587,997 active members*
2,892 visitors online*
Thread: Router Mount
Page 1 of 2 12
Results 1 to 20 of 25
    Dec 2004
    20
    Router Mount
    I seem to recall seeing a really nice aluminum router mount for a porter cable 7518 that someone had made, ( I think it was the first job they did on their machine), If someone recalls this post can you please direct me to it. Thanks, John.
    Mar 2003
    779
    Look at this post. http://www.cnczone.com/forums/showthread.php?t=171
    find post numbers 47 and 48 on page 6
    Jeff Davis (HomeCNC)
    http://www.homecnc.info
    Dec 2004
    20
    Thats the one Jeff, thanks , John
    Mar 2003
    779
    John, Were you able to do something with the code I sent you?
    Dec 2004
    20
    Jeff, I have a .375 collet on order for my router since all I have is .250 & .500. My router is now temporarily mounted with mounts I made out of oak so I can use it to make the aluminum ones. I did run your file with a v groove bit in wood just to see how it worked and it came out perfect. I'll let you know when I use it on the aluminum. Thanks again, John.
    Dec 2004
    20
    Jeff, here are some pics of my machine making the mounts with your g code. This is the first actual run done on the machine. Notice the "high tech" temporary oak mounts. I was surprised they held up as well as they did on the aluminum. Thanks again for the code. John
    Attached Thumbnails Attached Thumbnails IMGP0656.JPG   IMGP0658.JPG   IMGP0659.JPG   IMGP0661.JPG
    Mar 2003
    779
    Hey John! That did work out great! I have already received an email from someone else, who read this post, wanting the code for them as well. I think when I find it I will post it here for all others who need it.
    Apr 2003
    19
    Quote Originally Posted by HomeCNC
    If you could post the code Jeff, that would be great as they look just what I need
    Steve
    Aug 2004
    3215
    Just wanted to say looking great guys.
    Also noticed dry cutting alumn. what bit and stepdown did you use?
    Thanks, Joe
    Mar 2003
    779
    Without knowing the capability of his setup I chose a 3/8" end mill and had a step down of .050. I forgot to get the code over the weekend. If I forget again maybe Wired can post what I sent him. I will also try to remember when I get home tonight.
    Apr 2004
    162
    Router mounts
    If you are able to locae the code for these mounts, I would be interested in having a go at them myself.. right now, I have a very shaky mount system, and would love to have one that actually looks good.. HAhahaha
    btw.. thanks for offering them up!
    Eddie
    Dec 2004
    20
    Here are the g-codes for the 7518 router mounts
    Attached Files Attached Files
    Apr 2004
    162
    THANK YOU! I appreciate it.. Now I just need to pick up some quality wood to make them from... then when I get some decent end mills and a variable speed control, maybe I will consider attempting aluminum...
    Eddie
    Mar 2003
    779
    Some more info about setup for the router mounts.
    The G-code is built to use a 3/8” end mill. The 0,0,0 is the lower left corner and at the top of the ½” material. I would use two bolts in the center area of the part to hold down the plate while you run the G-code for cutting the outside profile. Then clamp the part from the outside and run the G-code for cutting the inside hole out. The plate stock is 6.0 in X and 5.35 in Y and .50 in Z.
    This mount is for the Porter Cable #7518 3-1/4 HP rounter.
    http://www.cnczone.com/forums/attach...tachmentid=193
    http://www.cnczone.com/forums/attach...tachmentid=196
    Apr 2004
    162
    Well, of course, I had to leap ahead and not think things through.. as usual.. Just realized that this was designed for a full-size router, and since I am using a laminate router, my body is much smaller in diameter.. oh well.. I am going to buy a new item anyways.. it is a rotozip from walmart for $39.96.. it has a 1/4" & a 1/8" collet.
    It has a built in, non-removable handle wich may be a problem for mounting, but for the interchangable collet, I am willing to work with that.. anybody used one of these as a cutting source yet, and maybe made a mount for it? *GRIN* .. if not, I guess I will have to learn a CAD program, and design my own....
    Will make a good excuse to learn CAD after all, I guess.
    Eddie
    Apr 2004
    162
    FOLLOWUP.. it is not an actual ROTOZIP brand.. trying to remember the name.. thinking it is a Black & Decker, but not sure.. will post when I recall the brand name...
  17. #17
    Apr 2004
    162
  18. #18
    Aug 2004
    3215
    Its black and deckers version of the rotozip, but i would stick with rotozip, the one i use on my cnc has a variable speed settings, 15,000, 20,000, 25,000 and 30,000 rpm. and also has a cool light that shines on the work piece.
    Joe
  19. #19
    Apr 2004
    162
    B&D v.s. Rotozip
    Would I be able to use a variable speed control for a router with this to adjust the speed?
    This one is $39.96 (plus my 10% discount) and a brand name Rotozip costs a minimum of $89.96.
    I have also noticed that ALL the Rotozip brands I have found now have a hand tightened drill press style 3-chuck bit holder, as opposed to a replacable collett with a wrench tightening system, like this one. I thought i had seen people say that the 3-jaw chuck were not a good idea when applying sideways forces as is being done in Milling.
    I just have to wonder, though, since Rotozips are specifically made for sideways forces to be applied.. anyone able to give an opinion on this?
    Quote Originally Posted by joe2000che
    Joe
  20. #20
    Mar 2004
    636
    Error running the g code for the router mount
    I tried doing a dry run in turbocnc for the router mount code, but it says that it does not recognize some of the code. Is this meant to be run in say Mach 2 or other software? Does anyone have the code for this mount that is compatable with TurboCNC?
    Check out what I am working on at www.routerbitz.com!
Page 1 of 2 12
  1. Finding The Right Router
    By Crushmonkey in forum Commercial CNC Wood Routers
    Last Post: 06-19-2006, 07:17 AM
  2. Porter Cable Router Motor Mount
    By dowling177 in forum DIY CNC Router Table Machines
    Last Post: 04-05-2005, 01:40 AM
  3. RFQ - Makita Router Mount Bracket
    By samualt in forum Employment Opportunity
    Last Post: 01-26-2005, 06:43 AM
  4. Need advice on router mount
    By samualt in forum DIY CNC Router Table Machines
    Last Post: 11-08-2004, 04:14 PM
  5. z-axis router help help
    By camfambmw5 in forum DIY CNC Router Table Machines
    Last Post: 10-10-2003, 03:05 AM
