 G3 X.37 Y-.545 Z-.4694 I.125
    N721 G1 X.995 Z-.4737
    N722 G3 X1.12 Y-.42 Z-.475 J.125
    N723 G1 Y.39 Z-.4805
    N724 G3 X.995 Y.515 Z-.4819 I-.125
    N725 G1 X.37 Z-.4862
    N726 G3 X.245 Y.39 Z-.4875 J-.125
    N727 G1 Y-.42 Z-.493
    N728 G3 X.37 Y-.545 Z-.4944 I.125
    N729 G1 X.995 Z-.4987
    N730 G3 X1.12 Y-.42 Z-.5 J.125
    N731 G1 Y.39 Z-.5055
    N732 G3 X.995 Y.515 Z-.5069 I-.125
    N733 G1 X.37 Z-.5112
    N734 G3 X.245 Y.39 Z-.5125 J-.125
    N735 G1 Y-.42 Z-.518
    N736 G3 X.37 Y-.545 Z-.5194 I.125
    N737 G1 X.995 Z-.5237
    N738 G3 X1.12 Y-.42 Z-.525 J.125
    N739 G1 Y.39 Z-.5305
    N740 G3 X.995 Y.515 Z-.5319 I-.125
    N741 G1 X.37 Z-.5362
    N742 G3 X.245 Y.39 Z-.5375 J-.125
    N743 G1 Y-.42 Z-.543
    N744 G3 X.37 Y-.545 Z-.5444 I.125
    N745 G1 X.995 Z-.5487
    N746 G3 X1.12 Y-.42 Z-.55 J.125
    N747 G1 Y.39 Z-.5555
    N748 G3 X.995 Y.515 Z-.5569 I-.125
    N749 G1 X.37 Z-.5612
    N750 G3 X.245 Y.39 Z-.5625 J-.125
    N751 G1 Y-.42 Z-.568
    N752 G3 X.37 Y-.545 Z-.5694 I.125
    N753 G1 X.995 Z-.5737
    N754 G3 X1.12 Y-.42 Z-.575 J.125
    N755 G1 Y.39 Z-.5805
    N756 G3 X.995 Y.515 Z-.5819 I-.125
    N757 G1 X.37 Z-.5862
    N758 G3 X.245 Y.39 Z-.5875 J-.125
    N759 G1 Y-.42 Z-.593
    N760 G3 X.37 Y-.545 Z-.5944 I.125
    N761 G1 X.995 Z-.5987
    N762 G3 X1.12 Y-.42 Z-.6 J.125
    N763 G1 Y.39 Z-.6055
    N764 G3 X.995 Y.515 Z-.6069 I-.125
    N765 G1 X.37 Z-.6112
    N766 G3 X.245 Y.39 Z-.6125 J-.125
    N767 G1 Y-.42 Z-.618
    N768 G3 X.37 Y-.545 Z-.6194 I.125
    N769 G1 X.995 Z-.6237
    N770 G3 X1.12 Y-.42 Z-.625 J.125
    N771 G1 Y.39 Z-.6305
    N772 G3 X.995 Y.515 Z-.6319 I-.125
    N773 G1 X.37 Z-.6362
    N774 G3 X.245 Y.39 Z-.6375 J-.125
    N775 G1 Y-.42 Z-.643
    N776 G3 X.37 Y-.545 Z-.6444 I.125
    N777 G1 X.995 Z-.6487
    N778 G3 X1.12 Y-.42 Z-.65 J.125
    N779 G1 Y.39 Z-.6555
    N780 G3 X.995 Y.515 Z-.6569 I-.125
    N781 G1 X.37 Z-.6612
    N782 G3 X.245 Y.39 Z-.6625 J-.125
    N783 G1 Y-.42 Z-.668
    N784 G3 X.37 Y-.545 Z-.6694 I.125
    N785 G1 X.995 Z-.6737
    N786 G3 X1.12 Y-.42 Z-.675 J.125
    N787 G1 Y.39 Z-.6805
    N788 G3 X.995 Y.515 Z-.6819 I-.125
    N789 G1 X.37 Z-.6862
    N790 G3 X.245 Y.39 Z-.6875 J-.125
    N791 G1 Y-.42 Z-.693
    N792 G3 X.37 Y-.545 Z-.6944 I.125
    N793 G1 X.995 Z-.6987
    N794 G3 X1.12 Y-.42 Z-.7 J.125
    N795 G1 Y.39 Z-.7055
    N796 G3 X.995 Y.515 Z-.7069 I-.125
    N797 G1 X.37 Z-.7112
    N798 G3 X.245 Y.39 Z-.7125 J-.125
    N799 G1 Y-.42 Z-.718
    N800 G3 X.37 Y-.545 Z-.7194 I.125
    N801 G1 X.995 Z-.7237
    N802 G3 X1.12 Y-.42 Z-.725 J.125
    N803 G1 Y.39 Z-.7305
    N804 G3 X.995 Y.515 Z-.7319 I-.125
    N805 G1 X.37 Z-.7362
    N806 G3 X.245 Y.39 Z-.7375 J-.125
    N807 G1 Y-.42 Z-.743
    N808 G3 X.37 Y-.545 Z-.7444 I.125
    N809 G1 X.995 Z-.7487
    N810 G3 X1.12 Y-.42 Z-.75 J.125
    N811 G1 Y.39 Z-.7555
    N812 G3 X.995 Y.515 Z-.7569 I-.125
    N813 G1 X.37 Z-.7612
    N814 G3 X.245 Y.39 Z-.7625 J-.125
    N815 G1 Y-.42 Z-.768
    N816 G3 X.37 Y-.545 Z-.7694 I.125
    N817 G1 X.995 Z-.7737
    N818 G3 X1.12 Y-.42 Z-.775 J.125
    N819 G1 Y.39 Z-.7805
    N820 G3 X.995 Y.515 Z-.7819 I-.125
    N821 G1 X.37 Z-.7862
    N822 G3 X.245 Y.39 Z-.7875 J-.125
    N823 G1 Y-.42 Z-.793
    N824 G3 X.37 Y-.545 Z-.7944 I.125
    N825 G1 X.995 Z-.7987
    N826 G3 X1.12 Y-.42 Z-.8 J.125
    N827 G1 Y.39 Z-.8055
    N828 G3 X.995 Y.515 Z-.8069 I-.125
    N829 G1 X.37 Z-.8112
    N830 G3 X.245 Y.39 Z-.8125 J-.125
    N831 G1 Y-.42 Z-.818
    N832 G3 X.37 Y-.545 Z-.8194 I.125
    N833 G1 X.995 Z-.8237
    N834 G3 X1.12 Y-.42 Z-.825 J.125
    N835 G1 Y.39 Z-.8305
    N836 G3 X.995 Y.515 Z-.8319 I-.125
    N837 G1 X.37 Z-.8362
    N838 G3 X.245 Y.39 Z-.8375 J-.125
    N839 G1 Y-.42 Z-.843
    N840 G3 X.37 Y-.545 Z-.8444 I.125
    N841 G1 X.995 Z-.8487
    N842 G3 X1.12 Y-.42 Z-.85 J.125
    N843 G1 Y.39 Z-.8555
    N844 G3 X.995 Y.515 Z-.8569 I-.125
    N845 G1 X.37 Z-.8612
    N846 G3 X.245 Y.39 Z-.8625 J-.125
    N847 G1 Y-.42 Z-.868
    N848 G3 X.37 Y-.545 Z-.8694 I.125
    N849 G1 X.995 Z-.8737
    N850 G3 X1.12 Y-.42 Z-.875 J.125
    N851 G1 Y.39 Z-.8805
    N852 G3 X.995 Y.515 Z-.8819 I-.125
    N853 G1 X.37 Z-.8862
    N854 G3 X.245 Y.39 Z-.8875 J-.125
    N855 G1 Y-.42 Z-.893
    N856 G3 X.37 Y-.545 Z-.8944 I.125
    N857 G1 X.995 Z-.8987
    N858 G3 X1.12 Y-.42 Z-.9 J.125
    N859 G1 Y.39 Z-.9055
    N860 G3 X.995 Y.515 Z-.9069 I-.125
    N861 G1 X.37 Z-.9112
    N862 G3 X.245 Y.39 Z-.9125 J-.125
    N863 G1 Y-.42 Z-.918
    N864 G3 X.37 Y-.545 Z-.9194 I.125
    N865 G1 X.995 Z-.9237
    N866 G3 X1.12 Y-.42 Z-.925 J.125
    N867 G1 Y.39 Z-.9305
    N868 G3 X.995 Y.515 Z-.9319 I-.125
    N869 G1 X.37 Z-.9362
    N870 G3 X.245 Y.39 Z-.9375 J-.125
    N871 G1 Y-.42 Z-.943
    N872 G3 X.37 Y-.545 Z-.9444 I.125
    N873 G1 X.995 Z-.9487
    N874 G3 X1.12 Y-.42 Z-.95 J.125
    N875 G1 Y.39 Z-.9555
    N876 G3 X.995 Y.515 Z-.9569 I-.125
    N877 G1 X.37 Z-.9612
    N878 G3 X.245 Y.39 Z-.9625 J-.125
    N879 G1 Y-.42 Z-.968
    N880 G3 X.37 Y-.545 Z-.9694 I.125
    N881 G1 X.995 Z-.9737
    N882 G3 X1.12 Y-.42 Z-.975 J.125
    N883 G1 Y.39 Z-.9805
    N884 G3 X.995 Y.515 Z-.9819 I-.125
    N885 G1 X.37 Z-.9862
    N886 G3 X.245 Y.39 Z-.9875 J-.125
    N887 G1 Y-.42 Z-.993
    N888 G3 X.37 Y-.545 Z-.9944 I.125
    N889 G1 X.995 Z-.9987
    N890 G3 X1.12 Y-.42 Z-1. J.125
    N891 G1 Y.39
    N892 G3 X.995 Y.515 I-.125
    N893 G1 X.37
    N894 G3 X.245 Y.39 J-.125
    N895 G1 Y-.42
    N896 G3 X.37 Y-.545 I.125
    N897 G1 X.995
    N898 G3 X1.12 Y-.42 J.125
    N899 G0 Z2.5
    N900 G0 G90 G54 X1.12 Y-1.8827 S9000 M3
    N901 M33
    N902 G0 G90 A-97.5
    N903 M32
    N904 Z.25
    N905 Z.1
    N906 G1 Z0. F500.
    N907 G1 Y-1.5371 Z-.5534 F250.
    N908 X1.1193 Y-1.5288 Z-.5535
    N909 X1.1186 Y-1.5259
    N910 X1.114 Y-1.5157 Z-.5536
    N911 X1.1064 Y-1.5047 Z-.5537
    N912 X1.0952 Y-1.4934 Z-.5539
    N913 X1.08 Y-1.4821 Z-.5541
    N914 X1.0619 Y-1.4725 Z-.5543
    N915 X1.0412 Y-1.465 Z-.5545
    N916 X1.0185 Y-1.4602 Z-.5547
    N917 X.9906 Y-1.4583 Z-.555
    N918 X.3726 Z-.5611
    N919 X.3558 Y-1.459 Z-.5612
    N920 X.3437 Y-1.4605 Z-.5614
    N921 X.3185 Y-1.4667 Z-.5616
    N922 X.2974 Y-1.4752 Z-.5618
    N923 X.2791 Y-1.4861 Z-.562
    N924 X.2647 Y-1.4981 Z-.5622
    N925 X.2547 Y-1.5098 Z-.5624
    N926 X.2489 Y-1.5198 Z-.5625
    N927 X.2464 Y-1.5272 Z-.5626
    N928 X.245 Y-1.539 Z-.5627
    N929 Y-1.8827 Z-.5661
    N930 X.2461 Y-1.8908 Z-.5662
    N931 X.2492 Y-1.8984
    N932 X.2542 Y-1.9048 Z-.5663
    N933 X.2606 Y-1.9098 Z-.5664
    N934 X.2682 Y-1.9129
    N935 X.2763 Y-1.914 Z-.5665
    N936 X.2989 Z-.5668
    N937 X.3222 Z-.567
    N938 X.346 Z-.5672
    N939 X.37 Z-.5675
    N940 X.995 Z-.5736
    N941 X1.019 Z-.5738
    N942 X1.0428 Z-.5741
    N943 X1.0661 Z-.5743
    N944 X1.0888 Z-.5745
    N945 G3 X1.12 Y-1.8827 Z-.575 J.0313
    N946 G1 Y-1.5371 Z-.5784
    N947 X1.1193 Y-1.5288 Z-.5785
    N948 X1.1186 Y-1.5259
    N949 X1.114 Y-1.5157 Z-.5786
    N950 X1.1064 Y-1.5047 Z-.5787
    N951 X1.0952 Y-1.4934 Z-.5789
    N952 X1.08 Y-1.4821 Z-.5791
    N953 X1.0619 Y-1.4725 Z-.5793
    N954 X1.0412 Y-1.465 Z-.5795
    N955 X1.0185 Y-1.4602 Z-.5797
    N956 X.9906 Y-1.4583 Z-.58
    N957 X.3726 Z-.5861
    N958 X.3558 Y-1.459 Z-.5862
    N959 X.3437 Y-1.4605 Z-.5864
    N960 X.3185 Y-1.4667 Z-.5866
    N961 X.2974 Y-1.4752 Z-.5868
    N962 X.2791 Y-1.4861 Z-.587
    N963 X.2647 Y-1.4981 Z-.5872
    N964 X.2547 Y-1.5098 Z-.5874
    N965 X.2489 Y-1.5198 Z-.5875
    N966 X.2464 Y-1.5272 Z-.5876
    N967 X.245 Y-1.539 Z-.5877
    N968 Y-1.8827 Z-.5911
    N969 X.2461 Y-1.8908 Z-.5912
    N970 X.2492 Y-1.8984
    N971 X.2542 Y-1.9048 Z-.5913
    N972 X.2606 Y-1.9098 Z-.5914
    N973 X.2682 Y-1.9129
    N974 X.2763 Y-1.914 Z-.5915
    N975 X.2989 Z-.5918
    N976 X.3222 Z-.592
    N977 X.346 Z-.5922
    N978 X.37 Z-.5925
    N979 X.995 Z-.5986
    N980 X1.019 Z-.5988
    N981 X1.0428 Z-.5991
    N982 X1.0661 Z-.5993
    N983 X1.0888 Z-.5995
    N984 G3 X1.12 Y-1.8827 Z-.6 J.0313
    N985 G1 Y-1.5371 Z-.6034
    N986 X1.1193 Y-1.5288 Z-.6035
    N987 X1.1186 Y-1.5259
    N988 X1.114 Y-1.5157 Z-.6036
    N989 X1.1064 Y-1.5047 Z-.6037
    N990 X1.0952 Y-1.4934 Z-.6039
    N991 X1.08 Y-1.4821 Z-.6041
    N992 X1.0619 Y-1.4725 Z-.6043
    N993 X1.0412 Y-1.465 Z-.6045
    N994 X1.0185 Y-1.4602 Z-.6047
    N995 X.9906 Y-1.4583 Z-.605
    N996 X.3726 Z-.6111
    N997 X.3558 Y-1.459 Z-.6112
    N998 X.3437 Y-1.4605 Z-.6114
    N999 X.3185 Y-1.4667 Z-.6116
    N1000 X.2974 Y-1.4752 Z-.6118
    N1001 X.2791 Y-1.4861 Z-.612
    N1002 X.2647 Y-1.4981 Z-.6122
    N1003 X.2547 Y-1.5098 Z-.6124
    N1004 X.2489 Y-1.5198 Z-.6125
    N1005 X.2464 Y-1.5272 Z-.6126
    N1006 X.245 Y-1.539 Z-.6127
    N1007 Y-1.8827 Z-.6161
    N1008 X.2461 Y-1.8908 Z-.6162
    N1009 X.2492 Y-1.8984
    N1010 X.2542 Y-1.9048 Z-.6163
    N1011 X.2606 Y-1.9098 Z-.6164
    N1012 X.2682 Y-1.9129
    N1013 X.2763 Y-1.914 Z-.6165
    N1014 X.2989 Z-.6168
    N1015 X.3222 Z-.617
    N1016 X.346 Z-.6172
    N1017 X.37 Z-.6175
    N1018 X.995 Z-.6236
    N1019 X1.019 Z-.6238
    N1020 X1.0428 Z-.6241
    N1021 X1.0661 Z-.6243
    N1022 X1.0888 Z-.6245
    N1023 G3 X1.12 Y-1.8827 Z-.625 J.0313
    N1024 G1 Y-1.5371 Z-.6284
    N1025 X1.1193 Y-1.5288 Z-.6285
    N1026 X1.1186 Y-1.5259
    N1027 X1.114 Y-1.5157 Z-.6286
    N1028 X1.1064 Y-1.5047 Z-.6287
    N1029 X1.0952 Y-1.4934 Z-.6289
    N1030 X1.08 Y-1.4821 Z-.6291
    N1031 X1.0619 Y-1.4725 Z-.6293
    N1032 X1.0412 Y-1.465 Z-.6295
    N1033 X1.0185 Y-1.4602 Z-.6297
    N1034 X.9906 Y-1.4583 Z-.63
    N1035 X.3726 Z-.6361
    N1036 X.3558 Y-1.459 Z-.6362
    N1037 X.3437 Y-1.4605 Z-.6364
    N1038 X.3185 Y-1.4667 Z-.6366
    N1039 X.2974 Y-1.4752 Z-.6368
    N1040 X.2791 Y-1.4861 Z-.637
    N1041 X.2647 Y-1.4981 Z-.6372
    N1042 X.2547 Y-1.5098 Z-.6374
    N1043 X.2489 Y-1.5198 Z-.6375
    N1044 X.2464 Y-1.5272 Z-.6376
    N1045 X.245 Y-1.539 Z-.6377
    N1046 Y-1.8827 Z-.6411
    N1047 X.2461 Y-1.8908 Z-.6412
    N1048 X.2492 Y-1.8984
    N1049 X.2542 Y-1.9048 Z-.6413
    N1050 X.2606 Y-1.9098 Z-.6414
    N1051 X.2682 Y-1.9129
    N1052 X.2763 Y-1.914 Z-.6415
    N1053 X.2989 Z-.6418
    N1054 X.3222 Z-.642
    N1055 X.346 Z-.6422
    N1056 X.37 Z-.6425
    N1057 X.995 Z-.6486
    N1058 X1.019 Z-.6488
    N1059 X1.0428 Z-.6491
    N1060 X1.0661 Z-.6493
    N1061 X1.0888 Z-.6495
    N1062 G3 X1.12 Y-1.8827 Z-.65 J.0313
    N1063 G1 Y-1.5371 Z-.6534
    N1064 X1.1193 Y-1.5288 Z-.6535
    N1065 X1.1186 Y-1.5259
    N1066 X1.114 Y-1.5157 Z-.6536
    N1067 X1.1064 Y-1.5047 Z-.6537
    N1068 X1.0952 Y-1.4934 Z-.6539
    N1069 X1.08 Y-1.4821 Z-.6541
    N1070 X1.0619 Y-1.4725 Z-.6543
    N1071 X1.0412 Y-1.465 Z-.6545
    N1072 X1.0185 Y-1.4602 Z-.6547
    N1073 X.9906 Y-1.4583 Z-.655
    N1074 X.3726 Z-.6611
    N1075 X.3558 Y-1.459 Z-.6612
    N1076 X.3437 Y-1.4605 Z-.6614
    N1077 X.3185 Y-1.4667 Z-.6616
    N1078 X.2974 Y-1.4752 Z-.6618
    N1079 X.2791 Y-1.4861 Z-.662
    N1080 X.2647 Y-1.4981 Z-.6622
    N1081 X.2547 Y-1.5098 Z-.6624
    N1082 X.2489 Y-1.5198 Z-.6625
    N1083 X.2464 Y-1.5272 Z-.6626
    N1084 X.245 Y-1.539 Z-.6627
    N1085 Y-1.8827 Z-.6661
    N1086 X.2461 Y-1.8908 Z-.6662
    N1087 X.2492 Y-1.8984
    N1088 X.2542 Y-1.9048 Z-.6663
    N1089 X.2606 Y-1.9098 Z-.6664
    N1090 X.2682 Y-1.9129
    N1091 X.2763 Y-1.914 Z-.6665
    N1092 X.2989 Z-.6668
    N1093 X.3222 Z-.667
    N1094 X.346 Z-.6672
    N1095 X.37 Z-.6675
    N1096 X.995 Z-.6736
    N1097 X1.019 Z-.6738
    N1098 X1.0428 Z-.6741
    N1099 X1.0661 Z-.6743
    N1100 X1.0888 Z-.6745
    N1101 G3 X1.12 Y-1.8827 Z-.675 J.0313
    N1102 G1 Y-1.5371 Z-.6784
    N1103 X1.1193 Y-1.5288 Z-.6785
    N1104 X1.1186 Y-1.5259
    N1105 X1.114 Y-1.5157 Z-.6786
    N1106 X1.1064 Y-1.5047 Z-.6787
    N1107 X1.0952 Y-1.4934 Z-.6789
    N1108 X1.08 Y-1.4821 Z-.6791
    N1109 X1.0619 Y-1.4725 Z-.6793
    N1110 X1.0412 Y-1.465 Z-.6795
    N1111 X1.0185 Y-1.4602 Z-.6797
    N1112 X.9906 Y-1.4583 Z-.68
    N1113 X.3726 Z-.6861
    N1114 X.3558 Y-1.459 Z-.6862
    N1115 X.3437 Y-1.4605 Z-.6864
    N1116 X.3185 Y-1.4667 Z-.6866
    N1117 X.2974 Y-1.4752 Z-.6868
    N1118 X.2791 Y-1.4861 Z-.687
    N1119 X.2647 Y-1.4981 Z-.6872
    N1120 X.2547 Y-1.5098 Z-.6874
    N1121 X.2489 Y-1.5198 Z-.6875
    N1122 X.2464 Y-1.5272 Z-.6876
    N1123 X.245 Y-1.539 Z-.6877
    N1124 Y-1.8827 Z-.6911
    N1125 X.2461 Y-1.8908 Z-.6912
    N1126 X.2492 Y-1.8984
    N1127 X.2542 Y-1.9048 Z-.6913
    N1128 X.2606 Y-1.9098 Z-.6914
    N1129 X.2682 Y-1.9129
    N1130 X.2763 Y-1.914 Z-.6915
    N1131 X.2989 Z-.6918
    N1132 X.3222 Z-.692
    N1133 X.346 Z-.6922
    N1134 X.37 Z-.6925
    N1135 X.995 Z-.6986
    N1136 X1.019 Z-.6988
    N1137 X1.0428 Z-.6991
    N1138 X1.0661 Z-.6993
    N1139 X1.0888 Z-.6995
    N1140 G3 X1.12 Y-1.8827 Z-.7 J.0313
    N1141 G1 Y-1.5371 Z-.7034
    N1142 X1.1193 Y-1.5288 Z-.7035
    N1143 X1.1186 Y-1.5259
    N1144 X1.114 Y-1.5157 Z-.7036
    N1145 X1.1064 Y-1.5047 Z-.7037
    N1146 X1.0952 Y-1.4934 Z-.7039
    N1147 X1.08 Y-1.4821 Z-.7041
    N1148 X1.0619 Y-1.4725 Z-.7043
    N1149 X1.0412 Y-1.465 Z-.7045
    N1150 X1.0185 Y-1.4602 Z-.7047
    N1151 X.9906 Y-1.4583 Z-.705
    N1152 X.3726 Z-.7111
    N1153 X.3558 Y-1.459 Z-.7112
    N1154 X.3437 Y-1.4605 Z-.7114
    N1155 X.3185 Y-1.4667 Z-.7116
    N1156 X.2974 Y-1.4752 Z-.7118
    N1157 X.2791 Y-1.4861 Z-.712
    N1158 X.2647 Y-1.4981 Z-.7122
    N1159 X.2547 Y-1.5098 Z-.7124
    N1160 X.2489 Y-1.5198 Z-.7125
    N1161 X.2464 Y-1.5272 Z-.7126
    N1162 X.245 Y-1.539 Z-.7127
    N1163 Y-1.8827 Z-.7161
    N1164 X.2461 Y-1.8908 Z-.7162
    N1165 X.2492 Y-1.8984
    N1166 X.2542 Y-1.9048 Z-.7163
    N1167 X.2606 Y-1.9098 Z-.7164
    N1168 X.2682 Y-1.9129
    N1169 X.2763 Y-1.914 Z-.7165
    N1170 X.2989 Z-.7168
    N1171 X.3222 Z-.717
    N1172 X.346 Z-.7172
    N1173 X.37 Z-.7175
    N1174 X.995 Z-.7236
    N1175 X1.019 Z-.7238
    N1176 X1.0428 Z-.7241
    N1177 X1.0661 Z-.7243
    N1178 X1.0888 Z-.7245
    N1179 G3 X1.12 Y-1.8827 Z-.725 J.0313
    N1180 G1 Y-1.5371 Z-.7284
    N1181 X1.1193 Y-1.5288 Z-.7285
    N1182 X1.1186 Y-1.5259
    N1183 X1.114 Y-1.5157 Z-.7286
    N1184 X1.1064 Y-1.5047 Z-.7287
    N1185 X1.0952 Y-1.4934 Z-.7289
    N1186 X1.08 Y-1.4821 Z-.7291
    N1187 X1.0619 Y-1.4725 Z-.7293
    N1188 X1.0412 Y-1.465 Z-.7295
    N1189 X1.0185 Y-1.4602 Z-.7297
    N1190 X.9906 Y-1.4583 Z-.73
    N1191 X.3726 Z-.7361
    N1192 X.3558 Y-1.459 Z-.7362
    N1193 X.3437 Y-1.4605 Z-.7364
    N1194 X.3185 Y-1.4667 Z-.7366
    N1195 X.2974 Y-1.4752 Z-.7368
    N1196 X.2791 Y-1.4861 Z-.737
    N1197 X.2647 Y-1.4981 Z-.7372
    N1198 X.2547 Y-1.5098 Z-.7374
    N1199 X.2489 Y-1.5198 Z-.7375
    N1200 X.2464 Y-1.5272 Z-.7376
    N1201 X.245 Y-1.539 Z-.7377
    N1202 Y-1.8827 Z-.7411
    N1203 X.2461 Y-1.8908 Z-.7412
    N1204 X.2492 Y-1.8984
    N1205 X.2542 Y-1.9048 Z-.7413
    N1206 X.2606 Y-1.9098 Z-.7414
    N1207 X.2682 Y-1.9129
    N1208 X.2763 Y-1.914 Z-.7415
    N1209 X.2989 Z-.7418
    N1210 X.3222 Z-.742
    N1211 X.346 Z-.7422
    N1212 X.37 Z-.7425
    N1213 X.995 Z-.7486
    N1214 X1.019 Z-.7488
    N1215 X1.0428 Z-.7491
    N1216 X1.0661 Z-.7493
    N1217 X1.0888 Z-.7495
    N1218 G3 X1.12 Y-1.8827 Z-.75 J.0313
    N1219 G1 Y-1.5371 Z-.7534
    N1220 X1.1193 Y-1.5288 Z-.7535
    N1221 X1.1186 Y-1.5259
    N1222 X1.114 Y-1.5157 Z-.7536
    N1223 X1.1064 Y-1.5047 Z-.7537
    N1224 X1.0952 Y-1.4934 Z-.7539
    N1225 X1.08 Y-1.4821 Z-.7541
    N1226 X1.0619 Y-1.4725 Z-.7543
    N1227 X1.0412 Y-1.465 Z-.7545
    N1228 X1.0185 Y-1.4602 Z-.7547
    N1229 X.9906 Y-1.4583 Z-.755
    N1230 X.3726 Z-.7611
    N1231 X.3558 Y-1.459 Z-.7612
    N1232 X.3437 Y-1.4605 Z-.7614
    N1233 X.3185 Y-1.4667 Z-.7616
    N1234 X.2974 Y-1.4752 Z-.7618
    N1235 X.2791 Y-1.4861 Z-.762
    N1236 X.2647 Y-1.4981 Z-.7622
    N1237 X.2547 Y-1.5098 Z-.7624
    N1238 X.2489 Y-1.5198 Z-.7625
    N1239 X.2464 Y-1.5272 Z-.7626
    N1240 X.245 Y-1.539 Z-.7627
    N1241 Y-1.8827 Z-.7661
    N1242 X.2461 Y-1.8908 Z-.7662
    N1243 X.2492 Y-1.8984
    N1244 X.2542 Y-1.9048 Z-.7663
    N1245 X.2606 Y-1.9098 Z-.7664
    N1246 X.2682 Y-1.9129
    N1247 X.2763 Y-1.914 Z-.7665
    N1248 X.2989 Z-.7668
    N1249 X.3222 Z-.767
    N1250 X.346 Z-.7672
    N1251 X.37 Z-.7675
    N1252 X.995 Z-.7736
    N1253 X1.019 Z-.7738
    N1254 X1.0428 Z-.7741
    N1255 X1.0661 Z-.7743
    N1256 X1.0888 Z-.7745
    N1257 G3 X1.12 Y-1.8827 Z-.775 J.0313
    N1258 G1 Y-1.5371 Z-.7784
    N1259 X1.1193 Y-1.5288 Z-.7785
    N1260 X1.1186 Y-1.5259
    N1261 X1.114 Y-1.5157 Z-.7786
    N1262 X1.1064 Y-1.5047 Z-.7787
    N1263 X1.0952 Y-1.4934 Z-.7789
    N1264 X1.08 Y-1.4821 Z-.7791
    N1265 X1.0619 Y-1.4725 Z-.7793
    N1266 X1.0412 Y-1.465 Z-.7795
    N1267 X1.0185 Y-1.4602 Z-.7797
    N1268 X.9906 Y-1.4583 Z-.78
    N1269 X.3726 Z-.7861
    N1270 X.3558 Y-1.459 Z-.7862
    N1271 X.3437 Y-1.4605 Z-.7864
    N1272 X.3185 Y-1.4667 Z-.7866
    N1273 X.2974 Y-1.4752 Z-.7868
    N1274 X.2791 Y-1.4861 Z-.787
    N1275 X.2647 Y-1.4981 Z-.7872
    N1276 X.2547 Y-1.5098 Z-.7874
    N1277 X.2489 Y-1.5198 Z-.7875
    N1278 X.2464 Y-1.5272 Z-.7876
    N1279 X.245 Y-1.539 Z-.7877
    N1280 Y-1.8827 Z-.7911
    N1281 X.2461 Y-1.8908 Z-.7912
    N1282 X.2492 Y-1.8984
    N1283 X.2542 Y-1.9048 Z-.7913
    N1284 X.2606 Y-1.9098 Z-.7914
    N1285 X.2682 Y-1.9129
    N1286 X.2763 Y-1.914 Z-.7915
    N1287 X.2989 Z-.7918
    N1288 X.3222 Z-.792
    N1289 X.346 Z-.7922
    N1290 X.37 Z-.7925
    N1291 X.995 Z-.7986
    N1292 X1.019 Z-.7988
    N1293 X1.0428 Z-.7991
    N1294 X1.0661 Z-.7993
    N1295 X1.0888 Z-.7995
    N1296 G3 X1.12 Y-1.8827 Z-.8 J.0313
    N1297 G1 Y-1.5371 Z-.8034
    N1298 X1.1193 Y-1.5288 Z-.8035
    N1299 X1.1186 Y-1.5259
    N1300 X1.114 Y-1.5157 Z-.8036
    N1301 X1.1064 Y-1.5047 Z-.8037
    N1302 X1.0952 Y-1.4934 Z-.8039
    N1303 X1.08 Y-1.4821 Z-.8041
    N1304 X1.0619 Y-1.4725 Z-.8043
    N1305 X1.0412 Y-1.465 Z-.8045
    N1306 X1.0185 Y-1.4602 Z-.8047
    N1307 X.9906 Y-1.4583 Z-.805
    N1308 X.3726 Z-.8111
    N1309 X.3558 Y-1.459 Z-.8112
    N1310 X.3437 Y-1.4605 Z-.8114
    N1311 X.3185 Y-1.4667 Z-.8116
    N1312 X.2974 Y-1.4752 Z-.8118
    N1313 X.2791 Y-1.4861 Z-.812
    N1314 X.2647 Y-1.4981 Z-.8122
    N1315 X.2547 Y-1.5098 Z-.8124
    N1316 X.2489 Y-1.5198 Z-.8125
    N1317 X.2464 Y-1.5272 Z-.8126
    N1318 X.245 Y-1.539 Z-.8127
    N1319 Y-1.8827 Z-.8161
    N1320 X.2461 Y-1.8908 Z-.8162
    N1321 X.2492 Y-1.8984
    N1322 X.2542 Y-1.9048 Z-.8163
    N1323 X.2606 Y-1.9098 Z-.8164
    N1324 X.2682 Y-1.9129
    N1325 X.2763 Y-1.914 Z-.8165
    N1326 X.2989 Z-.8168
    N1327 X.3222 Z-.817
    N1328 X.346 Z-.8172
    N1329 X.37 Z-.8175
    N1330 X.995 Z-.8236
    N1331 X1.019 Z-.8238
    N1332 X1.0428 Z-.8241
    N1333 X1.0661 Z-.8243
    N1334 X1.0888 Z-.8245
    N1335 G3 X1.12 Y-1.8827 Z-.825 J.0313
    N1336 G1 Y-1.5371 Z-.8284
    N1337 X1.1193 Y-1.5288 Z-.8285
    N1338 X1.1186 Y-1.5259
    N1339 X1.114 Y-1.5157 Z-.8286
    N1340 X1.1064 Y-1.5047 Z-.8287
    N1341 X1.0952 Y-1.4934 Z-.8289
    N1342 X1.08 Y-1.4821 Z-.8291
    N1343 X1.0619 Y-1.4725 Z-.8293
    N1344 X1.0412 Y-1.465 Z-.8295
    N1345 X1.0185 Y-1.4602 Z-.8297
    N1346 X.9906 Y-1.4583 Z-.83
    N1347 X.3726 Z-.8361
    N1348 X.3558 Y-1.459 Z-.8362
    N1349 X.3437 Y-1.4605 Z-.8364
    N1350 X.3185 Y-1.4667 Z-.8366
    N1351 X.2974 Y-1.4752 Z-.8368
    N1352 X.2791 Y-1.4861 Z-.837
    N1353 X.2647 Y-1.4981 Z-.8372
    N1354 X.2547 Y-1.5098 Z-.8374
    N1355 X.2489 Y-1.5198 Z-.8375
    N1356 X.2464 Y-1.5272 Z-.8376
    N1357 X.245 Y-1.539 Z-.8377
    N1358 Y-1.8827 Z-.8411
    N1359 X.2461 Y-1.8908 Z-.8412
    N1360 X.2492 Y-1.8984
    N1361 X.2542 Y-1.9048 Z-.8413
    N1362 X.2606 Y-1.9098 Z-.8414
    N1363 X.2682 Y-1.9129
    N1364 X.2763 Y-1.914 Z-.8415
    N1365 X.2989 Z-.8418
    N1366 X.3222 Z-.842
    N1367 X.346 Z-.8422
    N1368 X.37 Z-.8425
    N1369 X.995 Z-.8486
    N1370 X1.019 Z-.8488
    N1371 X1.0428 Z-.8491
    N1372 X1.0661 Z-.8493
    N1373 X1.0888 Z-.8495
    N1374 G3 X1.12 Y-1.8827 Z-.85 J.0313
    N1375 G1 Y-1.5371 Z-.8534
    N1376 X1.1193 Y-1.5288 Z-.8535
    N1377 X1.1186 Y-1.5259
    N1378 X1.114 Y-1.5157 Z-.8536
    N1379 X1.1064 Y-1.5047 Z-.8537
    N1380 X1.0952 Y-1.4934 Z-.8539
    N1381 X1.08 Y-1.4821 Z-.8541
    N1382 X1.0619 Y-1.4725 Z-.8543
    N1383 X1.0412 Y-1.465 Z-.8545
    N1384 X1.0185 Y-1.4602 Z-.8547
    N1385 X.9906 Y-1.4583 Z-.855
    N1386 X.3726 Z-.8611
    N1387 X.3558 Y-1.459 Z-.8612
    N1388 X.3437 Y-1.4605 Z-.8614
    N1389 X.3185 Y-1.4667 Z-.8616
    N1390 X.2974 Y-1.4752 Z-.8618
    N1391 X.2791 Y-1.4861 Z-.862
    N1392 X.2647 Y-1.4981 Z-.8622
    N1393 X.2547 Y-1.5098 Z-.8624
    N1394 X.2489 Y-1.5198 Z-.8625
    N1395 X.2464 Y-1.5272 Z-.8626
    N1396 X.245 Y-1.539 Z-.8627
    N1397 Y-1.8827 Z-.8661
    N1398 X.2461 Y-1.8908 Z-.8662
    N1399 X.2492 Y-1.8984
    N1400 X.2542 Y-1.9048 Z-.8663
    N1401 X.2606 Y-1.9098 Z-.8664
    N1402 X.2682 Y-1.9129
    N1403 X.2763 Y-1.914 Z-.8665
    N1404 X.2989 Z-.8668
    N1405 X.3222 Z-.867
    N1406 X.346 Z-.8672
    N1407 X.37 Z-.8675
    N1408 X.995 Z-.8736
    N1409 X1.019 Z-.8738
    N1410 X1.0428 Z-.8741
    N1411 X1.0661 Z-.8743
    N1412 X1.0888 Z-.8745
    N1413 G3 X1.12 Y-1.8827 Z-.875 J.0313
    N1414 G1 Y-1.5371 Z-.8784
    N1415 X1.1193 Y-1.5288 Z-.8785
    N1416 X1.1186 Y-1.5259
    N1417 X1.114 Y-1.5157 Z-.8786
    N1418 X1.1064 Y-1.5047 Z-.8787
    N1419 X1.0952 Y-1.4934 Z-.8789
    N1420 X1.08 Y-1.4821 Z-.8791
    N1421 X1.0619 Y-1.4725 Z-.8793
    N1422 X1.0412 Y-1.465 Z-.8795
    N1423 X1.0185 Y-1.4602 Z-.8797
    N1424 X.9906 Y-1.4583 Z-.88
    N1425 X.3726 Z-.8861
    N1426 X.3558 Y-1.459 Z-.8862
    N1427 X.3437 Y-1.4605 Z-.8864
    N1428 X.3185 Y-1.4667 Z-.8866
    N1429 X.2974 Y-1.4752 Z-.8868
    N1430 X.2791 Y-1.4861 Z-.887
    N1431 X.2647 Y-1.4981 Z-.8872
    N1432 X.2547 Y-1.5098 Z-.8874
    N1433 X.2489 Y-1.5198 Z-.8875
    N1434 X.2464 Y-1.5272 Z-.8876
    N1435 X.245 Y-1.539 Z-.8877
    N1436 Y-1.8827 Z-.8911
    N1437 X.2461 Y-1.8908 Z-.8912
    N1438 X.2492 Y-1.8984
    N1439 X.2542 Y-1.9048 Z-.8913
    N1440 X.2606 Y-1.9098 Z-.8914
    N1441 X.2682 Y-1.9129
    N1442 X.2763 Y-1.914 Z-.8915
    N1443 X.2989 Z-.8918
    N1444 X.3222 Z-.892
    N1445 X.346 Z-.8922
    N1446 X.37 Z-.8925
    N1447 X.995 Z-.8986
    N1448 X1.019 Z-.8988
    N1449 X1.0428 Z-.8991
    N1450 X1.0661 Z-.8993
    N1451 X1.0888 Z-.8995
    N1452 G3 X1.12 Y-1.8827 Z-.9 J.0313
    N1453 G1 Y-1.5371 Z-.9034
    N1454 X1.1193 Y-1.5288 Z-.9035
    N1455 X1.1186 Y-1.5259
    N1456 X1.114 Y-1.5157 Z-.9036
    N1457 X1.1064 Y-1.5047 Z-.9037
    N1458 X1.0952 Y-1.4934 Z-.9039
    N1459 X1.08 Y-1.4821 Z-.9041
    N1460 X1.0619 Y-1.4725 Z-.9043
    N1461 X1.0412 Y-1.465 Z-.9045
    N1462 X1.0185 Y-1.4602 Z-.9047
    N1463 X.9906 Y-1.4583 Z-.905
    N1464 X.3726 Z-.9111
    N1465 X.3558 Y-1.459 Z-.9112
    N1466 X.3437 Y-1.4605 Z-.9114
    N1467 X.3185 Y-1.4667 Z-.9116
    N1468 X.2974 Y-1.4752 Z-.9118
    N1469 X.2791 Y-1.4861 Z-.912
    N1470 X.2647 Y-1.4981 Z-.9122
    N1471 X.2547 Y-1.5098 Z-.9124
    N1472 X.2489 Y-1.5198 Z-.9125
    N1473 X.2464 Y-1.5272 Z-.9126
    N1474 X.245 Y-1.539 Z-.9127
    N1475 Y-1.8827 Z-.9161
    N1476 X.2461 Y-1.8908 Z-.9162
    N1477 X.2492 Y-1.8984
    N1478 X.2542 Y-1.9048 Z-.9163
    N1479 X.2606 Y-1.9098 Z-.9164
    N1480 X.2682 Y-1.9129
    N1481 X.2763 Y-1.914 Z-.9165
    N1482 X.2989 Z-.9168
    N1483 X.3222 Z-.917
    N1484 X.346 Z-.9172
    N1485 X.37 Z-.9175
    N1486 X.995 Z-.9236
    N1487 X1.019 Z-.9238
    N1488 X1.0428 Z-.9241
    N1489 X1.0661 Z-.9243
    N1490 X1.0888 Z-.9245
    N1491 G3 X1.12 Y-1.8827 Z-.925 J.0313
    N1492 G1 Y-1.5371 Z-.9284
    N1493 X1.1193 Y-1.5288 Z-.9285
    N1494 X1.1186 Y-1.5259
    N1495 X1.114 Y-1.5157 Z-.9286
    N1496 X1.1064 Y-1.5047 Z-.9287
    N1497 X1.0952 Y-1.4934 Z-.9289
    N1498 X1.08 Y-1.4821 Z-.9291
    N1499 X1.0619 Y-1.4725 Z-.9293
    N1500 X1.0412 Y-1.465 Z-.9295
    N1501 X1.0185 Y-1.4602 Z-.9297
    N1502 X.9906 Y-1.4583 Z-.93
    N1503 X.3726 Z-.9361
    N1504 X.3558 Y-1.459 Z-.9362
    N1505 X.3437 Y-1.4605 Z-.9364
    N1506 X.3185 Y-1.4667 Z-.9366
    N1507 X.2974 Y-1.4752 Z-.9368
    N1508 X.2791 Y-1.4861 Z-.937
    N1509 X.2647 Y-1.4981 Z-.9372
    N1510 X.2547 Y-1.5098 Z-.9374
    N1511 X.2489 Y-1.5198 Z-.9375
    N1512 X.2464 Y-1.5272 Z-.9376
    N1513 X.245 Y-1.539 Z-.9377
    N1514 Y-1.8827 Z-.9411
    N1515 X.2461 Y-1.8908 Z-.9412
    N1516 X.2492 Y-1.8984
    N1517 X.2542 Y-1.9048 Z-.9413
    N1518 X.2606 Y-1.9098 Z-.9414
    N1519 X.2682 Y-1.9129
    N1520 X.2763 Y-1.914 Z-.9415
    N1521 X.2989 Z-.9418
    N1522 X.3222 Z-.942
    N1523 X.346 Z-.9422
    N1524 X.37 Z-.9425
    N1525 X.995 Z-.9486
    N1526 X1.019 Z-.9488
    N1527 X1.0428 Z-.9491
    N1528 X1.0661 Z-.9493
    N1529 X1.0888 Z-.9495
    N1530 G3 X1.12 Y-1.8827 Z-.95 J.0313
    N1531 G1 Y-1.5371 Z-.9534
    N1532 X1.1193 Y-1.5288 Z-.9535
    N1533 X1.1186 Y-1.5259
    N1534 X1.114 Y-1.5157 Z-.9536
    N1535 X1.1064 Y-1.5047 Z-.9537
    N1536 X1.0952 Y-1.4934 Z-.9539
    N1537 X1.08 Y-1.4821 Z-.9541
    N1538 X1.0619 Y-1.4725 Z-.9543
    N1539 X1.0412 Y-1.465 Z-.9545
    N1540 X1.0185 Y-1.4602 Z-.9547
    N1541 X.9906 Y-1.4583 Z-.955
    N1542 X.3726 Z-.9611
    N1543 X.3558 Y-1.459 Z-.9612
    N1544 X.3437 Y-1.4605 Z-.9614
    N1545 X.3185 Y-1.4667 Z-.9616
    N1546 X.2974 Y-1.4752 Z-.9618
    N1547 X.2791 Y-1.4861 Z-.962
    N1548 X.2647 Y-1.4981 Z-.9622
    N1549 X.2547 Y-1.5098 Z-.9624
    N1550 X.2489 Y-1.5198 Z-.9625
    N1551 X.2464 Y-1.5272 Z-.9626
    N1552 X.245 Y-1.539 Z-.9627
    N1553 Y-1.8827 Z-.9661
    N1554 X.2461 Y-1.8908 Z-.9662
    N1555 X.2492 Y-1.8984
    N1556 X.2542 Y-1.9048 Z-.9663
    N1557 X.2606 Y-1.9098 Z-.9664
    N1558 X.2682 Y-1.9129
    N1559 X.2763 Y-1.914 Z-.9665
    N1560 X.2989 Z-.9668
    N1561 X.3222 Z-.967
    N1562 X.346 Z-.9672
    N1563 X.37 Z-.9675
    N1564 X.995 Z-.9736
    N1565 X1.019 Z-.9738
    N1566 X1.0428 Z-.9741
    N1567 X1.0661 Z-.9743
    N1568 X1.0888 Z-.9745
    N1569 G3 X1.12 Y-1.8827 Z-.975 J.0313
    N1570 G1 Y-1.5371 Z-.9784
    N1571 X1.1193 Y-1.5288 Z-.9785
    N1572 X1.1186 Y-1.5259
    N1573 X1.114 Y-1.5157 Z-.9786
    N1574 X1.1064 Y-1.5047 Z-.9787
    N1575 X1.0952 Y-1.4934 Z-.9789
    N1576 X1.08 Y-1.4821 Z-.9791
    N1577 X1.0619 Y-1.4725 Z-.9793
    N1578 X1.0412 Y-1.465 Z-.9795
    N1579 X1.0185 Y-1.4602 Z-.9797
    N1580 X.9906 Y-1.4583 Z-.98
    N1581 X.3726 Z-.9861
    N1582 X.3558 Y-1.459 Z-.9862
    N1583 X.3437 Y-1.4605 Z-.9864
    N1584 X.3185 Y-1.4667 Z-.9866
    N1585 X.2974 Y-1.4752 Z-.9868
    N1586 X.2791 Y-1.4861 Z-.987
    N1587 X.2647 Y-1.4981 Z-.9872
    N1588 X.2547 Y-1.5098 Z-.9874
    N1589 X.2489 Y-1.5198 Z-.9875
    N1590 X.2464 Y-1.5272 Z-.9876
    N1591 X.245 Y-1.539 Z-.9877
    N1592 Y-1.8827 Z-.9911
    N1593 X.2461 Y-1.8908 Z-.9912
    N1594 X.2492 Y-1.8984
    N1595 X.2542 Y-1.9048 Z-.9913
    N1596 X.2606 Y-1.9098 Z-.9914
    N1597 X.2682 Y-1.9129
    N1598 X.2763 Y-1.914 Z-.9915
    N1599 X.2989 Z-.9918
    N1600 X.3222 Z-.992
    N1601 X.346 Z-.9922
    N1602 X.37 Z-.9925
    N1603 X.995 Z-.9986
    N1604 X1.019 Z-.9988
    N1605 X1.0428 Z-.9991
    N1606 X1.0661 Z-.9993
    N1607 X1.0888 Z-.9995
    N1608 G3 X1.12 Y-1.8827 Z-1. J.0313
    N1609 G1 Y-1.5371 Z-1.0034
    N1610 X1.1193 Y-1.5288 Z-1.0035
    N1611 X1.1186 Y-1.5259
    N1612 X1.114 Y-1.5157 Z-1.0036
    N1613 X1.1064 Y-1.5047 Z-1.0037
    N1614 X1.0952 Y-1.4934 Z-1.0039
    N1615 X1.08 Y-1.4821 Z-1.0041
    N1616 X1.0619 Y-1.4725 Z-1.0043
    N1617 X1.0412 Y-1.465 Z-1.0045
    N1618 X1.0185 Y-1.4602 Z-1.0047
    N1619 X.9906 Y-1.4583 Z-1.005
    N1620 X.3726 Z-1.0111
    N1621 X.3558 Y-1.459 Z-1.0112
    N1622 X.3437 Y-1.4605 Z-1.0114
    N1623 X.3185 Y-1.4667 Z-1.0116
    N1624 X.2974 Y-1.4752 Z-1.0118
    N1625 X.2791 Y-1.4861 Z-1.012
    N1626 X.2647 Y-1.4981 Z-1.0122
    N1627 X.2547 Y-1.5098 Z-1.0124
    N1628 X.2489 Y-1.5198 Z-1.0125
    N1629 X.2464 Y-1.5272 Z-1.0126
    N1630 X.245 Y-1.539 Z-1.0127
    N1631 Y-1.8827 Z-1.0161
    N1632 X.2461 Y-1.8908 Z-1.0162
    N1633 X.2492 Y-1.8984
    N1634 X.2542 Y-1.9048 Z-1.0163
    N1635 X.2606 Y-1.9098 Z-1.0164
    N1636 X.2682 Y-1.9129
    N1637 X.2763 Y-1.914 Z-1.0165
    N1638 X.2989 Z-1.0168
    N1639 X.3222 Z-1.017
    N1640 X.346 Z-1.0172
    N1641 X.37 Z-1.0175
    N1642 X.995 Z-1.0236
    N1643 X1.019 Z-1.0238
    N1644 X1.0428 Z-1.0241
    N1645 X1.0661 Z-1.0243
    N1646 X1.0888 Z-1.0245
    N1647 G3 X1.12 Y-1.8827 Z-1.025 J.0313
    N1648 G1 Y-1.5371 Z-1.0284
    N1649 X1.1193 Y-1.5288 Z-1.0285
    N1650 X1.1186 Y-1.5259
    N1651 X1.114 Y-1.5157 Z-1.0286
    N1652 X1.1064 Y-1.5047 Z-1.0287
    N1653 X1.0952 Y-1.4934 Z-1.0289
    N1654 X1.08 Y-1.4821 Z-1.0291
    N1655 X1.0619 Y-1.4725 Z-1.0293
    N1656 X1.0412 Y-1.465 Z-1.0295
