![Quote](images/misc/quote_icon.png)
Originally Posted by
Need TECH Help!
Hi Tom,
The 150 is slightly smoother but nothing like the finish of a single axis cut.
Attached is a picture of closed loop at the Drives only. Even tho picture does not show it well,there is now a very visible pattern about every .100 to .125". Checking with a .0001" indicator as before, the high to low spots is easily .0008"
With closed loop still at drives only , watching the encoder readout in KMCNC, X and Y are off by .0002-.0004" from what was commanded.
So i would say when KFLOP is in closed loop mode that it is doing what it can with the way the drives are in Step/Dir mode.
Next test will be in analog mode.
Troy
