Originally Posted by
dengo
Sorry no, I don't quite get where you are coming from.
If you are working out from the centre of a piece of solid stock and just plunging in Z then I guess that at least your first move in X or Y will be a full width cut.
Maybe try using a helical entry to start the passes.
If you have your step overs set correctly (for example a 10mm tool may have a Min.Offset of 3mm and a Max.Offset of 8mm) and you are still getting full width slots then it could be the way your post is set up.