    N1657 X1.0185 Y-1.4602 Z-1.0297
    N1658 X.9906 Y-1.4583 Z-1.03
    N1659 X.3726 Z-1.0361
    N1660 X.3558 Y-1.459 Z-1.0362
    N1661 X.3437 Y-1.4605 Z-1.0364
    N1662 X.3185 Y-1.4667 Z-1.0366
    N1663 X.2974 Y-1.4752 Z-1.0368
    N1664 X.2791 Y-1.4861 Z-1.037
    N1665 X.2647 Y-1.4981 Z-1.0372
    N1666 X.2547 Y-1.5098 Z-1.0374
    N1667 X.2489 Y-1.5198 Z-1.0375
    N1668 X.2464 Y-1.5272 Z-1.0376
    N1669 X.245 Y-1.539 Z-1.0377
    N1670 Y-1.8827 Z-1.0411
    N1671 X.2461 Y-1.8908 Z-1.0412
    N1672 X.2492 Y-1.8984
    N1673 X.2542 Y-1.9048 Z-1.0413
    N1674 X.2606 Y-1.9098 Z-1.0414
    N1675 X.2682 Y-1.9129
    N1676 X.2763 Y-1.914 Z-1.0415
    N1677 X.2989 Z-1.0418
    N1678 X.3222 Z-1.042
    N1679 X.346 Z-1.0422
    N1680 X.37 Z-1.0425
    N1681 X.995 Z-1.0486
    N1682 X1.019 Z-1.0488
    N1683 X1.0428 Z-1.0491
    N1684 X1.0661 Z-1.0493
    N1685 X1.0888 Z-1.0495
    N1686 G3 X1.12 Y-1.8827 Z-1.05 J.0313
    N1687 G1 Y-1.5371 Z-1.0534
    N1688 X1.1193 Y-1.5288 Z-1.0535
    N1689 X1.1186 Y-1.5259
    N1690 X1.114 Y-1.5157 Z-1.0536
    N1691 X1.1064 Y-1.5047 Z-1.0537
    N1692 X1.0952 Y-1.4934 Z-1.0539
    N1693 X1.08 Y-1.4821 Z-1.0541
    N1694 X1.0619 Y-1.4725 Z-1.0543
    N1695 X1.0412 Y-1.465 Z-1.0545
    N1696 X1.0185 Y-1.4602 Z-1.0547
    N1697 X.9906 Y-1.4583 Z-1.055
    N1698 X.3726 Z-1.0611
    N1699 X.3558 Y-1.459 Z-1.0612
    N1700 X.3437 Y-1.4605 Z-1.0614
    N1701 X.3185 Y-1.4667 Z-1.0616
    N1702 X.2974 Y-1.4752 Z-1.0618
    N1703 X.2791 Y-1.4861 Z-1.062
    N1704 X.2647 Y-1.4981 Z-1.0622
    N1705 X.2547 Y-1.5098 Z-1.0624
    N1706 X.2489 Y-1.5198 Z-1.0625
    N1707 X.2464 Y-1.5272 Z-1.0626
    N1708 X.245 Y-1.539 Z-1.0627
    N1709 Y-1.8827 Z-1.0661
    N1710 X.2461 Y-1.8908 Z-1.0662
    N1711 X.2492 Y-1.8984
    N1712 X.2542 Y-1.9048 Z-1.0663
    N1713 X.2606 Y-1.9098 Z-1.0664
    N1714 X.2682 Y-1.9129
    N1715 X.2763 Y-1.914 Z-1.0665
    N1716 X.2989 Z-1.0668
    N1717 X.3222 Z-1.067
    N1718 X.346 Z-1.0672
    N1719 X.37 Z-1.0675
    N1720 X.995 Z-1.0736
    N1721 X1.019 Z-1.0738
    N1722 X1.0428 Z-1.0741
    N1723 X1.0661 Z-1.0743
    N1724 X1.0888 Z-1.0745
    N1725 G3 X1.12 Y-1.8827 Z-1.075 J.0313
    N1726 G1 Y-1.5371 Z-1.0784
    N1727 X1.1193 Y-1.5288 Z-1.0785
    N1728 X1.1186 Y-1.5259
    N1729 X1.114 Y-1.5157 Z-1.0786
    N1730 X1.1064 Y-1.5047 Z-1.0787
    N1731 X1.0952 Y-1.4934 Z-1.0789
    N1732 X1.08 Y-1.4821 Z-1.0791
    N1733 X1.0619 Y-1.4725 Z-1.0793
    N1734 X1.0412 Y-1.465 Z-1.0795
    N1735 X1.0185 Y-1.4602 Z-1.0797
    N1736 X.9906 Y-1.4583 Z-1.08
    N1737 X.3726 Z-1.0861
    N1738 X.3558 Y-1.459 Z-1.0862
    N1739 X.3437 Y-1.4605 Z-1.0864
    N1740 X.3185 Y-1.4667 Z-1.0866
    N1741 X.2974 Y-1.4752 Z-1.0868
    N1742 X.2791 Y-1.4861 Z-1.087
    N1743 X.2647 Y-1.4981 Z-1.0872
    N1744 X.2547 Y-1.5098 Z-1.0874
    N1745 X.2489 Y-1.5198 Z-1.0875
    N1746 X.2464 Y-1.5272 Z-1.0876
    N1747 X.245 Y-1.539 Z-1.0877
    N1748 Y-1.8827 Z-1.0911
    N1749 X.2461 Y-1.8908 Z-1.0912
    N1750 X.2492 Y-1.8984
    N1751 X.2542 Y-1.9048 Z-1.0913
    N1752 X.2606 Y-1.9098 Z-1.0914
    N1753 X.2682 Y-1.9129
    N1754 X.2763 Y-1.914 Z-1.0915
    N1755 X.2989 Z-1.0918
    N1756 X.3222 Z-1.092
    N1757 X.346 Z-1.0922
    N1758 X.37 Z-1.0925
    N1759 X.995 Z-1.0986
    N1760 X1.019 Z-1.0988
    N1761 X1.0428 Z-1.0991
    N1762 X1.0661 Z-1.0993
    N1763 X1.0888 Z-1.0995
    N1764 G3 X1.12 Y-1.8827 Z-1.1 J.0313
    N1765 G1 Y-1.5371 Z-1.1034
    N1766 X1.1193 Y-1.5288 Z-1.1035
    N1767 X1.1186 Y-1.5259
    N1768 X1.114 Y-1.5157 Z-1.1036
    N1769 X1.1064 Y-1.5047 Z-1.1037
    N1770 X1.0952 Y-1.4934 Z-1.1039
    N1771 X1.08 Y-1.4821 Z-1.1041
    N1772 X1.0619 Y-1.4725 Z-1.1043
    N1773 X1.0412 Y-1.465 Z-1.1045
    N1774 X1.0185 Y-1.4602 Z-1.1047
    N1775 X.9906 Y-1.4583 Z-1.105
    N1776 X.3726 Z-1.1111
    N1777 X.3558 Y-1.459 Z-1.1112
    N1778 X.3437 Y-1.4605 Z-1.1114
    N1779 X.3185 Y-1.4667 Z-1.1116
    N1780 X.2974 Y-1.4752 Z-1.1118
    N1781 X.2791 Y-1.4861 Z-1.112
    N1782 X.2647 Y-1.4981 Z-1.1122
    N1783 X.2547 Y-1.5098 Z-1.1124
    N1784 X.2489 Y-1.5198 Z-1.1125
    N1785 X.2464 Y-1.5272 Z-1.1126
    N1786 X.245 Y-1.539 Z-1.1127
    N1787 Y-1.8827 Z-1.1161
    N1788 X.2461 Y-1.8908 Z-1.1162
    N1789 X.2492 Y-1.8984
    N1790 X.2542 Y-1.9048 Z-1.1163
    N1791 X.2606 Y-1.9098 Z-1.1164
    N1792 X.2682 Y-1.9129
    N1793 X.2763 Y-1.914 Z-1.1165
    N1794 X.2989 Z-1.1168
    N1795 X.3222 Z-1.117
    N1796 X.346 Z-1.1172
    N1797 X.37 Z-1.1175
    N1798 X.995 Z-1.1236
    N1799 X1.019 Z-1.1238
    N1800 X1.0428 Z-1.1241
    N1801 X1.0661 Z-1.1243
    N1802 X1.0888 Z-1.1245
    N1803 G3 X1.12 Y-1.8827 Z-1.125 J.0313
    N1804 G1 Y-1.5371 Z-1.1284
    N1805 X1.1193 Y-1.5288 Z-1.1285
    N1806 X1.1186 Y-1.5259
    N1807 X1.114 Y-1.5157 Z-1.1286
    N1808 X1.1064 Y-1.5047 Z-1.1287
    N1809 X1.0952 Y-1.4934 Z-1.1289
    N1810 X1.08 Y-1.4821 Z-1.1291
    N1811 X1.0619 Y-1.4725 Z-1.1293
    N1812 X1.0412 Y-1.465 Z-1.1295
    N1813 X1.0185 Y-1.4602 Z-1.1297
    N1814 X.9906 Y-1.4583 Z-1.13
    N1815 X.3726 Z-1.1361
    N1816 X.3558 Y-1.459 Z-1.1362
    N1817 X.3437 Y-1.4605 Z-1.1364
    N1818 X.3185 Y-1.4667 Z-1.1366
    N1819 X.2974 Y-1.4752 Z-1.1368
    N1820 X.2791 Y-1.4861 Z-1.137
    N1821 X.2647 Y-1.4981 Z-1.1372
    N1822 X.2547 Y-1.5098 Z-1.1374
    N1823 X.2489 Y-1.5198 Z-1.1375
    N1824 X.2464 Y-1.5272 Z-1.1376
    N1825 X.245 Y-1.539 Z-1.1377
    N1826 Y-1.8827 Z-1.1411
    N1827 X.2461 Y-1.8908 Z-1.1412
    N1828 X.2492 Y-1.8984
    N1829 X.2542 Y-1.9048 Z-1.1413
    N1830 X.2606 Y-1.9098 Z-1.1414
    N1831 X.2682 Y-1.9129
    N1832 X.2763 Y-1.914 Z-1.1415
    N1833 X.2989 Z-1.1418
    N1834 X.3222 Z-1.142
    N1835 X.346 Z-1.1422
    N1836 X.37 Z-1.1425
    N1837 X.995 Z-1.1486
    N1838 X1.019 Z-1.1488
    N1839 X1.0428 Z-1.1491
    N1840 X1.0661 Z-1.1493
    N1841 X1.0888 Z-1.1495
    N1842 G3 X1.12 Y-1.8827 Z-1.15 J.0313
    N1843 G1 Y-1.5371 Z-1.1534
    N1844 X1.1193 Y-1.5288 Z-1.1535
    N1845 X1.1186 Y-1.5259
    N1846 X1.114 Y-1.5157 Z-1.1536
    N1847 X1.1064 Y-1.5047 Z-1.1537
    N1848 X1.0952 Y-1.4934 Z-1.1539
    N1849 X1.08 Y-1.4821 Z-1.1541
    N1850 X1.0619 Y-1.4725 Z-1.1543
    N1851 X1.0412 Y-1.465 Z-1.1545
    N1852 X1.0185 Y-1.4602 Z-1.1547
    N1853 X.9906 Y-1.4583 Z-1.155
    N1854 X.3726 Z-1.1611
    N1855 X.3558 Y-1.459 Z-1.1612
    N1856 X.3437 Y-1.4605 Z-1.1614
    N1857 X.3185 Y-1.4667 Z-1.1616
    N1858 X.2974 Y-1.4752 Z-1.1618
    N1859 X.2791 Y-1.4861 Z-1.162
    N1860 X.2647 Y-1.4981 Z-1.1622
    N1861 X.2547 Y-1.5098 Z-1.1624
    N1862 X.2489 Y-1.5198 Z-1.1625
    N1863 X.2464 Y-1.5272 Z-1.1626
    N1864 X.245 Y-1.539 Z-1.1627
    N1865 Y-1.8827 Z-1.1661
    N1866 X.2461 Y-1.8908 Z-1.1662
    N1867 X.2492 Y-1.8984
    N1868 X.2542 Y-1.9048 Z-1.1663
    N1869 X.2606 Y-1.9098 Z-1.1664
    N1870 X.2682 Y-1.9129
    N1871 X.2763 Y-1.914 Z-1.1665
    N1872 X.2989 Z-1.1668
    N1873 X.3222 Z-1.167
    N1874 X.346 Z-1.1672
    N1875 X.37 Z-1.1675
    N1876 X.995 Z-1.1736
    N1877 X1.019 Z-1.1738
    N1878 X1.0428 Z-1.1741
    N1879 X1.0661 Z-1.1743
    N1880 X1.0888 Z-1.1745
    N1881 G3 X1.12 Y-1.8827 Z-1.175 J.0313
    N1882 G1 Y-1.5371 Z-1.1784
    N1883 X1.1193 Y-1.5288 Z-1.1785
    N1884 X1.1186 Y-1.5259
    N1885 X1.114 Y-1.5157 Z-1.1786
    N1886 X1.1064 Y-1.5047 Z-1.1787
    N1887 X1.0952 Y-1.4934 Z-1.1789
    N1888 X1.08 Y-1.4821 Z-1.1791
    N1889 X1.0619 Y-1.4725 Z-1.1793
    N1890 X1.0412 Y-1.465 Z-1.1795
    N1891 X1.0185 Y-1.4602 Z-1.1797
    N1892 X.9906 Y-1.4583 Z-1.18
    N1893 X.3726 Z-1.1861
    N1894 X.3558 Y-1.459 Z-1.1862
    N1895 X.3437 Y-1.4605 Z-1.1864
    N1896 X.3185 Y-1.4667 Z-1.1866
    N1897 X.2974 Y-1.4752 Z-1.1868
    N1898 X.2791 Y-1.4861 Z-1.187
    N1899 X.2647 Y-1.4981 Z-1.1872
    N1900 X.2547 Y-1.5098 Z-1.1874
    N1901 X.2489 Y-1.5198 Z-1.1875
    N1902 X.2464 Y-1.5272 Z-1.1876
    N1903 X.245 Y-1.539 Z-1.1877
    N1904 Y-1.8827 Z-1.1911
    N1905 X.2461 Y-1.8908 Z-1.1912
    N1906 X.2492 Y-1.8984
    N1907 X.2542 Y-1.9048 Z-1.1913
    N1908 X.2606 Y-1.9098 Z-1.1914
    N1909 X.2682 Y-1.9129
    N1910 X.2763 Y-1.914 Z-1.1915
    N1911 X.2989 Z-1.1918
    N1912 X.3222 Z-1.192
    N1913 X.346 Z-1.1922
    N1914 X.37 Z-1.1925
    N1915 X.995 Z-1.1986
    N1916 X1.019 Z-1.1988
    N1917 X1.0428 Z-1.1991
    N1918 X1.0661 Z-1.1993
    N1919 X1.0888 Z-1.1995
    N1920 G3 X1.12 Y-1.8827 Z-1.2 J.0313
    N1921 G1 Y-1.5371 Z-1.2034
    N1922 X1.1193 Y-1.5288 Z-1.2035
    N1923 X1.1186 Y-1.5259
    N1924 X1.114 Y-1.5157 Z-1.2036
    N1925 X1.1064 Y-1.5047 Z-1.2037
    N1926 X1.0952 Y-1.4934 Z-1.2039
    N1927 X1.08 Y-1.4821 Z-1.2041
    N1928 X1.0619 Y-1.4725 Z-1.2043
    N1929 X1.0412 Y-1.465 Z-1.2045
    N1930 X1.0185 Y-1.4602 Z-1.2047
    N1931 X.9906 Y-1.4583 Z-1.205
    N1932 X.3726 Z-1.2111
    N1933 X.3558 Y-1.459 Z-1.2112
    N1934 X.3437 Y-1.4605 Z-1.2114
    N1935 X.3185 Y-1.4667 Z-1.2116
    N1936 X.2974 Y-1.4752 Z-1.2118
    N1937 X.2791 Y-1.4861 Z-1.212
    N1938 X.2647 Y-1.4981 Z-1.2122
    N1939 X.2547 Y-1.5098 Z-1.2124
    N1940 X.2489 Y-1.5198 Z-1.2125
    N1941 X.2464 Y-1.5272 Z-1.2126
    N1942 X.245 Y-1.539 Z-1.2127
    N1943 Y-1.8827 Z-1.2161
    N1944 X.2461 Y-1.8908 Z-1.2162
    N1945 X.2492 Y-1.8984
    N1946 X.2542 Y-1.9048 Z-1.2163
    N1947 X.2606 Y-1.9098 Z-1.2164
    N1948 X.2682 Y-1.9129
    N1949 X.2763 Y-1.914 Z-1.2165
    N1950 X.2989 Z-1.2168
    N1951 X.3222 Z-1.217
    N1952 X.346 Z-1.2172
    N1953 X.37 Z-1.2175
    N1954 X.995 Z-1.2236
    N1955 X1.019 Z-1.2238
    N1956 X1.0428 Z-1.2241
    N1957 X1.0661 Z-1.2243
    N1958 X1.0888 Z-1.2245
    N1959 G3 X1.12 Y-1.8827 Z-1.225 J.0313
    N1960 G1 Y-1.5371 Z-1.2284
    N1961 X1.1193 Y-1.5288 Z-1.2285
    N1962 X1.1186 Y-1.5259
    N1963 X1.114 Y-1.5157 Z-1.2286
    N1964 X1.1064 Y-1.5047 Z-1.2287
    N1965 X1.0952 Y-1.4934 Z-1.2289
    N1966 X1.08 Y-1.4821 Z-1.2291
    N1967 X1.0619 Y-1.4725 Z-1.2293
    N1968 X1.0412 Y-1.465 Z-1.2295
    N1969 X1.0185 Y-1.4602 Z-1.2297
    N1970 X.9906 Y-1.4583 Z-1.23
    N1971 X.3726 Z-1.2361
    N1972 X.3558 Y-1.459 Z-1.2362
    N1973 X.3437 Y-1.4605 Z-1.2364
    N1974 X.3185 Y-1.4667 Z-1.2366
    N1975 X.2974 Y-1.4752 Z-1.2368
    N1976 X.2791 Y-1.4861 Z-1.237
    N1977 X.2647 Y-1.4981 Z-1.2372
    N1978 X.2547 Y-1.5098 Z-1.2374
    N1979 X.2489 Y-1.5198 Z-1.2375
    N1980 X.2464 Y-1.5272 Z-1.2376
    N1981 X.245 Y-1.539 Z-1.2377
    N1982 Y-1.8827 Z-1.2411
    N1983 X.2461 Y-1.8908 Z-1.2412
    N1984 X.2492 Y-1.8984
    N1985 X.2542 Y-1.9048 Z-1.2413
    N1986 X.2606 Y-1.9098 Z-1.2414
    N1987 X.2682 Y-1.9129
    N1988 X.2763 Y-1.914 Z-1.2415
    N1989 X.2989 Z-1.2418
    N1990 X.3222 Z-1.242
    N1991 X.346 Z-1.2422
    N1992 X.37 Z-1.2425
    N1993 X.995 Z-1.2486
    N1994 X1.019 Z-1.2488
    N1995 X1.0428 Z-1.2491
    N1996 X1.0661 Z-1.2493
    N1997 X1.0888 Z-1.2495
    N1998 G3 X1.12 Y-1.8827 Z-1.25 J.0313
    N1999 G1 Y-1.5371 Z-1.2534
    N2000 X1.1193 Y-1.5288 Z-1.2535
    N2001 X1.1186 Y-1.5259
    N2002 X1.114 Y-1.5157 Z-1.2536
    N2003 X1.1064 Y-1.5047 Z-1.2537
    N2004 X1.0952 Y-1.4934 Z-1.2539
    N2005 X1.08 Y-1.4821 Z-1.2541
    N2006 X1.0619 Y-1.4725 Z-1.2543
    N2007 X1.0412 Y-1.465 Z-1.2545
    N2008 X1.0185 Y-1.4602 Z-1.2547
    N2009 X.9906 Y-1.4583 Z-1.255
    N2010 X.3726 Z-1.2611
    N2011 X.3558 Y-1.459 Z-1.2612
    N2012 X.3437 Y-1.4605 Z-1.2614
    N2013 X.3185 Y-1.4667 Z-1.2616
    N2014 X.2974 Y-1.4752 Z-1.2618
    N2015 X.2791 Y-1.4861 Z-1.262
    N2016 X.2647 Y-1.4981 Z-1.2622
    N2017 X.2547 Y-1.5098 Z-1.2624
    N2018 X.2489 Y-1.5198 Z-1.2625
    N2019 X.2464 Y-1.5272 Z-1.2626
    N2020 X.245 Y-1.539 Z-1.2627
    N2021 Y-1.8827 Z-1.2661
    N2022 X.2461 Y-1.8908 Z-1.2662
    N2023 X.2492 Y-1.8984
    N2024 X.2542 Y-1.9048 Z-1.2663
    N2025 X.2606 Y-1.9098 Z-1.2664
    N2026 X.2682 Y-1.9129
    N2027 X.2763 Y-1.914 Z-1.2665
    N2028 X.2989 Z-1.2668
    N2029 X.3222 Z-1.267
    N2030 X.346 Z-1.2672
    N2031 X.37 Z-1.2675
    N2032 X.995 Z-1.2736
    N2033 X1.019 Z-1.2738
    N2034 X1.0428 Z-1.2741
    N2035 X1.0661 Z-1.2743
    N2036 X1.0888 Z-1.2745
    N2037 G3 X1.12 Y-1.8827 Z-1.275 J.0313
    N2038 G1 Y-1.5371 Z-1.2784
    N2039 X1.1193 Y-1.5288 Z-1.2785
    N2040 X1.1186 Y-1.5259
    N2041 X1.114 Y-1.5157 Z-1.2786
    N2042 X1.1064 Y-1.5047 Z-1.2787
    N2043 X1.0952 Y-1.4934 Z-1.2789
    N2044 X1.08 Y-1.4821 Z-1.2791
    N2045 X1.0619 Y-1.4725 Z-1.2793
    N2046 X1.0412 Y-1.465 Z-1.2795
    N2047 X1.0185 Y-1.4602 Z-1.2797
    N2048 X.9906 Y-1.4583 Z-1.28
    N2049 X.3726 Z-1.2861
    N2050 X.3558 Y-1.459 Z-1.2862
    N2051 X.3437 Y-1.4605 Z-1.2864
    N2052 X.3185 Y-1.4667 Z-1.2866
    N2053 X.2974 Y-1.4752 Z-1.2868
    N2054 X.2791 Y-1.4861 Z-1.287
    N2055 X.2647 Y-1.4981 Z-1.2872
    N2056 X.2547 Y-1.5098 Z-1.2874
    N2057 X.2489 Y-1.5198 Z-1.2875
    N2058 X.2464 Y-1.5272 Z-1.2876
    N2059 X.245 Y-1.539 Z-1.2877
    N2060 Y-1.8827 Z-1.2911
    N2061 X.2461 Y-1.8908 Z-1.2912
    N2062 X.2492 Y-1.8984
    N2063 X.2542 Y-1.9048 Z-1.2913
    N2064 X.2606 Y-1.9098 Z-1.2914
    N2065 X.2682 Y-1.9129
    N2066 X.2763 Y-1.914 Z-1.2915
    N2067 X.2989 Z-1.2918
    N2068 X.3222 Z-1.292
    N2069 X.346 Z-1.2922
    N2070 X.37 Z-1.2925
    N2071 X.995 Z-1.2986
    N2072 X1.019 Z-1.2988
    N2073 X1.0428 Z-1.2991
    N2074 X1.0661 Z-1.2993
    N2075 X1.0888 Z-1.2995
    N2076 G3 X1.12 Y-1.8827 Z-1.3 J.0313
    N2077 G1 Y-1.5371 Z-1.3034
    N2078 X1.1193 Y-1.5288 Z-1.3035
    N2079 X1.1186 Y-1.5259
    N2080 X1.114 Y-1.5157 Z-1.3036
    N2081 X1.1064 Y-1.5047 Z-1.3037
    N2082 X1.0952 Y-1.4934 Z-1.3039
    N2083 X1.08 Y-1.4821 Z-1.3041
    N2084 X1.0619 Y-1.4725 Z-1.3043
    N2085 X1.0412 Y-1.465 Z-1.3045
    N2086 X1.0185 Y-1.4602 Z-1.3047
    N2087 X.9906 Y-1.4583 Z-1.305
    N2088 X.3726 Z-1.3111
    N2089 X.3558 Y-1.459 Z-1.3112
    N2090 X.3437 Y-1.4605 Z-1.3114
    N2091 X.3185 Y-1.4667 Z-1.3116
    N2092 X.2974 Y-1.4752 Z-1.3118
    N2093 X.2791 Y-1.4861 Z-1.312
    N2094 X.2647 Y-1.4981 Z-1.3122
    N2095 X.2547 Y-1.5098 Z-1.3124
    N2096 X.2489 Y-1.5198 Z-1.3125
    N2097 X.2464 Y-1.5272 Z-1.3126
    N2098 X.245 Y-1.539 Z-1.3127
    N2099 Y-1.8827 Z-1.3161
    N2100 X.2461 Y-1.8908 Z-1.3162
    N2101 X.2492 Y-1.8984
    N2102 X.2542 Y-1.9048 Z-1.3163
    N2103 X.2606 Y-1.9098 Z-1.3164
    N2104 X.2682 Y-1.9129
    N2105 X.2763 Y-1.914 Z-1.3165
    N2106 X.2989 Z-1.3168
    N2107 X.3222 Z-1.317
    N2108 X.346 Z-1.3172
    N2109 X.37 Z-1.3175
    N2110 X.995 Z-1.3236
    N2111 X1.019 Z-1.3238
    N2112 X1.0428 Z-1.3241
    N2113 X1.0661 Z-1.3243
    N2114 X1.0888 Z-1.3245
    N2115 G3 X1.12 Y-1.8827 Z-1.325 J.0313
    N2116 G1 Y-1.5371 Z-1.3284
    N2117 X1.1193 Y-1.5288 Z-1.3285
    N2118 X1.1186 Y-1.5259
    N2119 X1.114 Y-1.5157 Z-1.3286
    N2120 X1.1064 Y-1.5047 Z-1.3287
    N2121 X1.0952 Y-1.4934 Z-1.3289
    N2122 X1.08 Y-1.4821 Z-1.3291
    N2123 X1.0619 Y-1.4725 Z-1.3293
    N2124 X1.0412 Y-1.465 Z-1.3295
    N2125 X1.0185 Y-1.4602 Z-1.3297
    N2126 X.9906 Y-1.4583 Z-1.33
    N2127 X.3726 Z-1.3361
    N2128 X.3558 Y-1.459 Z-1.3362
    N2129 X.3437 Y-1.4605 Z-1.3364
    N2130 X.3185 Y-1.4667 Z-1.3366
    N2131 X.2974 Y-1.4752 Z-1.3368
    N2132 X.2791 Y-1.4861 Z-1.337
    N2133 X.2647 Y-1.4981 Z-1.3372
    N2134 X.2547 Y-1.5098 Z-1.3374
    N2135 X.2489 Y-1.5198 Z-1.3375
    N2136 X.2464 Y-1.5272 Z-1.3376
    N2137 X.245 Y-1.539 Z-1.3377
    N2138 Y-1.8827 Z-1.3411
    N2139 X.2461 Y-1.8908 Z-1.3412
    N2140 X.2492 Y-1.8984
    N2141 X.2542 Y-1.9048 Z-1.3413
    N2142 X.2606 Y-1.9098 Z-1.3414
    N2143 X.2682 Y-1.9129
    N2144 X.2763 Y-1.914 Z-1.3415
    N2145 X.2989 Z-1.3418
    N2146 X.3222 Z-1.342
    N2147 X.346 Z-1.3422
    N2148 X.37 Z-1.3425
    N2149 X.995 Z-1.3486
    N2150 X1.019 Z-1.3488
    N2151 X1.0428 Z-1.3491
    N2152 X1.0661 Z-1.3493
    N2153 X1.0888 Z-1.3495
    N2154 G3 X1.12 Y-1.8827 Z-1.35 J.0313
    N2155 G1 Y-1.5371 Z-1.3534
    N2156 X1.1193 Y-1.5288 Z-1.3535
    N2157 X1.1186 Y-1.5259
    N2158 X1.114 Y-1.5157 Z-1.3536
    N2159 X1.1064 Y-1.5047 Z-1.3537
    N2160 X1.0952 Y-1.4934 Z-1.3539
    N2161 X1.08 Y-1.4821 Z-1.3541
    N2162 X1.0619 Y-1.4725 Z-1.3543
    N2163 X1.0412 Y-1.465 Z-1.3545
    N2164 X1.0185 Y-1.4602 Z-1.3547
    N2165 X.9906 Y-1.4583 Z-1.355
    N2166 X.3726 Z-1.3611
    N2167 X.3558 Y-1.459 Z-1.3612
    N2168 X.3437 Y-1.4605 Z-1.3614
    N2169 X.3185 Y-1.4667 Z-1.3616
    N2170 X.2974 Y-1.4752 Z-1.3618
    N2171 X.2791 Y-1.4861 Z-1.362
    N2172 X.2647 Y-1.4981 Z-1.3622
    N2173 X.2547 Y-1.5098 Z-1.3624
    N2174 X.2489 Y-1.5198 Z-1.3625
    N2175 X.2464 Y-1.5272 Z-1.3626
    N2176 X.245 Y-1.539 Z-1.3627
    N2177 Y-1.8827 Z-1.3661
    N2178 X.2461 Y-1.8908 Z-1.3662
    N2179 X.2492 Y-1.8984
    N2180 X.2542 Y-1.9048 Z-1.3663
    N2181 X.2606 Y-1.9098 Z-1.3664
    N2182 X.2682 Y-1.9129
    N2183 X.2763 Y-1.914 Z-1.3665
    N2184 X.2989 Z-1.3668
    N2185 X.3222 Z-1.367
    N2186 X.346 Z-1.3672
    N2187 X.37 Z-1.3675
    N2188 X.995 Z-1.3736
    N2189 X1.019 Z-1.3738
    N2190 X1.0428 Z-1.3741
    N2191 X1.0661 Z-1.3743
    N2192 X1.0888 Z-1.3745
    N2193 G3 X1.12 Y-1.8827 Z-1.375 J.0313
    N2194 G1 Y-1.5371 Z-1.3784
    N2195 X1.1193 Y-1.5288 Z-1.3785
    N2196 X1.1186 Y-1.5259
    N2197 X1.114 Y-1.5157 Z-1.3786
    N2198 X1.1064 Y-1.5047 Z-1.3787
    N2199 X1.0952 Y-1.4934 Z-1.3789
    N2200 X1.08 Y-1.4821 Z-1.3791
    N2201 X1.0619 Y-1.4725 Z-1.3793
    N2202 X1.0412 Y-1.465 Z-1.3795
    N2203 X1.0185 Y-1.4602 Z-1.3797
    N2204 X.9906 Y-1.4583 Z-1.38
    N2205 X.3726 Z-1.3861
    N2206 X.3558 Y-1.459 Z-1.3862
    N2207 X.3437 Y-1.4605 Z-1.3864
    N2208 X.3185 Y-1.4667 Z-1.3866
    N2209 X.2974 Y-1.4752 Z-1.3868
    N2210 X.2791 Y-1.4861 Z-1.387
    N2211 X.2647 Y-1.4981 Z-1.3872
    N2212 X.2547 Y-1.5098 Z-1.3874
    N2213 X.2489 Y-1.5198 Z-1.3875
    N2214 X.2464 Y-1.5272 Z-1.3876
    N2215 X.245 Y-1.539 Z-1.3877
    N2216 Y-1.8827 Z-1.3911
    N2217 X.2461 Y-1.8908 Z-1.3912
    N2218 X.2492 Y-1.8984
    N2219 X.2542 Y-1.9048 Z-1.3913
    N2220 X.2606 Y-1.9098 Z-1.3914
    N2221 X.2682 Y-1.9129
    N2222 X.2763 Y-1.914 Z-1.3915
    N2223 X.2989 Z-1.3918
    N2224 X.3222 Z-1.392
    N2225 X.346 Z-1.3922
    N2226 X.37 Z-1.3925
    N2227 X.995 Z-1.3986
    N2228 X1.019 Z-1.3988
    N2229 X1.0428 Z-1.3991
    N2230 X1.0661 Z-1.3993
    N2231 X1.0888 Z-1.3995
    N2232 G3 X1.12 Y-1.8827 Z-1.4 J.0313
    N2233 G1 Y-1.5371 Z-1.4034
    N2234 X1.1193 Y-1.5288 Z-1.4035
    N2235 X1.1186 Y-1.5259
    N2236 X1.114 Y-1.5157 Z-1.4036
    N2237 X1.1064 Y-1.5047 Z-1.4037
    N2238 X1.0952 Y-1.4934 Z-1.4039
    N2239 X1.08 Y-1.4821 Z-1.4041
    N2240 X1.0619 Y-1.4725 Z-1.4043
    N2241 X1.0412 Y-1.465 Z-1.4045
    N2242 X1.0185 Y-1.4602 Z-1.4047
    N2243 X.9906 Y-1.4583 Z-1.405
    N2244 X.3726 Z-1.4111
    N2245 X.3558 Y-1.459 Z-1.4112
    N2246 X.3437 Y-1.4605 Z-1.4114
    N2247 X.3185 Y-1.4667 Z-1.4116
    N2248 X.2974 Y-1.4752 Z-1.4118
    N2249 X.2791 Y-1.4861 Z-1.412
    N2250 X.2647 Y-1.4981 Z-1.4122
    N2251 X.2547 Y-1.5098 Z-1.4124
    N2252 X.2489 Y-1.5198 Z-1.4125
    N2253 X.2464 Y-1.5272 Z-1.4126
    N2254 X.245 Y-1.539 Z-1.4127
    N2255 Y-1.8827 Z-1.4161
    N2256 X.2461 Y-1.8908 Z-1.4162
    N2257 X.2492 Y-1.8984
    N2258 X.2542 Y-1.9048 Z-1.4163
    N2259 X.2606 Y-1.9098 Z-1.4164
    N2260 X.2682 Y-1.9129
    N2261 X.2763 Y-1.914 Z-1.4165
    N2262 X.2989 Z-1.4168
    N2263 X.3222 Z-1.417
    N2264 X.346 Z-1.4172
    N2265 X.37 Z-1.4175
    N2266 X.995 Z-1.4236
    N2267 X1.019 Z-1.4238
    N2268 X1.0428 Z-1.4241
    N2269 X1.0661 Z-1.4243
    N2270 X1.0888 Z-1.4245
    N2271 G3 X1.12 Y-1.8827 Z-1.425 J.0313
    N2272 G1 Y-1.5371 Z-1.4284
    N2273 X1.1193 Y-1.5288 Z-1.4285
    N2274 X1.1186 Y-1.5259
    N2275 X1.114 Y-1.5157 Z-1.4286
    N2276 X1.1064 Y-1.5047 Z-1.4287
    N2277 X1.0952 Y-1.4934 Z-1.4289
    N2278 X1.08 Y-1.4821 Z-1.4291
    N2279 X1.0619 Y-1.4725 Z-1.4293
    N2280 X1.0412 Y-1.465 Z-1.4295
    N2281 X1.0185 Y-1.4602 Z-1.4297
    N2282 X.9906 Y-1.4583 Z-1.43
    N2283 X.3726 Z-1.4361
    N2284 X.3558 Y-1.459 Z-1.4362
    N2285 X.3437 Y-1.4605 Z-1.4364
    N2286 X.3185 Y-1.4667 Z-1.4366
    N2287 X.2974 Y-1.4752 Z-1.4368
    N2288 X.2791 Y-1.4861 Z-1.437
    N2289 X.2647 Y-1.4981 Z-1.4372
    N2290 X.2547 Y-1.5098 Z-1.4374
    N2291 X.2489 Y-1.5198 Z-1.4375
    N2292 X.2464 Y-1.5272 Z-1.4376
    N2293 X.245 Y-1.539 Z-1.4377
    N2294 Y-1.8827 Z-1.4411
    N2295 X.2461 Y-1.8908 Z-1.4412
    N2296 X.2492 Y-1.8984
    N2297 X.2542 Y-1.9048 Z-1.4413
    N2298 X.2606 Y-1.9098 Z-1.4414
    N2299 X.2682 Y-1.9129
    N2300 X.2763 Y-1.914 Z-1.4415
    N2301 X.2989 Z-1.4418
    N2302 X.3222 Z-1.442
    N2303 X.346 Z-1.4422
    N2304 X.37 Z-1.4425
    N2305 X.995 Z-1.4486
    N2306 X1.019 Z-1.4488
    N2307 X1.0428 Z-1.4491
    N2308 X1.0661 Z-1.4493
    N2309 X1.0888 Z-1.4495
    N2310 G3 X1.12 Y-1.8827 Z-1.45 J.0313
    N2311 G1 Y-1.5371 Z-1.4534
    N2312 X1.1193 Y-1.5288 Z-1.4535
    N2313 X1.1186 Y-1.5259
    N2314 X1.114 Y-1.5157 Z-1.4536
    N2315 X1.1064 Y-1.5047 Z-1.4537
    N2316 X1.0952 Y-1.4934 Z-1.4539
    N2317 X1.08 Y-1.4821 Z-1.4541
    N2318 X1.0619 Y-1.4725 Z-1.4543
    N2319 X1.0412 Y-1.465 Z-1.4545
    N2320 X1.0185 Y-1.4602 Z-1.4547
    N2321 X.9906 Y-1.4583 Z-1.455
    N2322 X.3726 Z-1.4611
    N2323 X.3558 Y-1.459 Z-1.4612
    N2324 X.3437 Y-1.4605 Z-1.4614
    N2325 X.3185 Y-1.4667 Z-1.4616
    N2326 X.2974 Y-1.4752 Z-1.4618
    N2327 X.2791 Y-1.4861 Z-1.462
    N2328 X.2647 Y-1.4981 Z-1.4622
    N2329 X.2547 Y-1.5098 Z-1.4624
    N2330 X.2489 Y-1.5198 Z-1.4625
    N2331 X.2464 Y-1.5272 Z-1.4626
    N2332 X.245 Y-1.539 Z-1.4627
    N2333 Y-1.8827 Z-1.4661
    N2334 X.2461 Y-1.8908 Z-1.4662
    N2335 X.2492 Y-1.8984
    N2336 X.2542 Y-1.9048 Z-1.4663
    N2337 X.2606 Y-1.9098 Z-1.4664
    N2338 X.2682 Y-1.9129
    N2339 X.2763 Y-1.914 Z-1.4665
    N2340 X.2989 Z-1.4668
    N2341 X.3222 Z-1.467
    N2342 X.346 Z-1.4672
    N2343 X.37 Z-1.4675
    N2344 X.995 Z-1.4736
    N2345 X1.019 Z-1.4738
    N2346 X1.0428 Z-1.4741
    N2347 X1.0661 Z-1.4743
    N2348 X1.0888 Z-1.4745
    N2349 G3 X1.12 Y-1.8827 Z-1.475 J.0313
    N2350 G1 Y-1.5371 Z-1.4784
    N2351 X1.1193 Y-1.5288 Z-1.4785
    N2352 X1.1186 Y-1.5259
    N2353 X1.114 Y-1.5157 Z-1.4786
    N2354 X1.1064 Y-1.5047 Z-1.4787
    N2355 X1.0952 Y-1.4934 Z-1.4789
    N2356 X1.08 Y-1.4821 Z-1.4791
    N2357 X1.0619 Y-1.4725 Z-1.4793
    N2358 X1.0412 Y-1.465 Z-1.4795
    N2359 X1.0185 Y-1.4602 Z-1.4797
    N2360 X.9906 Y-1.4583 Z-1.48
    N2361 X.3726 Z-1.4861
    N2362 X.3558 Y-1.459 Z-1.4862
    N2363 X.3437 Y-1.4605 Z-1.4864
    N2364 X.3185 Y-1.4667 Z-1.4866
    N2365 X.2974 Y-1.4752 Z-1.4868
    N2366 X.2791 Y-1.4861 Z-1.487
    N2367 X.2647 Y-1.4981 Z-1.4872
    N2368 X.2547 Y-1.5098 Z-1.4874
    N2369 X.2489 Y-1.5198 Z-1.4875
    N2370 X.2464 Y-1.5272 Z-1.4876
    N2371 X.245 Y-1.539 Z-1.4877
    N2372 Y-1.8827 Z-1.4911
    N2373 X.2461 Y-1.8908 Z-1.4912
    N2374 X.2492 Y-1.8984
    N2375 X.2542 Y-1.9048 Z-1.4913
    N2376 X.2606 Y-1.9098 Z-1.4914
    N2377 X.2682 Y-1.9129
    N2378 X.2763 Y-1.914 Z-1.4915
    N2379 X.2989 Z-1.4918
    N2380 X.3222 Z-1.492
    N2381 X.346 Z-1.4922
    N2382 X.37 Z-1.4925
    N2383 X.995 Z-1.4986
    N2384 X1.019 Z-1.4988
    N2385 X1.0428 Z-1.4991
    N2386 X1.0661 Z-1.4993
    N2387 X1.0888 Z-1.4995
    N2388 G3 X1.12 Y-1.8827 Z-1.5 J.0313
    N2389 G1 Y-1.5371 Z-1.5034
    N2390 X1.1193 Y-1.5288 Z-1.5035
    N2391 X1.1186 Y-1.5259
    N2392 X1.114 Y-1.5157 Z-1.5036
    N2393 X1.1064 Y-1.5047 Z-1.5037
    N2394 X1.0952 Y-1.4934 Z-1.5039
    N2395 X1.08 Y-1.4821 Z-1.5041
    N2396 X1.0619 Y-1.4725 Z-1.5043
    N2397 X1.0412 Y-1.465 Z-1.5045
    N2398 X1.0185 Y-1.4602 Z-1.5047
    N2399 X.9906 Y-1.4583 Z-1.505
    N2400 X.3726 Z-1.5111
    N2401 X.3558 Y-1.459 Z-1.5112
    N2402 X.3437 Y-1.4605 Z-1.5114
    N2403 X.3185 Y-1.4667 Z-1.5116
    N2404 X.2974 Y-1.4752 Z-1.5118
    N2405 X.2791 Y-1.4861 Z-1.512
    N2406 X.2647 Y-1.4981 Z-1.5122
    N2407 X.2547 Y-1.5098 Z-1.5124
    N2408 X.2489 Y-1.5198 Z-1.5125
    N2409 X.2464 Y-1.5272 Z-1.5126
    N2410 X.245 Y-1.539 Z-1.5127
    N2411 Y-1.8827 Z-1.5161
    N2412 X.2461 Y-1.8908 Z-1.5162
    N2413 X.2492 Y-1.8984
    N2414 X.2542 Y-1.9048 Z-1.5163
    N2415 X.2606 Y-1.9098 Z-1.5164
    N2416 X.2682 Y-1.9129
    N2417 X.2763 Y-1.914 Z-1.5165
    N2418 X.2989 Z-1.5168
    N2419 X.3222 Z-1.517
    N2420 X.346 Z-1.5172
    N2421 X.37 Z-1.5175
    N2422 X.995 Z-1.5236
    N2423 X1.019 Z-1.5238
    N2424 X1.0428 Z-1.5241
    N2425 X1.0661 Z-1.5243
    N2426 X1.0888 Z-1.5245
    N2427 G3 X1.12 Y-1.8827 Z-1.525 J.0313
    N2428 G1 Y-1.5371 Z-1.5284
    N2429 X1.1193 Y-1.5288 Z-1.5285
    N2430 X1.1186 Y-1.5259
    N2431 X1.114 Y-1.5157 Z-1.5286
    N2432 X1.1064 Y-1.5047 Z-1.5287
    N2433 X1.0952 Y-1.4934 Z-1.5289
    N2434 X1.08 Y-1.4821 Z-1.5291
    N2435 X1.0619 Y-1.4725 Z-1.5293
    N2436 X1.0412 Y-1.465 Z-1.5295
    N2437 X1.0185 Y-1.4602 Z-1.5297
    N2438 X.9906 Y-1.4583 Z-1.53
    N2439 X.3726 Z-1.5361
    N2440 X.3558 Y-1.459 Z-1.5362
    N2441 X.3437 Y-1.4605 Z-1.5364
    N2442 X.3185 Y-1.4667 Z-1.5366
    N2443 X.2974 Y-1.4752 Z-1.5368
    N2444 X.2791 Y-1.4861 Z-1.537
    N2445 X.2647 Y-1.4981 Z-1.5372
    N2446 X.2547 Y-1.5098 Z-1.5374
    N2447 X.2489 Y-1.5198 Z-1.5375
    N2448 X.2464 Y-1.5272 Z-1.5376
    N2449 X.245 Y-1.539 Z-1.5377
    N2450 Y-1.8827 Z-1.5411
    N2451 X.2461 Y-1.8908 Z-1.5412
    N2452 X.2492 Y-1.8984
    N2453 X.2542 Y-1.9048 Z-1.5413
    N2454 X.2606 Y-1.9098 Z-1.5414
    N2455 X.2682 Y-1.9129
    N2456 X.2763 Y-1.914 Z-1.5415
    N2457 X.2989 Z-1.5418
    N2458 X.3222 Z-1.542
    N2459 X.346 Z-1.5422
    N2460 X.37 Z-1.5425
    N2461 X.995 Z-1.5486
    N2462 X1.019 Z-1.5488
    N2463 X1.0428 Z-1.5491
    N2464 X1.0661 Z-1.5493
    N2465 X1.0888 Z-1.5495
    N2466 G3 X1.12 Y-1.8827 Z-1.55 J.0313
    N2467 G1 Y-1.5371 Z-1.5534
    N2468 X1.1193 Y-1.5288 Z-1.5535
    N2469 X1.1186 Y-1.5259
    N2470 X1.114 Y-1.5157 Z-1.5536
    N2471 X1.1064 Y-1.5047 Z-1.5537
    N2472 X1.0952 Y-1.4934 Z-1.5539
    N2473 X1.08 Y-1.4821 Z-1.5541
    N2474 X1.0619 Y-1.4725 Z-1.5543
    N2475 X1.0412 Y-1.465 Z-1.5545
    N2476 X1.0185 Y-1.4602 Z-1.5547
    N2477 X.9906 Y-1.4583 Z-1.555
    N2478 X.3726 Z-1.5611
    N2479 X.3558 Y-1.459 Z-1.5612
    N2480 X.3437 Y-1.4605 Z-1.5614
    N2481 X.3185 Y-1.4667 Z-1.5616
    N2482 X.2974 Y-1.4752 Z-1.5618
    N2483 X.2791 Y-1.4861 Z-1.562
    N2484 X.2647 Y-1.4981 Z-1.5622
    N2485 X.2547 Y-1.5098 Z-1.5624
    N2486 X.2489 Y-1.5198 Z-1.5625
    N2487 X.2464 Y-1.5272 Z-1.5626
    N2488 X.245 Y-1.539 Z-1.5627
    N2489 Y-1.8827 Z-1.5661
    N2490 X.2461 Y-1.8908 Z-1.5662
    N2491 X.2492 Y-1.8984
    N2492 X.2542 Y-1.9048 Z-1.5663
    N2493 X.2606 Y-1.9098 Z-1.5664
    N2494 X.2682 Y-1.9129
    N2495 X.2763 Y-1.914 Z-1.5665
    N2496 X.2989 Z-1.5668
    N2497 X.3222 Z-1.567
    N2498 X.346 Z-1.5672
    N2499 X.37 Z-1.5675
    N2500 X.995 Z-1.5736
    N2501 X1.019 Z-1.5738
    N2502 X1.0428 Z-1.5741
    N2503 X1.0661 Z-1.5743
    N2504 X1.0888 Z-1.5745
    N2505 G3 X1.12 Y-1.8827 Z-1.575 J.0313
    N2506 G1 Y-1.5371 Z-1.5784
    N2507 X1.1193 Y-1.5288 Z-1.5785
    N2508 X1.1186 Y-1.5259
    N2509 X1.114 Y-1.5157 Z-1.5786
    N2510 X1.1064 Y-1.5047 Z-1.5787
    N2511 X1.0952 Y-1.4934 Z-1.5789
    N2512 X1.08 Y-1.4821 Z-1.5791
    N2513 X1.0619 Y-1.4725 Z-1.5793
    N2514 X1.0412 Y-1.465 Z-1.5795
    N2515 X1.0185 Y-1.4602 Z-1.5797
    N2516 X.9906 Y-1.4583 Z-1.58
    N2517 X.3726 Z-1.5861
    N2518 X.3558 Y-1.459 Z-1.5862
    N2519 X.3437 Y-1.4605 Z-1.5864
    N2520 X.3185 Y-1.4667 Z-1.5866
    N2521 X.2974 Y-1.4752 Z-1.5868
    N2522 X.2791 Y-1.4861 Z-1.587
    N2523 X.2647 Y-1.4981 Z-1.5872
    N2524 X.2547 Y-1.5098 Z-1.5874
    N2525 X.2489 Y-1.5198 Z-1.5875
    N2526 X.2464 Y-1.5272 Z-1.5876
    N2527 X.245 Y-1.539 Z-1.5877
    N2528 Y-1.8827 Z-1.5911
    N2529 X.2461 Y-1.8908 Z-1.5912
    N2530 X.2492 Y-1.8984
    N2531 X.2542 Y-1.9048 Z-1.5913
    N2532 X.2606 Y-1.9098 Z-1.5914
    N2533 X.2682 Y-1.9129
    N2534 X.2763 Y-1.914 Z-1.5915
    N2535 X.2989 Z-1.5918
    N2536 X.3222 Z-1.592
    N2537 X.346 Z-1.5922
    N2538 X.37 Z-1.5925
    N2539 X.995 Z-1.5986
    N2540 X1.019 Z-1.5988
    N2541 X1.0428 Z-1.5991
    N2542 X1.0661 Z-1.5993
    N2543 X1.0888 Z-1.5995
    N2544 G3 X1.12 Y-1.8827 Z-1.6 J.0313
    N2545 G1 Y-1.5371 Z-1.6034
    N2546 X1.1193 Y-1.5288 Z-1.6035
    N2547 X1.1186 Y-1.5259
    N2548 X1.114 Y-1.5157 Z-1.6036
    N2549 X1.1064 Y-1.5047 Z-1.6037
    N2550 X1.0952 Y-1.4934 Z-1.6039
    N2551 X1.08 Y-1.4821 Z-1.6041
    N2552 X1.0619 Y-1.4725 Z-1.6043
    N2553 X1.0412 Y-1.465 Z-1.6045
    N2554 X1.0185 Y-1.4602 Z-1.6047
    N2555 X.9906 Y-1.4583 Z-1.605
    N2556 X.3726 Z-1.6111
    N2557 X.3558 Y-1.459 Z-1.6112
    N2558 X.3437 Y-1.4605 Z-1.6114
    N2559 X.3185 Y-1.4667 Z-1.6116
    N2560 X.2974 Y-1.4752 Z-1.6118
    N2561 X.2791 Y-1.4861 Z-1.612
    N2562 X.2647 Y-1.4981 Z-1.6122
    N2563 X.2547 Y-1.5098 Z-1.6124
    N2564 X.2489 Y-1.5198 Z-1.6125
