587,881 active members*
4,193 visitors online*
    Jan 2007
    21
    Router bit for foam
    Hi, Im looking for a router bit for EPS, Poly foam and soft wood (Balsa and Basswood) .I hope some one can point me to the right place.I can find small bits but no big bits I attached a link to a picture of the bits
    im looking for. Here are the specs.
    CUTTER HEAD DIMENSIONS: 1.22" (31mm) Diameter X 2.83" (72mm) Length.
    SHAFT/SHANK DIMENSIONS: 1/2" Diameter X 1.5" (38.1mm) Length.
    This cutter is also suited to any CNC Machine that takes A 1/2" Shank
    I cant find any one in the US that makes this size of bit.Thank you
    for your help.
    Mark
    Jun 2007
    32
    I cut XPS foam all the time. We use standard HSS tooling for most everything. I have had several custom cutters made by OSG Sossner, and an Italian company Fapil. I have a 2" ball HSS with a 1" shank that OSG made. Long lead time, but it was nice when we recieved them.
    I am not sure that you will be able to cut the Balsa and Basswood with the same cutter. All my cutters have upshear to get the chips out of the channel.
    Paul
  1. BIG router bit for foam
    By benergy in forum Material Machining Solutions
    Last Post: 10-30-2017, 12:37 PM
  2. Foam router
    By KrashKing405 in forum CNC Wire Foam Cutter Machines
    Last Post: 12-26-2006, 12:51 AM
  3. CNC Foam Cutting Router
    By pitsbros in forum Hobby Discussion
    Last Post: 09-28-2006, 04:12 AM
  4. What is the best router to cut this foam/rubber?
    By Darc in forum DIY CNC Router Table Machines
    Last Post: 08-28-2005, 02:39 AM
  5. Foam Cutter/Router
    By CADkathy in forum CNC Wire Foam Cutter Machines
    Last Post: 11-19-2004, 04:30 PM
