603,333 active members*
3,581 visitors online*
Results 1 to 5 of 5
    Hello everybody!
    How can I declare a round workpiece in block form? Is it possible in general?
    Thanks in advance
    Regards
    4runner
    Wissen ist das einzige Gut das sich vermehrt, wenn man es teilt.
    Sep 2005
    439
    Hello 4runner
    Unfortunately it’s not possible. But you can program a circle pivot of a desired size with an according tool. And your block form will be round.
    <br /><br /><br />herzliche Grüße<br /><br />Gonzales
    Feb 2005
    314
    Hello 4runner,
    Only foursquare is possible.
    When I have a round detail, then I choose BLK form a bit bigger than the diameter and program a small circle of a desired diameter in the first line.
    Don’t forget to delete the line at the end.
    <b>MfG<br />mister</b><br /><br />--<br /><br /><i>Wenn man Erfolg hat, ist es das Schwerste, jemanden zu finden, der sich mit einem darüber freut.</i>
    Thanks a lot for your rapid answers!
    I also thought that only foursquare details are possible to make. But I can help myself as you wrote
    Regards
    4runner
    Nov 2006
    279
    It’s a cool thing. Thanks for the tip!
