Re: Router losing data / information
Originally Posted by
Gary-Wiant
Since I got my spindle & vfd setup my router hasn't finished a job correctly. I sent a job with 5 cuts & after the first 3 went fine the 4th one started cutting diagonally across the board. I reset everything & tried again it did the same after the second shape. So I sent just the outside pocket cut it did the shape but didn't cut the whole way through the pvc the whole way around the shape. It kind of looks like it ramps out of the whole (part of it cuts through part of it doesnt).
I check all data cables & everything seems right. I also sent my g-code to a local machine shop & he said it looks correct without any issues
Any help is greatly appreciated
The answer may be in your first sentence if this just started happening. It could be electrical noise, maybe try moving the VFD cable well away from your signal cables. Maybe a grounding issue?
Jim Dawson
Sandy, Oregon, USA
