603,942 active members*
3,334 visitors online*
Results 1 to 6 of 6
Hybrid View
edu333 ROUGHING OPERATION Inconel... 02-20-2012, 04:01 PM
bubba107 I always call my cutting tool... 02-21-2012, 04:13 AM
yancho Read the packages of plates.... 02-21-2012, 09:01 PM
yancho Good luck 02-21-2012, 09:03 PM
aukylo when we are doing inco 710 I... 03-02-2012, 04:46 AM
uli12us I would better try carbide... 05-19-2012, 05:59 PM
    Feb 2012
    ROUGHING OPERATION Inconel 625!!!
    Hello all people, this is my first post here
    I have one problem turning Inconel 625, Im just using CERAMICS and Geometry of CNGN120712, and I have a bad surface facing.
    Im using Vc 250 F0.12 Ap1 , and I have always crater wear and bad surface.
    I heard that I need a lot of cutting speed.
    Somebody can help me? Some idea?
    Thanks ind advance
    Mar 2008
    7
    I always call my cutting tool supplier when I have a problem like that they have a huge amount of info on different feeds and speeds to run for any material .
    Good luck
    Oct 2010
    44
    Read the packages of plates. When you get a minimum speed and feed will start to have results. Different manufacturers give different valuable features of cutting tools and the rise to maximum, reduces tool life.
    Oct 2010
    44
    Good luck
    Mar 2012
    when we are doing inco 710 I think it is we use G50 constant surface speed. I think the speed tops out around 1000rpm. works great after you bump the speed up. we take around 50 cut per side. What type cutter are you using?
    Apr 2002
    5003
    I would better try carbide tools, which should be really sharp without or with TIN coating and much lubrication. From some tool producers there are special tools for aluminium. If you use those with low cutting speeds, they should make a good surface.
  1. VCarve Pro - Roughing and Re-Roughing
    By louieatienza in forum Vectric
    Last Post: 01-20-2014, 05:20 AM
  2. New to site, Need help with Inconel 625.
    By Erik F. in forum MetalWork Discussion
    Last Post: 11-02-2009, 06:18 AM
  3. Haas vs Inconel
    By espinja in forum Haas Mills
    Last Post: 10-24-2009, 02:19 AM
  4. inconel 710
    By jaimeoro in forum RFQ Feedback
    Last Post: 03-24-2009, 07:25 AM
  5. inconel
    By positiverake1 in forum MetalWork Discussion
    Last Post: 10-16-2007, 05:27 AM
