Can someone help me in giving info about any software which can rotate an NC program over Y axis by 180 degrees. This is a case where if i have a program running from Bottom to Top in Z axis it has to change to Top to bottom and the X axis Co-Ordinates will change from Negative to Positive and vice versa.
Cimco editor can only rotate in 2 axis (X and Y point 2 axis rotation) or even X and Y mirror. The case i' am looking at is similar to making Z mirror but this is rotation of 180 degrees and not mirror.
Thanks in advance![]()