    N2565 X.2464 Y-1.5272 Z-1.6126
    N2566 X.245 Y-1.539 Z-1.6127
    N2567 Y-1.8827 Z-1.6161
    N2568 X.2461 Y-1.8908 Z-1.6162
    N2569 X.2492 Y-1.8984
    N2570 X.2542 Y-1.9048 Z-1.6163
    N2571 X.2606 Y-1.9098 Z-1.6164
    N2572 X.2682 Y-1.9129
    N2573 X.2763 Y-1.914 Z-1.6165
    N2574 X.2989 Z-1.6168
    N2575 X.3222 Z-1.617
    N2576 X.346 Z-1.6172
    N2577 X.37 Z-1.6175
    N2578 X.995 Z-1.6236
    N2579 X1.019 Z-1.6238
    N2580 X1.0428 Z-1.6241
    N2581 X1.0661 Z-1.6243
    N2582 X1.0888 Z-1.6245
    N2583 G3 X1.12 Y-1.8827 Z-1.625 J.0313
    N2584 G1 Y-1.5371 Z-1.6284
    N2585 X1.1193 Y-1.5288 Z-1.6285
    N2586 X1.1186 Y-1.5259
    N2587 X1.114 Y-1.5157 Z-1.6286
    N2588 X1.1064 Y-1.5047 Z-1.6287
    N2589 X1.0952 Y-1.4934 Z-1.6289
    N2590 X1.08 Y-1.4821 Z-1.6291
    N2591 X1.0619 Y-1.4725 Z-1.6293
    N2592 X1.0412 Y-1.465 Z-1.6295
    N2593 X1.0185 Y-1.4602 Z-1.6297
    N2594 X.9906 Y-1.4583 Z-1.63
    N2595 X.3726 Z-1.6361
    N2596 X.3558 Y-1.459 Z-1.6362
    N2597 X.3437 Y-1.4605 Z-1.6364
    N2598 X.3185 Y-1.4667 Z-1.6366
    N2599 X.2974 Y-1.4752 Z-1.6368
    N2600 X.2791 Y-1.4861 Z-1.637
    N2601 X.2647 Y-1.4981 Z-1.6372
    N2602 X.2547 Y-1.5098 Z-1.6374
    N2603 X.2489 Y-1.5198 Z-1.6375
    N2604 X.2464 Y-1.5272 Z-1.6376
    N2605 X.245 Y-1.539 Z-1.6377
    N2606 Y-1.8827 Z-1.6411
    N2607 X.2461 Y-1.8908 Z-1.6412
    N2608 X.2492 Y-1.8984
    N2609 X.2542 Y-1.9048 Z-1.6413
    N2610 X.2606 Y-1.9098 Z-1.6414
    N2611 X.2682 Y-1.9129
    N2612 X.2763 Y-1.914 Z-1.6415
    N2613 X.2989 Z-1.6418
    N2614 X.3222 Z-1.642
    N2615 X.346 Z-1.6422
    N2616 X.37 Z-1.6425
    N2617 X.995 Z-1.6486
    N2618 X1.019 Z-1.6488
    N2619 X1.0428 Z-1.6491
    N2620 X1.0661 Z-1.6493
    N2621 X1.0888 Z-1.6495
    N2622 G3 X1.12 Y-1.8827 Z-1.65 J.0313
    N2623 G1 Y-1.5371 Z-1.6534
    N2624 X1.1193 Y-1.5288 Z-1.6535
    N2625 X1.1186 Y-1.5259
    N2626 X1.114 Y-1.5157 Z-1.6536
    N2627 X1.1064 Y-1.5047 Z-1.6537
    N2628 X1.0952 Y-1.4934 Z-1.6539
    N2629 X1.08 Y-1.4821 Z-1.6541
    N2630 X1.0619 Y-1.4725 Z-1.6543
    N2631 X1.0412 Y-1.465 Z-1.6545
    N2632 X1.0185 Y-1.4602 Z-1.6547
    N2633 X.9906 Y-1.4583 Z-1.655
    N2634 X.3726 Z-1.6611
    N2635 X.3558 Y-1.459 Z-1.6612
    N2636 X.3437 Y-1.4605 Z-1.6614
    N2637 X.3185 Y-1.4667 Z-1.6616
    N2638 X.2974 Y-1.4752 Z-1.6618
    N2639 X.2791 Y-1.4861 Z-1.662
    N2640 X.2647 Y-1.4981 Z-1.6622
    N2641 X.2547 Y-1.5098 Z-1.6624
    N2642 X.2489 Y-1.5198 Z-1.6625
    N2643 X.2464 Y-1.5272 Z-1.6626
    N2644 X.245 Y-1.539 Z-1.6627
    N2645 Y-1.8827 Z-1.6661
    N2646 X.2461 Y-1.8908 Z-1.6662
    N2647 X.2492 Y-1.8984
    N2648 X.2542 Y-1.9048 Z-1.6663
    N2649 X.2606 Y-1.9098 Z-1.6664
    N2650 X.2682 Y-1.9129
    N2651 X.2763 Y-1.914 Z-1.6665
    N2652 X.2989 Z-1.6668
    N2653 X.3222 Z-1.667
    N2654 X.346 Z-1.6672
    N2655 X.37 Z-1.6675
    N2656 X.995 Z-1.6736
    N2657 X1.019 Z-1.6738
    N2658 X1.0428 Z-1.6741
    N2659 X1.0661 Z-1.6743
    N2660 X1.0888 Z-1.6745
    N2661 G3 X1.12 Y-1.8827 Z-1.675 J.0313
    N2662 G1 Y-1.5371 Z-1.6784
    N2663 X1.1193 Y-1.5288 Z-1.6785
    N2664 X1.1186 Y-1.5259
    N2665 X1.114 Y-1.5157 Z-1.6786
    N2666 X1.1064 Y-1.5047 Z-1.6787
    N2667 X1.0952 Y-1.4934 Z-1.6789
    N2668 X1.08 Y-1.4821 Z-1.6791
    N2669 X1.0619 Y-1.4725 Z-1.6793
    N2670 X1.0412 Y-1.465 Z-1.6795
    N2671 X1.0185 Y-1.4602 Z-1.6797
    N2672 X.9906 Y-1.4583 Z-1.68
    N2673 X.3726 Z-1.6861
    N2674 X.3558 Y-1.459 Z-1.6862
    N2675 X.3437 Y-1.4605 Z-1.6864
    N2676 X.3185 Y-1.4667 Z-1.6866
    N2677 X.2974 Y-1.4752 Z-1.6868
    N2678 X.2791 Y-1.4861 Z-1.687
    N2679 X.2647 Y-1.4981 Z-1.6872
    N2680 X.2547 Y-1.5098 Z-1.6874
    N2681 X.2489 Y-1.5198 Z-1.6875
    N2682 X.2464 Y-1.5272 Z-1.6876
    N2683 X.245 Y-1.539 Z-1.6877
    N2684 Y-1.8827 Z-1.6911
    N2685 X.2461 Y-1.8908 Z-1.6912
    N2686 X.2492 Y-1.8984
    N2687 X.2542 Y-1.9048 Z-1.6913
    N2688 X.2606 Y-1.9098 Z-1.6914
    N2689 X.2682 Y-1.9129
    N2690 X.2763 Y-1.914 Z-1.6915
    N2691 X.2989 Z-1.6918
    N2692 X.3222 Z-1.692
    N2693 X.346 Z-1.6922
    N2694 X.37 Z-1.6925
    N2695 X.995 Z-1.6986
    N2696 X1.019 Z-1.6988
    N2697 X1.0428 Z-1.6991
    N2698 X1.0661 Z-1.6993
    N2699 X1.0888 Z-1.6995
    N2700 G3 X1.12 Y-1.8827 Z-1.7 J.0313
    N2701 G1 Y-1.5371 Z-1.7034
    N2702 X1.1193 Y-1.5288 Z-1.7035
    N2703 X1.1186 Y-1.5259
    N2704 X1.114 Y-1.5157 Z-1.7036
    N2705 X1.1064 Y-1.5047 Z-1.7037
    N2706 X1.0952 Y-1.4934 Z-1.7039
    N2707 X1.08 Y-1.4821 Z-1.7041
    N2708 X1.0619 Y-1.4725 Z-1.7043
    N2709 X1.0412 Y-1.465 Z-1.7045
    N2710 X1.0185 Y-1.4602 Z-1.7047
    N2711 X.9906 Y-1.4583 Z-1.705
    N2712 X.3726 Z-1.7111
    N2713 X.3558 Y-1.459 Z-1.7112
    N2714 X.3437 Y-1.4605 Z-1.7114
    N2715 X.3185 Y-1.4667 Z-1.7116
    N2716 X.2974 Y-1.4752 Z-1.7118
    N2717 X.2791 Y-1.4861 Z-1.712
    N2718 X.2647 Y-1.4981 Z-1.7122
    N2719 X.2547 Y-1.5098 Z-1.7124
    N2720 X.2489 Y-1.5198 Z-1.7125
    N2721 X.2464 Y-1.5272 Z-1.7126
    N2722 X.245 Y-1.539 Z-1.7127
    N2723 Y-1.8827 Z-1.7161
    N2724 X.2461 Y-1.8908 Z-1.7162
    N2725 X.2492 Y-1.8984
    N2726 X.2542 Y-1.9048 Z-1.7163
    N2727 X.2606 Y-1.9098 Z-1.7164
    N2728 X.2682 Y-1.9129
    N2729 X.2763 Y-1.914 Z-1.7165
    N2730 X.2989 Z-1.7168
    N2731 X.3222 Z-1.717
    N2732 X.346 Z-1.7172
    N2733 X.37 Z-1.7175
    N2734 X.995 Z-1.7236
    N2735 X1.019 Z-1.7238
    N2736 X1.0428 Z-1.7241
    N2737 X1.0661 Z-1.7243
    N2738 X1.0888 Z-1.7245
    N2739 G3 X1.12 Y-1.8827 Z-1.725 J.0313
    N2740 G1 Y-1.5371 Z-1.7284
    N2741 X1.1193 Y-1.5288 Z-1.7285
    N2742 X1.1186 Y-1.5259
    N2743 X1.114 Y-1.5157 Z-1.7286
    N2744 X1.1064 Y-1.5047 Z-1.7287
    N2745 X1.0952 Y-1.4934 Z-1.7289
    N2746 X1.08 Y-1.4821 Z-1.7291
    N2747 X1.0619 Y-1.4725 Z-1.7293
    N2748 X1.0412 Y-1.465 Z-1.7295
    N2749 X1.0185 Y-1.4602 Z-1.7297
    N2750 X.9906 Y-1.4583 Z-1.73
    N2751 X.3726 Z-1.7361
    N2752 X.3558 Y-1.459 Z-1.7362
    N2753 X.3437 Y-1.4605 Z-1.7364
    N2754 X.3185 Y-1.4667 Z-1.7366
    N2755 X.2974 Y-1.4752 Z-1.7368
    N2756 X.2791 Y-1.4861 Z-1.737
    N2757 X.2647 Y-1.4981 Z-1.7372
    N2758 X.2547 Y-1.5098 Z-1.7374
    N2759 X.2489 Y-1.5198 Z-1.7375
    N2760 X.2464 Y-1.5272 Z-1.7376
    N2761 X.245 Y-1.539 Z-1.7377
    N2762 Y-1.8827 Z-1.7411
    N2763 X.2461 Y-1.8908 Z-1.7412
    N2764 X.2492 Y-1.8984
    N2765 X.2542 Y-1.9048 Z-1.7413
    N2766 X.2606 Y-1.9098 Z-1.7414
    N2767 X.2682 Y-1.9129
    N2768 X.2763 Y-1.914 Z-1.7415
    N2769 X.2989 Z-1.7418
    N2770 X.3222 Z-1.742
    N2771 X.346 Z-1.7422
    N2772 X.37 Z-1.7425
    N2773 X.995 Z-1.7486
    N2774 X1.019 Z-1.7488
    N2775 X1.0428 Z-1.7491
    N2776 X1.0661 Z-1.7493
    N2777 X1.0888 Z-1.7495
    N2778 G3 X1.12 Y-1.8827 Z-1.75 J.0313
    N2779 G1 Y-1.5371 Z-1.7534
    N2780 X1.1193 Y-1.5288 Z-1.7535
    N2781 X1.1186 Y-1.5259
    N2782 X1.114 Y-1.5157 Z-1.7536
    N2783 X1.1064 Y-1.5047 Z-1.7537
    N2784 X1.0952 Y-1.4934 Z-1.7539
    N2785 X1.08 Y-1.4821 Z-1.7541
    N2786 X1.0619 Y-1.4725 Z-1.7543
    N2787 X1.0412 Y-1.465 Z-1.7545
    N2788 X1.0185 Y-1.4602 Z-1.7547
    N2789 X.9906 Y-1.4583 Z-1.755
    N2790 X.3726 Z-1.7611
    N2791 X.3558 Y-1.459 Z-1.7612
    N2792 X.3437 Y-1.4605 Z-1.7614
    N2793 X.3185 Y-1.4667 Z-1.7616
    N2794 X.2974 Y-1.4752 Z-1.7618
    N2795 X.2791 Y-1.4861 Z-1.762
    N2796 X.2647 Y-1.4981 Z-1.7622
    N2797 X.2547 Y-1.5098 Z-1.7624
    N2798 X.2489 Y-1.5198 Z-1.7625
    N2799 X.2464 Y-1.5272 Z-1.7626
    N2800 X.245 Y-1.539 Z-1.7627
    N2801 Y-1.8827 Z-1.7661
    N2802 X.2461 Y-1.8908 Z-1.7662
    N2803 X.2492 Y-1.8984
    N2804 X.2542 Y-1.9048 Z-1.7663
    N2805 X.2606 Y-1.9098 Z-1.7664
    N2806 X.2682 Y-1.9129
    N2807 X.2763 Y-1.914 Z-1.7665
    N2808 X.2989 Z-1.7668
    N2809 X.3222 Z-1.767
    N2810 X.346 Z-1.7672
    N2811 X.37 Z-1.7675
    N2812 X.995 Z-1.7736
    N2813 X1.019 Z-1.7738
    N2814 X1.0428 Z-1.7741
    N2815 X1.0661 Z-1.7743
    N2816 X1.0888 Z-1.7745
    N2817 G3 X1.12 Y-1.8827 Z-1.775 J.0313
    N2818 G1 Y-1.5371 Z-1.7784
    N2819 X1.1193 Y-1.5288 Z-1.7785
    N2820 X1.1186 Y-1.5259
    N2821 X1.114 Y-1.5157 Z-1.7786
    N2822 X1.1064 Y-1.5047 Z-1.7787
    N2823 X1.0952 Y-1.4934 Z-1.7789
    N2824 X1.08 Y-1.4821 Z-1.7791
    N2825 X1.0619 Y-1.4725 Z-1.7793
    N2826 X1.0412 Y-1.465 Z-1.7795
    N2827 X1.0185 Y-1.4602 Z-1.7797
    N2828 X.9906 Y-1.4583 Z-1.78
    N2829 X.3726 Z-1.7861
    N2830 X.3558 Y-1.459 Z-1.7862
    N2831 X.3437 Y-1.4605 Z-1.7864
    N2832 X.3185 Y-1.4667 Z-1.7866
    N2833 X.2974 Y-1.4752 Z-1.7868
    N2834 X.2791 Y-1.4861 Z-1.787
    N2835 X.2647 Y-1.4981 Z-1.7872
    N2836 X.2547 Y-1.5098 Z-1.7874
    N2837 X.2489 Y-1.5198 Z-1.7875
    N2838 X.2464 Y-1.5272 Z-1.7876
    N2839 X.245 Y-1.539 Z-1.7877
    N2840 Y-1.8827 Z-1.7911
    N2841 X.2461 Y-1.8908 Z-1.7912
    N2842 X.2492 Y-1.8984
    N2843 X.2542 Y-1.9048 Z-1.7913
    N2844 X.2606 Y-1.9098 Z-1.7914
    N2845 X.2682 Y-1.9129
    N2846 X.2763 Y-1.914 Z-1.7915
    N2847 X.2989 Z-1.7918
    N2848 X.3222 Z-1.792
    N2849 X.346 Z-1.7922
    N2850 X.37 Z-1.7925
    N2851 X.995 Z-1.7986
    N2852 X1.019 Z-1.7988
    N2853 X1.0428 Z-1.7991
    N2854 X1.0661 Z-1.7993
    N2855 X1.0888 Z-1.7995
    N2856 G3 X1.12 Y-1.8827 Z-1.8 J.0313
    N2857 G1 Y-1.5371 Z-1.8034
    N2858 X1.1193 Y-1.5288 Z-1.8035
    N2859 X1.1186 Y-1.5259
    N2860 X1.114 Y-1.5157 Z-1.8036
    N2861 X1.1064 Y-1.5047 Z-1.8037
    N2862 X1.0952 Y-1.4934 Z-1.8039
    N2863 X1.08 Y-1.4821 Z-1.8041
    N2864 X1.0619 Y-1.4725 Z-1.8043
    N2865 X1.0412 Y-1.465 Z-1.8045
    N2866 X1.0185 Y-1.4602 Z-1.8047
    N2867 X.9906 Y-1.4583 Z-1.805
    N2868 X.3726 Z-1.8111
    N2869 X.3558 Y-1.459 Z-1.8112
    N2870 X.3437 Y-1.4605 Z-1.8114
    N2871 X.3185 Y-1.4667 Z-1.8116
    N2872 X.2974 Y-1.4752 Z-1.8118
    N2873 X.2791 Y-1.4861 Z-1.812
    N2874 X.2647 Y-1.4981 Z-1.8122
    N2875 X.2547 Y-1.5098 Z-1.8124
    N2876 X.2489 Y-1.5198 Z-1.8125
    N2877 X.2464 Y-1.5272 Z-1.8126
    N2878 X.245 Y-1.539 Z-1.8127
    N2879 Y-1.8827 Z-1.8161
    N2880 X.2461 Y-1.8908 Z-1.8162
    N2881 X.2492 Y-1.8984
    N2882 X.2542 Y-1.9048 Z-1.8163
    N2883 X.2606 Y-1.9098 Z-1.8164
    N2884 X.2682 Y-1.9129
    N2885 X.2763 Y-1.914 Z-1.8165
    N2886 X.2989 Z-1.8168
    N2887 X.3222 Z-1.817
    N2888 X.346 Z-1.8172
    N2889 X.37 Z-1.8175
    N2890 X.995 Z-1.8236
    N2891 X1.019 Z-1.8238
    N2892 X1.0428 Z-1.8241
    N2893 X1.0661 Z-1.8243
    N2894 X1.0888 Z-1.8245
    N2895 G3 X1.12 Y-1.8827 Z-1.825 J.0313
    N2896 G1 Y-1.5371 Z-1.8284
    N2897 X1.1193 Y-1.5288 Z-1.8285
    N2898 X1.1186 Y-1.5259
    N2899 X1.114 Y-1.5157 Z-1.8286
    N2900 X1.1064 Y-1.5047 Z-1.8287
    N2901 X1.0952 Y-1.4934 Z-1.8289
    N2902 X1.08 Y-1.4821 Z-1.8291
    N2903 X1.0619 Y-1.4725 Z-1.8293
    N2904 X1.0412 Y-1.465 Z-1.8295
    N2905 X1.0185 Y-1.4602 Z-1.8297
    N2906 X.9906 Y-1.4583 Z-1.83
    N2907 X.3726 Z-1.8361
    N2908 X.3558 Y-1.459 Z-1.8362
    N2909 X.3437 Y-1.4605 Z-1.8364
    N2910 X.3185 Y-1.4667 Z-1.8366
    N2911 X.2974 Y-1.4752 Z-1.8368
    N2912 X.2791 Y-1.4861 Z-1.837
    N2913 X.2647 Y-1.4981 Z-1.8372
    N2914 X.2547 Y-1.5098 Z-1.8374
    N2915 X.2489 Y-1.5198 Z-1.8375
    N2916 X.2464 Y-1.5272 Z-1.8376
    N2917 X.245 Y-1.539 Z-1.8377
    N2918 Y-1.8827 Z-1.8411
    N2919 X.2461 Y-1.8908 Z-1.8412
    N2920 X.2492 Y-1.8984
    N2921 X.2542 Y-1.9048 Z-1.8413
    N2922 X.2606 Y-1.9098 Z-1.8414
    N2923 X.2682 Y-1.9129
    N2924 X.2763 Y-1.914 Z-1.8415
    N2925 X.2989 Z-1.8418
    N2926 X.3222 Z-1.842
    N2927 X.346 Z-1.8422
    N2928 X.37 Z-1.8425
    N2929 X.995 Z-1.8486
    N2930 X1.019 Z-1.8488
    N2931 X1.0428 Z-1.8491
    N2932 X1.0661 Z-1.8493
    N2933 X1.0888 Z-1.8495
    N2934 G3 X1.12 Y-1.8827 Z-1.85 J.0313
    N2935 G1 Y-1.5371 Z-1.8534
    N2936 X1.1193 Y-1.5288 Z-1.8535
    N2937 X1.1186 Y-1.5259
    N2938 X1.114 Y-1.5157 Z-1.8536
    N2939 X1.1064 Y-1.5047 Z-1.8537
    N2940 X1.0952 Y-1.4934 Z-1.8539
    N2941 X1.08 Y-1.4821 Z-1.8541
    N2942 X1.0619 Y-1.4725 Z-1.8543
    N2943 X1.0412 Y-1.465 Z-1.8545
    N2944 X1.0185 Y-1.4602 Z-1.8547
    N2945 X.9906 Y-1.4583 Z-1.855
    N2946 X.3726 Z-1.8611
    N2947 X.3558 Y-1.459 Z-1.8612
    N2948 X.3437 Y-1.4605 Z-1.8614
    N2949 X.3185 Y-1.4667 Z-1.8616
    N2950 X.2974 Y-1.4752 Z-1.8618
    N2951 X.2791 Y-1.4861 Z-1.862
    N2952 X.2647 Y-1.4981 Z-1.8622
    N2953 X.2547 Y-1.5098 Z-1.8624
    N2954 X.2489 Y-1.5198 Z-1.8625
    N2955 X.2464 Y-1.5272 Z-1.8626
    N2956 X.245 Y-1.539 Z-1.8627
    N2957 Y-1.8827 Z-1.8661
    N2958 X.2461 Y-1.8908 Z-1.8662
    N2959 X.2492 Y-1.8984
    N2960 X.2542 Y-1.9048 Z-1.8663
    N2961 X.2606 Y-1.9098 Z-1.8664
    N2962 X.2682 Y-1.9129
    N2963 X.2763 Y-1.914 Z-1.8665
    N2964 X.2989 Z-1.8668
    N2965 X.3222 Z-1.867
    N2966 X.346 Z-1.8672
    N2967 X.37 Z-1.8675
    N2968 X.995 Z-1.8736
    N2969 X1.019 Z-1.8738
    N2970 X1.0428 Z-1.8741
    N2971 X1.0661 Z-1.8743
    N2972 X1.0888 Z-1.8745
    N2973 G3 X1.12 Y-1.8827 Z-1.875 J.0313
    N2974 G1 Y-1.5371 Z-1.8784
    N2975 X1.1193 Y-1.5288 Z-1.8785
    N2976 X1.1186 Y-1.5259
    N2977 X1.114 Y-1.5157 Z-1.8786
    N2978 X1.1064 Y-1.5047 Z-1.8787
    N2979 X1.0952 Y-1.4934 Z-1.8789
    N2980 X1.08 Y-1.4821 Z-1.8791
    N2981 X1.0619 Y-1.4725 Z-1.8793
    N2982 X1.0412 Y-1.465 Z-1.8795
    N2983 X1.0185 Y-1.4602 Z-1.8797
    N2984 X.9906 Y-1.4583 Z-1.88
    N2985 X.3726 Z-1.8861
    N2986 X.3558 Y-1.459 Z-1.8862
    N2987 X.3437 Y-1.4605 Z-1.8864
    N2988 X.3185 Y-1.4667 Z-1.8866
    N2989 X.2974 Y-1.4752 Z-1.8868
    N2990 X.2791 Y-1.4861 Z-1.887
    N2991 X.2647 Y-1.4981 Z-1.8872
    N2992 X.2547 Y-1.5098 Z-1.8874
    N2993 X.2489 Y-1.5198 Z-1.8875
    N2994 X.2464 Y-1.5272 Z-1.8876
    N2995 X.245 Y-1.539 Z-1.8877
    N2996 Y-1.8827 Z-1.8911
    N2997 X.2461 Y-1.8908 Z-1.8912
    N2998 X.2492 Y-1.8984
    N2999 X.2542 Y-1.9048 Z-1.8913
    N3000 X.2606 Y-1.9098 Z-1.8914
    N3001 X.2682 Y-1.9129
    N3002 X.2763 Y-1.914 Z-1.8915
    N3003 X.2989 Z-1.8918
    N3004 X.3222 Z-1.892
    N3005 X.346 Z-1.8922
    N3006 X.37 Z-1.8925
    N3007 X.995 Z-1.8986
    N3008 X1.019 Z-1.8988
    N3009 X1.0428 Z-1.8991
    N3010 X1.0661 Z-1.8993
    N3011 X1.0888 Z-1.8995
    N3012 G3 X1.12 Y-1.8827 Z-1.9 J.0313
    N3013 G1 Y-1.5371 Z-1.9034
    N3014 X1.1193 Y-1.5288 Z-1.9035
    N3015 X1.1186 Y-1.5259
    N3016 X1.114 Y-1.5157 Z-1.9036
    N3017 X1.1064 Y-1.5047 Z-1.9037
    N3018 X1.0952 Y-1.4934 Z-1.9039
    N3019 X1.08 Y-1.4821 Z-1.9041
    N3020 X1.0619 Y-1.4725 Z-1.9043
    N3021 X1.0412 Y-1.465 Z-1.9045
    N3022 X1.0185 Y-1.4602 Z-1.9047
    N3023 X.9906 Y-1.4583 Z-1.905
    N3024 X.3726 Z-1.9111
    N3025 X.3558 Y-1.459 Z-1.9112
    N3026 X.3437 Y-1.4605 Z-1.9114
    N3027 X.3185 Y-1.4667 Z-1.9116
    N3028 X.2974 Y-1.4752 Z-1.9118
    N3029 X.2791 Y-1.4861 Z-1.912
    N3030 X.2647 Y-1.4981 Z-1.9122
    N3031 X.2547 Y-1.5098 Z-1.9124
    N3032 X.2489 Y-1.5198 Z-1.9125
    N3033 X.2464 Y-1.5272 Z-1.9126
    N3034 X.245 Y-1.539 Z-1.9127
    N3035 Y-1.8827 Z-1.9161
    N3036 X.2461 Y-1.8908 Z-1.9162
    N3037 X.2492 Y-1.8984
    N3038 X.2542 Y-1.9048 Z-1.9163
    N3039 X.2606 Y-1.9098 Z-1.9164
    N3040 X.2682 Y-1.9129
    N3041 X.2763 Y-1.914 Z-1.9165
    N3042 X.2989 Z-1.9168
    N3043 X.3222 Z-1.917
    N3044 X.346 Z-1.9172
    N3045 X.37 Z-1.9175
    N3046 X.995 Z-1.9236
    N3047 X1.019 Z-1.9238
    N3048 X1.0428 Z-1.9241
    N3049 X1.0661 Z-1.9243
    N3050 X1.0888 Z-1.9245
    N3051 G3 X1.12 Y-1.8827 Z-1.925 J.0313
    N3052 G1 Y-1.5371 Z-1.9284
    N3053 X1.1193 Y-1.5288 Z-1.9285
    N3054 X1.1186 Y-1.5259
    N3055 X1.114 Y-1.5157 Z-1.9286
    N3056 X1.1064 Y-1.5047 Z-1.9287
    N3057 X1.0952 Y-1.4934 Z-1.9289
    N3058 X1.08 Y-1.4821 Z-1.9291
    N3059 X1.0619 Y-1.4725 Z-1.9293
    N3060 X1.0412 Y-1.465 Z-1.9295
    N3061 X1.0185 Y-1.4602 Z-1.9297
    N3062 X.9906 Y-1.4583 Z-1.93
    N3063 X.3726 Z-1.9361
    N3064 X.3558 Y-1.459 Z-1.9362
    N3065 X.3437 Y-1.4605 Z-1.9364
    N3066 X.3185 Y-1.4667 Z-1.9366
    N3067 X.2974 Y-1.4752 Z-1.9368
    N3068 X.2791 Y-1.4861 Z-1.937
    N3069 X.2647 Y-1.4981 Z-1.9372
    N3070 X.2547 Y-1.5098 Z-1.9374
    N3071 X.2489 Y-1.5198 Z-1.9375
    N3072 X.2464 Y-1.5272 Z-1.9376
    N3073 X.245 Y-1.539 Z-1.9377
    N3074 Y-1.8827 Z-1.9411
    N3075 X.2461 Y-1.8908 Z-1.9412
    N3076 X.2492 Y-1.8984
    N3077 X.2542 Y-1.9048 Z-1.9413
    N3078 X.2606 Y-1.9098 Z-1.9414
    N3079 X.2682 Y-1.9129
    N3080 X.2763 Y-1.914 Z-1.9415
    N3081 X.2989 Z-1.9418
    N3082 X.3222 Z-1.942
    N3083 X.346 Z-1.9422
    N3084 X.37 Z-1.9425
    N3085 X.995 Z-1.9486
    N3086 X1.019 Z-1.9488
    N3087 X1.0428 Z-1.9491
    N3088 X1.0661 Z-1.9493
    N3089 X1.0888 Z-1.9495
    N3090 G3 X1.12 Y-1.8827 Z-1.95 J.0313
    N3091 G1 Y-1.5371 Z-1.9534
    N3092 X1.1193 Y-1.5288 Z-1.9535
    N3093 X1.1186 Y-1.5259
    N3094 X1.114 Y-1.5157 Z-1.9536
    N3095 X1.1064 Y-1.5047 Z-1.9537
    N3096 X1.0952 Y-1.4934 Z-1.9539
    N3097 X1.08 Y-1.4821 Z-1.9541
    N3098 X1.0619 Y-1.4725 Z-1.9543
    N3099 X1.0412 Y-1.465 Z-1.9545
    N3100 X1.0185 Y-1.4602 Z-1.9547
    N3101 X.9906 Y-1.4583 Z-1.955
    N3102 X.3726 Z-1.9611
    N3103 X.3558 Y-1.459 Z-1.9612
    N3104 X.3437 Y-1.4605 Z-1.9614
    N3105 X.3185 Y-1.4667 Z-1.9616
    N3106 X.2974 Y-1.4752 Z-1.9618
    N3107 X.2791 Y-1.4861 Z-1.962
    N3108 X.2647 Y-1.4981 Z-1.9622
    N3109 X.2547 Y-1.5098 Z-1.9624
    N3110 X.2489 Y-1.5198 Z-1.9625
    N3111 X.2464 Y-1.5272 Z-1.9626
    N3112 X.245 Y-1.539 Z-1.9627
    N3113 Y-1.8827 Z-1.9661
    N3114 X.2461 Y-1.8908 Z-1.9662
    N3115 X.2492 Y-1.8984
    N3116 X.2542 Y-1.9048 Z-1.9663
    N3117 X.2606 Y-1.9098 Z-1.9664
    N3118 X.2682 Y-1.9129
    N3119 X.2763 Y-1.914 Z-1.9665
    N3120 X.2989 Z-1.9668
    N3121 X.3222 Z-1.967
    N3122 X.346 Z-1.9672
    N3123 X.37 Z-1.9675
    N3124 X.995 Z-1.9736
    N3125 X1.019 Z-1.9738
    N3126 X1.0428 Z-1.9741
    N3127 X1.0661 Z-1.9743
    N3128 X1.0888 Z-1.9745
    N3129 G3 X1.12 Y-1.8827 Z-1.975 J.0313
    N3130 G1 Y-1.5371 Z-1.9784
    N3131 X1.1193 Y-1.5288 Z-1.9785
    N3132 X1.1186 Y-1.5259
    N3133 X1.114 Y-1.5157 Z-1.9786
    N3134 X1.1064 Y-1.5047 Z-1.9787
    N3135 X1.0952 Y-1.4934 Z-1.9789
    N3136 X1.08 Y-1.4821 Z-1.9791
    N3137 X1.0619 Y-1.4725 Z-1.9793
    N3138 X1.0412 Y-1.465 Z-1.9795
    N3139 X1.0185 Y-1.4602 Z-1.9797
    N3140 X.9906 Y-1.4583 Z-1.98
    N3141 X.3726 Z-1.9861
    N3142 X.3558 Y-1.459 Z-1.9862
    N3143 X.3437 Y-1.4605 Z-1.9864
    N3144 X.3185 Y-1.4667 Z-1.9866
    N3145 X.2974 Y-1.4752 Z-1.9868
    N3146 X.2791 Y-1.4861 Z-1.987
    N3147 X.2647 Y-1.4981 Z-1.9872
    N3148 X.2547 Y-1.5098 Z-1.9874
    N3149 X.2489 Y-1.5198 Z-1.9875
    N3150 X.2464 Y-1.5272 Z-1.9876
    N3151 X.245 Y-1.539 Z-1.9877
    N3152 Y-1.8827 Z-1.9911
    N3153 X.2461 Y-1.8908 Z-1.9912
    N3154 X.2492 Y-1.8984
    N3155 X.2542 Y-1.9048 Z-1.9913
    N3156 X.2606 Y-1.9098 Z-1.9914
    N3157 X.2682 Y-1.9129
    N3158 X.2763 Y-1.914 Z-1.9915
    N3159 X.2989 Z-1.9918
    N3160 X.3222 Z-1.992
    N3161 X.346 Z-1.9922
    N3162 X.37 Z-1.9925
    N3163 X.995 Z-1.9986
    N3164 X1.019 Z-1.9988
    N3165 X1.0428 Z-1.9991
    N3166 X1.0661 Z-1.9993
    N3167 X1.0888 Z-1.9995
    N3168 G3 X1.12 Y-1.8827 Z-2. J.0313
    N3169 G1 Y-1.5371 Z-2.0034
    N3170 X1.1193 Y-1.5288 Z-2.0035
    N3171 X1.1186 Y-1.5259
    N3172 X1.114 Y-1.5157 Z-2.0036
    N3173 X1.1064 Y-1.5047 Z-2.0037
    N3174 X1.0952 Y-1.4934 Z-2.0039
    N3175 X1.08 Y-1.4821 Z-2.0041
    N3176 X1.0619 Y-1.4725 Z-2.0043
    N3177 X1.0412 Y-1.465 Z-2.0045
    N3178 X1.0185 Y-1.4602 Z-2.0047
    N3179 X.9906 Y-1.4583 Z-2.005
    N3180 X.3726 Z-2.0111
    N3181 X.3558 Y-1.459 Z-2.0112
    N3182 X.3437 Y-1.4605 Z-2.0114
    N3183 X.3185 Y-1.4667 Z-2.0116
    N3184 X.2974 Y-1.4752 Z-2.0118
    N3185 X.2791 Y-1.4861 Z-2.012
    N3186 X.2647 Y-1.4981 Z-2.0122
    N3187 X.2547 Y-1.5098 Z-2.0124
    N3188 X.2489 Y-1.5198 Z-2.0125
    N3189 X.2464 Y-1.5272 Z-2.0126
    N3190 X.245 Y-1.539 Z-2.0127
    N3191 Y-1.8827 Z-2.0161
    N3192 X.2461 Y-1.8908 Z-2.0162
    N3193 X.2492 Y-1.8984
    N3194 X.2542 Y-1.9048 Z-2.0163
    N3195 X.2606 Y-1.9098 Z-2.0164
    N3196 X.2682 Y-1.9129
    N3197 X.2763 Y-1.914 Z-2.0165
    N3198 X.2989 Z-2.0168
    N3199 X.3222 Z-2.017
    N3200 X.346 Z-2.0172
    N3201 X.37 Z-2.0175
    N3202 X.995 Z-2.0236
    N3203 X1.019 Z-2.0238
    N3204 X1.0428 Z-2.0241
    N3205 X1.0661 Z-2.0243
    N3206 X1.0888 Z-2.0245
    N3207 G3 X1.12 Y-1.8827 Z-2.025 J.0313
    N3208 G1 Y-1.5371 Z-2.0284
    N3209 X1.1193 Y-1.5288 Z-2.0285
    N3210 X1.1186 Y-1.5259
    N3211 X1.114 Y-1.5157 Z-2.0286
    N3212 X1.1064 Y-1.5047 Z-2.0287
    N3213 X1.0952 Y-1.4934 Z-2.0289
    N3214 X1.08 Y-1.4821 Z-2.0291
    N3215 X1.0619 Y-1.4725 Z-2.0293
    N3216 X1.0412 Y-1.465 Z-2.0295
    N3217 X1.0185 Y-1.4602 Z-2.0297
    N3218 X.9906 Y-1.4583 Z-2.03
    N3219 X.3726 Z-2.0361
    N3220 X.3558 Y-1.459 Z-2.0362
    N3221 X.3437 Y-1.4605 Z-2.0364
    N3222 X.3185 Y-1.4667 Z-2.0366
    N3223 X.2974 Y-1.4752 Z-2.0368
    N3224 X.2791 Y-1.4861 Z-2.037
    N3225 X.2647 Y-1.4981 Z-2.0372
    N3226 X.2547 Y-1.5098 Z-2.0374
    N3227 X.2489 Y-1.5198 Z-2.0375
    N3228 X.2464 Y-1.5272 Z-2.0376
    N3229 X.245 Y-1.539 Z-2.0377
    N3230 Y-1.8827 Z-2.0411
    N3231 X.2461 Y-1.8908 Z-2.0412
    N3232 X.2492 Y-1.8984
    N3233 X.2542 Y-1.9048 Z-2.0413
    N3234 X.2606 Y-1.9098 Z-2.0414
    N3235 X.2682 Y-1.9129
    N3236 X.2763 Y-1.914 Z-2.0415
    N3237 X.2989 Z-2.0418
    N3238 X.3222 Z-2.042
    N3239 X.346 Z-2.0422
    N3240 X.37 Z-2.0425
    N3241 X.995 Z-2.0486
    N3242 X1.019 Z-2.0488
    N3243 X1.0428 Z-2.0491
    N3244 X1.0661 Z-2.0493
    N3245 X1.0888 Z-2.0495
    N3246 G3 X1.12 Y-1.8827 Z-2.05 J.0313
    N3247 G1 Y-1.5371 Z-2.0534
    N3248 X1.1193 Y-1.5288 Z-2.0535
    N3249 X1.1186 Y-1.5259
    N3250 X1.114 Y-1.5157 Z-2.0536
    N3251 X1.1064 Y-1.5047 Z-2.0537
    N3252 X1.0952 Y-1.4934 Z-2.0539
    N3253 X1.08 Y-1.4821 Z-2.0541
    N3254 X1.0619 Y-1.4725 Z-2.0543
    N3255 X1.0412 Y-1.465 Z-2.0545
    N3256 X1.0185 Y-1.4602 Z-2.0547
    N3257 X.9906 Y-1.4583 Z-2.055
    N3258 X.3726 Z-2.0611
    N3259 X.3558 Y-1.459 Z-2.0612
    N3260 X.3437 Y-1.4605 Z-2.0614
    N3261 X.3185 Y-1.4667 Z-2.0616
    N3262 X.2974 Y-1.4752 Z-2.0618
    N3263 X.2791 Y-1.4861 Z-2.062
    N3264 X.2647 Y-1.4981 Z-2.0622
    N3265 X.2547 Y-1.5098 Z-2.0624
    N3266 X.2489 Y-1.5198 Z-2.0625
    N3267 X.2464 Y-1.5272 Z-2.0626
    N3268 X.245 Y-1.539 Z-2.0627
    N3269 Y-1.8827 Z-2.0661
    N3270 X.2461 Y-1.8908 Z-2.0662
    N3271 X.2492 Y-1.8984
    N3272 X.2542 Y-1.9048 Z-2.0663
    N3273 X.2606 Y-1.9098 Z-2.0664
    N3274 X.2682 Y-1.9129
    N3275 X.2763 Y-1.914 Z-2.0665
    N3276 X.2989 Z-2.0668
    N3277 X.3222 Z-2.067
    N3278 X.346 Z-2.0672
    N3279 X.37 Z-2.0675
    N3280 X.995 Z-2.0736
    N3281 X1.019 Z-2.0738
    N3282 X1.0428 Z-2.0741
    N3283 X1.0661 Z-2.0743
    N3284 X1.0888 Z-2.0745
    N3285 G3 X1.12 Y-1.8827 Z-2.075 J.0313
    N3286 G1 Y-1.5371 Z-2.0784
    N3287 X1.1193 Y-1.5288 Z-2.0785
    N3288 X1.1186 Y-1.5259
    N3289 X1.114 Y-1.5157 Z-2.0786
    N3290 X1.1064 Y-1.5047 Z-2.0787
    N3291 X1.0952 Y-1.4934 Z-2.0789
    N3292 X1.08 Y-1.4821 Z-2.0791
    N3293 X1.0619 Y-1.4725 Z-2.0793
    N3294 X1.0412 Y-1.465 Z-2.0795
    N3295 X1.0185 Y-1.4602 Z-2.0797
    N3296 X.9906 Y-1.4583 Z-2.08
    N3297 X.3726 Z-2.0861
    N3298 X.3558 Y-1.459 Z-2.0862
    N3299 X.3437 Y-1.4605 Z-2.0864
    N3300 X.3185 Y-1.4667 Z-2.0866
    N3301 X.2974 Y-1.4752 Z-2.0868
    N3302 X.2791 Y-1.4861 Z-2.087
    N3303 X.2647 Y-1.4981 Z-2.0872
    N3304 X.2547 Y-1.5098 Z-2.0874
    N3305 X.2489 Y-1.5198 Z-2.0875
    N3306 X.2464 Y-1.5272 Z-2.0876
    N3307 X.245 Y-1.539 Z-2.0877
    N3308 Y-1.8827 Z-2.0911
    N3309 X.2461 Y-1.8908 Z-2.0912
    N3310 X.2492 Y-1.8984
    N3311 X.2542 Y-1.9048 Z-2.0913
    N3312 X.2606 Y-1.9098 Z-2.0914
    N3313 X.2682 Y-1.9129
    N3314 X.2763 Y-1.914 Z-2.0915
    N3315 X.2989 Z-2.0918
    N3316 X.3222 Z-2.092
    N3317 X.346 Z-2.0922
    N3318 X.37 Z-2.0925
    N3319 X.995 Z-2.0986
    N3320 X1.019 Z-2.0988
    N3321 X1.0428 Z-2.0991
    N3322 X1.0661 Z-2.0993
    N3323 X1.0888 Z-2.0995
    N3324 G3 X1.12 Y-1.8827 Z-2.1 J.0313
    N3325 G1 Y-1.5371 Z-2.1034
    N3326 X1.1193 Y-1.5288 Z-2.1035
    N3327 X1.1186 Y-1.5259
    N3328 X1.114 Y-1.5157 Z-2.1036
    N3329 X1.1064 Y-1.5047 Z-2.1037
    N3330 X1.0952 Y-1.4934 Z-2.1039
    N3331 X1.08 Y-1.4821 Z-2.1041
    N3332 X1.0619 Y-1.4725 Z-2.1043
    N3333 X1.0412 Y-1.465 Z-2.1045
    N3334 X1.0185 Y-1.4602 Z-2.1047
    N3335 X.9906 Y-1.4583 Z-2.105
    N3336 X.3726 Z-2.1111
    N3337 X.3558 Y-1.459 Z-2.1112
    N3338 X.3437 Y-1.4605 Z-2.1114
    N3339 X.3185 Y-1.4667 Z-2.1116
    N3340 X.2974 Y-1.4752 Z-2.1118
    N3341 X.2791 Y-1.4861 Z-2.112
    N3342 X.2647 Y-1.4981 Z-2.1122
    N3343 X.2547 Y-1.5098 Z-2.1124
    N3344 X.2489 Y-1.5198 Z-2.1125
    N3345 X.2464 Y-1.5272 Z-2.1126
    N3346 X.245 Y-1.539 Z-2.1127
    N3347 Y-1.8827 Z-2.1161
    N3348 X.2461 Y-1.8908 Z-2.1162
    N3349 X.2492 Y-1.8984
    N3350 X.2542 Y-1.9048 Z-2.1163
    N3351 X.2606 Y-1.9098 Z-2.1164
    N3352 X.2682 Y-1.9129
    N3353 X.2763 Y-1.914 Z-2.1165
    N3354 X.2989 Z-2.1168
    N3355 X.3222 Z-2.117
    N3356 X.346 Z-2.1172
    N3357 X.37 Z-2.1175
    N3358 X.995 Z-2.1236
    N3359 X1.019 Z-2.1238
    N3360 X1.0428 Z-2.1241
    N3361 X1.0661 Z-2.1243
    N3362 X1.0888 Z-2.1245
    N3363 G3 X1.12 Y-1.8827 Z-2.125 J.0313
    N3364 G1 Y-1.5371 Z-2.1284
    N3365 X1.1193 Y-1.5288 Z-2.1285
    N3366 X1.1186 Y-1.5259
    N3367 X1.114 Y-1.5157 Z-2.1286
    N3368 X1.1064 Y-1.5047 Z-2.1287
    N3369 X1.0952 Y-1.4934 Z-2.1289
    N3370 X1.08 Y-1.4821 Z-2.1291
    N3371 X1.0619 Y-1.4725 Z-2.1293
    N3372 X1.0412 Y-1.465 Z-2.1295
    N3373 X1.0185 Y-1.4602 Z-2.1297
    N3374 X.9906 Y-1.4583 Z-2.13
    N3375 X.3726 Z-2.1361
    N3376 X.3558 Y-1.459 Z-2.1362
    N3377 X.3437 Y-1.4605 Z-2.1364
    N3378 X.3185 Y-1.4667 Z-2.1366
    N3379 X.2974 Y-1.4752 Z-2.1368
    N3380 X.2791 Y-1.4861 Z-2.137
    N3381 X.2647 Y-1.4981 Z-2.1372
    N3382 X.2547 Y-1.5098 Z-2.1374
    N3383 X.2489 Y-1.5198 Z-2.1375
    N3384 X.2464 Y-1.5272 Z-2.1376
    N3385 X.245 Y-1.539 Z-2.1377
    N3386 Y-1.8827 Z-2.1411
    N3387 X.2461 Y-1.8908 Z-2.1412
    N3388 X.2492 Y-1.8984
    N3389 X.2542 Y-1.9048 Z-2.1413
    N3390 X.2606 Y-1.9098 Z-2.1414
    N3391 X.2682 Y-1.9129
    N3392 X.2763 Y-1.914 Z-2.1415
    N3393 X.2989 Z-2.1418
    N3394 X.3222 Z-2.142
    N3395 X.346 Z-2.1422
    N3396 X.37 Z-2.1425
    N3397 X.995 Z-2.1486
    N3398 X1.019 Z-2.1488
    N3399 X1.0428 Z-2.1491
    N3400 X1.0661 Z-2.1493
    N3401 X1.0888 Z-2.1495
    N3402 G3 X1.12 Y-1.8827 Z-2.15 J.0313
    N3403 G1 Y-1.5371 Z-2.1534
    N3404 X1.1193 Y-1.5288 Z-2.1535
    N3405 X1.1186 Y-1.5259
    N3406 X1.114 Y-1.5157 Z-2.1536
    N3407 X1.1064 Y-1.5047 Z-2.1537
    N3408 X1.0952 Y-1.4934 Z-2.1539
    N3409 X1.08 Y-1.4821 Z-2.1541
    N3410 X1.0619 Y-1.4725 Z-2.1543
    N3411 X1.0412 Y-1.465 Z-2.1545
    N3412 X1.0185 Y-1.4602 Z-2.1547
    N3413 X.9906 Y-1.4583 Z-2.155
    N3414 X.3726 Z-2.1611
    N3415 X.3558 Y-1.459 Z-2.1612
    N3416 X.3437 Y-1.4605 Z-2.1614
    N3417 X.3185 Y-1.4667 Z-2.1616
    N3418 X.2974 Y-1.4752 Z-2.1618
    N3419 X.2791 Y-1.4861 Z-2.162
    N3420 X.2647 Y-1.4981 Z-2.1622
    N3421 X.2547 Y-1.5098 Z-2.1624
    N3422 X.2489 Y-1.5198 Z-2.1625
    N3423 X.2464 Y-1.5272 Z-2.1626
    N3424 X.245 Y-1.539 Z-2.1627
    N3425 Y-1.8827 Z-2.1661
    N3426 X.2461 Y-1.8908 Z-2.1662
    N3427 X.2492 Y-1.8984
    N3428 X.2542 Y-1.9048 Z-2.1663
    N3429 X.2606 Y-1.9098 Z-2.1664
    N3430 X.2682 Y-1.9129
    N3431 X.2763 Y-1.914 Z-2.1665
    N3432 X.2989 Z-2.1668
    N3433 X.3222 Z-2.167
    N3434 X.346 Z-2.1672
    N3435 X.37 Z-2.1675
    N3436 X.995 Z-2.1736
    N3437 X1.019 Z-2.1738
    N3438 X1.0428 Z-2.1741
    N3439 X1.0661 Z-2.1743
    N3440 X1.0888 Z-2.1745
    N3441 G3 X1.12 Y-1.8827 Z-2.175 J.0313
    N3442 G1 Y-1.5371 Z-2.1784
    N3443 X1.1193 Y-1.5288 Z-2.1785
    N3444 X1.1186 Y-1.5259
    N3445 X1.114 Y-1.5157 Z-2.1786
    N3446 X1.1064 Y-1.5047 Z-2.1787
    N3447 X1.0952 Y-1.4934 Z-2.1789
    N3448 X1.08 Y-1.4821 Z-2.1791
    N3449 X1.0619 Y-1.4725 Z-2.1793
    N3450 X1.0412 Y-1.465 Z-2.1795
    N3451 X1.0185 Y-1.4602 Z-2.1797
    N3452 X.9906 Y-1.4583 Z-2.18
    N3453 X.3726 Z-2.1861
    N3454 X.3558 Y-1.459 Z-2.1862
    N3455 X.3437 Y-1.4605 Z-2.1864
    N3456 X.3185 Y-1.4667 Z-2.1866
    N3457 X.2974 Y-1.4752 Z-2.1868
    N3458 X.2791 Y-1.4861 Z-2.187
    N3459 X.2647 Y-1.4981 Z-2.1872
    N3460 X.2547 Y-1.5098 Z-2.1874
    N3461 X.2489 Y-1.5198 Z-2.1875
    N3462 X.2464 Y-1.5272 Z-2.1876
    N3463 X.245 Y-1.539 Z-2.1877
    N3464 Y-1.8827 Z-2.1911
    N3465 X.2461 Y-1.8908 Z-2.1912
    N3466 X.2492 Y-1.8984
    N3467 X.2542 Y-1.9048 Z-2.1913
    N3468 X.2606 Y-1.9098 Z-2.1914
    N3469 X.2682 Y-1.9129
    N3470 X.2763 Y-1.914 Z-2.1915
    N3471 X.2989 Z-2.1918
    N3472 X.3222 Z-2.192
    N3473 X.346 Z-2.1922
