603,958 active members*
2,572 visitors online*
Thread: Rough Balls
Results 1 to 8 of 8
Hybrid View
riche543 Rough Balls 01-07-2012, 10:46 AM
riche543 Anyone with any suggestions... 01-12-2012, 01:01 PM
riche543 Bump please. Sent from... 02-16-2014, 10:59 PM
bhurts I used the same kind of screw... 02-17-2014, 07:07 AM
riche543 Rough Balls 02-17-2014, 08:40 AM
lkenney Maybe you are missing a ball?... 02-23-2014, 02:44 PM
victorofga the click sound says that.. ... 02-23-2014, 03:08 PM
riche543 Rough Balls 02-27-2014, 12:58 PM
    Oct 2011
    218
    Rough Balls
    Hi guys,
    Anyone know if it's possible to reball (not sure if that's the right term). This type of ballscrew. I bought a set X,Y,Z this one being Z. Now the x& y are great super smooth, just z is a little sticky, I'm sure 420oz motors will still turn it but thought I'd ask if anyone knows how too fix the sticky problem ?. There is no rust on the actual screw , & tried greasing it . I've only found info on reballing the types with the external tubes. Also don't see how or where the balls can be removed or inserted on this type. There are 3 small red plugs around outside as shown in photo with the number 2 & 4 on them.not sure how they would be removed. Any thoughts would be appreciated , thanks
    Riche
    Oct 2011
    218
    Anyone with any suggestions would be great
    Cheers
    Oct 2011
    218
    Bump please.
    Sent from my iPhone using Tapatalk 2
    Jun 2013
    1041
    I used the same kind of screw on a router. It seemed stiff and tight when I first got it. After running it for a while it smoothed out. I would suggest you use it for a while and see what happens. That same screw is still good after 2 years of regular use and has worked great.
    Ben
    Oct 2011
    218
    Rough Balls
    Thanks for reply, but this isn't a new screw & isn't the one in the pic. (But same screw) It's on my y axis now 1200mm. What happens is it seems to click / jump not much but does Make quite a loud click , it doesn't seem to affect the job.
    Suppose my question is has anyone got some info on maybe re-balling this type of screw , that doesn't have external tubes.
    Cheers
    Jan 2008
    282
    Maybe you are missing a ball? Just a thought.
    Lowell
    Jan 2007
    1795
    the click sound says that.. beyond it is annoying,,, it might cause no issue..
    it is possible to reball, but question how much youll reduce backlash.. when you reach 0.01-0.02 mm from there nut is tightening up
    also take into account if you take it apart, then ,,, can you put together?
    if you damage those plastic plugs, what is very possible, then can you replace them? do you have spare part?
    can you define the necessary diameter of balls?
    or you have to buy 10-20 set of balls differing 0.002 mm from each other ?
    press some grease into the nut and click might be eliminated.. if it were mine, I wouldn't think a minute long to taking apart..
    without prior experiment and tools you can ending up very easily to buying a new..
    just my two cent
    Oct 2011
    218
    Rough Balls
    Thanks for replies , funny thing is it's a 1200mm screw but only clicks in one spot , let's say 300mm up the screw , inspected the screw it's self & doesn't seem to be damaged, my only thought now is it's slightly miss aligned , I will try loosening the fixing at that end of screw to see if it's that. Funny though as it's only started recently & not when first built , as it's quite a solid build.
    Anyway
    Cheers guys
  1. How many balls in nut?
    By phantomcow2 in forum Linear and Rotary Motion
    Last Post: 05-19-2019, 04:51 PM
  2. V25 PRO Advanced Rough/Adaptive Rough
    By RAF. in forum BobCad-Cam
    Last Post: 10-09-2013, 03:51 PM
  3. I lost my balls.... help
    By eartaker in forum Benchtop Machines
    Last Post: 12-05-2010, 03:39 AM
  4. Z Level rough with multipule rough tools
    By mbi in forum FeatureCAM CAD/CAM
    Last Post: 02-26-2010, 05:45 AM
  5. I have all these little balls.
    By Georgie in forum Linear and Rotary Motion
    Last Post: 09-01-2009, 09:50 PM
