603,790 active members*
2,555 visitors online*
IndustryArena Forum > SignMaking > Signmaking Topics > Router Bit Recommendations?
Results 1 to 4 of 4
    Jul 2010
    I'm looking for good V cutting router bits that have a sharp point. The one I got from Rockler was anything but. Do any of you have recommendations of high quality bits that will cut sharp Vees for signs?
    Mar 2003
    35494
    They're quite expensive, but most manufacturers make a solid carbide 3 flute bit like this.
    Signmaking and Lettering Router Bits by Amana Tool
    You might also want to look at these.
    V Groove Miter Fold & Signmaking Insert Router Bits by Amana Tool
    Although smaller, I've had good results with this bit, although I only used it once. 60° 1/4"
    cnctoybox
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Dec 2004
    1316
    Those solid 3 flute cutters from Amana are very good. Quality of the cut is excellent.
    Jason
    Jul 2010
    Thanks for the advice guys. I ended up buying the 90 degree replaceable insert V bit from Amana. It was expensive ($95) but it cuts beautifully and the replaceable inserts at $15 each for two cutting edges are cheaper than paying to have a solid bit resharpened. So in the long run it's a pretty good investment.
  1. Recommendations for small chinese router
    By HerrBo in forum Want To Buy...Need help!
    Last Post: 04-21-2012, 06:36 AM
  2. CNC router tabletop recommendations
    By fuper in forum Want To Buy...Need help!
    Last Post: 05-27-2010, 01:16 AM
  3. Router Bit recommendations/suppliers
    By zeeway in forum DIY CNC Router Table Machines
    Last Post: 02-17-2010, 12:52 PM
  4. Software and controller recommendations for ROUTER
    By Scott Evans in forum Commercial CNC Wood Routers
    Last Post: 07-10-2007, 06:26 AM
  5. Recommendations Modify cnc router for foam
    By simso in forum CNC Wire Foam Cutter Machines
    Last Post: 04-09-2007, 05:05 PM