    N3474 X.37 Z-2.1925
    N3475 X.995 Z-2.1986
    N3476 X1.019 Z-2.1988
    N3477 X1.0428 Z-2.1991
    N3478 X1.0661 Z-2.1993
    N3479 X1.0888 Z-2.1995
    N3480 G3 X1.12 Y-1.8827 Z-2.2 J.0313
    N3481 G1 Y-1.5371 Z-2.2034
    N3482 X1.1193 Y-1.5288 Z-2.2035
    N3483 X1.1186 Y-1.5259
    N3484 X1.114 Y-1.5157 Z-2.2036
    N3485 X1.1064 Y-1.5047 Z-2.2037
    N3486 X1.0952 Y-1.4934 Z-2.2039
    N3487 X1.08 Y-1.4821 Z-2.2041
    N3488 X1.0619 Y-1.4725 Z-2.2043
    N3489 X1.0412 Y-1.465 Z-2.2045
    N3490 X1.0185 Y-1.4602 Z-2.2047
    N3491 X.9906 Y-1.4583 Z-2.205
    N3492 X.3726 Z-2.2111
    N3493 X.3558 Y-1.459 Z-2.2112
    N3494 X.3437 Y-1.4605 Z-2.2114
    N3495 X.3185 Y-1.4667 Z-2.2116
    N3496 X.2974 Y-1.4752 Z-2.2118
    N3497 X.2791 Y-1.4861 Z-2.212
    N3498 X.2647 Y-1.4981 Z-2.2122
    N3499 X.2547 Y-1.5098 Z-2.2124
    N3500 X.2489 Y-1.5198 Z-2.2125
    N3501 X.2464 Y-1.5272 Z-2.2126
    N3502 X.245 Y-1.539 Z-2.2127
    N3503 Y-1.8827 Z-2.2161
    N3504 X.2461 Y-1.8908 Z-2.2162
    N3505 X.2492 Y-1.8984
    N3506 X.2542 Y-1.9048 Z-2.2163
    N3507 X.2606 Y-1.9098 Z-2.2164
    N3508 X.2682 Y-1.9129
    N3509 X.2763 Y-1.914 Z-2.2165
    N3510 X.2989 Z-2.2168
    N3511 X.3222 Z-2.217
    N3512 X.346 Z-2.2172
    N3513 X.37 Z-2.2175
    N3514 X.995 Z-2.2236
    N3515 X1.019 Z-2.2238
    N3516 X1.0428 Z-2.2241
    N3517 X1.0661 Z-2.2243
    N3518 X1.0888 Z-2.2245
    N3519 G3 X1.12 Y-1.8827 Z-2.225 J.0313
    N3520 G1 Y-1.5371 Z-2.2284
    N3521 X1.1193 Y-1.5288 Z-2.2285
    N3522 X1.1186 Y-1.5259
    N3523 X1.114 Y-1.5157 Z-2.2286
    N3524 X1.1064 Y-1.5047 Z-2.2287
    N3525 X1.0952 Y-1.4934 Z-2.2289
    N3526 X1.08 Y-1.4821 Z-2.2291
    N3527 X1.0619 Y-1.4725 Z-2.2293
    N3528 X1.0412 Y-1.465 Z-2.2295
    N3529 X1.0185 Y-1.4602 Z-2.2297
    N3530 X.9906 Y-1.4583 Z-2.23
    N3531 X.3726 Z-2.2361
    N3532 X.3558 Y-1.459 Z-2.2362
    N3533 X.3437 Y-1.4605 Z-2.2364
    N3534 X.3185 Y-1.4667 Z-2.2366
    N3535 X.2974 Y-1.4752 Z-2.2368
    N3536 X.2791 Y-1.4861 Z-2.237
    N3537 X.2647 Y-1.4981 Z-2.2372
    N3538 X.2547 Y-1.5098 Z-2.2374
    N3539 X.2489 Y-1.5198 Z-2.2375
    N3540 X.2464 Y-1.5272 Z-2.2376
    N3541 X.245 Y-1.539 Z-2.2377
    N3542 Y-1.8827 Z-2.2411
    N3543 X.2461 Y-1.8908 Z-2.2412
    N3544 X.2492 Y-1.8984
    N3545 X.2542 Y-1.9048 Z-2.2413
    N3546 X.2606 Y-1.9098 Z-2.2414
    N3547 X.2682 Y-1.9129
    N3548 X.2763 Y-1.914 Z-2.2415
    N3549 X.2989 Z-2.2418
    N3550 X.3222 Z-2.242
    N3551 X.346 Z-2.2422
    N3552 X.37 Z-2.2425
    N3553 X.995 Z-2.2486
    N3554 X1.019 Z-2.2488
    N3555 X1.0428 Z-2.2491
    N3556 X1.0661 Z-2.2493
    N3557 X1.0888 Z-2.2495
    N3558 G3 X1.12 Y-1.8827 Z-2.25 J.0313
    N3559 G1 Y-1.5371 Z-2.2534
    N3560 X1.1193 Y-1.5288 Z-2.2535
    N3561 X1.1186 Y-1.5259
    N3562 X1.114 Y-1.5157 Z-2.2536
    N3563 X1.1064 Y-1.5047 Z-2.2537
    N3564 X1.0952 Y-1.4934 Z-2.2539
    N3565 X1.08 Y-1.4821 Z-2.2541
    N3566 X1.0619 Y-1.4725 Z-2.2543
    N3567 X1.0412 Y-1.465 Z-2.2545
    N3568 X1.0185 Y-1.4602 Z-2.2547
    N3569 X.9906 Y-1.4583 Z-2.255
    N3570 X.3726 Z-2.2611
    N3571 X.3558 Y-1.459 Z-2.2612
    N3572 X.3437 Y-1.4605 Z-2.2614
    N3573 X.3185 Y-1.4667 Z-2.2616
    N3574 X.2974 Y-1.4752 Z-2.2618
    N3575 X.2791 Y-1.4861 Z-2.262
    N3576 X.2647 Y-1.4981 Z-2.2622
    N3577 X.2547 Y-1.5098 Z-2.2624
    N3578 X.2489 Y-1.5198 Z-2.2625
    N3579 X.2464 Y-1.5272 Z-2.2626
    N3580 X.245 Y-1.539 Z-2.2627
    N3581 Y-1.8827 Z-2.2661
    N3582 X.2461 Y-1.8908 Z-2.2662
    N3583 X.2492 Y-1.8984
    N3584 X.2542 Y-1.9048 Z-2.2663
    N3585 X.2606 Y-1.9098 Z-2.2664
    N3586 X.2682 Y-1.9129
    N3587 X.2763 Y-1.914 Z-2.2665
    N3588 X.2989 Z-2.2668
    N3589 X.3222 Z-2.267
    N3590 X.346 Z-2.2672
    N3591 X.37 Z-2.2675
    N3592 X.995 Z-2.2736
    N3593 X1.019 Z-2.2738
    N3594 X1.0428 Z-2.2741
    N3595 X1.0661 Z-2.2743
    N3596 X1.0888 Z-2.2745
    N3597 G3 X1.12 Y-1.8827 Z-2.275 J.0313
    N3598 G1 Y-1.5371 Z-2.2784
    N3599 X1.1193 Y-1.5288 Z-2.2785
    N3600 X1.1186 Y-1.5259
    N3601 X1.114 Y-1.5157 Z-2.2786
    N3602 X1.1064 Y-1.5047 Z-2.2787
    N3603 X1.0952 Y-1.4934 Z-2.2789
    N3604 X1.08 Y-1.4821 Z-2.2791
    N3605 X1.0619 Y-1.4725 Z-2.2793
    N3606 X1.0412 Y-1.465 Z-2.2795
    N3607 X1.0185 Y-1.4602 Z-2.2797
    N3608 X.9906 Y-1.4583 Z-2.28
    N3609 X.3726 Z-2.2861
    N3610 X.3558 Y-1.459 Z-2.2862
    N3611 X.3437 Y-1.4605 Z-2.2864
    N3612 X.3185 Y-1.4667 Z-2.2866
    N3613 X.2974 Y-1.4752 Z-2.2868
    N3614 X.2791 Y-1.4861 Z-2.287
    N3615 X.2647 Y-1.4981 Z-2.2872
    N3616 X.2547 Y-1.5098 Z-2.2874
    N3617 X.2489 Y-1.5198 Z-2.2875
    N3618 X.2464 Y-1.5272 Z-2.2876
    N3619 X.245 Y-1.539 Z-2.2877
    N3620 Y-1.8827 Z-2.2911
    N3621 X.2461 Y-1.8908 Z-2.2912
    N3622 X.2492 Y-1.8984
    N3623 X.2542 Y-1.9048 Z-2.2913
    N3624 X.2606 Y-1.9098 Z-2.2914
    N3625 X.2682 Y-1.9129
    N3626 X.2763 Y-1.914 Z-2.2915
    N3627 X.2989 Z-2.2918
    N3628 X.3222 Z-2.292
    N3629 X.346 Z-2.2922
    N3630 X.37 Z-2.2925
    N3631 X.995 Z-2.2986
    N3632 X1.019 Z-2.2988
    N3633 X1.0428 Z-2.2991
    N3634 X1.0661 Z-2.2993
    N3635 X1.0888 Z-2.2995
    N3636 G3 X1.12 Y-1.8827 Z-2.3 J.0313
    N3637 G1 Y-1.5371 Z-2.3034
    N3638 X1.1193 Y-1.5288 Z-2.3035
    N3639 X1.1186 Y-1.5259
    N3640 X1.114 Y-1.5157 Z-2.3036
    N3641 X1.1064 Y-1.5047 Z-2.3037
    N3642 X1.0952 Y-1.4934 Z-2.3039
    N3643 X1.08 Y-1.4821 Z-2.3041
    N3644 X1.0619 Y-1.4725 Z-2.3043
    N3645 X1.0412 Y-1.465 Z-2.3045
    N3646 X1.0185 Y-1.4602 Z-2.3047
    N3647 X.9906 Y-1.4583 Z-2.305
    N3648 X.3726 Z-2.3111
    N3649 X.3558 Y-1.459 Z-2.3112
    N3650 X.3437 Y-1.4605 Z-2.3114
    N3651 X.3185 Y-1.4667 Z-2.3116
    N3652 X.2974 Y-1.4752 Z-2.3118
    N3653 X.2791 Y-1.4861 Z-2.312
    N3654 X.2647 Y-1.4981 Z-2.3122
    N3655 X.2547 Y-1.5098 Z-2.3124
    N3656 X.2489 Y-1.5198 Z-2.3125
    N3657 X.2464 Y-1.5272 Z-2.3126
    N3658 X.245 Y-1.539 Z-2.3127
    N3659 Y-1.8827 Z-2.3161
    N3660 X.2461 Y-1.8908 Z-2.3162
    N3661 X.2492 Y-1.8984
    N3662 X.2542 Y-1.9048 Z-2.3163
    N3663 X.2606 Y-1.9098 Z-2.3164
    N3664 X.2682 Y-1.9129
    N3665 X.2763 Y-1.914 Z-2.3165
    N3666 X.2989 Z-2.3168
    N3667 X.3222 Z-2.317
    N3668 X.346 Z-2.3172
    N3669 X.37 Z-2.3175
    N3670 X.995 Z-2.3236
    N3671 X1.019 Z-2.3238
    N3672 X1.0428 Z-2.3241
    N3673 X1.0661 Z-2.3243
    N3674 X1.0888 Z-2.3245
    N3675 G3 X1.12 Y-1.8827 Z-2.325 J.0313
    N3676 G1 Y-1.5371 Z-2.3284
    N3677 X1.1193 Y-1.5288 Z-2.3285
    N3678 X1.1186 Y-1.5259
    N3679 X1.114 Y-1.5157 Z-2.3286
    N3680 X1.1064 Y-1.5047 Z-2.3287
    N3681 X1.0952 Y-1.4934 Z-2.3289
    N3682 X1.08 Y-1.4821 Z-2.3291
    N3683 X1.0619 Y-1.4725 Z-2.3293
    N3684 X1.0412 Y-1.465 Z-2.3295
    N3685 X1.0185 Y-1.4602 Z-2.3297
    N3686 X.9906 Y-1.4583 Z-2.33
    N3687 X.3726 Z-2.3361
    N3688 X.3558 Y-1.459 Z-2.3362
    N3689 X.3437 Y-1.4605 Z-2.3364
    N3690 X.3185 Y-1.4667 Z-2.3366
    N3691 X.2974 Y-1.4752 Z-2.3368
    N3692 X.2791 Y-1.4861 Z-2.337
    N3693 X.2647 Y-1.4981 Z-2.3372
    N3694 X.2547 Y-1.5098 Z-2.3374
    N3695 X.2489 Y-1.5198 Z-2.3375
    N3696 X.2464 Y-1.5272 Z-2.3376
    N3697 X.245 Y-1.539 Z-2.3377
    N3698 Y-1.8827 Z-2.3411
    N3699 X.2461 Y-1.8908 Z-2.3412
    N3700 X.2492 Y-1.8984
    N3701 X.2542 Y-1.9048 Z-2.3413
    N3702 X.2606 Y-1.9098 Z-2.3414
    N3703 X.2682 Y-1.9129
    N3704 X.2763 Y-1.914 Z-2.3415
    N3705 X.2989 Z-2.3418
    N3706 X.3222 Z-2.342
    N3707 X.346 Z-2.3422
    N3708 X.37 Z-2.3425
    N3709 X.995 Z-2.3486
    N3710 X1.019 Z-2.3488
    N3711 X1.0428 Z-2.3491
    N3712 X1.0661 Z-2.3493
    N3713 X1.0888 Z-2.3495
    N3714 G3 X1.12 Y-1.8827 Z-2.35 J.0313
    N3715 G1 Y-1.5371 Z-2.3534
    N3716 X1.1193 Y-1.5288 Z-2.3535
    N3717 X1.1186 Y-1.5259
    N3718 X1.114 Y-1.5157 Z-2.3536
    N3719 X1.1064 Y-1.5047 Z-2.3537
    N3720 X1.0952 Y-1.4934 Z-2.3539
    N3721 X1.08 Y-1.4821 Z-2.3541
    N3722 X1.0619 Y-1.4725 Z-2.3543
    N3723 X1.0412 Y-1.465 Z-2.3545
    N3724 X1.0185 Y-1.4602 Z-2.3547
    N3725 X.9906 Y-1.4583 Z-2.355
    N3726 X.3726 Z-2.3611
    N3727 X.3558 Y-1.459 Z-2.3612
    N3728 X.3437 Y-1.4605 Z-2.3614
    N3729 X.3185 Y-1.4667 Z-2.3616
    N3730 X.2974 Y-1.4752 Z-2.3618
    N3731 X.2791 Y-1.4861 Z-2.362
    N3732 X.2647 Y-1.4981 Z-2.3622
    N3733 X.2547 Y-1.5098 Z-2.3624
    N3734 X.2489 Y-1.5198 Z-2.3625
    N3735 X.2464 Y-1.5272 Z-2.3626
    N3736 X.245 Y-1.539 Z-2.3627
    N3737 Y-1.8827 Z-2.3661
    N3738 X.2461 Y-1.8908 Z-2.3662
    N3739 X.2492 Y-1.8984
    N3740 X.2542 Y-1.9048 Z-2.3663
    N3741 X.2606 Y-1.9098 Z-2.3664
    N3742 X.2682 Y-1.9129
    N3743 X.2763 Y-1.914 Z-2.3665
    N3744 X.2989 Z-2.3668
    N3745 X.3222 Z-2.367
    N3746 X.346 Z-2.3672
    N3747 X.37 Z-2.3675
    N3748 X.995 Z-2.3736
    N3749 X1.019 Z-2.3738
    N3750 X1.0428 Z-2.3741
    N3751 X1.0661 Z-2.3743
    N3752 X1.0888 Z-2.3745
    N3753 G3 X1.12 Y-1.8827 Z-2.375 J.0313
    N3754 G1 Y-1.5371 Z-2.3784
    N3755 X1.1193 Y-1.5288 Z-2.3785
    N3756 X1.1186 Y-1.5259
    N3757 X1.114 Y-1.5157 Z-2.3786
    N3758 X1.1064 Y-1.5047 Z-2.3787
    N3759 X1.0952 Y-1.4934 Z-2.3789
    N3760 X1.08 Y-1.4821 Z-2.3791
    N3761 X1.0619 Y-1.4725 Z-2.3793
    N3762 X1.0412 Y-1.465 Z-2.3795
    N3763 X1.0185 Y-1.4602 Z-2.3797
    N3764 X.9906 Y-1.4583 Z-2.38
    N3765 X.3726 Z-2.3861
    N3766 X.3558 Y-1.459 Z-2.3862
    N3767 X.3437 Y-1.4605 Z-2.3864
    N3768 X.3185 Y-1.4667 Z-2.3866
    N3769 X.2974 Y-1.4752 Z-2.3868
    N3770 X.2791 Y-1.4861 Z-2.387
    N3771 X.2647 Y-1.4981 Z-2.3872
    N3772 X.2547 Y-1.5098 Z-2.3874
    N3773 X.2489 Y-1.5198 Z-2.3875
    N3774 X.2464 Y-1.5272 Z-2.3876
    N3775 X.245 Y-1.539 Z-2.3877
    N3776 Y-1.8827 Z-2.3911
    N3777 X.2461 Y-1.8908 Z-2.3912
    N3778 X.2492 Y-1.8984
    N3779 X.2542 Y-1.9048 Z-2.3913
    N3780 X.2606 Y-1.9098 Z-2.3914
    N3781 X.2682 Y-1.9129
    N3782 X.2763 Y-1.914 Z-2.3915
    N3783 X.2989 Z-2.3918
    N3784 X.3222 Z-2.392
    N3785 X.346 Z-2.3922
    N3786 X.37 Z-2.3925
    N3787 X.995 Z-2.3986
    N3788 X1.019 Z-2.3988
    N3789 X1.0428 Z-2.3991
    N3790 X1.0661 Z-2.3993
    N3791 X1.0888 Z-2.3995
    N3792 G3 X1.12 Y-1.8827 Z-2.4 J.0313
    N3793 G1 Y-1.5371 Z-2.4034
    N3794 X1.1193 Y-1.5288 Z-2.4035
    N3795 X1.1186 Y-1.5259
    N3796 X1.114 Y-1.5157 Z-2.4036
    N3797 X1.1064 Y-1.5047 Z-2.4037
    N3798 X1.0952 Y-1.4934 Z-2.4039
    N3799 X1.08 Y-1.4821 Z-2.4041
    N3800 X1.0619 Y-1.4725 Z-2.4043
    N3801 X1.0412 Y-1.465 Z-2.4045
    N3802 X1.0185 Y-1.4602 Z-2.4047
    N3803 X.9906 Y-1.4583 Z-2.405
    N3804 X.3726 Z-2.4111
    N3805 X.3558 Y-1.459 Z-2.4112
    N3806 X.3437 Y-1.4605 Z-2.4114
    N3807 X.3185 Y-1.4667 Z-2.4116
    N3808 X.2974 Y-1.4752 Z-2.4118
    N3809 X.2791 Y-1.4861 Z-2.412
    N3810 X.2647 Y-1.4981 Z-2.4122
    N3811 X.2547 Y-1.5098 Z-2.4124
    N3812 X.2489 Y-1.5198 Z-2.4125
    N3813 X.2464 Y-1.5272 Z-2.4126
    N3814 X.245 Y-1.539 Z-2.4127
    N3815 Y-1.8827 Z-2.4161
    N3816 X.2461 Y-1.8908 Z-2.4162
    N3817 X.2492 Y-1.8984
    N3818 X.2542 Y-1.9048 Z-2.4163
    N3819 X.2606 Y-1.9098 Z-2.4164
    N3820 X.2682 Y-1.9129
    N3821 X.2763 Y-1.914 Z-2.4165
    N3822 X.2989 Z-2.4168
    N3823 X.3222 Z-2.417
    N3824 X.346 Z-2.4172
    N3825 X.37 Z-2.4175
    N3826 X.995 Z-2.4236
    N3827 X1.019 Z-2.4238
    N3828 X1.0428 Z-2.4241
    N3829 X1.0661 Z-2.4243
    N3830 X1.0888 Z-2.4245
    N3831 G3 X1.12 Y-1.8827 Z-2.425 J.0313
    N3832 G1 Y-1.5371 Z-2.4284
    N3833 X1.1193 Y-1.5288 Z-2.4285
    N3834 X1.1186 Y-1.5259
    N3835 X1.114 Y-1.5157 Z-2.4286
    N3836 X1.1064 Y-1.5047 Z-2.4287
    N3837 X1.0952 Y-1.4934 Z-2.4289
    N3838 X1.08 Y-1.4821 Z-2.4291
    N3839 X1.0619 Y-1.4725 Z-2.4293
    N3840 X1.0412 Y-1.465 Z-2.4295
    N3841 X1.0185 Y-1.4602 Z-2.4297
    N3842 X.9906 Y-1.4583 Z-2.43
    N3843 X.3726 Z-2.4361
    N3844 X.3558 Y-1.459 Z-2.4362
    N3845 X.3437 Y-1.4605 Z-2.4364
    N3846 X.3185 Y-1.4667 Z-2.4366
    N3847 X.2974 Y-1.4752 Z-2.4368
    N3848 X.2791 Y-1.4861 Z-2.437
    N3849 X.2647 Y-1.4981 Z-2.4372
    N3850 X.2547 Y-1.5098 Z-2.4374
    N3851 X.2489 Y-1.5198 Z-2.4375
    N3852 X.2464 Y-1.5272 Z-2.4376
    N3853 X.245 Y-1.539 Z-2.4377
    N3854 Y-1.8827 Z-2.4411
    N3855 X.2461 Y-1.8908 Z-2.4412
    N3856 X.2492 Y-1.8984
    N3857 X.2542 Y-1.9048 Z-2.4413
    N3858 X.2606 Y-1.9098 Z-2.4414
    N3859 X.2682 Y-1.9129
    N3860 X.2763 Y-1.914 Z-2.4415
    N3861 X.2989 Z-2.4418
    N3862 X.3222 Z-2.442
    N3863 X.346 Z-2.4422
    N3864 X.37 Z-2.4425
    N3865 X.995 Z-2.4486
    N3866 X1.019 Z-2.4488
    N3867 X1.0428 Z-2.4491
    N3868 X1.0661 Z-2.4493
    N3869 X1.0888 Z-2.4495
    N3870 G3 X1.12 Y-1.8827 Z-2.45 J.0313
    N3871 G1 Y-1.5371 Z-2.4534
    N3872 X1.1193 Y-1.5288 Z-2.4535
    N3873 X1.1186 Y-1.5259
    N3874 X1.114 Y-1.5157 Z-2.4536
    N3875 X1.1064 Y-1.5047 Z-2.4537
    N3876 X1.0952 Y-1.4934 Z-2.4539
    N3877 X1.08 Y-1.4821 Z-2.4541
    N3878 X1.0619 Y-1.4725 Z-2.4543
    N3879 X1.0412 Y-1.465 Z-2.4545
    N3880 X1.0185 Y-1.4602 Z-2.4547
    N3881 X.9906 Y-1.4583 Z-2.455
    N3882 X.3726 Z-2.4611
    N3883 X.3558 Y-1.459 Z-2.4612
    N3884 X.3437 Y-1.4605 Z-2.4614
    N3885 X.3185 Y-1.4667 Z-2.4616
    N3886 X.2974 Y-1.4752 Z-2.4618
    N3887 X.2791 Y-1.4861 Z-2.462
    N3888 X.2647 Y-1.4981 Z-2.4622
    N3889 X.2547 Y-1.5098 Z-2.4624
    N3890 X.2489 Y-1.5198 Z-2.4625
    N3891 X.2464 Y-1.5272 Z-2.4626
    N3892 X.245 Y-1.539 Z-2.4627
    N3893 Y-1.8827 Z-2.4661
    N3894 X.2461 Y-1.8908 Z-2.4662
    N3895 X.2492 Y-1.8984
    N3896 X.2542 Y-1.9048 Z-2.4663
    N3897 X.2606 Y-1.9098 Z-2.4664
    N3898 X.2682 Y-1.9129
    N3899 X.2763 Y-1.914 Z-2.4665
    N3900 X.2989 Z-2.4668
    N3901 X.3222 Z-2.467
    N3902 X.346 Z-2.4672
    N3903 X.37 Z-2.4675
    N3904 X.995 Z-2.4736
    N3905 X1.019 Z-2.4738
    N3906 X1.0428 Z-2.4741
    N3907 X1.0661 Z-2.4743
    N3908 X1.0888 Z-2.4745
    N3909 G3 X1.12 Y-1.8827 Z-2.475 J.0313
    N3910 G1 Y-1.5371 Z-2.4784
    N3911 X1.1193 Y-1.5288 Z-2.4785
    N3912 X1.1186 Y-1.5259
    N3913 X1.114 Y-1.5157 Z-2.4786
    N3914 X1.1064 Y-1.5047 Z-2.4787
    N3915 X1.0952 Y-1.4934 Z-2.4789
    N3916 X1.08 Y-1.4821 Z-2.4791
    N3917 X1.0619 Y-1.4725 Z-2.4793
    N3918 X1.0412 Y-1.465 Z-2.4795
    N3919 X1.0185 Y-1.4602 Z-2.4797
    N3920 X.9906 Y-1.4583 Z-2.48
    N3921 X.3726 Z-2.4861
    N3922 X.3558 Y-1.459 Z-2.4862
    N3923 X.3437 Y-1.4605 Z-2.4864
    N3924 X.3185 Y-1.4667 Z-2.4866
    N3925 X.2974 Y-1.4752 Z-2.4868
    N3926 X.2791 Y-1.4861 Z-2.487
    N3927 X.2647 Y-1.4981 Z-2.4872
    N3928 X.2547 Y-1.5098 Z-2.4874
    N3929 X.2489 Y-1.5198 Z-2.4875
    N3930 X.2464 Y-1.5272 Z-2.4876
    N3931 X.245 Y-1.539 Z-2.4877
    N3932 Y-1.8827 Z-2.4911
    N3933 X.2461 Y-1.8908 Z-2.4912
    N3934 X.2492 Y-1.8984
    N3935 X.2542 Y-1.9048 Z-2.4913
    N3936 X.2606 Y-1.9098 Z-2.4914
    N3937 X.2682 Y-1.9129
    N3938 X.2763 Y-1.914 Z-2.4915
    N3939 X.2989 Z-2.4918
    N3940 X.3222 Z-2.492
    N3941 X.346 Z-2.4922
    N3942 X.37 Z-2.4925
    N3943 X.995 Z-2.4986
    N3944 X1.019 Z-2.4988
    N3945 X1.0428 Z-2.4991
    N3946 X1.0661 Z-2.4993
    N3947 X1.0888 Z-2.4995
    N3948 G3 X1.12 Y-1.8827 Z-2.5 J.0313
    N3949 G1 Y-1.5371 Z-2.5034
    N3950 X1.1193 Y-1.5288 Z-2.5035
    N3951 X1.1186 Y-1.5259
    N3952 X1.114 Y-1.5157 Z-2.5036
    N3953 X1.1064 Y-1.5047 Z-2.5037
    N3954 X1.0952 Y-1.4934 Z-2.5039
    N3955 X1.08 Y-1.4821 Z-2.5041
    N3956 X1.0619 Y-1.4725 Z-2.5043
    N3957 X1.0412 Y-1.465 Z-2.5045
    N3958 X1.0185 Y-1.4602 Z-2.5047
    N3959 X.9906 Y-1.4583 Z-2.505
    N3960 X.3726 Z-2.5111
    N3961 X.3558 Y-1.459 Z-2.5112
    N3962 X.3437 Y-1.4605 Z-2.5114
    N3963 X.3185 Y-1.4667 Z-2.5116
    N3964 X.2974 Y-1.4752 Z-2.5118
    N3965 X.2791 Y-1.4861 Z-2.512
    N3966 X.2647 Y-1.4981 Z-2.5122
    N3967 X.2547 Y-1.5098 Z-2.5124
    N3968 X.2489 Y-1.5198 Z-2.5125
    N3969 X.2464 Y-1.5272 Z-2.5126
    N3970 X.245 Y-1.539 Z-2.5127
    N3971 Y-1.8827 Z-2.5161
    N3972 X.2461 Y-1.8908 Z-2.5162
    N3973 X.2492 Y-1.8984
    N3974 X.2542 Y-1.9048 Z-2.5163
    N3975 X.2606 Y-1.9098 Z-2.5164
    N3976 X.2682 Y-1.9129
    N3977 X.2763 Y-1.914 Z-2.5165
    N3978 X.2989 Z-2.5168
    N3979 X.3222 Z-2.517
    N3980 X.346 Z-2.5172
    N3981 X.37 Z-2.5175
    N3982 X.995 Z-2.5236
    N3983 X1.019 Z-2.5238
    N3984 X1.0428 Z-2.5241
    N3985 X1.0661 Z-2.5243
    N3986 X1.0888 Z-2.5245
    N3987 G3 X1.12 Y-1.8827 Z-2.525 J.0313
    N3988 G1 Y-1.5371 Z-2.5284
    N3989 X1.1193 Y-1.5288 Z-2.5285
    N3990 X1.1186 Y-1.5259
    N3991 X1.114 Y-1.5157 Z-2.5286
    N3992 X1.1064 Y-1.5047 Z-2.5287
    N3993 X1.0952 Y-1.4934 Z-2.5289
    N3994 X1.08 Y-1.4821 Z-2.5291
    N3995 X1.0619 Y-1.4725 Z-2.5293
    N3996 X1.0412 Y-1.465 Z-2.5295
    N3997 X1.0185 Y-1.4602 Z-2.5297
    N3998 X.9906 Y-1.4583 Z-2.53
    N3999 X.3726 Z-2.5361
    N4000 X.3558 Y-1.459 Z-2.5362
    N4001 X.3437 Y-1.4605 Z-2.5364
    N4002 X.3185 Y-1.4667 Z-2.5366
    N4003 X.2974 Y-1.4752 Z-2.5368
    N4004 X.2791 Y-1.4861 Z-2.537
    N4005 X.2647 Y-1.4981 Z-2.5372
    N4006 X.2547 Y-1.5098 Z-2.5374
    N4007 X.2489 Y-1.5198 Z-2.5375
    N4008 X.2464 Y-1.5272 Z-2.5376
    N4009 X.245 Y-1.539 Z-2.5377
    N4010 Y-1.8827 Z-2.5411
    N4011 X.2461 Y-1.8908 Z-2.5412
    N4012 X.2492 Y-1.8984
    N4013 X.2542 Y-1.9048 Z-2.5413
    N4014 X.2606 Y-1.9098 Z-2.5414
    N4015 X.2682 Y-1.9129
    N4016 X.2763 Y-1.914 Z-2.5415
    N4017 X.2989 Z-2.5418
    N4018 X.3222 Z-2.542
    N4019 X.346 Z-2.5422
    N4020 X.37 Z-2.5425
    N4021 X.995 Z-2.5486
    N4022 X1.019 Z-2.5488
    N4023 X1.0428 Z-2.5491
    N4024 X1.0661 Z-2.5493
    N4025 X1.0888 Z-2.5495
    N4026 G3 X1.12 Y-1.8827 Z-2.55 J.0313
    N4027 G1 Y-1.5371 Z-2.5534
    N4028 X1.1193 Y-1.5288 Z-2.5535
    N4029 X1.1186 Y-1.5259
    N4030 X1.114 Y-1.5157 Z-2.5536
    N4031 X1.1064 Y-1.5047 Z-2.5537
    N4032 X1.0952 Y-1.4934 Z-2.5539
    N4033 X1.08 Y-1.4821 Z-2.5541
    N4034 X1.0619 Y-1.4725 Z-2.5543
    N4035 X1.0412 Y-1.465 Z-2.5545
    N4036 X1.0185 Y-1.4602 Z-2.5547
    N4037 X.9906 Y-1.4583 Z-2.555
    N4038 X.3726 Z-2.5611
    N4039 X.3558 Y-1.459 Z-2.5612
    N4040 X.3437 Y-1.4605 Z-2.5614
    N4041 X.3185 Y-1.4667 Z-2.5616
    N4042 X.2974 Y-1.4752 Z-2.5618
    N4043 X.2791 Y-1.4861 Z-2.562
    N4044 X.2647 Y-1.4981 Z-2.5622
    N4045 X.2547 Y-1.5098 Z-2.5624
    N4046 X.2489 Y-1.5198 Z-2.5625
    N4047 X.2464 Y-1.5272 Z-2.5626
    N4048 X.245 Y-1.539 Z-2.5627
    N4049 Y-1.8827 Z-2.5661
    N4050 X.2461 Y-1.8908 Z-2.5662
    N4051 X.2492 Y-1.8984
    N4052 X.2542 Y-1.9048 Z-2.5663
    N4053 X.2606 Y-1.9098 Z-2.5664
    N4054 X.2682 Y-1.9129
    N4055 X.2763 Y-1.914 Z-2.5665
    N4056 X.2989 Z-2.5668
    N4057 X.3222 Z-2.567
    N4058 X.346 Z-2.5672
    N4059 X.37 Z-2.5675
    N4060 X.995 Z-2.5736
    N4061 X1.019 Z-2.5738
    N4062 X1.0428 Z-2.5741
    N4063 X1.0661 Z-2.5743
    N4064 X1.0888 Z-2.5745
    N4065 G3 X1.12 Y-1.8827 Z-2.575 J.0313
    N4066 G1 Y-1.5371 Z-2.5784
    N4067 X1.1193 Y-1.5288 Z-2.5785
    N4068 X1.1186 Y-1.5259
    N4069 X1.114 Y-1.5157 Z-2.5786
    N4070 X1.1064 Y-1.5047 Z-2.5787
    N4071 X1.0952 Y-1.4934 Z-2.5789
    N4072 X1.08 Y-1.4821 Z-2.5791
    N4073 X1.0619 Y-1.4725 Z-2.5793
    N4074 X1.0412 Y-1.465 Z-2.5795
    N4075 X1.0185 Y-1.4602 Z-2.5797
    N4076 X.9906 Y-1.4583 Z-2.58
    N4077 X.3726 Z-2.5861
    N4078 X.3558 Y-1.459 Z-2.5862
    N4079 X.3437 Y-1.4605 Z-2.5864
    N4080 X.3185 Y-1.4667 Z-2.5866
    N4081 X.2974 Y-1.4752 Z-2.5868
    N4082 X.2791 Y-1.4861 Z-2.587
    N4083 X.2647 Y-1.4981 Z-2.5872
    N4084 X.2547 Y-1.5098 Z-2.5874
    N4085 X.2489 Y-1.5198 Z-2.5875
    N4086 X.2464 Y-1.5272 Z-2.5876
    N4087 X.245 Y-1.539 Z-2.5877
    N4088 Y-1.8827 Z-2.5911
    N4089 X.2461 Y-1.8908 Z-2.5912
    N4090 X.2492 Y-1.8984
    N4091 X.2542 Y-1.9048 Z-2.5913
    N4092 X.2606 Y-1.9098 Z-2.5914
    N4093 X.2682 Y-1.9129
    N4094 X.2763 Y-1.914 Z-2.5915
    N4095 X.2989 Z-2.5918
    N4096 X.3222 Z-2.592
    N4097 X.346 Z-2.5922
    N4098 X.37 Z-2.5925
    N4099 X.995 Z-2.5986
    N4100 X1.019 Z-2.5988
    N4101 X1.0428 Z-2.5991
    N4102 X1.0661 Z-2.5993
    N4103 X1.0888 Z-2.5995
    N4104 G3 X1.12 Y-1.8827 Z-2.6 J.0313
    N4105 G1 Y-1.5371 Z-2.6034
    N4106 X1.1193 Y-1.5288 Z-2.6035
    N4107 X1.1186 Y-1.5259
    N4108 X1.114 Y-1.5157 Z-2.6036
    N4109 X1.1064 Y-1.5047 Z-2.6037
    N4110 X1.0952 Y-1.4934 Z-2.6039
    N4111 X1.08 Y-1.4821 Z-2.6041
    N4112 X1.0619 Y-1.4725 Z-2.6043
    N4113 X1.0412 Y-1.465 Z-2.6045
    N4114 X1.0185 Y-1.4602 Z-2.6047
    N4115 X.9906 Y-1.4583 Z-2.605
    N4116 X.3726 Z-2.6111
    N4117 X.3558 Y-1.459 Z-2.6112
    N4118 X.3437 Y-1.4605 Z-2.6114
    N4119 X.3185 Y-1.4667 Z-2.6116
    N4120 X.2974 Y-1.4752 Z-2.6118
    N4121 X.2791 Y-1.4861 Z-2.612
    N4122 X.2647 Y-1.4981 Z-2.6122
    N4123 X.2547 Y-1.5098 Z-2.6124
    N4124 X.2489 Y-1.5198 Z-2.6125
    N4125 X.2464 Y-1.5272 Z-2.6126
    N4126 X.245 Y-1.539 Z-2.6127
    N4127 Y-1.8827 Z-2.6161
    N4128 X.2461 Y-1.8908 Z-2.6162
    N4129 X.2492 Y-1.8984
    N4130 X.2542 Y-1.9048 Z-2.6163
    N4131 X.2606 Y-1.9098 Z-2.6164
    N4132 X.2682 Y-1.9129
    N4133 X.2763 Y-1.914 Z-2.6165
    N4134 X.2989 Z-2.6168
    N4135 X.3222 Z-2.617
    N4136 X.346 Z-2.6172
    N4137 X.37 Z-2.6175
    N4138 X.995 Z-2.6236
    N4139 X1.019 Z-2.6238
    N4140 X1.0428 Z-2.6241
    N4141 X1.0661 Z-2.6243
    N4142 X1.0888 Z-2.6245
    N4143 G3 X1.12 Y-1.8827 Z-2.625 J.0313
    N4144 G1 Y-1.5371 Z-2.6284
    N4145 X1.1193 Y-1.5288 Z-2.6285
    N4146 X1.1186 Y-1.5259
    N4147 X1.114 Y-1.5157 Z-2.6286
    N4148 X1.1064 Y-1.5047 Z-2.6287
    N4149 X1.0952 Y-1.4934 Z-2.6289
    N4150 X1.08 Y-1.4821 Z-2.6291
    N4151 X1.0619 Y-1.4725 Z-2.6293
    N4152 X1.0412 Y-1.465 Z-2.6295
    N4153 X1.0185 Y-1.4602 Z-2.6297
    N4154 X.9906 Y-1.4583 Z-2.63
    N4155 X.3726 Z-2.6361
    N4156 X.3558 Y-1.459 Z-2.6362
    N4157 X.3437 Y-1.4605 Z-2.6364
    N4158 X.3185 Y-1.4667 Z-2.6366
    N4159 X.2974 Y-1.4752 Z-2.6368
    N4160 X.2791 Y-1.4861 Z-2.637
    N4161 X.2647 Y-1.4981 Z-2.6372
    N4162 X.2547 Y-1.5098 Z-2.6374
    N4163 X.2489 Y-1.5198 Z-2.6375
    N4164 X.2464 Y-1.5272 Z-2.6376
    N4165 X.245 Y-1.539 Z-2.6377
    N4166 Y-1.8827 Z-2.6411
    N4167 X.2461 Y-1.8908 Z-2.6412
    N4168 X.2492 Y-1.8984
    N4169 X.2542 Y-1.9048 Z-2.6413
    N4170 X.2606 Y-1.9098 Z-2.6414
    N4171 X.2682 Y-1.9129
    N4172 X.2763 Y-1.914 Z-2.6415
    N4173 X.2989 Z-2.6418
    N4174 X.3222 Z-2.642
    N4175 X.346 Z-2.6422
    N4176 X.37 Z-2.6425
    N4177 X.995 Z-2.6486
    N4178 X1.019 Z-2.6488
    N4179 X1.0428 Z-2.6491
    N4180 X1.0661 Z-2.6493
    N4181 X1.0888 Z-2.6495
    N4182 G3 X1.12 Y-1.8827 Z-2.65 J.0313
    N4183 G1 Y-1.5371 Z-2.6534
    N4184 X1.1193 Y-1.5288 Z-2.6535
    N4185 X1.1186 Y-1.5259
    N4186 X1.114 Y-1.5157 Z-2.6536
    N4187 X1.1064 Y-1.5047 Z-2.6537
    N4188 X1.0952 Y-1.4934 Z-2.6539
    N4189 X1.08 Y-1.4821 Z-2.6541
    N4190 X1.0619 Y-1.4725 Z-2.6543
    N4191 X1.0412 Y-1.465 Z-2.6545
    N4192 X1.0185 Y-1.4602 Z-2.6547
    N4193 X.9906 Y-1.4583 Z-2.655
    N4194 X.3726 Z-2.6611
    N4195 X.3558 Y-1.459 Z-2.6612
    N4196 X.3437 Y-1.4605 Z-2.6614
    N4197 X.3185 Y-1.4667 Z-2.6616
    N4198 X.2974 Y-1.4752 Z-2.6618
    N4199 X.2791 Y-1.4861 Z-2.662
    N4200 X.2647 Y-1.4981 Z-2.6622
    N4201 X.2547 Y-1.5098 Z-2.6624
    N4202 X.2489 Y-1.5198 Z-2.6625
    N4203 X.2464 Y-1.5272 Z-2.6626
    N4204 X.245 Y-1.539 Z-2.6627
    N4205 Y-1.8827 Z-2.6661
    N4206 X.2461 Y-1.8908 Z-2.6662
    N4207 X.2492 Y-1.8984
    N4208 X.2542 Y-1.9048 Z-2.6663
    N4209 X.2606 Y-1.9098 Z-2.6664
    N4210 X.2682 Y-1.9129
    N4211 X.2763 Y-1.914 Z-2.6665
    N4212 X.2989 Z-2.6668
    N4213 X.3222 Z-2.667
    N4214 X.346 Z-2.6672
    N4215 X.37 Z-2.6675
    N4216 X.995 Z-2.6736
    N4217 X1.019 Z-2.6738
    N4218 X1.0428 Z-2.6741
    N4219 X1.0661 Z-2.6743
    N4220 X1.0888 Z-2.6745
    N4221 G3 X1.12 Y-1.8827 Z-2.675 J.0313
    N4222 G1 Y-1.5371 Z-2.6784
    N4223 X1.1193 Y-1.5288 Z-2.6785
    N4224 X1.1186 Y-1.5259
    N4225 X1.114 Y-1.5157 Z-2.6786
    N4226 X1.1064 Y-1.5047 Z-2.6787
    N4227 X1.0952 Y-1.4934 Z-2.6789
    N4228 X1.08 Y-1.4821 Z-2.6791
    N4229 X1.0619 Y-1.4725 Z-2.6793
    N4230 X1.0412 Y-1.465 Z-2.6795
    N4231 X1.0185 Y-1.4602 Z-2.6797
    N4232 X.9906 Y-1.4583 Z-2.68
    N4233 X.3726 Z-2.6861
    N4234 X.3558 Y-1.459 Z-2.6862
    N4235 X.3437 Y-1.4605 Z-2.6864
    N4236 X.3185 Y-1.4667 Z-2.6866
    N4237 X.2974 Y-1.4752 Z-2.6868
    N4238 X.2791 Y-1.4861 Z-2.687
    N4239 X.2647 Y-1.4981 Z-2.6872
    N4240 X.2547 Y-1.5098 Z-2.6874
    N4241 X.2489 Y-1.5198 Z-2.6875
    N4242 X.2464 Y-1.5272 Z-2.6876
    N4243 X.245 Y-1.539 Z-2.6877
    N4244 Y-1.8827 Z-2.6911
    N4245 X.2461 Y-1.8908 Z-2.6912
    N4246 X.2492 Y-1.8984
    N4247 X.2542 Y-1.9048 Z-2.6913
    N4248 X.2606 Y-1.9098 Z-2.6914
    N4249 X.2682 Y-1.9129
    N4250 X.2763 Y-1.914 Z-2.6915
    N4251 X.2989 Z-2.6918
    N4252 X.3222 Z-2.692
    N4253 X.346 Z-2.6922
    N4254 X.37 Z-2.6925
    N4255 X.995 Z-2.6986
    N4256 X1.019 Z-2.6988
    N4257 X1.0428 Z-2.6991
    N4258 X1.0661 Z-2.6993
    N4259 X1.0888 Z-2.6995
    N4260 G3 X1.12 Y-1.8827 Z-2.7 J.0313
    N4261 G1 Y-1.5371 Z-2.7034
    N4262 X1.1193 Y-1.5288 Z-2.7035
    N4263 X1.1186 Y-1.5259
    N4264 X1.114 Y-1.5157 Z-2.7036
    N4265 X1.1064 Y-1.5047 Z-2.7037
    N4266 X1.0952 Y-1.4934 Z-2.7039
    N4267 X1.08 Y-1.4821 Z-2.7041
    N4268 X1.0619 Y-1.4725 Z-2.7043
    N4269 X1.0412 Y-1.465 Z-2.7045
    N4270 X1.0185 Y-1.4602 Z-2.7047
    N4271 X.9906 Y-1.4583 Z-2.705
    N4272 X.3726 Z-2.7111
    N4273 X.3558 Y-1.459 Z-2.7112
    N4274 X.3437 Y-1.4605 Z-2.7114
    N4275 X.3185 Y-1.4667 Z-2.7116
    N4276 X.2974 Y-1.4752 Z-2.7118
    N4277 X.2791 Y-1.4861 Z-2.712
    N4278 X.2647 Y-1.4981 Z-2.7122
    N4279 X.2547 Y-1.5098 Z-2.7124
    N4280 X.2489 Y-1.5198 Z-2.7125
    N4281 X.2464 Y-1.5272 Z-2.7126
    N4282 X.245 Y-1.539 Z-2.7127
    N4283 Y-1.8827 Z-2.7161
    N4284 X.2461 Y-1.8908 Z-2.7162
    N4285 X.2492 Y-1.8984
    N4286 X.2542 Y-1.9048 Z-2.7163
    N4287 X.2606 Y-1.9098 Z-2.7164
    N4288 X.2682 Y-1.9129
    N4289 X.2763 Y-1.914 Z-2.7165
    N4290 X.2989 Z-2.7168
    N4291 X.3222 Z-2.717
    N4292 X.346 Z-2.7172
    N4293 X.37 Z-2.7175
    N4294 X.995 Z-2.7236
    N4295 X1.019 Z-2.7238
    N4296 X1.0428 Z-2.7241
    N4297 X1.0661 Z-2.7243
    N4298 X1.0888 Z-2.7245
    N4299 G3 X1.12 Y-1.8827 Z-2.725 J.0313
    N4300 G1 Y-1.5371 Z-2.7284
    N4301 X1.1193 Y-1.5288 Z-2.7285
    N4302 X1.1186 Y-1.5259
    N4303 X1.114 Y-1.5157 Z-2.7286
    N4304 X1.1064 Y-1.5047 Z-2.7287
    N4305 X1.0952 Y-1.4934 Z-2.7289
    N4306 X1.08 Y-1.4821 Z-2.7291
    N4307 X1.0619 Y-1.4725 Z-2.7293
    N4308 X1.0412 Y-1.465 Z-2.7295
    N4309 X1.0185 Y-1.4602 Z-2.7297
    N4310 X.9906 Y-1.4583 Z-2.73
    N4311 X.3726 Z-2.7361
    N4312 X.3558 Y-1.459 Z-2.7362
    N4313 X.3437 Y-1.4605 Z-2.7364
    N4314 X.3185 Y-1.4667 Z-2.7366
    N4315 X.2974 Y-1.4752 Z-2.7368
    N4316 X.2791 Y-1.4861 Z-2.737
    N4317 X.2647 Y-1.4981 Z-2.7372
    N4318 X.2547 Y-1.5098 Z-2.7374
    N4319 X.2489 Y-1.5198 Z-2.7375
    N4320 X.2464 Y-1.5272 Z-2.7376
    N4321 X.245 Y-1.539 Z-2.7377
    N4322 Y-1.8827 Z-2.7411
    N4323 X.2461 Y-1.8908 Z-2.7412
    N4324 X.2492 Y-1.8984
    N4325 X.2542 Y-1.9048 Z-2.7413
    N4326 X.2606 Y-1.9098 Z-2.7414
    N4327 X.2682 Y-1.9129
    N4328 X.2763 Y-1.914 Z-2.7415
    N4329 X.2989 Z-2.7418
    N4330 X.3222 Z-2.742
    N4331 X.346 Z-2.7422
    N4332 X.37 Z-2.7425
    N4333 X.995 Z-2.7486
    N4334 X1.019 Z-2.7488
    N4335 X1.0428 Z-2.7491
    N4336 X1.0661 Z-2.7493
    N4337 X1.0888 Z-2.7495
    N4338 G3 X1.12 Y-1.8827 Z-2.75 J.0313
    N4339 G1 Y-1.5371 Z-2.7534
    N4340 X1.1193 Y-1.5288 Z-2.7535
    N4341 X1.1186 Y-1.5259
    N4342 X1.114 Y-1.5157 Z-2.7536
    N4343 X1.1064 Y-1.5047 Z-2.7537
    N4344 X1.0952 Y-1.4934 Z-2.7539
    N4345 X1.08 Y-1.4821 Z-2.7541
    N4346 X1.0619 Y-1.4725 Z-2.7543
    N4347 X1.0412 Y-1.465 Z-2.7545
    N4348 X1.0185 Y-1.4602 Z-2.7547
    N4349 X.9906 Y-1.4583 Z-2.755
    N4350 X.869 Z-2.7562
    N4351 X.3726
    N4352 X.3558 Y-1.459
    N4353 X.3437 Y-1.4605
    N4354 X.3185 Y-1.4667
    N4355 X.2974 Y-1.4752
    N4356 X.2791 Y-1.4861
    N4357 X.2647 Y-1.4981
    N4358 X.2547 Y-1.5098
    N4359 X.2489 Y-1.5198
    N4360 X.2464 Y-1.5272
    N4361 X.245 Y-1.539
    N4362 Y-1.8827
    N4363 G3 X.2763 Y-1.914 I.0313
    N4364 G1 X.2989
    N4365 X.3222
    N4366 X.346
    N4367 X.37
    N4368 X.995
    N4369 X1.019
    N4370 X1.0428
    N4371 X1.0661
    N4372 X1.0888
    N4373 G3 X1.12 Y-1.8827 J.0313
    N4374 G1 Y-1.5371
    N4375 X1.1193 Y-1.5288
    N4376 X1.1186 Y-1.5259
    N4377 X1.114 Y-1.5157
    N4378 X1.1064 Y-1.5047
    N4379 X1.0952 Y-1.4934
    N4380 X1.08 Y-1.4821
    N4381 X1.0619 Y-1.4725
    N4382 X1.0412 Y-1.465
    N4383 X1.0185 Y-1.4602
    N4384 X.9906 Y-1.4583
    N4385 X.869
    N4386 G0 Z2.5
    N4387 G0 G90 G54 X1.12 Y1.5371 S9000 M3
    N4388 M33
    N4389 G0 G90 A-82.5
    N4390 M32
    N4391 Z.25
    N4392 Z.1
    N4393 G1 Z0. F500.
