603,785 active members*
17,317 visitors online*
IndustryArena Forum > Tools / Tooling Technology > CNC Tooling > Round Over Groove Router Bits
    Hello all.
    im searching for Round Over Groove Router Bits - for metal or plastic not wood, but for Styrofoam. we build models of castles and buildings and need this tool to create roof. we need to create something like this http://dl.dropbox.com/u/15047343/roof.jpg with this tool, because our standard metod of creating need a LOT of time - around 3 hours for one sample.....
    this tool describes it best
    Industrial CNC Round Over Groove Router Bits by Amana Tool
    the diameter of round part must be 4mm - 0.1575 inch...... :argue:
    Mar 2003
    35494
    Wood bits will cut plastic. But I doubt you'll find one for metal as the point would be too brittle.
    If you need a metric tool, then you'll probably need to find a european supplier.
    Point Cutting Roundover Bit by Amana Tool
    Groove Forming - Point Cutting Plunge Roundover Bits
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    GER21 - Thanx a lot, for me is no problem from where im order it, we try to make it close as possible to the 4mm - see our page MúzeumHistorickýchBudov what we do, is in 1:25 scale so we must stay close as possible that is have right scale.
    THANX
  1. Retrofitting the old V-Groove Router to round linear slides!
    By widgitmaster in forum CNC Wood Router Project Log
    Last Post: 11-24-2011, 07:52 PM
  2. My New 24x24 V-Groove Router Design Log
    Last Post: 11-04-2010, 08:26 PM
  3. My new V-Groove Router design
    By djmrozin in forum DIY CNC Router Table Machines
    Last Post: 01-25-2009, 05:45 PM
  4. Router bits, End mills v bits
    By bogger44 in forum Commercial CNC Wood Routers
    Last Post: 12-03-2008, 07:06 PM
  5. Using a router for the 1st time. Need advice of cut speeds, router bits etc.
    By Apples in forum DIY CNC Router Table Machines
    Last Post: 09-23-2006, 09:33 PM