    N4394 Y1.8828 Z-.5534 F250.
    N4395 G3 X1.0887 Y1.914 Z-.5539 I-.0313
    N4396 G1 X1.0661 Z-.5541
    N4397 X1.0428 Z-.5543
    N4398 X1.019 Z-.5546
    N4399 X.995 Z-.5548
    N4400 X.37 Z-.5609
    N4401 X.346 Z-.5612
    N4402 X.3222 Z-.5614
    N4403 X.2989 Z-.5616
    N4404 X.2762 Z-.5619
    N4405 X.2681 Y1.9129 Z-.562
    N4406 X.2606 Y1.9098
    N4407 X.2541 Y1.9049 Z-.5621
    N4408 X.2492 Y1.8984 Z-.5622
    N4409 X.2461 Y1.8909
    N4410 X.245 Y1.8828 Z-.5623
    N4411 Y1.539 Z-.5657
    N4412 X.2464 Y1.5272 Z-.5658
    N4413 X.2489 Y1.5198 Z-.5659
    N4414 X.2547 Y1.5098 Z-.566
    N4415 X.2647 Y1.4981 Z-.5662
    N4416 X.2791 Y1.4861 Z-.5663
    N4417 X.2974 Y1.4752 Z-.5666
    N4418 X.3185 Y1.4667 Z-.5668
    N4419 X.3437 Y1.4605 Z-.567
    N4420 X.3558 Y1.459 Z-.5672
    N4421 X.3726 Y1.4583 Z-.5673
    N4422 X.9906 Z-.5734
    N4423 X1.0185 Y1.4602 Z-.5737
    N4424 X1.0412 Y1.465 Z-.5739
    N4425 X1.0619 Y1.4725 Z-.5741
    N4426 X1.08 Y1.4821 Z-.5743
    N4427 X1.0952 Y1.4934 Z-.5745
    N4428 X1.1064 Y1.5047 Z-.5746
    N4429 X1.114 Y1.5157 Z-.5748
    N4430 X1.1186 Y1.5259 Z-.5749
    N4431 X1.1193 Y1.5288
    N4432 X1.12 Y1.5371 Z-.575
    N4433 Y1.8828 Z-.5784
    N4434 G3 X1.0887 Y1.914 Z-.5789 I-.0313
    N4435 G1 X1.0661 Z-.5791
    N4436 X1.0428 Z-.5793
    N4437 X1.019 Z-.5796
    N4438 X.995 Z-.5798
    N4439 X.37 Z-.5859
    N4440 X.346 Z-.5862
    N4441 X.3222 Z-.5864
    N4442 X.2989 Z-.5866
    N4443 X.2762 Z-.5869
    N4444 X.2681 Y1.9129 Z-.587
    N4445 X.2606 Y1.9098
    N4446 X.2541 Y1.9049 Z-.5871
    N4447 X.2492 Y1.8984 Z-.5872
    N4448 X.2461 Y1.8909
    N4449 X.245 Y1.8828 Z-.5873
    N4450 Y1.539 Z-.5907
    N4451 X.2464 Y1.5272 Z-.5908
    N4452 X.2489 Y1.5198 Z-.5909
    N4453 X.2547 Y1.5098 Z-.591
    N4454 X.2647 Y1.4981 Z-.5912
    N4455 X.2791 Y1.4861 Z-.5913
    N4456 X.2974 Y1.4752 Z-.5916
    N4457 X.3185 Y1.4667 Z-.5918
    N4458 X.3437 Y1.4605 Z-.592
    N4459 X.3558 Y1.459 Z-.5922
    N4460 X.3726 Y1.4583 Z-.5923
    N4461 X.9906 Z-.5984
    N4462 X1.0185 Y1.4602 Z-.5987
    N4463 X1.0412 Y1.465 Z-.5989
    N4464 X1.0619 Y1.4725 Z-.5991
    N4465 X1.08 Y1.4821 Z-.5993
    N4466 X1.0952 Y1.4934 Z-.5995
    N4467 X1.1064 Y1.5047 Z-.5996
    N4468 X1.114 Y1.5157 Z-.5998
    N4469 X1.1186 Y1.5259 Z-.5999
    N4470 X1.1193 Y1.5288
    N4471 X1.12 Y1.5371 Z-.6
    N4472 Y1.8828 Z-.6034
    N4473 G3 X1.0887 Y1.914 Z-.6039 I-.0313
    N4474 G1 X1.0661 Z-.6041
    N4475 X1.0428 Z-.6043
    N4476 X1.019 Z-.6046
    N4477 X.995 Z-.6048
    N4478 X.37 Z-.6109
    N4479 X.346 Z-.6112
    N4480 X.3222 Z-.6114
    N4481 X.2989 Z-.6116
    N4482 X.2762 Z-.6119
    N4483 X.2681 Y1.9129 Z-.612
    N4484 X.2606 Y1.9098
    N4485 X.2541 Y1.9049 Z-.6121
    N4486 X.2492 Y1.8984 Z-.6122
    N4487 X.2461 Y1.8909
    N4488 X.245 Y1.8828 Z-.6123
    N4489 Y1.539 Z-.6157
    N4490 X.2464 Y1.5272 Z-.6158
    N4491 X.2489 Y1.5198 Z-.6159
    N4492 X.2547 Y1.5098 Z-.616
    N4493 X.2647 Y1.4981 Z-.6162
    N4494 X.2791 Y1.4861 Z-.6163
    N4495 X.2974 Y1.4752 Z-.6166
    N4496 X.3185 Y1.4667 Z-.6168
    N4497 X.3437 Y1.4605 Z-.617
    N4498 X.3558 Y1.459 Z-.6172
    N4499 X.3726 Y1.4583 Z-.6173
    N4500 X.9906 Z-.6234
    N4501 X1.0185 Y1.4602 Z-.6237
    N4502 X1.0412 Y1.465 Z-.6239
    N4503 X1.0619 Y1.4725 Z-.6241
    N4504 X1.08 Y1.4821 Z-.6243
    N4505 X1.0952 Y1.4934 Z-.6245
    N4506 X1.1064 Y1.5047 Z-.6246
    N4507 X1.114 Y1.5157 Z-.6248
    N4508 X1.1186 Y1.5259 Z-.6249
    N4509 X1.1193 Y1.5288
    N4510 X1.12 Y1.5371 Z-.625
    N4511 Y1.8828 Z-.6284
    N4512 G3 X1.0887 Y1.914 Z-.6289 I-.0313
    N4513 G1 X1.0661 Z-.6291
    N4514 X1.0428 Z-.6293
    N4515 X1.019 Z-.6296
    N4516 X.995 Z-.6298
    N4517 X.37 Z-.6359
    N4518 X.346 Z-.6362
    N4519 X.3222 Z-.6364
    N4520 X.2989 Z-.6366
    N4521 X.2762 Z-.6369
    N4522 X.2681 Y1.9129 Z-.637
    N4523 X.2606 Y1.9098
    N4524 X.2541 Y1.9049 Z-.6371
    N4525 X.2492 Y1.8984 Z-.6372
    N4526 X.2461 Y1.8909
    N4527 X.245 Y1.8828 Z-.6373
    N4528 Y1.539 Z-.6407
    N4529 X.2464 Y1.5272 Z-.6408
    N4530 X.2489 Y1.5198 Z-.6409
    N4531 X.2547 Y1.5098 Z-.641
    N4532 X.2647 Y1.4981 Z-.6412
    N4533 X.2791 Y1.4861 Z-.6413
    N4534 X.2974 Y1.4752 Z-.6416
    N4535 X.3185 Y1.4667 Z-.6418
    N4536 X.3437 Y1.4605 Z-.642
    N4537 X.3558 Y1.459 Z-.6422
    N4538 X.3726 Y1.4583 Z-.6423
    N4539 X.9906 Z-.6484
    N4540 X1.0185 Y1.4602 Z-.6487
    N4541 X1.0412 Y1.465 Z-.6489
    N4542 X1.0619 Y1.4725 Z-.6491
    N4543 X1.08 Y1.4821 Z-.6493
    N4544 X1.0952 Y1.4934 Z-.6495
    N4545 X1.1064 Y1.5047 Z-.6496
    N4546 X1.114 Y1.5157 Z-.6498
    N4547 X1.1186 Y1.5259 Z-.6499
    N4548 X1.1193 Y1.5288
    N4549 X1.12 Y1.5371 Z-.65
    N4550 Y1.8828 Z-.6534
    N4551 G3 X1.0887 Y1.914 Z-.6539 I-.0313
    N4552 G1 X1.0661 Z-.6541
    N4553 X1.0428 Z-.6543
    N4554 X1.019 Z-.6546
    N4555 X.995 Z-.6548
    N4556 X.37 Z-.6609
    N4557 X.346 Z-.6612
    N4558 X.3222 Z-.6614
    N4559 X.2989 Z-.6616
    N4560 X.2762 Z-.6619
    N4561 X.2681 Y1.9129 Z-.662
    N4562 X.2606 Y1.9098
    N4563 X.2541 Y1.9049 Z-.6621
    N4564 X.2492 Y1.8984 Z-.6622
    N4565 X.2461 Y1.8909
    N4566 X.245 Y1.8828 Z-.6623
    N4567 Y1.539 Z-.6657
    N4568 X.2464 Y1.5272 Z-.6658
    N4569 X.2489 Y1.5198 Z-.6659
    N4570 X.2547 Y1.5098 Z-.666
    N4571 X.2647 Y1.4981 Z-.6662
    N4572 X.2791 Y1.4861 Z-.6663
    N4573 X.2974 Y1.4752 Z-.6666
    N4574 X.3185 Y1.4667 Z-.6668
    N4575 X.3437 Y1.4605 Z-.667
    N4576 X.3558 Y1.459 Z-.6672
    N4577 X.3726 Y1.4583 Z-.6673
    N4578 X.9906 Z-.6734
    N4579 X1.0185 Y1.4602 Z-.6737
    N4580 X1.0412 Y1.465 Z-.6739
    N4581 X1.0619 Y1.4725 Z-.6741
    N4582 X1.08 Y1.4821 Z-.6743
    N4583 X1.0952 Y1.4934 Z-.6745
    N4584 X1.1064 Y1.5047 Z-.6746
    N4585 X1.114 Y1.5157 Z-.6748
    N4586 X1.1186 Y1.5259 Z-.6749
    N4587 X1.1193 Y1.5288
    N4588 X1.12 Y1.5371 Z-.675
    N4589 Y1.8828 Z-.6784
    N4590 G3 X1.0887 Y1.914 Z-.6789 I-.0313
    N4591 G1 X1.0661 Z-.6791
    N4592 X1.0428 Z-.6793
    N4593 X1.019 Z-.6796
    N4594 X.995 Z-.6798
    N4595 X.37 Z-.6859
    N4596 X.346 Z-.6862
    N4597 X.3222 Z-.6864
    N4598 X.2989 Z-.6866
    N4599 X.2762 Z-.6869
    N4600 X.2681 Y1.9129 Z-.687
    N4601 X.2606 Y1.9098
    N4602 X.2541 Y1.9049 Z-.6871
    N4603 X.2492 Y1.8984 Z-.6872
    N4604 X.2461 Y1.8909
    N4605 X.245 Y1.8828 Z-.6873
    N4606 Y1.539 Z-.6907
    N4607 X.2464 Y1.5272 Z-.6908
    N4608 X.2489 Y1.5198 Z-.6909
    N4609 X.2547 Y1.5098 Z-.691
    N4610 X.2647 Y1.4981 Z-.6912
    N4611 X.2791 Y1.4861 Z-.6913
    N4612 X.2974 Y1.4752 Z-.6916
    N4613 X.3185 Y1.4667 Z-.6918
    N4614 X.3437 Y1.4605 Z-.692
    N4615 X.3558 Y1.459 Z-.6922
    N4616 X.3726 Y1.4583 Z-.6923
    N4617 X.9906 Z-.6984
    N4618 X1.0185 Y1.4602 Z-.6987
    N4619 X1.0412 Y1.465 Z-.6989
    N4620 X1.0619 Y1.4725 Z-.6991
    N4621 X1.08 Y1.4821 Z-.6993
    N4622 X1.0952 Y1.4934 Z-.6995
    N4623 X1.1064 Y1.5047 Z-.6996
    N4624 X1.114 Y1.5157 Z-.6998
    N4625 X1.1186 Y1.5259 Z-.6999
    N4626 X1.1193 Y1.5288
    N4627 X1.12 Y1.5371 Z-.7
    N4628 Y1.8828 Z-.7034
    N4629 G3 X1.0887 Y1.914 Z-.7039 I-.0313
    N4630 G1 X1.0661 Z-.7041
    N4631 X1.0428 Z-.7043
    N4632 X1.019 Z-.7046
    N4633 X.995 Z-.7048
    N4634 X.37 Z-.7109
    N4635 X.346 Z-.7112
    N4636 X.3222 Z-.7114
    N4637 X.2989 Z-.7116
    N4638 X.2762 Z-.7119
    N4639 X.2681 Y1.9129 Z-.712
    N4640 X.2606 Y1.9098
    N4641 X.2541 Y1.9049 Z-.7121
    N4642 X.2492 Y1.8984 Z-.7122
    N4643 X.2461 Y1.8909
    N4644 X.245 Y1.8828 Z-.7123
    N4645 Y1.539 Z-.7157
    N4646 X.2464 Y1.5272 Z-.7158
    N4647 X.2489 Y1.5198 Z-.7159
    N4648 X.2547 Y1.5098 Z-.716
    N4649 X.2647 Y1.4981 Z-.7162
    N4650 X.2791 Y1.4861 Z-.7163
    N4651 X.2974 Y1.4752 Z-.7166
    N4652 X.3185 Y1.4667 Z-.7168
    N4653 X.3437 Y1.4605 Z-.717
    N4654 X.3558 Y1.459 Z-.7172
    N4655 X.3726 Y1.4583 Z-.7173
    N4656 X.9906 Z-.7234
    N4657 X1.0185 Y1.4602 Z-.7237
    N4658 X1.0412 Y1.465 Z-.7239
    N4659 X1.0619 Y1.4725 Z-.7241
    N4660 X1.08 Y1.4821 Z-.7243
    N4661 X1.0952 Y1.4934 Z-.7245
    N4662 X1.1064 Y1.5047 Z-.7246
    N4663 X1.114 Y1.5157 Z-.7248
    N4664 X1.1186 Y1.5259 Z-.7249
    N4665 X1.1193 Y1.5288
    N4666 X1.12 Y1.5371 Z-.725
    N4667 Y1.8828 Z-.7284
    N4668 G3 X1.0887 Y1.914 Z-.7289 I-.0313
    N4669 G1 X1.0661 Z-.7291
    N4670 X1.0428 Z-.7293
    N4671 X1.019 Z-.7296
    N4672 X.995 Z-.7298
    N4673 X.37 Z-.7359
    N4674 X.346 Z-.7362
    N4675 X.3222 Z-.7364
    N4676 X.2989 Z-.7366
    N4677 X.2762 Z-.7369
    N4678 X.2681 Y1.9129 Z-.737
    N4679 X.2606 Y1.9098
    N4680 X.2541 Y1.9049 Z-.7371
    N4681 X.2492 Y1.8984 Z-.7372
    N4682 X.2461 Y1.8909
    N4683 X.245 Y1.8828 Z-.7373
    N4684 Y1.539 Z-.7407
    N4685 X.2464 Y1.5272 Z-.7408
    N4686 X.2489 Y1.5198 Z-.7409
    N4687 X.2547 Y1.5098 Z-.741
    N4688 X.2647 Y1.4981 Z-.7412
    N4689 X.2791 Y1.4861 Z-.7413
    N4690 X.2974 Y1.4752 Z-.7416
    N4691 X.3185 Y1.4667 Z-.7418
    N4692 X.3437 Y1.4605 Z-.742
    N4693 X.3558 Y1.459 Z-.7422
    N4694 X.3726 Y1.4583 Z-.7423
    N4695 X.9906 Z-.7484
    N4696 X1.0185 Y1.4602 Z-.7487
    N4697 X1.0412 Y1.465 Z-.7489
    N4698 X1.0619 Y1.4725 Z-.7491
    N4699 X1.08 Y1.4821 Z-.7493
    N4700 X1.0952 Y1.4934 Z-.7495
    N4701 X1.1064 Y1.5047 Z-.7496
    N4702 X1.114 Y1.5157 Z-.7498
    N4703 X1.1186 Y1.5259 Z-.7499
    N4704 X1.1193 Y1.5288
    N4705 X1.12 Y1.5371 Z-.75
    N4706 Y1.8828 Z-.7534
    N4707 G3 X1.0887 Y1.914 Z-.7539 I-.0313
    N4708 G1 X1.0661 Z-.7541
    N4709 X1.0428 Z-.7543
    N4710 X1.019 Z-.7546
    N4711 X.995 Z-.7548
    N4712 X.37 Z-.7609
    N4713 X.346 Z-.7612
    N4714 X.3222 Z-.7614
    N4715 X.2989 Z-.7616
    N4716 X.2762 Z-.7619
    N4717 X.2681 Y1.9129 Z-.762
    N4718 X.2606 Y1.9098
    N4719 X.2541 Y1.9049 Z-.7621
    N4720 X.2492 Y1.8984 Z-.7622
    N4721 X.2461 Y1.8909
    N4722 X.245 Y1.8828 Z-.7623
    N4723 Y1.539 Z-.7657
    N4724 X.2464 Y1.5272 Z-.7658
    N4725 X.2489 Y1.5198 Z-.7659
    N4726 X.2547 Y1.5098 Z-.766
    N4727 X.2647 Y1.4981 Z-.7662
    N4728 X.2791 Y1.4861 Z-.7663
    N4729 X.2974 Y1.4752 Z-.7666
    N4730 X.3185 Y1.4667 Z-.7668
    N4731 X.3437 Y1.4605 Z-.767
    N4732 X.3558 Y1.459 Z-.7672
    N4733 X.3726 Y1.4583 Z-.7673
    N4734 X.9906 Z-.7734
    N4735 X1.0185 Y1.4602 Z-.7737
    N4736 X1.0412 Y1.465 Z-.7739
    N4737 X1.0619 Y1.4725 Z-.7741
    N4738 X1.08 Y1.4821 Z-.7743
    N4739 X1.0952 Y1.4934 Z-.7745
    N4740 X1.1064 Y1.5047 Z-.7746
    N4741 X1.114 Y1.5157 Z-.7748
    N4742 X1.1186 Y1.5259 Z-.7749
    N4743 X1.1193 Y1.5288
    N4744 X1.12 Y1.5371 Z-.775
    N4745 Y1.8828 Z-.7784
    N4746 G3 X1.0887 Y1.914 Z-.7789 I-.0313
    N4747 G1 X1.0661 Z-.7791
    N4748 X1.0428 Z-.7793
    N4749 X1.019 Z-.7796
    N4750 X.995 Z-.7798
    N4751 X.37 Z-.7859
    N4752 X.346 Z-.7862
    N4753 X.3222 Z-.7864
    N4754 X.2989 Z-.7866
    N4755 X.2762 Z-.7869
    N4756 X.2681 Y1.9129 Z-.787
    N4757 X.2606 Y1.9098
    N4758 X.2541 Y1.9049 Z-.7871
    N4759 X.2492 Y1.8984 Z-.7872
    N4760 X.2461 Y1.8909
    N4761 X.245 Y1.8828 Z-.7873
    N4762 Y1.539 Z-.7907
    N4763 X.2464 Y1.5272 Z-.7908
    N4764 X.2489 Y1.5198 Z-.7909
    N4765 X.2547 Y1.5098 Z-.791
    N4766 X.2647 Y1.4981 Z-.7912
    N4767 X.2791 Y1.4861 Z-.7913
    N4768 X.2974 Y1.4752 Z-.7916
    N4769 X.3185 Y1.4667 Z-.7918
    N4770 X.3437 Y1.4605 Z-.792
    N4771 X.3558 Y1.459 Z-.7922
    N4772 X.3726 Y1.4583 Z-.7923
    N4773 X.9906 Z-.7984
    N4774 X1.0185 Y1.4602 Z-.7987
    N4775 X1.0412 Y1.465 Z-.7989
    N4776 X1.0619 Y1.4725 Z-.7991
    N4777 X1.08 Y1.4821 Z-.7993
    N4778 X1.0952 Y1.4934 Z-.7995
    N4779 X1.1064 Y1.5047 Z-.7996
    N4780 X1.114 Y1.5157 Z-.7998
    N4781 X1.1186 Y1.5259 Z-.7999
    N4782 X1.1193 Y1.5288
    N4783 X1.12 Y1.5371 Z-.8
    N4784 Y1.8828 Z-.8034
    N4785 G3 X1.0887 Y1.914 Z-.8039 I-.0313
    N4786 G1 X1.0661 Z-.8041
    N4787 X1.0428 Z-.8043
    N4788 X1.019 Z-.8046
    N4789 X.995 Z-.8048
    N4790 X.37 Z-.8109
    N4791 X.346 Z-.8112
    N4792 X.3222 Z-.8114
    N4793 X.2989 Z-.8116
    N4794 X.2762 Z-.8119
    N4795 X.2681 Y1.9129 Z-.812
    N4796 X.2606 Y1.9098
    N4797 X.2541 Y1.9049 Z-.8121
    N4798 X.2492 Y1.8984 Z-.8122
    N4799 X.2461 Y1.8909
    N4800 X.245 Y1.8828 Z-.8123
    N4801 Y1.539 Z-.8157
    N4802 X.2464 Y1.5272 Z-.8158
    N4803 X.2489 Y1.5198 Z-.8159
    N4804 X.2547 Y1.5098 Z-.816
    N4805 X.2647 Y1.4981 Z-.8162
    N4806 X.2791 Y1.4861 Z-.8163
    N4807 X.2974 Y1.4752 Z-.8166
    N4808 X.3185 Y1.4667 Z-.8168
    N4809 X.3437 Y1.4605 Z-.817
    N4810 X.3558 Y1.459 Z-.8172
    N4811 X.3726 Y1.4583 Z-.8173
    N4812 X.9906 Z-.8234
    N4813 X1.0185 Y1.4602 Z-.8237
    N4814 X1.0412 Y1.465 Z-.8239
    N4815 X1.0619 Y1.4725 Z-.8241
    N4816 X1.08 Y1.4821 Z-.8243
    N4817 X1.0952 Y1.4934 Z-.8245
    N4818 X1.1064 Y1.5047 Z-.8246
    N4819 X1.114 Y1.5157 Z-.8248
    N4820 X1.1186 Y1.5259 Z-.8249
    N4821 X1.1193 Y1.5288
    N4822 X1.12 Y1.5371 Z-.825
    N4823 Y1.8828 Z-.8284
    N4824 G3 X1.0887 Y1.914 Z-.8289 I-.0313
    N4825 G1 X1.0661 Z-.8291
    N4826 X1.0428 Z-.8293
    N4827 X1.019 Z-.8296
    N4828 X.995 Z-.8298
    N4829 X.37 Z-.8359
    N4830 X.346 Z-.8362
    N4831 X.3222 Z-.8364
    N4832 X.2989 Z-.8366
    N4833 X.2762 Z-.8369
    N4834 X.2681 Y1.9129 Z-.837
    N4835 X.2606 Y1.9098
    N4836 X.2541 Y1.9049 Z-.8371
    N4837 X.2492 Y1.8984 Z-.8372
    N4838 X.2461 Y1.8909
    N4839 X.245 Y1.8828 Z-.8373
    N4840 Y1.539 Z-.8407
    N4841 X.2464 Y1.5272 Z-.8408
    N4842 X.2489 Y1.5198 Z-.8409
    N4843 X.2547 Y1.5098 Z-.841
    N4844 X.2647 Y1.4981 Z-.8412
    N4845 X.2791 Y1.4861 Z-.8413
    N4846 X.2974 Y1.4752 Z-.8416
    N4847 X.3185 Y1.4667 Z-.8418
    N4848 X.3437 Y1.4605 Z-.842
    N4849 X.3558 Y1.459 Z-.8422
    N4850 X.3726 Y1.4583 Z-.8423
    N4851 X.9906 Z-.8484
    N4852 X1.0185 Y1.4602 Z-.8487
    N4853 X1.0412 Y1.465 Z-.8489
    N4854 X1.0619 Y1.4725 Z-.8491
    N4855 X1.08 Y1.4821 Z-.8493
    N4856 X1.0952 Y1.4934 Z-.8495
    N4857 X1.1064 Y1.5047 Z-.8496
    N4858 X1.114 Y1.5157 Z-.8498
    N4859 X1.1186 Y1.5259 Z-.8499
    N4860 X1.1193 Y1.5288
    N4861 X1.12 Y1.5371 Z-.85
    N4862 Y1.8828 Z-.8534
    N4863 G3 X1.0887 Y1.914 Z-.8539 I-.0313
    N4864 G1 X1.0661 Z-.8541
    N4865 X1.0428 Z-.8543
    N4866 X1.019 Z-.8546
    N4867 X.995 Z-.8548
    N4868 X.37 Z-.8609
    N4869 X.346 Z-.8612
    N4870 X.3222 Z-.8614
    N4871 X.2989 Z-.8616
    N4872 X.2762 Z-.8619
    N4873 X.2681 Y1.9129 Z-.862
    N4874 X.2606 Y1.9098
    N4875 X.2541 Y1.9049 Z-.8621
    N4876 X.2492 Y1.8984 Z-.8622
    N4877 X.2461 Y1.8909
    N4878 X.245 Y1.8828 Z-.8623
    N4879 Y1.539 Z-.8657
    N4880 X.2464 Y1.5272 Z-.8658
    N4881 X.2489 Y1.5198 Z-.8659
    N4882 X.2547 Y1.5098 Z-.866
    N4883 X.2647 Y1.4981 Z-.8662
    N4884 X.2791 Y1.4861 Z-.8663
    N4885 X.2974 Y1.4752 Z-.8666
    N4886 X.3185 Y1.4667 Z-.8668
    N4887 X.3437 Y1.4605 Z-.867
    N4888 X.3558 Y1.459 Z-.8672
    N4889 X.3726 Y1.4583 Z-.8673
    N4890 X.9906 Z-.8734
    N4891 X1.0185 Y1.4602 Z-.8737
    N4892 X1.0412 Y1.465 Z-.8739
    N4893 X1.0619 Y1.4725 Z-.8741
    N4894 X1.08 Y1.4821 Z-.8743
    N4895 X1.0952 Y1.4934 Z-.8745
    N4896 X1.1064 Y1.5047 Z-.8746
    N4897 X1.114 Y1.5157 Z-.8748
    N4898 X1.1186 Y1.5259 Z-.8749
    N4899 X1.1193 Y1.5288
    N4900 X1.12 Y1.5371 Z-.875
    N4901 Y1.8828 Z-.8784
    N4902 G3 X1.0887 Y1.914 Z-.8789 I-.0313
    N4903 G1 X1.0661 Z-.8791
    N4904 X1.0428 Z-.8793
    N4905 X1.019 Z-.8796
    N4906 X.995 Z-.8798
    N4907 X.37 Z-.8859
    N4908 X.346 Z-.8862
    N4909 X.3222 Z-.8864
    N4910 X.2989 Z-.8866
    N4911 X.2762 Z-.8869
    N4912 X.2681 Y1.9129 Z-.887
    N4913 X.2606 Y1.9098
    N4914 X.2541 Y1.9049 Z-.8871
    N4915 X.2492 Y1.8984 Z-.8872
    N4916 X.2461 Y1.8909
    N4917 X.245 Y1.8828 Z-.8873
    N4918 Y1.539 Z-.8907
    N4919 X.2464 Y1.5272 Z-.8908
    N4920 X.2489 Y1.5198 Z-.8909
    N4921 X.2547 Y1.5098 Z-.891
    N4922 X.2647 Y1.4981 Z-.8912
    N4923 X.2791 Y1.4861 Z-.8913
    N4924 X.2974 Y1.4752 Z-.8916
    N4925 X.3185 Y1.4667 Z-.8918
    N4926 X.3437 Y1.4605 Z-.892
    N4927 X.3558 Y1.459 Z-.8922
    N4928 X.3726 Y1.4583 Z-.8923
    N4929 X.9906 Z-.8984
    N4930 X1.0185 Y1.4602 Z-.8987
    N4931 X1.0412 Y1.465 Z-.8989
    N4932 X1.0619 Y1.4725 Z-.8991
    N4933 X1.08 Y1.4821 Z-.8993
    N4934 X1.0952 Y1.4934 Z-.8995
    N4935 X1.1064 Y1.5047 Z-.8996
    N4936 X1.114 Y1.5157 Z-.8998
    N4937 X1.1186 Y1.5259 Z-.8999
    N4938 X1.1193 Y1.5288
    N4939 X1.12 Y1.5371 Z-.9
    N4940 Y1.8828 Z-.9034
    N4941 G3 X1.0887 Y1.914 Z-.9039 I-.0313
    N4942 G1 X1.0661 Z-.9041
    N4943 X1.0428 Z-.9043
    N4944 X1.019 Z-.9046
    N4945 X.995 Z-.9048
    N4946 X.37 Z-.9109
    N4947 X.346 Z-.9112
    N4948 X.3222 Z-.9114
    N4949 X.2989 Z-.9116
    N4950 X.2762 Z-.9119
    N4951 X.2681 Y1.9129 Z-.912
    N4952 X.2606 Y1.9098
    N4953 X.2541 Y1.9049 Z-.9121
    N4954 X.2492 Y1.8984 Z-.9122
    N4955 X.2461 Y1.8909
    N4956 X.245 Y1.8828 Z-.9123
    N4957 Y1.539 Z-.9157
    N4958 X.2464 Y1.5272 Z-.9158
    N4959 X.2489 Y1.5198 Z-.9159
    N4960 X.2547 Y1.5098 Z-.916
    N4961 X.2647 Y1.4981 Z-.9162
    N4962 X.2791 Y1.4861 Z-.9163
    N4963 X.2974 Y1.4752 Z-.9166
    N4964 X.3185 Y1.4667 Z-.9168
    N4965 X.3437 Y1.4605 Z-.917
    N4966 X.3558 Y1.459 Z-.9172
    N4967 X.3726 Y1.4583 Z-.9173
    N4968 X.9906 Z-.9234
    N4969 X1.0185 Y1.4602 Z-.9237
    N4970 X1.0412 Y1.465 Z-.9239
    N4971 X1.0619 Y1.4725 Z-.9241
    N4972 X1.08 Y1.4821 Z-.9243
    N4973 X1.0952 Y1.4934 Z-.9245
    N4974 X1.1064 Y1.5047 Z-.9246
    N4975 X1.114 Y1.5157 Z-.9248
    N4976 X1.1186 Y1.5259 Z-.9249
    N4977 X1.1193 Y1.5288
    N4978 X1.12 Y1.5371 Z-.925
    N4979 Y1.8828 Z-.9284
    N4980 G3 X1.0887 Y1.914 Z-.9289 I-.0313
    N4981 G1 X1.0661 Z-.9291
    N4982 X1.0428 Z-.9293
    N4983 X1.019 Z-.9296
    N4984 X.995 Z-.9298
    N4985 X.37 Z-.9359
    N4986 X.346 Z-.9362
    N4987 X.3222 Z-.9364
    N4988 X.2989 Z-.9366
    N4989 X.2762 Z-.9369
    N4990 X.2681 Y1.9129 Z-.937
    N4991 X.2606 Y1.9098
    N4992 X.2541 Y1.9049 Z-.9371
    N4993 X.2492 Y1.8984 Z-.9372
    N4994 X.2461 Y1.8909
    N4995 X.245 Y1.8828 Z-.9373
    N4996 Y1.539 Z-.9407
    N4997 X.2464 Y1.5272 Z-.9408
    N4998 X.2489 Y1.5198 Z-.9409
    N4999 X.2547 Y1.5098 Z-.941
    N5000 X.2647 Y1.4981 Z-.9412
    N5001 X.2791 Y1.4861 Z-.9413
    N5002 X.2974 Y1.4752 Z-.9416
    N5003 X.3185 Y1.4667 Z-.9418
    N5004 X.3437 Y1.4605 Z-.942
    N5005 X.3558 Y1.459 Z-.9422
    N5006 X.3726 Y1.4583 Z-.9423
    N5007 X.9906 Z-.9484
    N5008 X1.0185 Y1.4602 Z-.9487
    N5009 X1.0412 Y1.465 Z-.9489
    N5010 X1.0619 Y1.4725 Z-.9491
    N5011 X1.08 Y1.4821 Z-.9493
    N5012 X1.0952 Y1.4934 Z-.9495
    N5013 X1.1064 Y1.5047 Z-.9496
    N5014 X1.114 Y1.5157 Z-.9498
    N5015 X1.1186 Y1.5259 Z-.9499
    N5016 X1.1193 Y1.5288
    N5017 X1.12 Y1.5371 Z-.95
    N5018 Y1.8828 Z-.9534
    N5019 G3 X1.0887 Y1.914 Z-.9539 I-.0313
    N5020 G1 X1.0661 Z-.9541
    N5021 X1.0428 Z-.9543
    N5022 X1.019 Z-.9546
    N5023 X.995 Z-.9548
    N5024 X.37 Z-.9609
    N5025 X.346 Z-.9612
    N5026 X.3222 Z-.9614
    N5027 X.2989 Z-.9616
    N5028 X.2762 Z-.9619
    N5029 X.2681 Y1.9129 Z-.962
    N5030 X.2606 Y1.9098
    N5031 X.2541 Y1.9049 Z-.9621
    N5032 X.2492 Y1.8984 Z-.9622
    N5033 X.2461 Y1.8909
    N5034 X.245 Y1.8828 Z-.9623
    N5035 Y1.539 Z-.9657
    N5036 X.2464 Y1.5272 Z-.9658
    N5037 X.2489 Y1.5198 Z-.9659
    N5038 X.2547 Y1.5098 Z-.966
    N5039 X.2647 Y1.4981 Z-.9662
    N5040 X.2791 Y1.4861 Z-.9663
    N5041 X.2974 Y1.4752 Z-.9666
    N5042 X.3185 Y1.4667 Z-.9668
    N5043 X.3437 Y1.4605 Z-.967
    N5044 X.3558 Y1.459 Z-.9672
    N5045 X.3726 Y1.4583 Z-.9673
    N5046 X.9906 Z-.9734
    N5047 X1.0185 Y1.4602 Z-.9737
    N5048 X1.0412 Y1.465 Z-.9739
    N5049 X1.0619 Y1.4725 Z-.9741
    N5050 X1.08 Y1.4821 Z-.9743
    N5051 X1.0952 Y1.4934 Z-.9745
    N5052 X1.1064 Y1.5047 Z-.9746
    N5053 X1.114 Y1.5157 Z-.9748
    N5054 X1.1186 Y1.5259 Z-.9749
    N5055 X1.1193 Y1.5288
    N5056 X1.12 Y1.5371 Z-.975
    N5057 Y1.8828 Z-.9784
    N5058 G3 X1.0887 Y1.914 Z-.9789 I-.0313
    N5059 G1 X1.0661 Z-.9791
    N5060 X1.0428 Z-.9793
    N5061 X1.019 Z-.9796
    N5062 X.995 Z-.9798
    N5063 X.37 Z-.9859
    N5064 X.346 Z-.9862
    N5065 X.3222 Z-.9864
    N5066 X.2989 Z-.9866
    N5067 X.2762 Z-.9869
    N5068 X.2681 Y1.9129 Z-.987
    N5069 X.2606 Y1.9098
    N5070 X.2541 Y1.9049 Z-.9871
    N5071 X.2492 Y1.8984 Z-.9872
    N5072 X.2461 Y1.8909
    N5073 X.245 Y1.8828 Z-.9873
    N5074 Y1.539 Z-.9907
    N5075 X.2464 Y1.5272 Z-.9908
    N5076 X.2489 Y1.5198 Z-.9909
    N5077 X.2547 Y1.5098 Z-.991
    N5078 X.2647 Y1.4981 Z-.9912
    N5079 X.2791 Y1.4861 Z-.9913
    N5080 X.2974 Y1.4752 Z-.9916
    N5081 X.3185 Y1.4667 Z-.9918
    N5082 X.3437 Y1.4605 Z-.992
    N5083 X.3558 Y1.459 Z-.9922
    N5084 X.3726 Y1.4583 Z-.9923
    N5085 X.9906 Z-.9984
    N5086 X1.0185 Y1.4602 Z-.9987
    N5087 X1.0412 Y1.465 Z-.9989
    N5088 X1.0619 Y1.4725 Z-.9991
    N5089 X1.08 Y1.4821 Z-.9993
    N5090 X1.0952 Y1.4934 Z-.9995
    N5091 X1.1064 Y1.5047 Z-.9996
    N5092 X1.114 Y1.5157 Z-.9998
    N5093 X1.1186 Y1.5259 Z-.9999
    N5094 X1.1193 Y1.5288
    N5095 X1.12 Y1.5371 Z-1.
    N5096 Y1.8828 Z-1.0034
    N5097 G3 X1.0887 Y1.914 Z-1.0039 I-.0313
    N5098 G1 X1.0661 Z-1.0041
    N5099 X1.0428 Z-1.0043
    N5100 X1.019 Z-1.0046
    N5101 X.995 Z-1.0048
    N5102 X.37 Z-1.0109
    N5103 X.346 Z-1.0112
    N5104 X.3222 Z-1.0114
    N5105 X.2989 Z-1.0116
    N5106 X.2762 Z-1.0119
    N5107 X.2681 Y1.9129 Z-1.012
    N5108 X.2606 Y1.9098
    N5109 X.2541 Y1.9049 Z-1.0121
    N5110 X.2492 Y1.8984 Z-1.0122
    N5111 X.2461 Y1.8909
    N5112 X.245 Y1.8828 Z-1.0123
    N5113 Y1.539 Z-1.0157
    N5114 X.2464 Y1.5272 Z-1.0158
    N5115 X.2489 Y1.5198 Z-1.0159
    N5116 X.2547 Y1.5098 Z-1.016
    N5117 X.2647 Y1.4981 Z-1.0162
    N5118 X.2791 Y1.4861 Z-1.0163
    N5119 X.2974 Y1.4752 Z-1.0166
    N5120 X.3185 Y1.4667 Z-1.0168
    N5121 X.3437 Y1.4605 Z-1.017
    N5122 X.3558 Y1.459 Z-1.0172
    N5123 X.3726 Y1.4583 Z-1.0173
    N5124 X.9906 Z-1.0234
    N5125 X1.0185 Y1.4602 Z-1.0237
    N5126 X1.0412 Y1.465 Z-1.0239
    N5127 X1.0619 Y1.4725 Z-1.0241
    N5128 X1.08 Y1.4821 Z-1.0243
    N5129 X1.0952 Y1.4934 Z-1.0245
    N5130 X1.1064 Y1.5047 Z-1.0246
    N5131 X1.114 Y1.5157 Z-1.0248
    N5132 X1.1186 Y1.5259 Z-1.0249
    N5133 X1.1193 Y1.5288
    N5134 X1.12 Y1.5371 Z-1.025
    N5135 Y1.8828 Z-1.0284
    N5136 G3 X1.0887 Y1.914 Z-1.0289 I-.0313
    N5137 G1 X1.0661 Z-1.0291
    N5138 X1.0428 Z-1.0293
    N5139 X1.019 Z-1.0296
    N5140 X.995 Z-1.0298
    N5141 X.37 Z-1.0359
    N5142 X.346 Z-1.0362
    N5143 X.3222 Z-1.0364
    N5144 X.2989 Z-1.0366
    N5145 X.2762 Z-1.0369
    N5146 X.2681 Y1.9129 Z-1.037
    N5147 X.2606 Y1.9098
    N5148 X.2541 Y1.9049 Z-1.0371
    N5149 X.2492 Y1.8984 Z-1.0372
    N5150 X.2461 Y1.8909
    N5151 X.245 Y1.8828 Z-1.0373
    N5152 Y1.539 Z-1.0407
    N5153 X.2464 Y1.5272 Z-1.0408
    N5154 X.2489 Y1.5198 Z-1.0409
    N5155 X.2547 Y1.5098 Z-1.041
    N5156 X.2647 Y1.4981 Z-1.0412
    N5157 X.2791 Y1.4861 Z-1.0413
    N5158 X.2974 Y1.4752 Z-1.0416
    N5159 X.3185 Y1.4667 Z-1.0418
    N5160 X.3437 Y1.4605 Z-1.042
    N5161 X.3558 Y1.459 Z-1.0422
    N5162 X.3726 Y1.4583 Z-1.0423
    N5163 X.9906 Z-1.0484
    N5164 X1.0185 Y1.4602 Z-1.0487
    N5165 X1.0412 Y1.465 Z-1.0489
    N5166 X1.0619 Y1.4725 Z-1.0491
    N5167 X1.08 Y1.4821 Z-1.0493
    N5168 X1.0952 Y1.4934 Z-1.0495
    N5169 X1.1064 Y1.5047 Z-1.0496
    N5170 X1.114 Y1.5157 Z-1.0498
    N5171 X1.1186 Y1.5259 Z-1.0499
    N5172 X1.1193 Y1.5288
    N5173 X1.12 Y1.5371 Z-1.05
    N5174 Y1.8828 Z-1.0534
    N5175 G3 X1.0887 Y1.914 Z-1.0539 I-.0313
    N5176 G1 X1.0661 Z-1.0541
    N5177 X1.0428 Z-1.0543
    N5178 X1.019 Z-1.0546
    N5179 X.995 Z-1.0548
    N5180 X.37 Z-1.0609
    N5181 X.346 Z-1.0612
    N5182 X.3222 Z-1.0614
    N5183 X.2989 Z-1.0616
    N5184 X.2762 Z-1.0619
    N5185 X.2681 Y1.9129 Z-1.062
    N5186 X.2606 Y1.9098
    N5187 X.2541 Y1.9049 Z-1.0621
    N5188 X.2492 Y1.8984 Z-1.0622
    N5189 X.2461 Y1.8909
    N5190 X.245 Y1.8828 Z-1.0623
    N5191 Y1.539 Z-1.0657
    N5192 X.2464 Y1.5272 Z-1.0658
    N5193 X.2489 Y1.5198 Z-1.0659
    N5194 X.2547 Y1.5098 Z-1.066
    N5195 X.2647 Y1.4981 Z-1.0662
    N5196 X.2791 Y1.4861 Z-1.0663
    N5197 X.2974 Y1.4752 Z-1.0666
    N5198 X.3185 Y1.4667 Z-1.0668
    N5199 X.3437 Y1.4605 Z-1.067
    N5200 X.3558 Y1.459 Z-1.0672
    N5201 X.3726 Y1.4583 Z-1.0673
    N5202 X.9906 Z-1.0734
    N5203 X1.0185 Y1.4602 Z-1.0737
    N5204 X1.0412 Y1.465 Z-1.0739
    N5205 X1.0619 Y1.4725 Z-1.0741
    N5206 X1.08 Y1.4821 Z-1.0743
    N5207 X1.0952 Y1.4934 Z-1.0745
    N5208 X1.1064 Y1.5047 Z-1.0746
    N5209 X1.114 Y1.5157 Z-1.0748
    N5210 X1.1186 Y1.5259 Z-1.0749
    N5211 X1.1193 Y1.5288
    N5212 X1.12 Y1.5371 Z-1.075
    N5213 Y1.8828 Z-1.0784
    N5214 G3 X1.0887 Y1.914 Z-1.0789 I-.0313
    N5215 G1 X1.0661 Z-1.0791
    N5216 X1.0428 Z-1.0793
    N5217 X1.019 Z-1.0796
    N5218 X.995 Z-1.0798
    N5219 X.37 Z-1.0859
    N5220 X.346 Z-1.0862
    N5221 X.3222 Z-1.0864
    N5222 X.2989 Z-1.0866
    N5223 X.2762 Z-1.0869
    N5224 X.2681 Y1.9129 Z-1.087
    N5225 X.2606 Y1.9098
    N5226 X.2541 Y1.9049 Z-1.0871
    N5227 X.2492 Y1.8984 Z-1.0872
    N5228 X.2461 Y1.8909
    N5229 X.245 Y1.8828 Z-1.0873
    N5230 Y1.539 Z-1.0907
    N5231 X.2464 Y1.5272 Z-1.0908
    N5232 X.2489 Y1.5198 Z-1.0909
    N5233 X.2547 Y1.5098 Z-1.091
    N5234 X.2647 Y1.4981 Z-1.0912
    N5235 X.2791 Y1.4861 Z-1.0913
    N5236 X.2974 Y1.4752 Z-1.0916
    N5237 X.3185 Y1.4667 Z-1.0918
    N5238 X.3437 Y1.4605 Z-1.092
    N5239 X.3558 Y1.459 Z-1.0922
    N5240 X.3726 Y1.4583 Z-1.0923
    N5241 X.9906 Z-1.0984
    N5242 X1.0185 Y1.4602 Z-1.0987
    N5243 X1.0412 Y1.465 Z-1.0989
    N5244 X1.0619 Y1.4725 Z-1.0991
    N5245 X1.08 Y1.4821 Z-1.0993
    N5246 X1.0952 Y1.4934 Z-1.0995
    N5247 X1.1064 Y1.5047 Z-1.0996
    N5248 X1.114 Y1.5157 Z-1.0998
    N5249 X1.1186 Y1.5259 Z-1.0999
    N5250 X1.1193 Y1.5288
    N5251 X1.12 Y1.5371 Z-1.1
    N5252 Y1.8828 Z-1.1034
    N5253 G3 X1.0887 Y1.914 Z-1.1039 I-.0313
    N5254 G1 X1.0661 Z-1.1041
    N5255 X1.0428 Z-1.1043
    N5256 X1.019 Z-1.1046
    N5257 X.995 Z-1.1048
    N5258 X.37 Z-1.1109
    N5259 X.346 Z-1.1112
    N5260 X.3222 Z-1.1114
    N5261 X.2989 Z-1.1116
    N5262 X.2762 Z-1.1119
    N5263 X.2681 Y1.9129 Z-1.112
    N5264 X.2606 Y1.9098
    N5265 X.2541 Y1.9049 Z-1.1121
    N5266 X.2492 Y1.8984 Z-1.1122
    N5267 X.2461 Y1.8909
    N5268 X.245 Y1.8828 Z-1.1123
    N5269 Y1.539 Z-1.1157
    N5270 X.2464 Y1.5272 Z-1.1158
    N5271 X.2489 Y1.5198 Z-1.1159
    N5272 X.2547 Y1.5098 Z-1.116
    N5273 X.2647 Y1.4981 Z-1.1162
    N5274 X.2791 Y1.4861 Z-1.1163
    N5275 X.2974 Y1.4752 Z-1.1166
    N5276 X.3185 Y1.4667 Z-1.1168
    N5277 X.3437 Y1.4605 Z-1.117
    N5278 X.3558 Y1.459 Z-1.1172
    N5279 X.3726 Y1.4583 Z-1.1173
    N5280 X.9906 Z-1.1234
    N5281 X1.0185 Y1.4602 Z-1.1237
    N5282 X1.0412 Y1.465 Z-1.1239
    N5283 X1.0619 Y1.4725 Z-1.1241
    N5284 X1.08 Y1.4821 Z-1.1243
    N5285 X1.0952 Y1.4934 Z-1.1245
    N5286 X1.1064 Y1.5047 Z-1.1246
    N5287 X1.114 Y1.5157 Z-1.1248
    N5288 X1.1186 Y1.5259 Z-1.1249
    N5289 X1.1193 Y1.5288
    N5290 X1.12 Y1.5371 Z-1.125
    N5291 Y1.8828 Z-1.1284
    N5292 G3 X1.0887 Y1.914 Z-1.1289 I-.0313
    N5293 G1 X1.0661 Z-1.1291
    N5294 X1.0428 Z-1.1293
    N5295 X1.019 Z-1.1296
    N5296 X.995 Z-1.1298
    N5297 X.37 Z-1.1359
    N5298 X.346 Z-1.1362
    N5299 X.3222 Z-1.1364
    N5300 X.2989 Z-1.1366
    N5301 X.2762 Z-1.1369
    N5302 X.2681 Y1.9129 Z-1.137
    N5303 X.2606 Y1.9098
    N5304 X.2541 Y1.9049 Z-1.1371
    N5305 X.2492 Y1.8984 Z-1.1372
    N5306 X.2461 Y1.8909
    N5307 X.245 Y1.8828 Z-1.1373
    N5308 Y1.539 Z-1.1407
    N5309 X.2464 Y1.5272 Z-1.1408
    N5310 X.2489 Y1.5198 Z-1.1409
    N5311 X.2547 Y1.5098 Z-1.141
    N5312 X.2647 Y1.4981 Z-1.1412
    N5313 X.2791 Y1.4861 Z-1.1413
    N5314 X.2974 Y1.4752 Z-1.1416
    N5315 X.3185 Y1.4667 Z-1.1418
    N5316 X.3437 Y1.4605 Z-1.142
    N5317 X.3558 Y1.459 Z-1.1422
    N5318 X.3726 Y1.4583 Z-1.1423
    N5319 X.9906 Z-1.1484
    N5320 X1.0185 Y1.4602 Z-1.1487
    N5321 X1.0412 Y1.465 Z-1.1489
    N5322 X1.0619 Y1.4725 Z-1.1491
    N5323 X1.08 Y1.4821 Z-1.1493
    N5324 X1.0952 Y1.4934 Z-1.1495
    N5325 X1.1064 Y1.5047 Z-1.1496
    N5326 X1.114 Y1.5157 Z-1.1498
    N5327 X1.1186 Y1.5259 Z-1.1499
    N5328 X1.1193 Y1.5288
    N5329 X1.12 Y1.5371 Z-1.15
    N5330 Y1.8828 Z-1.1534
    N5331 G3 X1.0887 Y1.914 Z-1.1539 I-.0313
    N5332 G1 X1.0661 Z-1.1541
    N5333 X1.0428 Z-1.1543
    N5334 X1.019 Z-1.1546
    N5335 X.995 Z-1.1548
    N5336 X.37 Z-1.1609
    N5337 X.346 Z-1.1612
    N5338 X.3222 Z-1.1614
    N5339 X.2989 Z-1.1616
    N5340 X.2762 Z-1.1619
    N5341 X.2681 Y1.9129 Z-1.162
    N5342 X.2606 Y1.9098
    N5343 X.2541 Y1.9049 Z-1.1621
    N5344 X.2492 Y1.8984 Z-1.1622
    N5345 X.2461 Y1.8909
    N5346 X.245 Y1.8828 Z-1.1623
    N5347 Y1.539 Z-1.1657
    N5348 X.2464 Y1.5272 Z-1.1658
    N5349 X.2489 Y1.5198 Z-1.1659
    N5350 X.2547 Y1.5098 Z-1.166
    N5351 X.2647 Y1.4981 Z-1.1662
    N5352 X.2791 Y1.4861 Z-1.1663
    N5353 X.2974 Y1.4752 Z-1.1666
    N5354 X.3185 Y1.4667 Z-1.1668
    N5355 X.3437 Y1.4605 Z-1.167
    N5356 X.3558 Y1.459 Z-1.1672
    N5357 X.3726 Y1.4583 Z-1.1673
    N5358 X.9906 Z-1.1734
    N5359 X1.0185 Y1.4602 Z-1.1737
    N5360 X1.0412 Y1.465 Z-1.1739
    N5361 X1.0619 Y1.4725 Z-1.1741
    N5362 X1.08 Y1.4821 Z-1.1743
    N5363 X1.0952 Y1.4934 Z-1.1745
    N5364 X1.1064 Y1.5047 Z-1.1746
    N5365 X1.114 Y1.5157 Z-1.1748
    N5366 X1.1186 Y1.5259 Z-1.1749
    N5367 X1.1193 Y1.5288
    N5368 X1.12 Y1.5371 Z-1.175
    N5369 Y1.8828 Z-1.1784
    N5370 G3 X1.0887 Y1.914 Z-1.1789 I-.0313
    N5371 G1 X1.0661 Z-1.1791
    N5372 X1.0428 Z-1.1793
    N5373 X1.019 Z-1.1796
    N5374 X.995 Z-1.1798
    N5375 X.37 Z-1.1859
    N5376 X.346 Z-1.1862
    N5377 X.3222 Z-1.1864
    N5378 X.2989 Z-1.1866
    N5379 X.2762 Z-1.1869
    N5380 X.2681 Y1.9129 Z-1.187
    N5381 X.2606 Y1.9098
    N5382 X.2541 Y1.9049 Z-1.1871
    N5383 X.2492 Y1.8984 Z-1.1872
    N5384 X.2461 Y1.8909
    N5385 X.245 Y1.8828 Z-1.1873
    N5386 Y1.539 Z-1.1907
    N5387 X.2464 Y1.5272 Z-1.1908
    N5388 X.2489 Y1.5198 Z-1.1909
    N5389 X.2547 Y1.5098 Z-1.191
    N5390 X.2647 Y1.4981 Z-1.1912
    N5391 X.2791 Y1.4861 Z-1.1913
    N5392 X.2974 Y1.4752 Z-1.1916
    N5393 X.3185 Y1.4667 Z-1.1918
    N5394 X.3437 Y1.4605 Z-1.192
    N5395 X.3558 Y1.459 Z-1.1922
    N5396 X.3726 Y1.4583 Z-1.1923
    N5397 X.9906 Z-1.1984
    N5398 X1.0185 Y1.4602 Z-1.1987
    N5399 X1.0412 Y1.465 Z-1.1989
    N5400 X1.0619 Y1.4725 Z-1.1991
    N5401 X1.08 Y1.4821 Z-1.1993
    N5402 X1.0952 Y1.4934 Z-1.1995
    N5403 X1.1064 Y1.5047 Z-1.1996
    N5404 X1.114 Y1.5157 Z-1.1998
    N5405 X1.1186 Y1.5259 Z-1.1999
    N5406 X1.1193 Y1.5288
    N5407 X1.12 Y1.5371 Z-1.2
    N5408 Y1.8828 Z-1.2034
    N5409 G3 X1.0887 Y1.914 Z-1.2039 I-.0313
    N5410 G1 X1.0661 Z-1.2041
    N5411 X1.0428 Z-1.2043
    N5412 X1.019 Z-1.2046
    N5413 X.995 Z-1.2048
    N5414 X.37 Z-1.2109
    N5415 X.346 Z-1.2112
    N5416 X.3222 Z-1.2114
    N5417 X.2989 Z-1.2116
    N5418 X.2762 Z-1.2119
    N5419 X.2681 Y1.9129 Z-1.212
    N5420 X.2606 Y1.9098
    N5421 X.2541 Y1.9049 Z-1.2121
    N5422 X.2492 Y1.8984 Z-1.2122
    N5423 X.2461 Y1.8909
    N5424 X.245 Y1.8828 Z-1.2123
    N5425 Y1.539 Z-1.2157
    N5426 X.2464 Y1.5272 Z-1.2158
    N5427 X.2489 Y1.5198 Z-1.2159
    N5428 X.2547 Y1.5098 Z-1.216
    N5429 X.2647 Y1.4981 Z-1.2162
    N5430 X.2791 Y1.4861 Z-1.2163
    N5431 X.2974 Y1.4752 Z-1.2166
    N5432 X.3185 Y1.4667 Z-1.2168
    N5433 X.3437 Y1.4605 Z-1.217
    N5434 X.3558 Y1.459 Z-1.2172
    N5435 X.3726 Y1.4583 Z-1.2173
    N5436 X.9906 Z-1.2234
    N5437 X1.0185 Y1.4602 Z-1.2237
    N5438 X1.0412 Y1.465 Z-1.2239
    N5439 X1.0619 Y1.4725 Z-1.2241
    N5440 X1.08 Y1.4821 Z-1.2243
    N5441 X1.0952 Y1.4934 Z-1.2245
    N5442 X1.1064 Y1.5047 Z-1.2246
    N5443 X1.114 Y1.5157 Z-1.2248
    N5444 X1.1186 Y1.5259 Z-1.2249
    N5445 X1.1193 Y1.5288
    N5446 X1.12 Y1.5371 Z-1.225
    N5447 Y1.8828 Z-1.2284
    N5448 G3 X1.0887 Y1.914 Z-1.2289 I-.0313
    N5449 G1 X1.0661 Z-1.2291
    N5450 X1.0428 Z-1.2293
    N5451 X1.019 Z-1.2296
    N5452 X.995 Z-1.2298
    N5453 X.37 Z-1.2359
    N5454 X.346 Z-1.2362
    N5455 X.3222 Z-1.2364
    N5456 X.2989 Z-1.2366
    N5457 X.2762 Z-1.2369
    N5458 X.2681 Y1.9129 Z-1.237
    N5459 X.2606 Y1.9098
    N5460 X.2541 Y1.9049 Z-1.2371
    N5461 X.2492 Y1.8984 Z-1.2372
    N5462 X.2461 Y1.8909
    N5463 X.245 Y1.8828 Z-1.2373
    N5464 Y1.539 Z-1.2407
    N5465 X.2464 Y1.5272 Z-1.2408
    N5466 X.2489 Y1.5198 Z-1.2409
    N5467 X.2547 Y1.5098 Z-1.241
    N5468 X.2647 Y1.4981 Z-1.2412
    N5469 X.2791 Y1.4861 Z-1.2413
    N5470 X.2974 Y1.4752 Z-1.2416
    N5471 X.3185 Y1.4667 Z-1.2418
    N5472 X.3437 Y1.4605 Z-1.242
    N5473 X.3558 Y1.459 Z-1.2422
    N5474 X.3726 Y1.4583 Z-1.2423
    N5475 X.9906 Z-1.2484
    N5476 X1.0185 Y1.4602 Z-1.2487
    N5477 X1.0412 Y1.465 Z-1.2489
    N5478 X1.0619 Y1.4725 Z-1.2491
    N5479 X1.08 Y1.4821 Z-1.2493
    N5480 X1.0952 Y1.4934 Z-1.2495
    N5481 X1.1064 Y1.5047 Z-1.2496
    N5482 X1.114 Y1.5157 Z-1.2498
    N5483 X1.1186 Y1.5259 Z-1.2499
    N5484 X1.1193 Y1.5288
    N5485 X1.12 Y1.5371 Z-1.25
    N5486 Y1.8828 Z-1.2534
    N5487 G3 X1.0887 Y1.914 Z-1.2539 I-.0313
    N5488 G1 X1.0661 Z-1.2541
    N5489 X1.0428 Z-1.2543
    N5490 X1.019 Z-1.2546
    N5491 X.995 Z-1.2548
    N5492 X.37 Z-1.2609
    N5493 X.346 Z-1.2612
    N5494 X.3222 Z-1.2614
    N5495 X.2989 Z-1.2616
    N5496 X.2762 Z-1.2619
    N5497 X.2681 Y1.9129 Z-1.262
    N5498 X.2606 Y1.9098
    N5499 X.2541 Y1.9049 Z-1.2621
    N5500 X.2492 Y1.8984 Z-1.2622
    N5501 X.2461 Y1.8909
    N5502 X.245 Y1.8828 Z-1.2623
    N5503 Y1.539 Z-1.2657
    N5504 X.2464 Y1.5272 Z-1.2658
    N5505 X.2489 Y1.5198 Z-1.2659
    N5506 X.2547 Y1.5098 Z-1.266
    N5507 X.2647 Y1.4981 Z-1.2662
    N5508 X.2791 Y1.4861 Z-1.2663
    N5509 X.2974 Y1.4752 Z-1.2666
    N5510 X.3185 Y1.4667 Z-1.2668
    N5511 X.3437 Y1.4605 Z-1.267
    N5512 X.3558 Y1.459 Z-1.2672
    N5513 X.3726 Y1.4583 Z-1.2673
    N5514 X.9906 Z-1.2734
    N5515 X1.0185 Y1.4602 Z-1.2737
    N5516 X1.0412 Y1.465 Z-1.2739
    N5517 X1.0619 Y1.4725 Z-1.2741
    N5518 X1.08 Y1.4821 Z-1.2743
    N5519 X1.0952 Y1.4934 Z-1.2745
    N5520 X1.1064 Y1.5047 Z-1.2746
    N5521 X1.114 Y1.5157 Z-1.2748
    N5522 X1.1186 Y1.5259 Z-1.2749
    N5523 X1.1193 Y1.5288
    N5524 X1.12 Y1.5371 Z-1.275
    N5525 Y1.8828 Z-1.2784
    N5526 G3 X1.0887 Y1.914 Z-1.2789 I-.0313
    N5527 G1 X1.0661 Z-1.2791
    N5528 X1.0428 Z-1.2793
    N5529 X1.019 Z-1.2796
    N5530 X.995 Z-1.2798
    N5531 X.37 Z-1.2859
    N5532 X.346 Z-1.2862
    N5533 X.3222 Z-1.2864
    N5534 X.2989 Z-1.2866
    N5535 X.2762 Z-1.2869
    N5536 X.2681 Y1.9129 Z-1.287
    N5537 X.2606 Y1.9098
    N5538 X.2541 Y1.9049 Z-1.2871
    N5539 X.2492 Y1.8984 Z-1.2872
    N5540 X.2461 Y1.8909
    N5541 X.245 Y1.8828 Z-1.2873
    N5542 Y1.539 Z-1.2907
    N5543 X.2464 Y1.5272 Z-1.2908
    N5544 X.2489 Y1.5198 Z-1.2909
    N5545 X.2547 Y1.5098 Z-1.291
    N5546 X.2647 Y1.4981 Z-1.2912
    N5547 X.2791 Y1.4861 Z-1.2913
    N5548 X.2974 Y1.4752 Z-1.2916
    N5549 X.3185 Y1.4667 Z-1.2918
    N5550 X.3437 Y1.4605 Z-1.292
    N5551 X.3558 Y1.459 Z-1.2922
    N5552 X.3726 Y1.4583 Z-1.2923
    N5553 X.9906 Z-1.2984
    N5554 X1.0185 Y1.4602 Z-1.2987
    N5555 X1.0412 Y1.465 Z-1.2989
    N5556 X1.0619 Y1.4725 Z-1.2991
    N5557 X1.08 Y1.4821 Z-1.2993
    N5558 X1.0952 Y1.4934 Z-1.2995
    N5559 X1.1064 Y1.5047 Z-1.2996
    N5560 X1.114 Y1.5157 Z-1.2998
    N5561 X1.1186 Y1.5259 Z-1.2999
    N5562 X1.1193 Y1.5288
    N5563 X1.12 Y1.5371 Z-1.3
    N5564 Y1.8828 Z-1.3034
    N5565 G3 X1.0887 Y1.914 Z-1.3039 I-.0313
    N5566 G1 X1.0661 Z-1.3041
    N5567 X1.0428 Z-1.3043
    N5568 X1.019 Z-1.3046
    N5569 X.995 Z-1.3048
    N5570 X.37 Z-1.3109
    N5571 X.346 Z-1.3112
    N5572 X.3222 Z-1.3114
    N5573 X.2989 Z-1.3116
    N5574 X.2762 Z-1.3119
    N5575 X.2681 Y1.9129 Z-1.312
    N5576 X.2606 Y1.9098
    N5577 X.2541 Y1.9049 Z-1.3121
    N5578 X.2492 Y1.8984 Z-1.3122
    N5579 X.2461 Y1.8909
    N5580 X.245 Y1.8828 Z-1.3123
    N5581 Y1.539 Z-1.3157
    N5582 X.2464 Y1.5272 Z-1.3158
    N5583 X.2489 Y1.5198 Z-1.3159
    N5584 X.2547 Y1.5098 Z-1.316
    N5585 X.2647 Y1.4981 Z-1.3162
    N5586 X.2791 Y1.4861 Z-1.3163
    N5587 X.2974 Y1.4752 Z-1.3166
    N5588 X.3185 Y1.4667 Z-1.3168
    N5589 X.3437 Y1.4605 Z-1.317
    N5590 X.3558 Y1.459 Z-1.3172
    N5591 X.3726 Y1.4583 Z-1.3173
    N5592 X.9906 Z-1.3234
    N5593 X1.0185 Y1.4602 Z-1.3237
    N5594 X1.0412 Y1.465 Z-1.3239
    N5595 X1.0619 Y1.4725 Z-1.3241
    N5596 X1.08 Y1.4821 Z-1.3243
    N5597 X1.0952 Y1.4934 Z-1.3245
    N5598 X1.1064 Y1.5047 Z-1.3246
    N5599 X1.114 Y1.5157 Z-1.3248
    N5600 X1.1186 Y1.5259 Z-1.3249
    N5601 X1.1193 Y1.5288
    N5602 X1.12 Y1.5371 Z-1.325
    N5603 Y1.8828 Z-1.3284
    N5604 G3 X1.0887 Y1.914 Z-1.3289 I-.0313
    N5605 G1 X1.0661 Z-1.3291
    N5606 X1.0428 Z-1.3293
    N5607 X1.019 Z-1.3296
    N5608 X.995 Z-1.3298
    N5609 X.37 Z-1.3359
    N5610 X.346 Z-1.3362
    N5611 X.3222 Z-1.3364
    N5612 X.2989 Z-1.3366
    N5613 X.2762 Z-1.3369
    N5614 X.2681 Y1.9129 Z-1.337
    N5615 X.2606 Y1.9098
    N5616 X.2541 Y1.9049 Z-1.3371
    N5617 X.2492 Y1.8984 Z-1.3372
    N5618 X.2461 Y1.8909
    N5619 X.245 Y1.8828 Z-1.3373
    N5620 Y1.539 Z-1.3407
    N5621 X.2464 Y1.5272 Z-1.3408
    N5622 X.2489 Y1.5198 Z-1.3409
    N5623 X.2547 Y1.5098 Z-1.341
    N5624 X.2647 Y1.4981 Z-1.3412
    N5625 X.2791 Y1.4861 Z-1.3413
    N5626 X.2974 Y1.4752 Z-1.3416
    N5627 X.3185 Y1.4667 Z-1.3418
    N5628 X.3437 Y1.4605 Z-1.342
    N5629 X.3558 Y1.459 Z-1.3422
    N5630 X.3726 Y1.4583 Z-1.3423
    N5631 X.9906 Z-1.3484
    N5632 X1.0185 Y1.4602 Z-1.3487
    N5633 X1.0412 Y1.465 Z-1.3489
    N5634 X1.0619 Y1.4725 Z-1.3491
    N5635 X1.08 Y1.4821 Z-1.3493
    N5636 X1.0952 Y1.4934 Z-1.3495
    N5637 X1.1064 Y1.5047 Z-1.3496
    N5638 X1.114 Y1.5157 Z-1.3498
    N5639 X1.1186 Y1.5259 Z-1.3499
    N5640 X1.1193 Y1.5288
    N5641 X1.12 Y1.5371 Z-1.35
    N5642 Y1.8828 Z-1.3534
    N5643 G3 X1.0887 Y1.914 Z-1.3539 I-.0313
    N5644 G1 X1.0661 Z-1.3541
    N5645 X1.0428 Z-1.3543
    N5646 X1.019 Z-1.3546
    N5647 X.995 Z-1.3548
    N5648 X.37 Z-1.3609
    N5649 X.346 Z-1.3612
    N5650 X.3222 Z-1.3614
    N5651 X.2989 Z-1.3616
    N5652 X.2762 Z-1.3619
    N5653 X.2681 Y1.9129 Z-1.362
    N5654 X.2606 Y1.9098
    N5655 X.2541 Y1.9049 Z-1.3621
    N5656 X.2492 Y1.8984 Z-1.3622
    N5657 X.2461 Y1.8909
    N5658 X.245 Y1.8828 Z-1.3623
    N5659 Y1.539 Z-1.3657
    N5660 X.2464 Y1.5272 Z-1.3658
    N5661 X.2489 Y1.5198 Z-1.3659
    N5662 X.2547 Y1.5098 Z-1.366
    N5663 X.2647 Y1.4981 Z-1.3662
    N5664 X.2791 Y1.4861 Z-1.3663
    N5665 X.2974 Y1.4752 Z-1.3666
    N5666 X.3185 Y1.4667 Z-1.3668
    N5667 X.3437 Y1.4605 Z-1.367
    N5668 X.3558 Y1.459 Z-1.3672
    N5669 X.3726 Y1.4583 Z-1.3673
    N5670 X.9906 Z-1.3734
    N5671 X1.0185 Y1.4602 Z-1.3737
    N5672 X1.0412 Y1.465 Z-1.3739
    N5673 X1.0619 Y1.4725 Z-1.3741
    N5674 X1.08 Y1.4821 Z-1.3743
    N5675 X1.0952 Y1.4934 Z-1.3745
    N5676 X1.1064 Y1.5047 Z-1.3746
    N5677 X1.114 Y1.5157 Z-1.3748
    N5678 X1.1186 Y1.5259 Z-1.3749
    N5679 X1.1193 Y1.5288
    N5680 X1.12 Y1.5371 Z-1.375
    N5681 Y1.8828 Z-1.3784
    N5682 G3 X1.0887 Y1.914 Z-1.3789 I-.0313
    N5683 G1 X1.0661 Z-1.3791
    N5684 X1.0428 Z-1.3793
    N5685 X1.019 Z-1.3796
    N5686 X.995 Z-1.3798
    N5687 X.37 Z-1.3859
    N5688 X.346 Z-1.3862
    N5689 X.3222 Z-1.3864
    N5690 X.2989 Z-1.3866
    N5691 X.2762 Z-1.3869
    N5692 X.2681 Y1.9129 Z-1.387
    N5693 X.2606 Y1.9098
    N5694 X.2541 Y1.9049 Z-1.3871
    N5695 X.2492 Y1.8984 Z-1.3872
    N5696 X.2461 Y1.8909
    N5697 X.245 Y1.8828 Z-1.3873
    N5698 Y1.539 Z-1.3907
    N5699 X.2464 Y1.5272 Z-1.3908
    N5700 X.2489 Y1.5198 Z-1.3909
    N5701 X.2547 Y1.5098 Z-1.391
    N5702 X.2647 Y1.4981 Z-1.3912
    N5703 X.2791 Y1.4861 Z-1.3913
    N5704 X.2974 Y1.4752 Z-1.3916
    N5705 X.3185 Y1.4667 Z-1.3918
    N5706 X.3437 Y1.4605 Z-1.392
    N5707 X.3558 Y1.459 Z-1.3922
    N5708 X.3726 Y1.4583 Z-1.3923
    N5709 X.9906 Z-1.3984
    N5710 X1.0185 Y1.4602 Z-1.3987
    N5711 X1.0412 Y1.465 Z-1.3989
    N5712 X1.0619 Y1.4725 Z-1.3991
    N5713 X1.08 Y1.4821 Z-1.3993
    N5714 X1.0952 Y1.4934 Z-1.3995
    N5715 X1.1064 Y1.5047 Z-1.3996
    N5716 X1.114 Y1.5157 Z-1.3998
    N5717 X1.1186 Y1.5259 Z-1.3999
    N5718 X1.1193 Y1.5288
    N5719 X1.12 Y1.5371 Z-1.4
    N5720 Y1.8828 Z-1.4034
    N5721 G3 X1.0887 Y1.914 Z-1.4039 I-.0313
    N5722 G1 X1.0661 Z-1.4041
    N5723 X1.0428 Z-1.4043
    N5724 X1.019 Z-1.4046
    N5725 X.995 Z-1.4048
    N5726 X.37 Z-1.4109
    N5727 X.346 Z-1.4112
    N5728 X.3222 Z-1.4114
    N5729 X.2989 Z-1.4116
    N5730 X.2762 Z-1.4119
    N5731 X.2681 Y1.9129 Z-1.412
    N5732 X.2606 Y1.9098
    N5733 X.2541 Y1.9049 Z-1.4121
    N5734 X.2492 Y1.8984 Z-1.4122
    N5735 X.2461 Y1.8909
    N5736 X.245 Y1.8828 Z-1.4123
    N5737 Y1.539 Z-1.4157
    N5738 X.2464 Y1.5272 Z-1.4158
    N5739 X.2489 Y1.5198 Z-1.4159
    N5740 X.2547 Y1.5098 Z-1.416
    N5741 X.2647 Y1.4981 Z-1.4162
    N5742 X.2791 Y1.4861 Z-1.4163
    N5743 X.2974 Y1.4752 Z-1.4166
    N5744 X.3185 Y1.4667 Z-1.4168
    N5745 X.3437 Y1.4605 Z-1.417
    N5746 X.3558 Y1.459 Z-1.4172
    N5747 X.3726 Y1.4583 Z-1.4173
    N5748 X.9906 Z-1.4234
    N5749 X1.0185 Y1.4602 Z-1.4237
    N5750 X1.0412 Y1.465 Z-1.4239
    N5751 X1.0619 Y1.4725 Z-1.4241
    N5752 X1.08 Y1.4821 Z-1.4243
    N5753 X1.0952 Y1.4934 Z-1.4245
    N5754 X1.1064 Y1.5047 Z-1.4246
    N5755 X1.114 Y1.5157 Z-1.4248
    N5756 X1.1186 Y1.5259 Z-1.4249
    N5757 X1.1193 Y1.5288
    N5758 X1.12 Y1.5371 Z-1.425
    N5759 Y1.8828 Z-1.4284
    N5760 G3 X1.0887 Y1.914 Z-1.4289 I-.0313
    N5761 G1 X1.0661 Z-1.4291
    N5762 X1.0428 Z-1.4293
    N5763 X1.019 Z-1.4296
    N5764 X.995 Z-1.4298
    N5765 X.37 Z-1.4359
    N5766 X.346 Z-1.4362
    N5767 X.3222 Z-1.4364
    N5768 X.2989 Z-1.4366
    N5769 X.2762 Z-1.4369
    N5770 X.2681 Y1.9129 Z-1.437
    N5771 X.2606 Y1.9098
    N5772 X.2541 Y1.9049 Z-1.4371
    N5773 X.2492 Y1.8984 Z-1.4372
    N5774 X.2461 Y1.8909
    N5775 X.245 Y1.8828 Z-1.4373
    N5776 Y1.539 Z-1.4407
    N5777 X.2464 Y1.5272 Z-1.4408
    N5778 X.2489 Y1.5198 Z-1.4409
    N5779 X.2547 Y1.5098 Z-1.441
    N5780 X.2647 Y1.4981 Z-1.4412
    N5781 X.2791 Y1.4861 Z-1.4413
    N5782 X.2974 Y1.4752 Z-1.4416
    N5783 X.3185 Y1.4667 Z-1.4418
    N5784 X.3437 Y1.4605 Z-1.442
    N5785 X.3558 Y1.459 Z-1.4422
    N5786 X.3726 Y1.4583 Z-1.4423
    N5787 X.9906 Z-1.4484
    N5788 X1.0185 Y1.4602 Z-1.4487
    N5789 X1.0412 Y1.465 Z-1.4489
    N5790 X1.0619 Y1.4725 Z-1.4491
    N5791 X1.08 Y1.4821 Z-1.4493
    N5792 X1.0952 Y1.4934 Z-1.4495
    N5793 X1.1064 Y1.5047 Z-1.4496
    N5794 X1.114 Y1.5157 Z-1.4498
    N5795 X1.1186 Y1.5259 Z-1.4499
    N5796 X1.1193 Y1.5288
    N5797 X1.12 Y1.5371 Z-1.45
    N5798 Y1.8828 Z-1.4534
    N5799 G3 X1.0887 Y1.914 Z-1.4539 I-.0313
    N5800 G1 X1.0661 Z-1.4541
    N5801 X1.0428 Z-1.4543
    N5802 X1.019 Z-1.4546
    N5803 X.995 Z-1.4548
    N5804 X.37 Z-1.4609
    N5805 X.346 Z-1.4612
    N5806 X.3222 Z-1.4614
    N5807 X.2989 Z-1.4616
    N5808 X.2762 Z-1.4619
    N5809 X.2681 Y1.9129 Z-1.462
    N5810 X.2606 Y1.9098
    N5811 X.2541 Y1.9049 Z-1.4621
    N5812 X.2492 Y1.8984 Z-1.4622
    N5813 X.2461 Y1.8909
    N5814 X.245 Y1.8828 Z-1.4623
    N5815 Y1.539 Z-1.4657
    N5816 X.2464 Y1.5272 Z-1.4658
    N5817 X.2489 Y1.5198 Z-1.4659
    N5818 X.2547 Y1.5098 Z-1.466
    N5819 X.2647 Y1.4981 Z-1.4662
    N5820 X.2791 Y1.4861 Z-1.4663
    N5821 X.2974 Y1.4752 Z-1.4666
    N5822 X.3185 Y1.4667 Z-1.4668
    N5823 X.3437 Y1.4605 Z-1.467
    N5824 X.3558 Y1.459 Z-1.4672
    N5825 X.3726 Y1.4583 Z-1.4673
    N5826 X.9906 Z-1.4734
    N5827 X1.0185 Y1.4602 Z-1.4737
    N5828 X1.0412 Y1.465 Z-1.4739
    N5829 X1.0619 Y1.4725 Z-1.4741
    N5830 X1.08 Y1.4821 Z-1.4743
    N5831 X1.0952 Y1.4934 Z-1.4745
    N5832 X1.1064 Y1.5047 Z-1.4746
    N5833 X1.114 Y1.5157 Z-1.4748
    N5834 X1.1186 Y1.5259 Z-1.4749
    N5835 X1.1193 Y1.5288
    N5836 X1.12 Y1.5371 Z-1.475
    N5837 Y1.8828 Z-1.4784
    N5838 G3 X1.0887 Y1.914 Z-1.4789 I-.0313
    N5839 G1 X1.0661 Z-1.4791
    N5840 X1.0428 Z-1.4793
    N5841 X1.019 Z-1.4796
    N5842 X.995 Z-1.4798
    N5843 X.37 Z-1.4859
    N5844 X.346 Z-1.4862
    N5845 X.3222 Z-1.4864
    N5846 X.2989 Z-1.4866
    N5847 X.2762 Z-1.4869
    N5848 X.2681 Y1.9129 Z-1.487
    N5849 X.2606 Y1.9098
    N5850 X.2541 Y1.9049 Z-1.4871
    N5851 X.2492 Y1.8984 Z-1.4872
    N5852 X.2461 Y1.8909
    N5853 X.245 Y1.8828 Z-1.4873
    N5854 Y1.539 Z-1.4907
    N5855 X.2464 Y1.5272 Z-1.4908
    N5856 X.2489 Y1.5198 Z-1.4909
    N5857 X.2547 Y1.5098 Z-1.491
    N5858 X.2647 Y1.4981 Z-1.4912
    N5859 X.2791 Y1.4861 Z-1.4913
    N5860 X.2974 Y1.4752 Z-1.4916
    N5861 X.3185 Y1.4667 Z-1.4918
    N5862 X.3437 Y1.4605 Z-1.492
    N5863 X.3558 Y1.459 Z-1.4922
    N5864 X.3726 Y1.4583 Z-1.4923
    N5865 X.9906 Z-1.4984
    N5866 X1.0185 Y1.4602 Z-1.4987
    N5867 X1.0412 Y1.465 Z-1.4989
    N5868 X1.0619 Y1.4725 Z-1.4991
    N5869 X1.08 Y1.4821 Z-1.4993
    N5870 X1.0952 Y1.4934 Z-1.4995
    N5871 X1.1064 Y1.5047 Z-1.4996
    N5872 X1.114 Y1.5157 Z-1.4998
    N5873 X1.1186 Y1.5259 Z-1.4999
    N5874 X1.1193 Y1.5288
    N5875 X1.12 Y1.5371 Z-1.5
    N5876 Y1.8828 Z-1.5034
    N5877 G3 X1.0887 Y1.914 Z-1.5039 I-.0313
    N5878 G1 X1.0661 Z-1.5041
    N5879 X1.0428 Z-1.5043
    N5880 X1.019 Z-1.5046
    N5881 X.995 Z-1.5048
    N5882 X.37 Z-1.5109
    N5883 X.346 Z-1.5112
    N5884 X.3222 Z-1.5114
    N5885 X.2989 Z-1.5116
    N5886 X.2762 Z-1.5119
    N5887 X.2681 Y1.9129 Z-1.512
    N5888 X.2606 Y1.9098
    N5889 X.2541 Y1.9049 Z-1.5121
    N5890 X.2492 Y1.8984 Z-1.5122
    N5891 X.2461 Y1.8909
    N5892 X.245 Y1.8828 Z-1.5123
    N5893 Y1.539 Z-1.5157
    N5894 X.2464 Y1.5272 Z-1.5158
    N5895 X.2489 Y1.5198 Z-1.5159
    N5896 X.2547 Y1.5098 Z-1.516
    N5897 X.2647 Y1.4981 Z-1.5162
    N5898 X.2791 Y1.4861 Z-1.5163
    N5899 X.2974 Y1.4752 Z-1.5166
    N5900 X.3185 Y1.4667 Z-1.5168
    N5901 X.3437 Y1.4605 Z-1.517
    N5902 X.3558 Y1.459 Z-1.5172
    N5903 X.3726 Y1.4583 Z-1.5173
    N5904 X.9906 Z-1.5234
    N5905 X1.0185 Y1.4602 Z-1.5237
    N5906 X1.0412 Y1.465 Z-1.5239
    N5907 X1.0619 Y1.4725 Z-1.5241
    N5908 X1.08 Y1.4821 Z-1.5243
    N5909 X1.0952 Y1.4934 Z-1.5245
    N5910 X1.1064 Y1.5047 Z-1.5246
    N5911 X1.114 Y1.5157 Z-1.5248
    N5912 X1.1186 Y1.5259 Z-1.5249
    N5913 X1.1193 Y1.5288
    N5914 X1.12 Y1.5371 Z-1.525
    N5915 Y1.8828 Z-1.5284
    N5916 G3 X1.0887 Y1.914 Z-1.5289 I-.0313
    N5917 G1 X1.0661 Z-1.5291
    N5918 X1.0428 Z-1.5293
    N5919 X1.019 Z-1.5296
    N5920 X.995 Z-1.5298
    N5921 X.37 Z-1.5359
    N5922 X.346 Z-1.5362
    N5923 X.3222 Z-1.5364
    N5924 X.2989 Z-1.5366
    N5925 X.2762 Z-1.5369
    N5926 X.2681 Y1.9129 Z-1.537
    N5927 X.2606 Y1.9098
    N5928 X.2541 Y1.9049 Z-1.5371
    N5929 X.2492 Y1.8984 Z-1.5372
    N5930 X.2461 Y1.8909
    N5931 X.245 Y1.8828 Z-1.5373
    N5932 Y1.539 Z-1.5407
    N5933 X.2464 Y1.5272 Z-1.5408
    N5934 X.2489 Y1.5198 Z-1.5409
    N5935 X.2547 Y1.5098 Z-1.541
    N5936 X.2647 Y1.4981 Z-1.5412
    N5937 X.2791 Y1.4861 Z-1.5413
    N5938 X.2974 Y1.4752 Z-1.5416
    N5939 X.3185 Y1.4667 Z-1.5418
    N5940 X.3437 Y1.4605 Z-1.542
    N5941 X.3558 Y1.459 Z-1.5422
    N5942 X.3726 Y1.4583 Z-1.5423
    N5943 X.9906 Z-1.5484
    N5944 X1.0185 Y1.4602 Z-1.5487
    N5945 X1.0412 Y1.465 Z-1.5489
    N5946 X1.0619 Y1.4725 Z-1.5491
    N5947 X1.08 Y1.4821 Z-1.5493
    N5948 X1.0952 Y1.4934 Z-1.5495
    N5949 X1.1064 Y1.5047 Z-1.5496
    N5950 X1.114 Y1.5157 Z-1.5498
    N5951 X1.1186 Y1.5259 Z-1.5499
    N5952 X1.1193 Y1.5288
    N5953 X1.12 Y1.5371 Z-1.55
    N5954 Y1.8828 Z-1.5534
    N5955 G3 X1.0887 Y1.914 Z-1.5539 I-.0313
    N5956 G1 X1.0661 Z-1.5541
    N5957 X1.0428 Z-1.5543
    N5958 X1.019 Z-1.5546
    N5959 X.995 Z-1.5548
    N5960 X.37 Z-1.5609
    N5961 X.346 Z-1.5612
    N5962 X.3222 Z-1.5614
    N5963 X.2989 Z-1.5616
    N5964 X.2762 Z-1.5619
    N5965 X.2681 Y1.9129 Z-1.562
    N5966 X.2606 Y1.9098
    N5967 X.2541 Y1.9049 Z-1.5621
    N5968 X.2492 Y1.8984 Z-1.5622
    N5969 X.2461 Y1.8909
    N5970 X.245 Y1.8828 Z-1.5623
    N5971 Y1.539 Z-1.5657
    N5972 X.2464 Y1.5272 Z-1.5658
    N5973 X.2489 Y1.5198 Z-1.5659
    N5974 X.2547 Y1.5098 Z-1.566
    N5975 X.2647 Y1.4981 Z-1.5662
    N5976 X.2791 Y1.4861 Z-1.5663
    N5977 X.2974 Y1.4752 Z-1.5666
    N5978 X.3185 Y1.4667 Z-1.5668
    N5979 X.3437 Y1.4605 Z-1.567
    N5980 X.3558 Y1.459 Z-1.5672
    N5981 X.3726 Y1.4583 Z-1.5673
    N5982 X.9906 Z-1.5734
    N5983 X1.0185 Y1.4602 Z-1.5737
    N5984 X1.0412 Y1.465 Z-1.5739
    N5985 X1.0619 Y1.4725 Z-1.5741
    N5986 X1.08 Y1.4821 Z-1.5743
    N5987 X1.0952 Y1.4934 Z-1.5745
    N5988 X1.1064 Y1.5047 Z-1.5746
    N5989 X1.114 Y1.5157 Z-1.5748
    N5990 X1.1186 Y1.5259 Z-1.5749
    N5991 X1.1193 Y1.5288
    N5992 X1.12 Y1.5371 Z-1.575
    N5993 Y1.8828 Z-1.5784
    N5994 G3 X1.0887 Y1.914 Z-1.5789 I-.0313
    N5995 G1 X1.0661 Z-1.5791
    N5996 X1.0428 Z-1.5793
    N5997 X1.019 Z-1.5796
    N5998 X.995 Z-1.5798
    N5999 X.37 Z-1.5859
    N6000 X.346 Z-1.5862
    N6001 X.3222 Z-1.5864
    N6002 X.2989 Z-1.5866
    N6003 X.2762 Z-1.5869
    N6004 X.2681 Y1.9129 Z-1.587
    N6005 X.2606 Y1.9098
    N6006 X.2541 Y1.9049 Z-1.5871
    N6007 X.2492 Y1.8984 Z-1.5872
    N6008 X.2461 Y1.8909
    N6009 X.245 Y1.8828 Z-1.5873
    N6010 Y1.539 Z-1.5907
    N6011 X.2464 Y1.5272 Z-1.5908
    N6012 X.2489 Y1.5198 Z-1.5909
    N6013 X.2547 Y1.5098 Z-1.591
    N6014 X.2647 Y1.4981 Z-1.5912
    N6015 X.2791 Y1.4861 Z-1.5913
    N6016 X.2974 Y1.4752 Z-1.5916
    N6017 X.3185 Y1.4667 Z-1.5918
    N6018 X.3437 Y1.4605 Z-1.592
    N6019 X.3558 Y1.459 Z-1.5922
    N6020 X.3726 Y1.4583 Z-1.5923
    N6021 X.9906 Z-1.5984
    N6022 X1.0185 Y1.4602 Z-1.5987
    N6023 X1.0412 Y1.465 Z-1.5989
    N6024 X1.0619 Y1.4725 Z-1.5991
    N6025 X1.08 Y1.4821 Z-1.5993
    N6026 X1.0952 Y1.4934 Z-1.5995
    N6027 X1.1064 Y1.5047 Z-1.5996
    N6028 X1.114 Y1.5157 Z-1.5998
    N6029 X1.1186 Y1.5259 Z-1.5999
    N6030 X1.1193 Y1.5288
    N6031 X1.12 Y1.5371 Z-1.6
    N6032 Y1.8828 Z-1.6034
    N6033 G3 X1.0887 Y1.914 Z-1.6039 I-.0313
    N6034 G1 X1.0661 Z-1.6041
    N6035 X1.0428 Z-1.6043
    N6036 X1.019 Z-1.6046
    N6037 X.995 Z-1.6048
    N6038 X.37 Z-1.6109
    N6039 X.346 Z-1.6112
    N6040 X.3222 Z-1.6114
    N6041 X.2989 Z-1.6116
    N6042 X.2762 Z-1.6119
    N6043 X.2681 Y1.9129 Z-1.612
    N6044 X.2606 Y1.9098
    N6045 X.2541 Y1.9049 Z-1.6121
    N6046 X.2492 Y1.8984 Z-1.6122
    N6047 X.2461 Y1.8909
    N6048 X.245 Y1.8828 Z-1.6123
    N6049 Y1.539 Z-1.6157
    N6050 X.2464 Y1.5272 Z-1.6158
    N6051 X.2489 Y1.5198 Z-1.6159
    N6052 X.2547 Y1.5098 Z-1.616
    N6053 X.2647 Y1.4981 Z-1.6162
    N6054 X.2791 Y1.4861 Z-1.6163
    N6055 X.2974 Y1.4752 Z-1.6166
    N6056 X.3185 Y1.4667 Z-1.6168
    N6057 X.3437 Y1.4605 Z-1.617
    N6058 X.3558 Y1.459 Z-1.6172
    N6059 X.3726 Y1.4583 Z-1.6173
    N6060 X.9906 Z-1.6234
    N6061 X1.0185 Y1.4602 Z-1.6237
    N6062 X1.0412 Y1.465 Z-1.6239
    N6063 X1.0619 Y1.4725 Z-1.6241
    N6064 X1.08 Y1.4821 Z-1.6243
    N6065 X1.0952 Y1.4934 Z-1.6245
    N6066 X1.1064 Y1.5047 Z-1.6246
    N6067 X1.114 Y1.5157 Z-1.6248
    N6068 X1.1186 Y1.5259 Z-1.6249
    N6069 X1.1193 Y1.5288
    N6070 X1.12 Y1.5371 Z-1.625
    N6071 Y1.8828 Z-1.6284
    N6072 G3 X1.0887 Y1.914 Z-1.6289 I-.0313
    N6073 G1 X1.0661 Z-1.6291
    N6074 X1.0428 Z-1.6293
    N6075 X1.019 Z-1.6296
    N6076 X.995 Z-1.6298
    N6077 X.37 Z-1.6359
    N6078 X.346 Z-1.6362
    N6079 X.3222 Z-1.6364
    N6080 X.2989 Z-1.6366
    N6081 X.2762 Z-1.6369
    N6082 X.2681 Y1.9129 Z-1.637
    N6083 X.2606 Y1.9098
    N6084 X.2541 Y1.9049 Z-1.6371
    N6085 X.2492 Y1.8984 Z-1.6372
    N6086 X.2461 Y1.8909
    N6087 X.245 Y1.8828 Z-1.6373
    N6088 Y1.539 Z-1.6407
    N6089 X.2464 Y1.5272 Z-1.6408
    N6090 X.2489 Y1.5198 Z-1.6409
    N6091 X.2547 Y1.5098 Z-1.641
    N6092 X.2647 Y1.4981 Z-1.6412
    N6093 X.2791 Y1.4861 Z-1.6413
    N6094 X.2974 Y1.4752 Z-1.6416
    N6095 X.3185 Y1.4667 Z-1.6418
    N6096 X.3437 Y1.4605 Z-1.642
    N6097 X.3558 Y1.459 Z-1.6422
    N6098 X.3726 Y1.4583 Z-1.6423
    N6099 X.9906 Z-1.6484
    N6100 X1.0185 Y1.4602 Z-1.6487
    N6101 X1.0412 Y1.465 Z-1.6489
    N6102 X1.0619 Y1.4725 Z-1.6491
    N6103 X1.08 Y1.4821 Z-1.6493
    N6104 X1.0952 Y1.4934 Z-1.6495
    N6105 X1.1064 Y1.5047 Z-1.6496
    N6106 X1.114 Y1.5157 Z-1.6498
    N6107 X1.1186 Y1.5259 Z-1.6499
    N6108 X1.1193 Y1.5288
    N6109 X1.12 Y1.5371 Z-1.65
    N6110 Y1.8828 Z-1.6534
    N6111 G3 X1.0887 Y1.914 Z-1.6539 I-.0313
    N6112 G1 X1.0661 Z-1.6541
    N6113 X1.0428 Z-1.6543
    N6114 X1.019 Z-1.6546
    N6115 X.995 Z-1.6548
    N6116 X.37 Z-1.6609
    N6117 X.346 Z-1.6612
    N6118 X.3222 Z-1.6614
    N6119 X.2989 Z-1.6616
    N6120 X.2762 Z-1.6619
    N6121 X.2681 Y1.9129 Z-1.662
    N6122 X.2606 Y1.9098
    N6123 X.2541 Y1.9049 Z-1.6621
    N6124 X.2492 Y1.8984 Z-1.6622
    N6125 X.2461 Y1.8909
    N6126 X.245 Y1.8828 Z-1.6623
    N6127 Y1.539 Z-1.6657
    N6128 X.2464 Y1.5272 Z-1.6658
    N6129 X.2489 Y1.5198 Z-1.6659
    N6130 X.2547 Y1.5098 Z-1.666
    N6131 X.2647 Y1.4981 Z-1.6662
    N6132 X.2791 Y1.4861 Z-1.6663
    N6133 X.2974 Y1.4752 Z-1.6666
    N6134 X.3185 Y1.4667 Z-1.6668
    N6135 X.3437 Y1.4605 Z-1.667
    N6136 X.3558 Y1.459 Z-1.6672
    N6137 X.3726 Y1.4583 Z-1.6673
    N6138 X.9906 Z-1.6734
    N6139 X1.0185 Y1.4602 Z-1.6737
    N6140 X1.0412 Y1.465 Z-1.6739
    N6141 X1.0619 Y1.4725 Z-1.6741
    N6142 X1.08 Y1.4821 Z-1.6743
    N6143 X1.0952 Y1.4934 Z-1.6745
    N6144 X1.1064 Y1.5047 Z-1.6746
    N6145 X1.114 Y1.5157 Z-1.6748
    N6146 X1.1186 Y1.5259 Z-1.6749
    N6147 X1.1193 Y1.5288
    N6148 X1.12 Y1.5371 Z-1.675
    N6149 Y1.8828 Z-1.6784
    N6150 G3 X1.0887 Y1.914 Z-1.6789 I-.0313
    N6151 G1 X1.0661 Z-1.6791
    N6152 X1.0428 Z-1.6793
    N6153 X1.019 Z-1.6796
    N6154 X.995 Z-1.6798
    N6155 X.37 Z-1.6859
    N6156 X.346 Z-1.6862
    N6157 X.3222 Z-1.6864
    N6158 X.2989 Z-1.6866
    N6159 X.2762 Z-1.6869
    N6160 X.2681 Y1.9129 Z-1.687
    N6161 X.2606 Y1.9098
    N6162 X.2541 Y1.9049 Z-1.6871
    N6163 X.2492 Y1.8984 Z-1.6872
    N6164 X.2461 Y1.8909
    N6165 X.245 Y1.8828 Z-1.6873
    N6166 Y1.539 Z-1.6907
    N6167 X.2464 Y1.5272 Z-1.6908
    N6168 X.2489 Y1.5198 Z-1.6909
    N6169 X.2547 Y1.5098 Z-1.691
    N6170 X.2647 Y1.4981 Z-1.6912
    N6171 X.2791 Y1.4861 Z-1.6913
    N6172 X.2974 Y1.4752 Z-1.6916
    N6173 X.3185 Y1.4667 Z-1.6918
    N6174 X.3437 Y1.4605 Z-1.692
    N6175 X.3558 Y1.459 Z-1.6922
    N6176 X.3726 Y1.4583 Z-1.6923
    N6177 X.9906 Z-1.6984
    N6178 X1.0185 Y1.4602 Z-1.6987
    N6179 X1.0412 Y1.465 Z-1.6989
    N6180 X1.0619 Y1.4725 Z-1.6991
    N6181 X1.08 Y1.4821 Z-1.6993
    N6182 X1.0952 Y1.4934 Z-1.6995
    N6183 X1.1064 Y1.5047 Z-1.6996
    N6184 X1.114 Y1.5157 Z-1.6998
    N6185 X1.1186 Y1.5259 Z-1.6999
    N6186 X1.1193 Y1.5288
    N6187 X1.12 Y1.5371 Z-1.7
    N6188 Y1.8828 Z-1.7034
    N6189 G3 X1.0887 Y1.914 Z-1.7039 I-.0313
    N6190 G1 X1.0661 Z-1.7041
    N6191 X1.0428 Z-1.7043
    N6192 X1.019 Z-1.7046
    N6193 X.995 Z-1.7048
    N6194 X.37 Z-1.7109
    N6195 X.346 Z-1.7112
    N6196 X.3222 Z-1.7114
    N6197 X.2989 Z-1.7116
    N6198 X.2762 Z-1.7119
    N6199 X.2681 Y1.9129 Z-1.712
    N6200 X.2606 Y1.9098
    N6201 X.2541 Y1.9049 Z-1.7121
    N6202 X.2492 Y1.8984 Z-1.7122
    N6203 X.2461 Y1.8909
    N6204 X.245 Y1.8828 Z-1.7123
    N6205 Y1.539 Z-1.7157
    N6206 X.2464 Y1.5272 Z-1.7158
    N6207 X.2489 Y1.5198 Z-1.7159
    N6208 X.2547 Y1.5098 Z-1.716
    N6209 X.2647 Y1.4981 Z-1.7162
    N6210 X.2791 Y1.4861 Z-1.7163
    N6211 X.2974 Y1.4752 Z-1.7166
    N6212 X.3185 Y1.4667 Z-1.7168
    N6213 X.3437 Y1.4605 Z-1.717
    N6214 X.3558 Y1.459 Z-1.7172
    N6215 X.3726 Y1.4583 Z-1.7173
    N6216 X.9906 Z-1.7234
    N6217 X1.0185 Y1.4602 Z-1.7237
    N6218 X1.0412 Y1.465 Z-1.7239
    N6219 X1.0619 Y1.4725 Z-1.7241
    N6220 X1.08 Y1.4821 Z-1.7243
    N6221 X1.0952 Y1.4934 Z-1.7245
    N6222 X1.1064 Y1.5047 Z-1.7246
    N6223 X1.114 Y1.5157 Z-1.7248
    N6224 X1.1186 Y1.5259 Z-1.7249
    N6225 X1.1193 Y1.5288
    N6226 X1.12 Y1.5371 Z-1.725
    N6227 Y1.8828 Z-1.7284
    N6228 G3 X1.0887 Y1.914 Z-1.7289 I-.0313
    N6229 G1 X1.0661 Z-1.7291
    N6230 X1.0428 Z-1.7293
    N6231 X1.019 Z-1.7296
    N6232 X.995 Z-1.7298
    N6233 X.37 Z-1.7359
    N6234 X.346 Z-1.7362
    N6235 X.3222 Z-1.7364
    N6236 X.2989 Z-1.7366
    N6237 X.2762 Z-1.7369
    N6238 X.2681 Y1.9129 Z-1.737
    N6239 X.2606 Y1.9098
    N6240 X.2541 Y1.9049 Z-1.7371
    N6241 X.2492 Y1.8984 Z-1.7372
    N6242 X.2461 Y1.8909
    N6243 X.245 Y1.8828 Z-1.7373
    N6244 Y1.539 Z-1.7407
    N6245 X.2464 Y1.5272 Z-1.7408
    N6246 X.2489 Y1.5198 Z-1.7409
    N6247 X.2547 Y1.5098 Z-1.741
    N6248 X.2647 Y1.4981 Z-1.7412
    N6249 X.2791 Y1.4861 Z-1.7413
    N6250 X.2974 Y1.4752 Z-1.7416
    N6251 X.3185 Y1.4667 Z-1.7418
    N6252 X.3437 Y1.4605 Z-1.742
    N6253 X.3558 Y1.459 Z-1.7422
    N6254 X.3726 Y1.4583 Z-1.7423
    N6255 X.9906 Z-1.7484
    N6256 X1.0185 Y1.4602 Z-1.7487
    N6257 X1.0412 Y1.465 Z-1.7489
    N6258 X1.0619 Y1.4725 Z-1.7491
    N6259 X1.08 Y1.4821 Z-1.7493
    N6260 X1.0952 Y1.4934 Z-1.7495
    N6261 X1.1064 Y1.5047 Z-1.7496
    N6262 X1.114 Y1.5157 Z-1.7498
    N6263 X1.1186 Y1.5259 Z-1.7499
    N6264 X1.1193 Y1.5288
    N6265 X1.12 Y1.5371 Z-1.75
    N6266 Y1.8828 Z-1.7534
    N6267 G3 X1.0887 Y1.914 Z-1.7539 I-.0313
    N6268 G1 X1.0661 Z-1.7541
    N6269 X1.0428 Z-1.7543
    N6270 X1.019 Z-1.7546
    N6271 X.995 Z-1.7548
    N6272 X.37 Z-1.7609
    N6273 X.346 Z-1.7612
    N6274 X.3222 Z-1.7614
    N6275 X.2989 Z-1.7616
    N6276 X.2762 Z-1.7619
    N6277 X.2681 Y1.9129 Z-1.762
    N6278 X.2606 Y1.9098
    N6279 X.2541 Y1.9049 Z-1.7621
    N6280 X.2492 Y1.8984 Z-1.7622
    N6281 X.2461 Y1.8909
    N6282 X.245 Y1.8828 Z-1.7623
    N6283 Y1.539 Z-1.7657
    N6284 X.2464 Y1.5272 Z-1.7658
    N6285 X.2489 Y1.5198 Z-1.7659
    N6286 X.2547 Y1.5098 Z-1.766
    N6287 X.2647 Y1.4981 Z-1.7662
    N6288 X.2791 Y1.4861 Z-1.7663
    N6289 X.2974 Y1.4752 Z-1.7666
    N6290 X.3185 Y1.4667 Z-1.7668
    N6291 X.3437 Y1.4605 Z-1.767
    N6292 X.3558 Y1.459 Z-1.7672
    N6293 X.3726 Y1.4583 Z-1.7673
    N6294 X.9906 Z-1.7734
    N6295 X1.0185 Y1.4602 Z-1.7737
    N6296 X1.0412 Y1.465 Z-1.7739
    N6297 X1.0619 Y1.4725 Z-1.7741
    N6298 X1.08 Y1.4821 Z-1.7743
    N6299 X1.0952 Y1.4934 Z-1.7745
    N6300 X1.1064 Y1.5047 Z-1.7746
    N6301 X1.114 Y1.5157 Z-1.7748
    N6302 X1.1186 Y1.5259 Z-1.7749
    N6303 X1.1193 Y1.5288
    N6304 X1.12 Y1.5371 Z-1.775
    N6305 Y1.8828 Z-1.7784
    N6306 G3 X1.0887 Y1.914 Z-1.7789 I-.0313
    N6307 G1 X1.0661 Z-1.7791
    N6308 X1.0428 Z-1.7793
    N6309 X1.019 Z-1.7796
    N6310 X.995 Z-1.7798
    N6311 X.37 Z-1.7859
    N6312 X.346 Z-1.7862
    N6313 X.3222 Z-1.7864
    N6314 X.2989 Z-1.7866
    N6315 X.2762 Z-1.7869
    N6316 X.2681 Y1.9129 Z-1.787
    N6317 X.2606 Y1.9098
    N6318 X.2541 Y1.9049 Z-1.7871
    N6319 X.2492 Y1.8984 Z-1.7872
    N6320 X.2461 Y1.8909
    N6321 X.245 Y1.8828 Z-1.7873
    N6322 Y1.539 Z-1.7907
    N6323 X.2464 Y1.5272 Z-1.7908
    N6324 X.2489 Y1.5198 Z-1.7909
    N6325 X.2547 Y1.5098 Z-1.791
    N6326 X.2647 Y1.4981 Z-1.7912
    N6327 X.2791 Y1.4861 Z-1.7913
    N6328 X.2974 Y1.4752 Z-1.7916
    N6329 X.3185 Y1.4667 Z-1.7918
    N6330 X.3437 Y1.4605 Z-1.792
    N6331 X.3558 Y1.459 Z-1.7922
    N6332 X.3726 Y1.4583 Z-1.7923
    N6333 X.9906 Z-1.7984
    N6334 X1.0185 Y1.4602 Z-1.7987
    N6335 X1.0412 Y1.465 Z-1.7989
    N6336 X1.0619 Y1.4725 Z-1.7991
    N6337 X1.08 Y1.4821 Z-1.7993
    N6338 X1.0952 Y1.4934 Z-1.7995
    N6339 X1.1064 Y1.5047 Z-1.7996
    N6340 X1.114 Y1.5157 Z-1.7998
    N6341 X1.1186 Y1.5259 Z-1.7999
    N6342 X1.1193 Y1.5288
    N6343 X1.12 Y1.5371 Z-1.8
    N6344 Y1.8828 Z-1.8034
    N6345 G3 X1.0887 Y1.914 Z-1.8039 I-.0313
    N6346 G1 X1.0661 Z-1.8041
    N6347 X1.0428 Z-1.8043
    N6348 X1.019 Z-1.8046
    N6349 X.995 Z-1.8048
    N6350 X.37 Z-1.8109
    N6351 X.346 Z-1.8112
    N6352 X.3222 Z-1.8114
    N6353 X.2989 Z-1.8116
    N6354 X.2762 Z-1.8119
    N6355 X.2681 Y1.9129 Z-1.812
    N6356 X.2606 Y1.9098
    N6357 X.2541 Y1.9049 Z-1.8121
    N6358 X.2492 Y1.8984 Z-1.8122
    N6359 X.2461 Y1.8909
    N6360 X.245 Y1.8828 Z-1.8123
    N6361 Y1.539 Z-1.8157
    N6362 X.2464 Y1.5272 Z-1.8158
    N6363 X.2489 Y1.5198 Z-1.8159
    N6364 X.2547 Y1.5098 Z-1.816
    N6365 X.2647 Y1.4981 Z-1.8162
    N6366 X.2791 Y1.4861 Z-1.8163
    N6367 X.2974 Y1.4752 Z-1.8166
    N6368 X.3185 Y1.4667 Z-1.8168
    N6369 X.3437 Y1.4605 Z-1.817
    N6370 X.3558 Y1.459 Z-1.8172
    N6371 X.3726 Y1.4583 Z-1.8173
    N6372 X.9906 Z-1.8234
    N6373 X1.0185 Y1.4602 Z-1.8237
    N6374 X1.0412 Y1.465 Z-1.8239
    N6375 X1.0619 Y1.4725 Z-1.8241
    N6376 X1.08 Y1.4821 Z-1.8243
    N6377 X1.0952 Y1.4934 Z-1.8245
    N6378 X1.1064 Y1.5047 Z-1.8246
    N6379 X1.114 Y1.5157 Z-1.8248
    N6380 X1.1186 Y1.5259 Z-1.8249
    N6381 X1.1193 Y1.5288
    N6382 X1.12 Y1.5371 Z-1.825
    N6383 Y1.8828 Z-1.8284
    N6384 G3 X1.0887 Y1.914 Z-1.8289 I-.0313
    N6385 G1 X1.0661 Z-1.8291
    N6386 X1.0428 Z-1.8293
    N6387 X1.019 Z-1.8296
    N6388 X.995 Z-1.8298
    N6389 X.37 Z-1.8359
    N6390 X.346 Z-1.8362
    N6391 X.3222 Z-1.8364
    N6392 X.2989 Z-1.8366
    N6393 X.2762 Z-1.8369
    N6394 X.2681 Y1.9129 Z-1.837
    N6395 X.2606 Y1.9098
    N6396 X.2541 Y1.9049 Z-1.8371
    N6397 X.2492 Y1.8984 Z-1.8372
    N6398 X.2461 Y1.8909
    N6399 X.245 Y1.8828 Z-1.8373
    N6400 Y1.539 Z-1.8407
    N6401 X.2464 Y1.5272 Z-1.8408
    N6402 X.2489 Y1.5198 Z-1.8409
    N6403 X.2547 Y1.5098 Z-1.841
    N6404 X.2647 Y1.4981 Z-1.8412
    N6405 X.2791 Y1.4861 Z-1.8413
    N6406 X.2974 Y1.4752 Z-1.8416
    N6407 X.3185 Y1.4667 Z-1.8418
    N6408 X.3437 Y1.4605 Z-1.842
    N6409 X.3558 Y1.459 Z-1.8422
    N6410 X.3726 Y1.4583 Z-1.8423
    N6411 X.9906 Z-1.8484
    N6412 X1.0185 Y1.4602 Z-1.8487
    N6413 X1.0412 Y1.465 Z-1.8489
    N6414 X1.0619 Y1.4725 Z-1.8491
    N6415 X1.08 Y1.4821 Z-1.8493
    N6416 X1.0952 Y1.4934 Z-1.8495
    N6417 X1.1064 Y1.5047 Z-1.8496
    N6418 X1.114 Y1.5157 Z-1.8498
    N6419 X1.1186 Y1.5259 Z-1.8499
    N6420 X1.1193 Y1.5288
    N6421 X1.12 Y1.5371 Z-1.85
    N6422 Y1.8828 Z-1.8534
    N6423 G3 X1.0887 Y1.914 Z-1.8539 I-.0313
    N6424 G1 X1.0661 Z-1.8541
    N6425 X1.0428 Z-1.8543
    N6426 X1.019 Z-1.8546
    N6427 X.995 Z-1.8548
    N6428 X.37 Z-1.8609
    N6429 X.346 Z-1.8612
    N6430 X.3222 Z-1.8614
    N6431 X.2989 Z-1.8616
    N6432 X.2762 Z-1.8619
    N6433 X.2681 Y1.9129 Z-1.862
    N6434 X.2606 Y1.9098
    N6435 X.2541 Y1.9049 Z-1.8621
    N6436 X.2492 Y1.8984 Z-1.8622
    N6437 X.2461 Y1.8909
    N6438 X.245 Y1.8828 Z-1.8623
    N6439 Y1.539 Z-1.8657
    N6440 X.2464 Y1.5272 Z-1.8658
    N6441 X.2489 Y1.5198 Z-1.8659
    N6442 X.2547 Y1.5098 Z-1.866
    N6443 X.2647 Y1.4981 Z-1.8662
    N6444 X.2791 Y1.4861 Z-1.8663
    N6445 X.2974 Y1.4752 Z-1.8666
    N6446 X.3185 Y1.4667 Z-1.8668
    N6447 X.3437 Y1.4605 Z-1.867
    N6448 X.3558 Y1.459 Z-1.8672
    N6449 X.3726 Y1.4583 Z-1.8673
    N6450 X.9906 Z-1.8734
    N6451 X1.0185 Y1.4602 Z-1.8737
    N6452 X1.0412 Y1.465 Z-1.8739
    N6453 X1.0619 Y1.4725 Z-1.8741
    N6454 X1.08 Y1.4821 Z-1.8743
    N6455 X1.0952 Y1.4934 Z-1.8745
    N6456 X1.1064 Y1.5047 Z-1.8746
    N6457 X1.114 Y1.5157 Z-1.8748
    N6458 X1.1186 Y1.5259 Z-1.8749
    N6459 X1.1193 Y1.5288
    N6460 X1.12 Y1.5371 Z-1.875
    N6461 Y1.8828 Z-1.8784
    N6462 G3 X1.0887 Y1.914 Z-1.8789 I-.0313
    N6463 G1 X1.0661 Z-1.8791
    N6464 X1.0428 Z-1.8793
    N6465 X1.019 Z-1.8796
    N6466 X.995 Z-1.8798
    N6467 X.37 Z-1.8859
    N6468 X.346 Z-1.8862
    N6469 X.3222 Z-1.8864
    N6470 X.2989 Z-1.8866
    N6471 X.2762 Z-1.8869
    N6472 X.2681 Y1.9129 Z-1.887
    N6473 X.2606 Y1.9098
    N6474 X.2541 Y1.9049 Z-1.8871
    N6475 X.2492 Y1.8984 Z-1.8872
    N6476 X.2461 Y1.8909
    N6477 X.245 Y1.8828 Z-1.8873
    N6478 Y1.539 Z-1.8907
    N6479 X.2464 Y1.5272 Z-1.8908
    N6480 X.2489 Y1.5198 Z-1.8909
    N6481 X.2547 Y1.5098 Z-1.891
    N6482 X.2647 Y1.4981 Z-1.8912
    N6483 X.2791 Y1.4861 Z-1.8913
    N6484 X.2974 Y1.4752 Z-1.8916
    N6485 X.3185 Y1.4667 Z-1.8918
    N6486 X.3437 Y1.4605 Z-1.892
    N6487 X.3558 Y1.459 Z-1.8922
    N6488 X.3726 Y1.4583 Z-1.8923
    N6489 X.9906 Z-1.8984
    N6490 X1.0185 Y1.4602 Z-1.8987
    N6491 X1.0412 Y1.465 Z-1.8989
    N6492 X1.0619 Y1.4725 Z-1.8991
    N6493 X1.08 Y1.4821 Z-1.8993
    N6494 X1.0952 Y1.4934 Z-1.8995
    N6495 X1.1064 Y1.5047 Z-1.8996
    N6496 X1.114 Y1.5157 Z-1.8998
    N6497 X1.1186 Y1.5259 Z-1.8999
    N6498 X1.1193 Y1.5288
    N6499 X1.12 Y1.5371 Z-1.9
    N6500 Y1.8828 Z-1.9034
    N6501 G3 X1.0887 Y1.914 Z-1.9039 I-.0313
    N6502 G1 X1.0661 Z-1.9041
    N6503 X1.0428 Z-1.9043
    N6504 X1.019 Z-1.9046
    N6505 X.995 Z-1.9048
    N6506 X.37 Z-1.9109
    N6507 X.346 Z-1.9112
    N6508 X.3222 Z-1.9114
    N6509 X.2989 Z-1.9116
    N6510 X.2762 Z-1.9119
    N6511 X.2681 Y1.9129 Z-1.912
    N6512 X.2606 Y1.9098
    N6513 X.2541 Y1.9049 Z-1.9121
    N6514 X.2492 Y1.8984 Z-1.9122
    N6515 X.2461 Y1.8909
    N6516 X.245 Y1.8828 Z-1.9123
    N6517 Y1.539 Z-1.9157
    N6518 X.2464 Y1.5272 Z-1.9158
    N6519 X.2489 Y1.5198 Z-1.9159
    N6520 X.2547 Y1.5098 Z-1.916
    N6521 X.2647 Y1.4981 Z-1.9162
    N6522 X.2791 Y1.4861 Z-1.9163
    N6523 X.2974 Y1.4752 Z-1.9166
    N6524 X.3185 Y1.4667 Z-1.9168
    N6525 X.3437 Y1.4605 Z-1.917
    N6526 X.3558 Y1.459 Z-1.9172
    N6527 X.3726 Y1.4583 Z-1.9173
    N6528 X.9906 Z-1.9234
    N6529 X1.0185 Y1.4602 Z-1.9237
    N6530 X1.0412 Y1.465 Z-1.9239
    N6531 X1.0619 Y1.4725 Z-1.9241
    N6532 X1.08 Y1.4821 Z-1.9243
    N6533 X1.0952 Y1.4934 Z-1.9245
    N6534 X1.1064 Y1.5047 Z-1.9246
    N6535 X1.114 Y1.5157 Z-1.9248
    N6536 X1.1186 Y1.5259 Z-1.9249
    N6537 X1.1193 Y1.5288
    N6538 X1.12 Y1.5371 Z-1.925
    N6539 Y1.8828 Z-1.9284
    N6540 G3 X1.0887 Y1.914 Z-1.9289 I-.0313
    N6541 G1 X1.0661 Z-1.9291
    N6542 X1.0428 Z-1.9293
    N6543 X1.019 Z-1.9296
    N6544 X.995 Z-1.9298
    N6545 X.37 Z-1.9359
    N6546 X.346 Z-1.9362
    N6547 X.3222 Z-1.9364
    N6548 X.2989 Z-1.9366
    N6549 X.2762 Z-1.9369
    N6550 X.2681 Y1.9129 Z-1.937
    N6551 X.2606 Y1.9098
    N6552 X.2541 Y1.9049 Z-1.9371
    N6553 X.2492 Y1.8984 Z-1.9372
    N6554 X.2461 Y1.8909
    N6555 X.245 Y1.8828 Z-1.9373
    N6556 Y1.539 Z-1.9407
    N6557 X.2464 Y1.5272 Z-1.9408
    N6558 X.2489 Y1.5198 Z-1.9409
    N6559 X.2547 Y1.5098 Z-1.941
    N6560 X.2647 Y1.4981 Z-1.9412
    N6561 X.2791 Y1.4861 Z-1.9413
    N6562 X.2974 Y1.4752 Z-1.9416
    N6563 X.3185 Y1.4667 Z-1.9418
    N6564 X.3437 Y1.4605 Z-1.942
    N6565 X.3558 Y1.459 Z-1.9422
    N6566 X.3726 Y1.4583 Z-1.9423
    N6567 X.9906 Z-1.9484
    N6568 X1.0185 Y1.4602 Z-1.9487
    N6569 X1.0412 Y1.465 Z-1.9489
    N6570 X1.0619 Y1.4725 Z-1.9491
    N6571 X1.08 Y1.4821 Z-1.9493
    N6572 X1.0952 Y1.4934 Z-1.9495
    N6573 X1.1064 Y1.5047 Z-1.9496
    N6574 X1.114 Y1.5157 Z-1.9498
    N6575 X1.1186 Y1.5259 Z-1.9499
    N6576 X1.1193 Y1.5288
    N6577 X1.12 Y1.5371 Z-1.95
    N6578 Y1.8828 Z-1.9534
    N6579 G3 X1.0887 Y1.914 Z-1.9539 I-.0313
    N6580 G1 X1.0661 Z-1.9541
    N6581 X1.0428 Z-1.9543
    N6582 X1.019 Z-1.9546
    N6583 X.995 Z-1.9548
    N6584 X.37 Z-1.9609
    N6585 X.346 Z-1.9612
    N6586 X.3222 Z-1.9614
    N6587 X.2989 Z-1.9616
    N6588 X.2762 Z-1.9619
    N6589 X.2681 Y1.9129 Z-1.962
    N6590 X.2606 Y1.9098
    N6591 X.2541 Y1.9049 Z-1.9621
    N6592 X.2492 Y1.8984 Z-1.9622
    N6593 X.2461 Y1.8909
    N6594 X.245 Y1.8828 Z-1.9623
    N6595 Y1.539 Z-1.9657
    N6596 X.2464 Y1.5272 Z-1.9658
    N6597 X.2489 Y1.5198 Z-1.9659
    N6598 X.2547 Y1.5098 Z-1.966
    N6599 X.2647 Y1.4981 Z-1.9662
    N6600 X.2791 Y1.4861 Z-1.9663
    N6601 X.2974 Y1.4752 Z-1.9666
    N6602 X.3185 Y1.4667 Z-1.9668
    N6603 X.3437 Y1.4605 Z-1.967
    N6604 X.3558 Y1.459 Z-1.9672
    N6605 X.3726 Y1.4583 Z-1.9673
    N6606 X.9906 Z-1.9734
    N6607 X1.0185 Y1.4602 Z-1.9737
    N6608 X1.0412 Y1.465 Z-1.9739
    N6609 X1.0619 Y1.4725 Z-1.9741
    N6610 X1.08 Y1.4821 Z-1.9743
    N6611 X1.0952 Y1.4934 Z-1.9745
    N6612 X1.1064 Y1.5047 Z-1.9746
    N6613 X1.114 Y1.5157 Z-1.9748
    N6614 X1.1186 Y1.5259 Z-1.9749
    N6615 X1.1193 Y1.5288
    N6616 X1.12 Y1.5371 Z-1.975
    N6617 Y1.8828 Z-1.9784
    N6618 G3 X1.0887 Y1.914 Z-1.9789 I-.0313
    N6619 G1 X1.0661 Z-1.9791
    N6620 X1.0428 Z-1.9793
    N6621 X1.019 Z-1.9796
    N6622 X.995 Z-1.9798
    N6623 X.37 Z-1.9859
    N6624 X.346 Z-1.9862
    N6625 X.3222 Z-1.9864
    N6626 X.2989 Z-1.9866
    N6627 X.2762 Z-1.9869
    N6628 X.2681 Y1.9129 Z-1.987
    N6629 X.2606 Y1.9098
    N6630 X.2541 Y1.9049 Z-1.9871
    N6631 X.2492 Y1.8984 Z-1.9872
    N6632 X.2461 Y1.8909
    N6633 X.245 Y1.8828 Z-1.9873
    N6634 Y1.539 Z-1.9907
    N6635 X.2464 Y1.5272 Z-1.9908
    N6636 X.2489 Y1.5198 Z-1.9909
    N6637 X.2547 Y1.5098 Z-1.991
    N6638 X.2647 Y1.4981 Z-1.9912
    N6639 X.2791 Y1.4861 Z-1.9913
    N6640 X.2974 Y1.4752 Z-1.9916
    N6641 X.3185 Y1.4667 Z-1.9918
    N6642 X.3437 Y1.4605 Z-1.992
    N6643 X.3558 Y1.459 Z-1.9922
    N6644 X.3726 Y1.4583 Z-1.9923
    N6645 X.9906 Z-1.9984
    N6646 X1.0185 Y1.4602 Z-1.9987
    N6647 X1.0412 Y1.465 Z-1.9989
    N6648 X1.0619 Y1.4725 Z-1.9991
    N6649 X1.08 Y1.4821 Z-1.9993
    N6650 X1.0952 Y1.4934 Z-1.9995
    N6651 X1.1064 Y1.5047 Z-1.9996
    N6652 X1.114 Y1.5157 Z-1.9998
    N6653 X1.1186 Y1.5259 Z-1.9999
    N6654 X1.1193 Y1.5288
    N6655 X1.12 Y1.5371 Z-2.
    N6656 Y1.8828 Z-2.0034
    N6657 G3 X1.0887 Y1.914 Z-2.0039 I-.0313
    N6658 G1 X1.0661 Z-2.0041
    N6659 X1.0428 Z-2.0043
    N6660 X1.019 Z-2.0046
    N6661 X.995 Z-2.0048
    N6662 X.37 Z-2.0109
    N6663 X.346 Z-2.0112
    N6664 X.3222 Z-2.0114
    N6665 X.2989 Z-2.0116
    N6666 X.2762 Z-2.0119
    N6667 X.2681 Y1.9129 Z-2.012
    N6668 X.2606 Y1.9098
    N6669 X.2541 Y1.9049 Z-2.0121
    N6670 X.2492 Y1.8984 Z-2.0122
    N6671 X.2461 Y1.8909
    N6672 X.245 Y1.8828 Z-2.0123
    N6673 Y1.539 Z-2.0157
    N6674 X.2464 Y1.5272 Z-2.0158
    N6675 X.2489 Y1.5198 Z-2.0159
    N6676 X.2547 Y1.5098 Z-2.016
    N6677 X.2647 Y1.4981 Z-2.0162
    N6678 X.2791 Y1.4861 Z-2.0163
    N6679 X.2974 Y1.4752 Z-2.0166
    N6680 X.3185 Y1.4667 Z-2.0168
    N6681 X.3437 Y1.4605 Z-2.017
    N6682 X.3558 Y1.459 Z-2.0172
    N6683 X.3726 Y1.4583 Z-2.0173
    N6684 X.9906 Z-2.0234
    N6685 X1.0185 Y1.4602 Z-2.0237
    N6686 X1.0412 Y1.465 Z-2.0239
    N6687 X1.0619 Y1.4725 Z-2.0241
    N6688 X1.08 Y1.4821 Z-2.0243
    N6689 X1.0952 Y1.4934 Z-2.0245
    N6690 X1.1064 Y1.5047 Z-2.0246
    N6691 X1.114 Y1.5157 Z-2.0248
    N6692 X1.1186 Y1.5259 Z-2.0249
    N6693 X1.1193 Y1.5288
    N6694 X1.12 Y1.5371 Z-2.025
    N6695 Y1.8828 Z-2.0284
    N6696 G3 X1.0887 Y1.914 Z-2.0289 I-.0313
    N6697 G1 X1.0661 Z-2.0291
    N6698 X1.0428 Z-2.0293
    N6699 X1.019 Z-2.0296
    N6700 X.995 Z-2.0298
    N6701 X.37 Z-2.0359
    N6702 X.346 Z-2.0362
    N6703 X.3222 Z-2.0364
    N6704 X.2989 Z-2.0366
    N6705 X.2762 Z-2.0369
    N6706 X.2681 Y1.9129 Z-2.037
    N6707 X.2606 Y1.9098
    N6708 X.2541 Y1.9049 Z-2.0371
    N6709 X.2492 Y1.8984 Z-2.0372
    N6710 X.2461 Y1.8909
    N6711 X.245 Y1.8828 Z-2.0373
    N6712 Y1.539 Z-2.0407
    N6713 X.2464 Y1.5272 Z-2.0408
    N6714 X.2489 Y1.5198 Z-2.0409
    N6715 X.2547 Y1.5098 Z-2.041
    N6716 X.2647 Y1.4981 Z-2.0412
    N6717 X.2791 Y1.4861 Z-2.0413
    N6718 X.2974 Y1.4752 Z-2.0416
    N6719 X.3185 Y1.4667 Z-2.0418
    N6720 X.3437 Y1.4605 Z-2.042
    N6721 X.3558 Y1.459 Z-2.0422
    N6722 X.3726 Y1.4583 Z-2.0423
    N6723 X.9906 Z-2.0484
    N6724 X1.0185 Y1.4602 Z-2.0487
    N6725 X1.0412 Y1.465 Z-2.0489
    N6726 X1.0619 Y1.4725 Z-2.0491
    N6727 X1.08 Y1.4821 Z-2.0493
    N6728 X1.0952 Y1.4934 Z-2.0495
    N6729 X1.1064 Y1.5047 Z-2.0496
    N6730 X1.114 Y1.5157 Z-2.0498
    N6731 X1.1186 Y1.5259 Z-2.0499
    N6732 X1.1193 Y1.5288
    N6733 X1.12 Y1.5371 Z-2.05
    N6734 Y1.8828 Z-2.0534
    N6735 G3 X1.0887 Y1.914 Z-2.0539 I-.0313
    N6736 G1 X1.0661 Z-2.0541
    N6737 X1.0428 Z-2.0543
    N6738 X1.019 Z-2.0546
    N6739 X.995 Z-2.0548
    N6740 X.37 Z-2.0609
    N6741 X.346 Z-2.0612
    N6742 X.3222 Z-2.0614
    N6743 X.2989 Z-2.0616
    N6744 X.2762 Z-2.0619
    N6745 X.2681 Y1.9129 Z-2.062
    N6746 X.2606 Y1.9098
    N6747 X.2541 Y1.9049 Z-2.0621
    N6748 X.2492 Y1.8984 Z-2.0622
    N6749 X.2461 Y1.8909
    N6750 X.245 Y1.8828 Z-2.0623
    N6751 Y1.539 Z-2.0657
    N6752 X.2464 Y1.5272 Z-2.0658
    N6753 X.2489 Y1.5198 Z-2.0659
    N6754 X.2547 Y1.5098 Z-2.066
    N6755 X.2647 Y1.4981 Z-2.0662
    N6756 X.2791 Y1.4861 Z-2.0663
    N6757 X.2974 Y1.4752 Z-2.0666
    N6758 X.3185 Y1.4667 Z-2.0668
    N6759 X.3437 Y1.4605 Z-2.067
    N6760 X.3558 Y1.459 Z-2.0672
    N6761 X.3726 Y1.4583 Z-2.0673
    N6762 X.9906 Z-2.0734
    N6763 X1.0185 Y1.4602 Z-2.0737
    N6764 X1.0412 Y1.465 Z-2.0739
    N6765 X1.0619 Y1.4725 Z-2.0741
    N6766 X1.08 Y1.4821 Z-2.0743
    N6767 X1.0952 Y1.4934 Z-2.0745
    N6768 X1.1064 Y1.5047 Z-2.0746
    N6769 X1.114 Y1.5157 Z-2.0748
    N6770 X1.1186 Y1.5259 Z-2.0749
    N6771 X1.1193 Y1.5288
    N6772 X1.12 Y1.5371 Z-2.075
    N6773 Y1.8828 Z-2.0784
    N6774 G3 X1.0887 Y1.914 Z-2.0789 I-.0313
    N6775 G1 X1.0661 Z-2.0791
    N6776 X1.0428 Z-2.0793
    N6777 X1.019 Z-2.0796
    N6778 X.995 Z-2.0798
    N6779 X.37 Z-2.0859
    N6780 X.346 Z-2.0862
    N6781 X.3222 Z-2.0864
    N6782 X.2989 Z-2.0866
    N6783 X.2762 Z-2.0869
    N6784 X.2681 Y1.9129 Z-2.087
    N6785 X.2606 Y1.9098
    N6786 X.2541 Y1.9049 Z-2.0871
    N6787 X.2492 Y1.8984 Z-2.0872
    N6788 X.2461 Y1.8909
    N6789 X.245 Y1.8828 Z-2.0873
    N6790 Y1.539 Z-2.0907
    N6791 X.2464 Y1.5272 Z-2.0908
    N6792 X.2489 Y1.5198 Z-2.0909
    N6793 X.2547 Y1.5098 Z-2.091
    N6794 X.2647 Y1.4981 Z-2.0912
    N6795 X.2791 Y1.4861 Z-2.0913
    N6796 X.2974 Y1.4752 Z-2.0916
    N6797 X.3185 Y1.4667 Z-2.0918
    N6798 X.3437 Y1.4605 Z-2.092
    N6799 X.3558 Y1.459 Z-2.0922
    N6800 X.3726 Y1.4583 Z-2.0923
    N6801 X.9906 Z-2.0984
    N6802 X1.0185 Y1.4602 Z-2.0987
    N6803 X1.0412 Y1.465 Z-2.0989
    N6804 X1.0619 Y1.4725 Z-2.0991
    N6805 X1.08 Y1.4821 Z-2.0993
    N6806 X1.0952 Y1.4934 Z-2.0995
    N6807 X1.1064 Y1.5047 Z-2.0996
    N6808 X1.114 Y1.5157 Z-2.0998
    N6809 X1.1186 Y1.5259 Z-2.0999
    N6810 X1.1193 Y1.5288
    N6811 X1.12 Y1.5371 Z-2.1
    N6812 Y1.8828 Z-2.1034
    N6813 G3 X1.0887 Y1.914 Z-2.1039 I-.0313
    N6814 G1 X1.0661 Z-2.1041
    N6815 X1.0428 Z-2.1043
    N6816 X1.019 Z-2.1046
    N6817 X.995 Z-2.1048
    N6818 X.37 Z-2.1109
    N6819 X.346 Z-2.1112
    N6820 X.3222 Z-2.1114
    N6821 X.2989 Z-2.1116
    N6822 X.2762 Z-2.1119
    N6823 X.2681 Y1.9129 Z-2.112
    N6824 X.2606 Y1.9098
    N6825 X.2541 Y1.9049 Z-2.1121
    N6826 X.2492 Y1.8984 Z-2.1122
    N6827 X.2461 Y1.8909
    N6828 X.245 Y1.8828 Z-2.1123
    N6829 Y1.539 Z-2.1157
    N6830 X.2464 Y1.5272 Z-2.1158
    N6831 X.2489 Y1.5198 Z-2.1159
    N6832 X.2547 Y1.5098 Z-2.116
    N6833 X.2647 Y1.4981 Z-2.1162
    N6834 X.2791 Y1.4861 Z-2.1163
    N6835 X.2974 Y1.4752 Z-2.1166
    N6836 X.3185 Y1.4667 Z-2.1168
    N6837 X.3437 Y1.4605 Z-2.117
    N6838 X.3558 Y1.459 Z-2.1172
    N6839 X.3726 Y1.4583 Z-2.1173
    N6840 X.9906 Z-2.1234
    N6841 X1.0185 Y1.4602 Z-2.1237
    N6842 X1.0412 Y1.465 Z-2.1239
    N6843 X1.0619 Y1.4725 Z-2.1241
    N6844 X1.08 Y1.4821 Z-2.1243
    N6845 X1.0952 Y1.4934 Z-2.1245
    N6846 X1.1064 Y1.5047 Z-2.1246
    N6847 X1.114 Y1.5157 Z-2.1248
    N6848 X1.1186 Y1.5259 Z-2.1249
    N6849 X1.1193 Y1.5288
    N6850 X1.12 Y1.5371 Z-2.125
    N6851 Y1.8828 Z-2.1284
    N6852 G3 X1.0887 Y1.914 Z-2.1289 I-.0313
    N6853 G1 X1.0661 Z-2.1291
    N6854 X1.0428 Z-2.1293
    N6855 X1.019 Z-2.1296
    N6856 X.995 Z-2.1298
    N6857 X.37 Z-2.1359
    N6858 X.346 Z-2.1362
    N6859 X.3222 Z-2.1364
    N6860 X.2989 Z-2.1366
    N6861 X.2762 Z-2.1369
    N6862 X.2681 Y1.9129 Z-2.137
    N6863 X.2606 Y1.9098
    N6864 X.2541 Y1.9049 Z-2.1371
    N6865 X.2492 Y1.8984 Z-2.1372
    N6866 X.2461 Y1.8909
    N6867 X.245 Y1.8828 Z-2.1373
    N6868 Y1.539 Z-2.1407
    N6869 X.2464 Y1.5272 Z-2.1408
    N6870 X.2489 Y1.5198 Z-2.1409
    N6871 X.2547 Y1.5098 Z-2.141
    N6872 X.2647 Y1.4981 Z-2.1412
    N6873 X.2791 Y1.4861 Z-2.1413
    N6874 X.2974 Y1.4752 Z-2.1416
    N6875 X.3185 Y1.4667 Z-2.1418
    N6876 X.3437 Y1.4605 Z-2.142
    N6877 X.3558 Y1.459 Z-2.1422
    N6878 X.3726 Y1.4583 Z-2.1423
    N6879 X.9906 Z-2.1484
    N6880 X1.0185 Y1.4602 Z-2.1487
    N6881 X1.0412 Y1.465 Z-2.1489
    N6882 X1.0619 Y1.4725 Z-2.1491
    N6883 X1.08 Y1.4821 Z-2.1493
    N6884 X1.0952 Y1.4934 Z-2.1495
    N6885 X1.1064 Y1.5047 Z-2.1496
    N6886 X1.114 Y1.5157 Z-2.1498
    N6887 X1.1186 Y1.5259 Z-2.1499
    N6888 X1.1193 Y1.5288
    N6889 X1.12 Y1.5371 Z-2.15
    N6890 Y1.8828 Z-2.1534
    N6891 G3 X1.0887 Y1.914 Z-2.1539 I-.0313
    N6892 G1 X1.0661 Z-2.1541
    N6893 X1.0428 Z-2.1543
    N6894 X1.019 Z-2.1546
    N6895 X.995 Z-2.1548
    N6896 X.37 Z-2.1609
    N6897 X.346 Z-2.1612
    N6898 X.3222 Z-2.1614
    N6899 X.2989 Z-2.1616
    N6900 X.2762 Z-2.1619
    N6901 X.2681 Y1.9129 Z-2.162
    N6902 X.2606 Y1.9098
    N6903 X.2541 Y1.9049 Z-2.1621
    N6904 X.2492 Y1.8984 Z-2.1622
    N6905 X.2461 Y1.8909
    N6906 X.245 Y1.8828 Z-2.1623
    N6907 Y1.539 Z-2.1657
    N6908 X.2464 Y1.5272 Z-2.1658
    N6909 X.2489 Y1.5198 Z-2.1659
    N6910 X.2547 Y1.5098 Z-2.166
    N6911 X.2647 Y1.4981 Z-2.1662
    N6912 X.2791 Y1.4861 Z-2.1663
    N6913 X.2974 Y1.4752 Z-2.1666
    N6914 X.3185 Y1.4667 Z-2.1668
    N6915 X.3437 Y1.4605 Z-2.167
    N6916 X.3558 Y1.459 Z-2.1672
    N6917 X.3726 Y1.4583 Z-2.1673
    N6918 X.9906 Z-2.1734
    N6919 X1.0185 Y1.4602 Z-2.1737
    N6920 X1.0412 Y1.465 Z-2.1739
    N6921 X1.0619 Y1.4725 Z-2.1741
    N6922 X1.08 Y1.4821 Z-2.1743
    N6923 X1.0952 Y1.4934 Z-2.1745
    N6924 X1.1064 Y1.5047 Z-2.1746
    N6925 X1.114 Y1.5157 Z-2.1748
    N6926 X1.1186 Y1.5259 Z-2.1749
    N6927 X1.1193 Y1.5288
    N6928 X1.12 Y1.5371 Z-2.175
    N6929 Y1.8828 Z-2.1784
    N6930 G3 X1.0887 Y1.914 Z-2.1789 I-.0313
    N6931 G1 X1.0661 Z-2.1791
    N6932 X1.0428 Z-2.1793
    N6933 X1.019 Z-2.1796
    N6934 X.995 Z-2.1798
    N6935 X.37 Z-2.1859
    N6936 X.346 Z-2.1862
    N6937 X.3222 Z-2.1864
    N6938 X.2989 Z-2.1866
    N6939 X.2762 Z-2.1869
    N6940 X.2681 Y1.9129 Z-2.187
    N6941 X.2606 Y1.9098
    N6942 X.2541 Y1.9049 Z-2.1871
    N6943 X.2492 Y1.8984 Z-2.1872
    N6944 X.2461 Y1.8909
    N6945 X.245 Y1.8828 Z-2.1873
    N6946 Y1.539 Z-2.1907
    N6947 X.2464 Y1.5272 Z-2.1908
    N6948 X.2489 Y1.5198 Z-2.1909
    N6949 X.2547 Y1.5098 Z-2.191
    N6950 X.2647 Y1.4981 Z-2.1912
    N6951 X.2791 Y1.4861 Z-2.1913
    N6952 X.2974 Y1.4752 Z-2.1916
    N6953 X.3185 Y1.4667 Z-2.1918
    N6954 X.3437 Y1.4605 Z-2.192
    N6955 X.3558 Y1.459 Z-2.1922
    N6956 X.3726 Y1.4583 Z-2.1923
    N6957 X.9906 Z-2.1984
    N6958 X1.0185 Y1.4602 Z-2.1987
    N6959 X1.0412 Y1.465 Z-2.1989
    N6960 X1.0619 Y1.4725 Z-2.1991
    N6961 X1.08 Y1.4821 Z-2.1993
    N6962 X1.0952 Y1.4934 Z-2.1995
    N6963 X1.1064 Y1.5047 Z-2.1996
    N6964 X1.114 Y1.5157 Z-2.1998
    N6965 X1.1186 Y1.5259 Z-2.1999
    N6966 X1.1193 Y1.5288
    N6967 X1.12 Y1.5371 Z-2.2
    N6968 Y1.8828 Z-2.2034
    N6969 G3 X1.0887 Y1.914 Z-2.2039 I-.0313
    N6970 G1 X1.0661 Z-2.2041
    N6971 X1.0428 Z-2.2043
    N6972 X1.019 Z-2.2046
    N6973 X.995 Z-2.2048
    N6974 X.37 Z-2.2109
    N6975 X.346 Z-2.2112
    N6976 X.3222 Z-2.2114
    N6977 X.2989 Z-2.2116
    N6978 X.2762 Z-2.2119
    N6979 X.2681 Y1.9129 Z-2.212
    N6980 X.2606 Y1.9098
    N6981 X.2541 Y1.9049 Z-2.2121
    N6982 X.2492 Y1.8984 Z-2.2122
    N6983 X.2461 Y1.8909
    N6984 X.245 Y1.8828 Z-2.2123
    N6985 Y1.539 Z-2.2157
    N6986 X.2464 Y1.5272 Z-2.2158
    N6987 X.2489 Y1.5198 Z-2.2159
    N6988 X.2547 Y1.5098 Z-2.216
    N6989 X.2647 Y1.4981 Z-2.2162
    N6990 X.2791 Y1.4861 Z-2.2163
    N6991 X.2974 Y1.4752 Z-2.2166
    N6992 X.3185 Y1.4667 Z-2.2168
    N6993 X.3437 Y1.4605 Z-2.217
    N6994 X.3558 Y1.459 Z-2.2172
    N6995 X.3726 Y1.4583 Z-2.2173
    N6996 X.9906 Z-2.2234
    N6997 X1.0185 Y1.4602 Z-2.2237
    N6998 X1.0412 Y1.465 Z-2.2239
    N6999 X1.0619 Y1.4725 Z-2.2241
    N7000 X1.08 Y1.4821 Z-2.2243
    N7001 X1.0952 Y1.4934 Z-2.2245
    N7002 X1.1064 Y1.5047 Z-2.2246
    N7003 X1.114 Y1.5157 Z-2.2248
    N7004 X1.1186 Y1.5259 Z-2.2249
    N7005 X1.1193 Y1.5288
    N7006 X1.12 Y1.5371 Z-2.225
    N7007 Y1.8828 Z-2.2284
    N7008 G3 X1.0887 Y1.914 Z-2.2289 I-.0313
    N7009 G1 X1.0661 Z-2.2291
    N7010 X1.0428 Z-2.2293
    N7011 X1.019 Z-2.2296
    N7012 X.995 Z-2.2298
    N7013 X.37 Z-2.2359
    N7014 X.346 Z-2.2362
    N7015 X.3222 Z-2.2364
    N7016 X.2989 Z-2.2366
    N7017 X.2762 Z-2.2369
    N7018 X.2681 Y1.9129 Z-2.237
    N7019 X.2606 Y1.9098
    N7020 X.2541 Y1.9049 Z-2.2371
    N7021 X.2492 Y1.8984 Z-2.2372
    N7022 X.2461 Y1.8909
    N7023 X.245 Y1.8828 Z-2.2373
    N7024 Y1.539 Z-2.2407
    N7025 X.2464 Y1.5272 Z-2.2408
    N7026 X.2489 Y1.5198 Z-2.2409
    N7027 X.2547 Y1.5098 Z-2.241
    N7028 X.2647 Y1.4981 Z-2.2412
    N7029 X.2791 Y1.4861 Z-2.2413
    N7030 X.2974 Y1.4752 Z-2.2416
    N7031 X.3185 Y1.4667 Z-2.2418
    N7032 X.3437 Y1.4605 Z-2.242
    N7033 X.3558 Y1.459 Z-2.2422
    N7034 X.3726 Y1.4583 Z-2.2423
    N7035 X.9906 Z-2.2484
    N7036 X1.0185 Y1.4602 Z-2.2487
    N7037 X1.0412 Y1.465 Z-2.2489
    N7038 X1.0619 Y1.4725 Z-2.2491
    N7039 X1.08 Y1.4821 Z-2.2493
    N7040 X1.0952 Y1.4934 Z-2.2495
    N7041 X1.1064 Y1.5047 Z-2.2496
    N7042 X1.114 Y1.5157 Z-2.2498
    N7043 X1.1186 Y1.5259 Z-2.2499
    N7044 X1.1193 Y1.5288
    N7045 X1.12 Y1.5371 Z-2.25
    N7046 Y1.8828 Z-2.2534
    N7047 G3 X1.0887 Y1.914 Z-2.2539 I-.0313
    N7048 G1 X1.0661 Z-2.2541
    N7049 X1.0428 Z-2.2543
    N7050 X1.019 Z-2.2546
    N7051 X.995 Z-2.2548
    N7052 X.37 Z-2.2609
    N7053 X.346 Z-2.2612
    N7054 X.3222 Z-2.2614
    N7055 X.2989 Z-2.2616
    N7056 X.2762 Z-2.2619
    N7057 X.2681 Y1.9129 Z-2.262
    N7058 X.2606 Y1.9098
    N7059 X.2541 Y1.9049 Z-2.2621
    N7060 X.2492 Y1.8984 Z-2.2622
    N7061 X.2461 Y1.8909
    N7062 X.245 Y1.8828 Z-2.2623
    N7063 Y1.539 Z-2.2657
    N7064 X.2464 Y1.5272 Z-2.2658
    N7065 X.2489 Y1.5198 Z-2.2659
    N7066 X.2547 Y1.5098 Z-2.266
    N7067 X.2647 Y1.4981 Z-2.2662
    N7068 X.2791 Y1.4861 Z-2.2663
    N7069 X.2974 Y1.4752 Z-2.2666
    N7070 X.3185 Y1.4667 Z-2.2668
    N7071 X.3437 Y1.4605 Z-2.267
    N7072 X.3558 Y1.459 Z-2.2672
    N7073 X.3726 Y1.4583 Z-2.2673
    N7074 X.9906 Z-2.2734
    N7075 X1.0185 Y1.4602 Z-2.2737
    N7076 X1.0412 Y1.465 Z-2.2739
    N7077 X1.0619 Y1.4725 Z-2.2741
    N7078 X1.08 Y1.4821 Z-2.2743
    N7079 X1.0952 Y1.4934 Z-2.2745
    N7080 X1.1064 Y1.5047 Z-2.2746
    N7081 X1.114 Y1.5157 Z-2.2748
    N7082 X1.1186 Y1.5259 Z-2.2749
    N7083 X1.1193 Y1.5288
    N7084 X1.12 Y1.5371 Z-2.275
    N7085 Y1.8828 Z-2.2784
    N7086 G3 X1.0887 Y1.914 Z-2.2789 I-.0313
    N7087 G1 X1.0661 Z-2.2791
    N7088 X1.0428 Z-2.2793
    N7089 X1.019 Z-2.2796
    N7090 X.995 Z-2.2798
    N7091 X.37 Z-2.2859
    N7092 X.346 Z-2.2862
    N7093 X.3222 Z-2.2864
    N7094 X.2989 Z-2.2866
    N7095 X.2762 Z-2.2869
    N7096 X.2681 Y1.9129 Z-2.287
    N7097 X.2606 Y1.9098
    N7098 X.2541 Y1.9049 Z-2.2871
    N7099 X.2492 Y1.8984 Z-2.2872
    N7100 X.2461 Y1.8909
    N7101 X.245 Y1.8828 Z-2.2873
    N7102 Y1.539 Z-2.2907
    N7103 X.2464 Y1.5272 Z-2.2908
    N7104 X.2489 Y1.5198 Z-2.2909
    N7105 X.2547 Y1.5098 Z-2.291
    N7106 X.2647 Y1.4981 Z-2.2912
    N7107 X.2791 Y1.4861 Z-2.2913
    N7108 X.2974 Y1.4752 Z-2.2916
    N7109 X.3185 Y1.4667 Z-2.2918
    N7110 X.3437 Y1.4605 Z-2.292
    N7111 X.3558 Y1.459 Z-2.2922
    N7112 X.3726 Y1.4583 Z-2.2923
    N7113 X.9906 Z-2.2984
    N7114 X1.0185 Y1.4602 Z-2.2987
    N7115 X1.0412 Y1.465 Z-2.2989
    N7116 X1.0619 Y1.4725 Z-2.2991
    N7117 X1.08 Y1.4821 Z-2.2993
    N7118 X1.0952 Y1.4934 Z-2.2995
    N7119 X1.1064 Y1.5047 Z-2.2996
    N7120 X1.114 Y1.5157 Z-2.2998
    N7121 X1.1186 Y1.5259 Z-2.2999
    N7122 X1.1193 Y1.5288
    N7123 X1.12 Y1.5371 Z-2.3
    N7124 Y1.8828 Z-2.3034
    N7125 G3 X1.0887 Y1.914 Z-2.3039 I-.0313
    N7126 G1 X1.0661 Z-2.3041
    N7127 X1.0428 Z-2.3043
    N7128 X1.019 Z-2.3046
    N7129 X.995 Z-2.3048
    N7130 X.37 Z-2.3109
    N7131 X.346 Z-2.3112
    N7132 X.3222 Z-2.3114
    N7133 X.2989 Z-2.3116
    N7134 X.2762 Z-2.3119
    N7135 X.2681 Y1.9129 Z-2.312
    N7136 X.2606 Y1.9098
    N7137 X.2541 Y1.9049 Z-2.3121
    N7138 X.2492 Y1.8984 Z-2.3122
    N7139 X.2461 Y1.8909
    N7140 X.245 Y1.8828 Z-2.3123
    N7141 Y1.539 Z-2.3157
    N7142 X.2464 Y1.5272 Z-2.3158
    N7143 X.2489 Y1.5198 Z-2.3159
    N7144 X.2547 Y1.5098 Z-2.316
    N7145 X.2647 Y1.4981 Z-2.3162
    N7146 X.2791 Y1.4861 Z-2.3163
    N7147 X.2974 Y1.4752 Z-2.3166
    N7148 X.3185 Y1.4667 Z-2.3168
    N7149 X.3437 Y1.4605 Z-2.317
    N7150 X.3558 Y1.459 Z-2.3172
    N7151 X.3726 Y1.4583 Z-2.3173
    N7152 X.9906 Z-2.3234
    N7153 X1.0185 Y1.4602 Z-2.3237
    N7154 X1.0412 Y1.465 Z-2.3239
    N7155 X1.0619 Y1.4725 Z-2.3241
    N7156 X1.08 Y1.4821 Z-2.3243
    N7157 X1.0952 Y1.4934 Z-2.3245
    N7158 X1.1064 Y1.5047 Z-2.3246
    N7159 X1.114 Y1.5157 Z-2.3248
    N7160 X1.1186 Y1.5259 Z-2.3249
    N7161 X1.1193 Y1.5288
    N7162 X1.12 Y1.5371 Z-2.325
    N7163 Y1.8828 Z-2.3284
    N7164 G3 X1.0887 Y1.914 Z-2.3289 I-.0313
    N7165 G1 X1.0661 Z-2.3291
    N7166 X1.0428 Z-2.3293
    N7167 X1.019 Z-2.3296
    N7168 X.995 Z-2.3298
    N7169 X.37 Z-2.3359
    N7170 X.346 Z-2.3362
    N7171 X.3222 Z-2.3364
    N7172 X.2989 Z-2.3366
    N7173 X.2762 Z-2.3369
    N7174 X.2681 Y1.9129 Z-2.337
    N7175 X.2606 Y1.9098
    N7176 X.2541 Y1.9049 Z-2.3371
    N7177 X.2492 Y1.8984 Z-2.3372
    N7178 X.2461 Y1.8909
    N7179 X.245 Y1.8828 Z-2.3373
    N7180 Y1.539 Z-2.3407
    N7181 X.2464 Y1.5272 Z-2.3408
    N7182 X.2489 Y1.5198 Z-2.3409
    N7183 X.2547 Y1.5098 Z-2.341
    N7184 X.2647 Y1.4981 Z-2.3412
    N7185 X.2791 Y1.4861 Z-2.3413
    N7186 X.2974 Y1.4752 Z-2.3416
    N7187 X.3185 Y1.4667 Z-2.3418
    N7188 X.3437 Y1.4605 Z-2.342
    N7189 X.3558 Y1.459 Z-2.3422
    N7190 X.3726 Y1.4583 Z-2.3423
    N7191 X.9906 Z-2.3484
    N7192 X1.0185 Y1.4602 Z-2.3487
    N7193 X1.0412 Y1.465 Z-2.3489
    N7194 X1.0619 Y1.4725 Z-2.3491
    N7195 X1.08 Y1.4821 Z-2.3493
    N7196 X1.0952 Y1.4934 Z-2.3495
    N7197 X1.1064 Y1.5047 Z-2.3496
    N7198 X1.114 Y1.5157 Z-2.3498
    N7199 X1.1186 Y1.5259 Z-2.3499
    N7200 X1.1193 Y1.5288
    N7201 X1.12 Y1.5371 Z-2.35
    N7202 Y1.8828 Z-2.3534
    N7203 G3 X1.0887 Y1.914 Z-2.3539 I-.0313
    N7204 G1 X1.0661 Z-2.3541
    N7205 X1.0428 Z-2.3543
    N7206 X1.019 Z-2.3546
    N7207 X.995 Z-2.3548
    N7208 X.37 Z-2.3609
    N7209 X.346 Z-2.3612
    N7210 X.3222 Z-2.3614
    N7211 X.2989 Z-2.3616
    N7212 X.2762 Z-2.3619
    N7213 X.2681 Y1.9129 Z-2.362
    N7214 X.2606 Y1.9098
    N7215 X.2541 Y1.9049 Z-2.3621
    N7216 X.2492 Y1.8984 Z-2.3622
    N7217 X.2461 Y1.8909
    N7218 X.245 Y1.8828 Z-2.3623
    N7219 Y1.539 Z-2.3657
    N7220 X.2464 Y1.5272 Z-2.3658
    N7221 X.2489 Y1.5198 Z-2.3659
    N7222 X.2547 Y1.5098 Z-2.366
    N7223 X.2647 Y1.4981 Z-2.3662
    N7224 X.2791 Y1.4861 Z-2.3663
    N7225 X.2974 Y1.4752 Z-2.3666
    N7226 X.3185 Y1.4667 Z-2.3668
    N7227 X.3437 Y1.4605 Z-2.367
    N7228 X.3558 Y1.459 Z-2.3672
    N7229 X.3726 Y1.4583 Z-2.3673
    N7230 X.9906 Z-2.3734
    N7231 X1.0185 Y1.4602 Z-2.3737
    N7232 X1.0412 Y1.465 Z-2.3739
    N7233 X1.0619 Y1.4725 Z-2.3741
    N7234 X1.08 Y1.4821 Z-2.3743
    N7235 X1.0952 Y1.4934 Z-2.3745
    N7236 X1.1064 Y1.5047 Z-2.3746
    N7237 X1.114 Y1.5157 Z-2.3748
    N7238 X1.1186 Y1.5259 Z-2.3749
    N7239 X1.1193 Y1.5288
    N7240 X1.12 Y1.5371 Z-2.375
    N7241 Y1.8828 Z-2.3784
    N7242 G3 X1.0887 Y1.914 Z-2.3789 I-.0313
    N7243 G1 X1.0661 Z-2.3791
    N7244 X1.0428 Z-2.3793
    N7245 X1.019 Z-2.3796
    N7246 X.995 Z-2.3798
    N7247 X.37 Z-2.3859
    N7248 X.346 Z-2.3862
    N7249 X.3222 Z-2.3864
    N7250 X.2989 Z-2.3866
    N7251 X.2762 Z-2.3869
    N7252 X.2681 Y1.9129 Z-2.387
    N7253 X.2606 Y1.9098
    N7254 X.2541 Y1.9049 Z-2.3871
    N7255 X.2492 Y1.8984 Z-2.3872
    N7256 X.2461 Y1.8909
    N7257 X.245 Y1.8828 Z-2.3873
    N7258 Y1.539 Z-2.3907
    N7259 X.2464 Y1.5272 Z-2.3908
    N7260 X.2489 Y1.5198 Z-2.3909
    N7261 X.2547 Y1.5098 Z-2.391
    N7262 X.2647 Y1.4981 Z-2.3912
    N7263 X.2791 Y1.4861 Z-2.3913
    N7264 X.2974 Y1.4752 Z-2.3916
    N7265 X.3185 Y1.4667 Z-2.3918
    N7266 X.3437 Y1.4605 Z-2.392
    N7267 X.3558 Y1.459 Z-2.3922
    N7268 X.3726 Y1.4583 Z-2.3923
    N7269 X.9906 Z-2.3984
    N7270 X1.0185 Y1.4602 Z-2.3987
    N7271 X1.0412 Y1.465 Z-2.3989
    N7272 X1.0619 Y1.4725 Z-2.3991
    N7273 X1.08 Y1.4821 Z-2.3993
    N7274 X1.0952 Y1.4934 Z-2.3995
    N7275 X1.1064 Y1.5047 Z-2.3996
    N7276 X1.114 Y1.5157 Z-2.3998
    N7277 X1.1186 Y1.5259 Z-2.3999
    N7278 X1.1193 Y1.5288
    N7279 X1.12 Y1.5371 Z-2.4
    N7280 Y1.8828 Z-2.4034
    N7281 G3 X1.0887 Y1.914 Z-2.4039 I-.0313
    N7282 G1 X1.0661 Z-2.4041
    N7283 X1.0428 Z-2.4043
    N7284 X1.019 Z-2.4046
    N7285 X.995 Z-2.4048
    N7286 X.37 Z-2.4109
    N7287 X.346 Z-2.4112
    N7288 X.3222 Z-2.4114
    N7289 X.2989 Z-2.4116
    N7290 X.2762 Z-2.4119
    N7291 X.2681 Y1.9129 Z-2.412
    N7292 X.2606 Y1.9098
    N7293 X.2541 Y1.9049 Z-2.4121
    N7294 X.2492 Y1.8984 Z-2.4122
    N7295 X.2461 Y1.8909
    N7296 X.245 Y1.8828 Z-2.4123
    N7297 Y1.539 Z-2.4157
    N7298 X.2464 Y1.5272 Z-2.4158
    N7299 X.2489 Y1.5198 Z-2.4159
    N7300 X.2547 Y1.5098 Z-2.416
    N7301 X.2647 Y1.4981 Z-2.4162
    N7302 X.2791 Y1.4861 Z-2.4163
    N7303 X.2974 Y1.4752 Z-2.4166
    N7304 X.3185 Y1.4667 Z-2.4168
    N7305 X.3437 Y1.4605 Z-2.417
    N7306 X.3558 Y1.459 Z-2.4172
    N7307 X.3726 Y1.4583 Z-2.4173
    N7308 X.9906 Z-2.4234
    N7309 X1.0185 Y1.4602 Z-2.4237
    N7310 X1.0412 Y1.465 Z-2.4239
    N7311 X1.0619 Y1.4725 Z-2.4241
    N7312 X1.08 Y1.4821 Z-2.4243
    N7313 X1.0952 Y1.4934 Z-2.4245
    N7314 X1.1064 Y1.5047 Z-2.4246
    N7315 X1.114 Y1.5157 Z-2.4248
    N7316 X1.1186 Y1.5259 Z-2.4249
    N7317 X1.1193 Y1.5288
    N7318 X1.12 Y1.5371 Z-2.425
    N7319 Y1.8828 Z-2.4284
    N7320 G3 X1.0887 Y1.914 Z-2.4289 I-.0313
    N7321 G1 X1.0661 Z-2.4291
    N7322 X1.0428 Z-2.4293
    N7323 X1.019 Z-2.4296
    N7324 X.995 Z-2.4298
    N7325 X.37 Z-2.4359
    N7326 X.346 Z-2.4362
    N7327 X.3222 Z-2.4364
    N7328 X.2989 Z-2.4366
    N7329 X.2762 Z-2.4369
    N7330 X.2681 Y1.9129 Z-2.437
    N7331 X.2606 Y1.9098
    N7332 X.2541 Y1.9049 Z-2.4371
    N7333 X.2492 Y1.8984 Z-2.4372
    N7334 X.2461 Y1.8909
    N7335 X.245 Y1.8828 Z-2.4373
    N7336 Y1.539 Z-2.4407
    N7337 X.2464 Y1.5272 Z-2.4408
    N7338 X.2489 Y1.5198 Z-2.4409
    N7339 X.2547 Y1.5098 Z-2.441
    N7340 X.2647 Y1.4981 Z-2.4412
    N7341 X.2791 Y1.4861 Z-2.4413
    N7342 X.2974 Y1.4752 Z-2.4416
    N7343 X.3185 Y1.4667 Z-2.4418
    N7344 X.3437 Y1.4605 Z-2.442
    N7345 X.3558 Y1.459 Z-2.4422
    N7346 X.3726 Y1.4583 Z-2.4423
    N7347 X.9906 Z-2.4484
    N7348 X1.0185 Y1.4602 Z-2.4487
    N7349 X1.0412 Y1.465 Z-2.4489
    N7350 X1.0619 Y1.4725 Z-2.4491
    N7351 X1.08 Y1.4821 Z-2.4493
    N7352 X1.0952 Y1.4934 Z-2.4495
    N7353 X1.1064 Y1.5047 Z-2.4496
    N7354 X1.114 Y1.5157 Z-2.4498
    N7355 X1.1186 Y1.5259 Z-2.4499
    N7356 X1.1193 Y1.5288
    N7357 X1.12 Y1.5371 Z-2.45
    N7358 Y1.8828 Z-2.4534
    N7359 G3 X1.0887 Y1.914 Z-2.4539 I-.0313
    N7360 G1 X1.0661 Z-2.4541
    N7361 X1.0428 Z-2.4543
    N7362 X1.019 Z-2.4546
    N7363 X.995 Z-2.4548
    N7364 X.37 Z-2.4609
    N7365 X.346 Z-2.4612
    N7366 X.3222 Z-2.4614
    N7367 X.2989 Z-2.4616
    N7368 X.2762 Z-2.4619
    N7369 X.2681 Y1.9129 Z-2.462
    N7370 X.2606 Y1.9098
    N7371 X.2541 Y1.9049 Z-2.4621
    N7372 X.2492 Y1.8984 Z-2.4622
    N7373 X.2461 Y1.8909
    N7374 X.245 Y1.8828 Z-2.4623
    N7375 Y1.539 Z-2.4657
    N7376 X.2464 Y1.5272 Z-2.4658
    N7377 X.2489 Y1.5198 Z-2.4659
    N7378 X.2547 Y1.5098 Z-2.466
    N7379 X.2647 Y1.4981 Z-2.4662
    N7380 X.2791 Y1.4861 Z-2.4663
    N7381 X.2974 Y1.4752 Z-2.4666
    N7382 X.3185 Y1.4667 Z-2.4668
    N7383 X.3437 Y1.4605 Z-2.467
    N7384 X.3558 Y1.459 Z-2.4672
    N7385 X.3726 Y1.4583 Z-2.4673
    N7386 X.9906 Z-2.4734
    N7387 X1.0185 Y1.4602 Z-2.4737
    N7388 X1.0412 Y1.465 Z-2.4739
    N7389 X1.0619 Y1.4725 Z-2.4741
    N7390 X1.08 Y1.4821 Z-2.4743
    N7391 X1.0952 Y1.4934 Z-2.4745
    N7392 X1.1064 Y1.5047 Z-2.4746
    N7393 X1.114 Y1.5157 Z-2.4748
    N7394 X1.1186 Y1.5259 Z-2.4749
    N7395 X1.1193 Y1.5288
    N7396 X1.12 Y1.5371 Z-2.475
    N7397 Y1.8828 Z-2.4784
    N7398 G3 X1.0887 Y1.914 Z-2.4789 I-.0313
    N7399 G1 X1.0661 Z-2.4791
    N7400 X1.0428 Z-2.4793
    N7401 X1.019 Z-2.4796
    N7402 X.995 Z-2.4798
    N7403 X.37 Z-2.4859
    N7404 X.346 Z-2.4862
    N7405 X.3222 Z-2.4864
    N7406 X.2989 Z-2.4866
    N7407 X.2762 Z-2.4869
    N7408 X.2681 Y1.9129 Z-2.487
    N7409 X.2606 Y1.9098
    N7410 X.2541 Y1.9049 Z-2.4871
    N7411 X.2492 Y1.8984 Z-2.4872
    N7412 X.2461 Y1.8909
    N7413 X.245 Y1.8828 Z-2.4873
    N7414 Y1.539 Z-2.4907
    N7415 X.2464 Y1.5272 Z-2.4908
    N7416 X.2489 Y1.5198 Z-2.4909
    N7417 X.2547 Y1.5098 Z-2.491
    N7418 X.2647 Y1.4981 Z-2.4912
    N7419 X.2791 Y1.4861 Z-2.4913
    N7420 X.2974 Y1.4752 Z-2.4916
    N7421 X.3185 Y1.4667 Z-2.4918
    N7422 X.3437 Y1.4605 Z-2.492
    N7423 X.3558 Y1.459 Z-2.4922
    N7424 X.3726 Y1.4583 Z-2.4923
    N7425 X.9906 Z-2.4984
    N7426 X1.0185 Y1.4602 Z-2.4987
    N7427 X1.0412 Y1.465 Z-2.4989
    N7428 X1.0619 Y1.4725 Z-2.4991
    N7429 X1.08 Y1.4821 Z-2.4993
    N7430 X1.0952 Y1.4934 Z-2.4995
    N7431 X1.1064 Y1.5047 Z-2.4996
    N7432 X1.114 Y1.5157 Z-2.4998
    N7433 X1.1186 Y1.5259 Z-2.4999
    N7434 X1.1193 Y1.5288
    N7435 X1.12 Y1.5371 Z-2.5
    N7436 Y1.8828 Z-2.5034
    N7437 G3 X1.0887 Y1.914 Z-2.5039 I-.0313
    N7438 G1 X1.0661 Z-2.5041
    N7439 X1.0428 Z-2.5043
    N7440 X1.019 Z-2.5046
    N7441 X.995 Z-2.5048
    N7442 X.37 Z-2.5109
    N7443 X.346 Z-2.5112
    N7444 X.3222 Z-2.5114
    N7445 X.2989 Z-2.5116
    N7446 X.2762 Z-2.5119
    N7447 X.2681 Y1.9129 Z-2.512
    N7448 X.2606 Y1.9098
    N7449 X.2541 Y1.9049 Z-2.5121
    N7450 X.2492 Y1.8984 Z-2.5122
    N7451 X.2461 Y1.8909
    N7452 X.245 Y1.8828 Z-2.5123
    N7453 Y1.539 Z-2.5157
    N7454 X.2464 Y1.5272 Z-2.5158
    N7455 X.2489 Y1.5198 Z-2.5159
    N7456 X.2547 Y1.5098 Z-2.516
    N7457 X.2647 Y1.4981 Z-2.5162
    N7458 X.2791 Y1.4861 Z-2.5163
    N7459 X.2974 Y1.4752 Z-2.5166
    N7460 X.3185 Y1.4667 Z-2.5168
    N7461 X.3437 Y1.4605 Z-2.517
    N7462 X.3558 Y1.459 Z-2.5172
    N7463 X.3726 Y1.4583 Z-2.5173
    N7464 X.9906 Z-2.5234
    N7465 X1.0185 Y1.4602 Z-2.5237
    N7466 X1.0412 Y1.465 Z-2.5239
    N7467 X1.0619 Y1.4725 Z-2.5241
    N7468 X1.08 Y1.4821 Z-2.5243
    N7469 X1.0952 Y1.4934 Z-2.5245
    N7470 X1.1064 Y1.5047 Z-2.5246
    N7471 X1.114 Y1.5157 Z-2.5248
    N7472 X1.1186 Y1.5259 Z-2.5249
    N7473 X1.1193 Y1.5288
    N7474 X1.12 Y1.5371 Z-2.525
    N7475 Y1.8828 Z-2.5284
    N7476 G3 X1.0887 Y1.914 Z-2.5289 I-.0313
    N7477 G1 X1.0661 Z-2.5291
    N7478 X1.0428 Z-2.5293
    N7479 X1.019 Z-2.5296
    N7480 X.995 Z-2.5298
    N7481 X.37 Z-2.5359
    N7482 X.346 Z-2.5362
    N7483 X.3222 Z-2.5364
    N7484 X.2989 Z-2.5366
    N7485 X.2762 Z-2.5369
    N7486 X.2681 Y1.9129 Z-2.537
    N7487 X.2606 Y1.9098
    N7488 X.2541 Y1.9049 Z-2.5371
    N7489 X.2492 Y1.8984 Z-2.5372
    N7490 X.2461 Y1.8909
    N7491 X.245 Y1.8828 Z-2.5373
    N7492 Y1.539 Z-2.5407
    N7493 X.2464 Y1.5272 Z-2.5408
    N7494 X.2489 Y1.5198 Z-2.5409
    N7495 X.2547 Y1.5098 Z-2.541
    N7496 X.2647 Y1.4981 Z-2.5412
    N7497 X.2791 Y1.4861 Z-2.5413
    N7498 X.2974 Y1.4752 Z-2.5416
    N7499 X.3185 Y1.4667 Z-2.5418
    N7500 X.3437 Y1.4605 Z-2.542
    N7501 X.3558 Y1.459 Z-2.5422
    N7502 X.3726 Y1.4583 Z-2.5423
    N7503 X.9906 Z-2.5484
    N7504 X1.0185 Y1.4602 Z-2.5487
    N7505 X1.0412 Y1.465 Z-2.5489
    N7506 X1.0619 Y1.4725 Z-2.5491
    N7507 X1.08 Y1.4821 Z-2.5493
    N7508 X1.0952 Y1.4934 Z-2.5495
    N7509 X1.1064 Y1.5047 Z-2.5496
    N7510 X1.114 Y1.5157 Z-2.5498
    N7511 X1.1186 Y1.5259 Z-2.5499
    N7512 X1.1193 Y1.5288
    N7513 X1.12 Y1.5371 Z-2.55
    N7514 Y1.8828 Z-2.5534
    N7515 G3 X1.0887 Y1.914 Z-2.5539 I-.0313
    N7516 G1 X1.0661 Z-2.5541
    N7517 X1.0428 Z-2.5543
    N7518 X1.019 Z-2.5546
    N7519 X.995 Z-2.5548
    N7520 X.37 Z-2.5609
    N7521 X.346 Z-2.5612
    N7522 X.3222 Z-2.5614
    N7523 X.2989 Z-2.5616
    N7524 X.2762 Z-2.5619
    N7525 X.2681 Y1.9129 Z-2.562
    N7526 X.2606 Y1.9098
    N7527 X.2541 Y1.9049 Z-2.5621
    N7528 X.2492 Y1.8984 Z-2.5622
    N7529 X.2461 Y1.8909
    N7530 X.245 Y1.8828 Z-2.5623
    N7531 Y1.539 Z-2.5657
    N7532 X.2464 Y1.5272 Z-2.5658
    N7533 X.2489 Y1.5198 Z-2.5659
    N7534 X.2547 Y1.5098 Z-2.566
    N7535 X.2647 Y1.4981 Z-2.5662
    N7536 X.2791 Y1.4861 Z-2.5663
    N7537 X.2974 Y1.4752 Z-2.5666
    N7538 X.3185 Y1.4667 Z-2.5668
    N7539 X.3437 Y1.4605 Z-2.567
    N7540 X.3558 Y1.459 Z-2.5672
    N7541 X.3726 Y1.4583 Z-2.5673
    N7542 X.9906 Z-2.5734
    N7543 X1.0185 Y1.4602 Z-2.5737
    N7544 X1.0412 Y1.465 Z-2.5739
    N7545 X1.0619 Y1.4725 Z-2.5741
    N7546 X1.08 Y1.4821 Z-2.5743
    N7547 X1.0952 Y1.4934 Z-2.5745
    N7548 X1.1064 Y1.5047 Z-2.5746
    N7549 X1.114 Y1.5157 Z-2.5748
    N7550 X1.1186 Y1.5259 Z-2.5749
    N7551 X1.1193 Y1.5288
    N7552 X1.12 Y1.5371 Z-2.575
    N7553 Y1.8828 Z-2.5784
    N7554 G3 X1.0887 Y1.914 Z-2.5789 I-.0313
    N7555 G1 X1.0661 Z-2.5791
    N7556 X1.0428 Z-2.5793
    N7557 X1.019 Z-2.5796
    N7558 X.995 Z-2.5798
    N7559 X.37 Z-2.5859
    N7560 X.346 Z-2.5862
    N7561 X.3222 Z-2.5864
    N7562 X.2989 Z-2.5866
    N7563 X.2762 Z-2.5869
    N7564 X.2681 Y1.9129 Z-2.587
    N7565 X.2606 Y1.9098
    N7566 X.2541 Y1.9049 Z-2.5871
    N7567 X.2492 Y1.8984 Z-2.5872
    N7568 X.2461 Y1.8909
    N7569 X.245 Y1.8828 Z-2.5873
    N7570 Y1.539 Z-2.5907
    N7571 X.2464 Y1.5272 Z-2.5908
    N7572 X.2489 Y1.5198 Z-2.5909
    N7573 X.2547 Y1.5098 Z-2.591
    N7574 X.2647 Y1.4981 Z-2.5912
    N7575 X.2791 Y1.4861 Z-2.5913
    N7576 X.2974 Y1.4752 Z-2.5916
    N7577 X.3185 Y1.4667 Z-2.5918
    N7578 X.3437 Y1.4605 Z-2.592
    N7579 X.3558 Y1.459 Z-2.5922
    N7580 X.3726 Y1.4583 Z-2.5923
    N7581 X.9906 Z-2.5984
    N7582 X1.0185 Y1.4602 Z-2.5987
    N7583 X1.0412 Y1.465 Z-2.5989
    N7584 X1.0619 Y1.4725 Z-2.5991
    N7585 X1.08 Y1.4821 Z-2.5993
    N7586 X1.0952 Y1.4934 Z-2.5995
    N7587 X1.1064 Y1.5047 Z-2.5996
    N7588 X1.114 Y1.5157 Z-2.5998
    N7589 X1.1186 Y1.5259 Z-2.5999
    N7590 X1.1193 Y1.5288
    N7591 X1.12 Y1.5371 Z-2.6
    N7592 Y1.8828 Z-2.6034
    N7593 G3 X1.0887 Y1.914 Z-2.6039 I-.0313
    N7594 G1 X1.0661 Z-2.6041
    N7595 X1.0428 Z-2.6043
    N7596 X1.019 Z-2.6046
    N7597 X.995 Z-2.6048
    N7598 X.37 Z-2.6109
    N7599 X.346 Z-2.6112
    N7600 X.3222 Z-2.6114
    N7601 X.2989 Z-2.6116
    N7602 X.2762 Z-2.6119
    N7603 X.2681 Y1.9129 Z-2.612
    N7604 X.2606 Y1.9098
    N7605 X.2541 Y1.9049 Z-2.6121
    N7606 X.2492 Y1.8984 Z-2.6122
    N7607 X.2461 Y1.8909
    N7608 X.245 Y1.8828 Z-2.6123
    N7609 Y1.539 Z-2.6157
    N7610 X.2464 Y1.5272 Z-2.6158
    N7611 X.2489 Y1.5198 Z-2.6159
    N7612 X.2547 Y1.5098 Z-2.616
    N7613 X.2647 Y1.4981 Z-2.6162
    N7614 X.2791 Y1.4861 Z-2.6163
    N7615 X.2974 Y1.4752 Z-2.6166
    N7616 X.3185 Y1.4667 Z-2.6168
    N7617 X.3437 Y1.4605 Z-2.617
    N7618 X.3558 Y1.459 Z-2.6172
    N7619 X.3726 Y1.4583 Z-2.6173
    N7620 X.9906 Z-2.6234
    N7621 X1.0185 Y1.4602 Z-2.6237
    N7622 X1.0412 Y1.465 Z-2.6239
    N7623 X1.0619 Y1.4725 Z-2.6241
    N7624 X1.08 Y1.4821 Z-2.6243
    N7625 X1.0952 Y1.4934 Z-2.6245
    N7626 X1.1064 Y1.5047 Z-2.6246
    N7627 X1.114 Y1.5157 Z-2.6248
    N7628 X1.1186 Y1.5259 Z-2.6249
    N7629 X1.1193 Y1.5288
    N7630 X1.12 Y1.5371 Z-2.625
    N7631 Y1.8828 Z-2.6284
    N7632 G3 X1.0887 Y1.914 Z-2.6289 I-.0313
    N7633 G1 X1.0661 Z-2.6291
    N7634 X1.0428 Z-2.6293
    N7635 X1.019 Z-2.6296
    N7636 X.995 Z-2.6298
    N7637 X.37 Z-2.6359
    N7638 X.346 Z-2.6362
    N7639 X.3222 Z-2.6364
    N7640 X.2989 Z-2.6366
    N7641 X.2762 Z-2.6369
    N7642 X.2681 Y1.9129 Z-2.637
    N7643 X.2606 Y1.9098
    N7644 X.2541 Y1.9049 Z-2.6371
    N7645 X.2492 Y1.8984 Z-2.6372
    N7646 X.2461 Y1.8909
    N7647 X.245 Y1.8828 Z-2.6373
    N7648 Y1.539 Z-2.6407
    N7649 X.2464 Y1.5272 Z-2.6408
    N7650 X.2489 Y1.5198 Z-2.6409
    N7651 X.2547 Y1.5098 Z-2.641
    N7652 X.2647 Y1.4981 Z-2.6412
    N7653 X.2791 Y1.4861 Z-2.6413
    N7654 X.2974 Y1.4752 Z-2.6416
    N7655 X.3185 Y1.4667 Z-2.6418
    N7656 X.3437 Y1.4605 Z-2.642
    N7657 X.3558 Y1.459 Z-2.6422
    N7658 X.3726 Y1.4583 Z-2.6423
    N7659 X.9906 Z-2.6484
    N7660 X1.0185 Y1.4602 Z-2.6487
    N7661 X1.0412 Y1.465 Z-2.6489
    N7662 X1.0619 Y1.4725 Z-2.6491
    N7663 X1.08 Y1.4821 Z-2.6493
    N7664 X1.0952 Y1.4934 Z-2.6495
    N7665 X1.1064 Y1.5047 Z-2.6496
    N7666 X1.114 Y1.5157 Z-2.6498
    N7667 X1.1186 Y1.5259 Z-2.6499
    N7668 X1.1193 Y1.5288
    N7669 X1.12 Y1.5371 Z-2.65
    N7670 Y1.8828 Z-2.6534
    N7671 G3 X1.0887 Y1.914 Z-2.6539 I-.0313
    N7672 G1 X1.0661 Z-2.6541
    N7673 X1.0428 Z-2.6543
    N7674 X1.019 Z-2.6546
    N7675 X.995 Z-2.6548
    N7676 X.37 Z-2.6609
    N7677 X.346 Z-2.6612
    N7678 X.3222 Z-2.6614
    N7679 X.2989 Z-2.6616
    N7680 X.2762 Z-2.6619
    N7681 X.2681 Y1.9129 Z-2.662
    N7682 X.2606 Y1.9098
    N7683 X.2541 Y1.9049 Z-2.6621
    N7684 X.2492 Y1.8984 Z-2.6622
    N7685 X.2461 Y1.8909
    N7686 X.245 Y1.8828 Z-2.6623
    N7687 Y1.539 Z-2.6657
    N7688 X.2464 Y1.5272 Z-2.6658
    N7689 X.2489 Y1.5198 Z-2.6659
    N7690 X.2547 Y1.5098 Z-2.666
    N7691 X.2647 Y1.4981 Z-2.6662
    N7692 X.2791 Y1.4861 Z-2.6663
    N7693 X.2974 Y1.4752 Z-2.6666
    N7694 X.3185 Y1.4667 Z-2.6668
    N7695 X.3437 Y1.4605 Z-2.667
    N7696 X.3558 Y1.459 Z-2.6672
    N7697 X.3726 Y1.4583 Z-2.6673
    N7698 X.9906 Z-2.6734
    N7699 X1.0185 Y1.4602 Z-2.6737
    N7700 X1.0412 Y1.465 Z-2.6739
    N7701 X1.0619 Y1.4725 Z-2.6741
    N7702 X1.08 Y1.4821 Z-2.6743
    N7703 X1.0952 Y1.4934 Z-2.6745
    N7704 X1.1064 Y1.5047 Z-2.6746
    N7705 X1.114 Y1.5157 Z-2.6748
    N7706 X1.1186 Y1.5259 Z-2.6749
    N7707 X1.1193 Y1.5288
    N7708 X1.12 Y1.5371 Z-2.675
    N7709 Y1.8828 Z-2.6784
    N7710 G3 X1.0887 Y1.914 Z-2.6789 I-.0313
    N7711 G1 X1.0661 Z-2.6791
    N7712 X1.0428 Z-2.6793
    N7713 X1.019 Z-2.6796
    N7714 X.995 Z-2.6798
    N7715 X.37 Z-2.6859
    N7716 X.346 Z-2.6862
    N7717 X.3222 Z-2.6864
    N7718 X.2989 Z-2.6866
    N7719 X.2762 Z-2.6869
    N7720 X.2681 Y1.9129 Z-2.687
    N7721 X.2606 Y1.9098
    N7722 X.2541 Y1.9049 Z-2.6871
    N7723 X.2492 Y1.8984 Z-2.6872
    N7724 X.2461 Y1.8909
    N7725 X.245 Y1.8828 Z-2.6873
    N7726 Y1.539 Z-2.6907
    N7727 X.2464 Y1.5272 Z-2.6908
    N7728 X.2489 Y1.5198 Z-2.6909
    N7729 X.2547 Y1.5098 Z-2.691
    N7730 X.2647 Y1.4981 Z-2.6912
    N7731 X.2791 Y1.4861 Z-2.6913
    N7732 X.2974 Y1.4752 Z-2.6916
    N7733 X.3185 Y1.4667 Z-2.6918
    N7734 X.3437 Y1.4605 Z-2.692
    N7735 X.3558 Y1.459 Z-2.6922
    N7736 X.3726 Y1.4583 Z-2.6923
    N7737 X.9906 Z-2.6984
    N7738 X1.0185 Y1.4602 Z-2.6987
    N7739 X1.0412 Y1.465 Z-2.6989
    N7740 X1.0619 Y1.4725 Z-2.6991
    N7741 X1.08 Y1.4821 Z-2.6993
    N7742 X1.0952 Y1.4934 Z-2.6995
    N7743 X1.1064 Y1.5047 Z-2.6996
    N7744 X1.114 Y1.5157 Z-2.6998
    N7745 X1.1186 Y1.5259 Z-2.6999
    N7746 X1.1193 Y1.5288
    N7747 X1.12 Y1.5371 Z-2.7
    N7748 Y1.8828 Z-2.7034
    N7749 G3 X1.0887 Y1.914 Z-2.7039 I-.0313
    N7750 G1 X1.0661 Z-2.7041
    N7751 X1.0428 Z-2.7043
    N7752 X1.019 Z-2.7046
    N7753 X.995 Z-2.7048
    N7754 X.37 Z-2.7109
    N7755 X.346 Z-2.7112
    N7756 X.3222 Z-2.7114
    N7757 X.2989 Z-2.7116
    N7758 X.2762 Z-2.7119
    N7759 X.2681 Y1.9129 Z-2.712
    N7760 X.2606 Y1.9098
    N7761 X.2541 Y1.9049 Z-2.7121
    N7762 X.2492 Y1.8984 Z-2.7122
    N7763 X.2461 Y1.8909
    N7764 X.245 Y1.8828 Z-2.7123
    N7765 Y1.539 Z-2.7157
    N7766 X.2464 Y1.5272 Z-2.7158
    N7767 X.2489 Y1.5198 Z-2.7159
    N7768 X.2547 Y1.5098 Z-2.716
    N7769 X.2647 Y1.4981 Z-2.7162
    N7770 X.2791 Y1.4861 Z-2.7163
    N7771 X.2974 Y1.4752 Z-2.7166
    N7772 X.3185 Y1.4667 Z-2.7168
    N7773 X.3437 Y1.4605 Z-2.717
    N7774 X.3558 Y1.459 Z-2.7172
    N7775 X.3726 Y1.4583 Z-2.7173
    N7776 X.9906 Z-2.7234
    N7777 X1.0185 Y1.4602 Z-2.7237
    N7778 X1.0412 Y1.465 Z-2.7239
    N7779 X1.0619 Y1.4725 Z-2.7241
    N7780 X1.08 Y1.4821 Z-2.7243
    N7781 X1.0952 Y1.4934 Z-2.7245
    N7782 X1.1064 Y1.5047 Z-2.7246
    N7783 X1.114 Y1.5157 Z-2.7248
    N7784 X1.1186 Y1.5259 Z-2.7249
    N7785 X1.1193 Y1.5288
    N7786 X1.12 Y1.5371 Z-2.725
    N7787 Y1.8828 Z-2.7284
    N7788 G3 X1.0887 Y1.914 Z-2.7289 I-.0313
    N7789 G1 X1.0661 Z-2.7291
    N7790 X1.0428 Z-2.7293
    N7791 X1.019 Z-2.7296
    N7792 X.995 Z-2.7298
    N7793 X.37 Z-2.7359
    N7794 X.346 Z-2.7362
    N7795 X.3222 Z-2.7364
    N7796 X.2989 Z-2.7366
    N7797 X.2762 Z-2.7369
    N7798 X.2681 Y1.9129 Z-2.737
    N7799 X.2606 Y1.9098
    N7800 X.2541 Y1.9049 Z-2.7371
    N7801 X.2492 Y1.8984 Z-2.7372
    N7802 X.2461 Y1.8909
    N7803 X.245 Y1.8828 Z-2.7373
    N7804 Y1.539 Z-2.7407
    N7805 X.2464 Y1.5272 Z-2.7408
    N7806 X.2489 Y1.5198 Z-2.7409
    N7807 X.2547 Y1.5098 Z-2.741
    N7808 X.2647 Y1.4981 Z-2.7412
    N7809 X.2791 Y1.4861 Z-2.7413
    N7810 X.2974 Y1.4752 Z-2.7416
    N7811 X.3185 Y1.4667 Z-2.7418
    N7812 X.3437 Y1.4605 Z-2.742
    N7813 X.3558 Y1.459 Z-2.7422
    N7814 X.3726 Y1.4583 Z-2.7423
    N7815 X.9906 Z-2.7484
    N7816 X1.0185 Y1.4602 Z-2.7487
    N7817 X1.0412 Y1.465 Z-2.7489
    N7818 X1.0619 Y1.4725 Z-2.7491
    N7819 X1.08 Y1.4821 Z-2.7493
    N7820 X1.0952 Y1.4934 Z-2.7495
    N7821 X1.1064 Y1.5047 Z-2.7496
    N7822 X1.114 Y1.5157 Z-2.7498
    N7823 X1.1186 Y1.5259 Z-2.7499
    N7824 X1.1193 Y1.5288
    N7825 X1.12 Y1.5371 Z-2.75
    N7826 Y1.8828 Z-2.7534
    N7827 G3 X1.0887 Y1.914 Z-2.7539 I-.0313
    N7828 G1 X1.0661 Z-2.7541
    N7829 X1.0428 Z-2.7543
    N7830 X1.019 Z-2.7546
    N7831 X.995 Z-2.7548
    N7832 X.8519 Z-2.7562
    N7833 X.37
    N7834 X.346
    N7835 X.3222
    N7836 X.2989
    N7837 X.2762
    N7838 G3 X.245 Y1.8828 J-.0312
    N7839 G1 Y1.539
    N7840 X.2464 Y1.5272
    N7841 X.2489 Y1.5198
    N7842 X.2547 Y1.5098
    N7843 X.2647 Y1.4981
    N7844 X.2791 Y1.4861
    N7845 X.2974 Y1.4752
    N7846 X.3185 Y1.4667
    N7847 X.3437 Y1.4605
    N7848 X.3558 Y1.459
    N7849 X.3726 Y1.4583
    N7850 X.9906
    N7851 X1.0185 Y1.4602
    N7852 X1.0412 Y1.465
    N7853 X1.0619 Y1.4725
    N7854 X1.08 Y1.4821
    N7855 X1.0952 Y1.4934
    N7856 X1.1064 Y1.5047
    N7857 X1.114 Y1.5157
    N7858 X1.1186 Y1.5259
    N7859 X1.1193 Y1.5288
    N7860 X1.12 Y1.5371
    N7861 Y1.8828
    N7862 G3 X1.0887 Y1.914 I-.0313
    N7863 G1 X1.0661
    N7864 X1.0428
    N7865 X1.019
    N7866 X.995
    N7867 X.8519
    N7868 G0 Z2.5
    N7869 Y10.5 M5
    N7870 M33
    N7871 G0 G90 A0.
    N7872 M32
    N7873 G91 G28 Z0.
    N7874 M01
    N7875 T20 M6
    N7876 G91 G28 Z0.
    N7877 G90
    N7878 M2
    E
    Jun 2008
    9
    Re: Rotating H200 rotary table using 4th axis
    Thank you. Been on vacation, didn't see this til now
    Jun 2008
    9
    M33 and M22 are unclamp and clamp for rotating, correct?
    Jun 2008
    9
    Also how did you get your program in that little scrolling box?
    Jul 2010
    492
    m33 = unclamp
    m32 = clamp
    how to make the scrolling code box =
    ( Please remove the space after the word code )
    [code ]
    -- write down whatever here, like my nc code--
    [/code ]
    example
    Code:
    a
    b
    c
    d
    e
    f
    g
    h
    i
    j
    k
    l
    m
    n
    o
    p
    q
    r
    s
    t
    u
    v
    w
    x
    y
    z
    if all else fails, just hit the quote button and it will show you exactly how i wrote my post, which should be able to show you how its done....
    Jun 2008
    9
    Thanks, that pretty cool
    Jun 2008
    9
    Code:
    this
    is
    really
    cool
    nice
    trick
  1. Rotary table 4th axis set up
    By usfwalden in forum Knee Vertical Mills
    Last Post: 08-16-2018, 10:25 PM
  2. Hurco vmx42 with h200 rotary 4th.
    By Shane1234 in forum HURCO
    Last Post: 08-20-2017, 04:18 PM
  3. Rotary error when rotating around z axis.
    By Blackknight in forum NCPlot G-Code editor / backplotter
    Last Post: 05-22-2012, 11:38 PM
