587,311 active members*
3,486 visitors online*
Results 1 to 16 of 16
    Mar 2012
    68
    Router or spindle (chinese)
    I am in the process of getting the part for a crp4848 type machine and am trying to decide on how to go for the cutter. I want to be able to control the speed from mach3. I have a boach 1617, but I would still want to use that in handheld work, and it would be hard to take it in and out.
    I see 2 options.
    First would be a router with a super pid for the speed control, but I guess i would have to modify the router to disable its own speed control (compensation). So the cost would be a router (~$180), Super PID ($155), mount (~$100) for a estimate of $435.
    The second option would be a 2.2 kw chinese spindle. I would need spindle (359), vfd (199), mount(99), cooling (50) for a total of 707 from kelling. Or less than $300 + mount and cooling on ebay (which is what I would do).
    I was just wondering if anyone had any thoughts on this and if I am missing something big? I was also thinking about getting a smoothstepper for the control of the speed. The machine will be using 878oz motors from longsmotor and I will be cutting mdf, birchply and some alum (maybe).
    Any thoughts?
    Mar 2003
    35538
    The $300 on Ebay does not include a VFD. Most people recommend getting a Hitachi VFD, rather than the Chinese, which is about $200. The spindle is at least $175-$200 more.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Mar 2012
    68
    The spindle I saw on ebay was this one WATER COOLED SPINDLE MOTOR 2.2KW & INVERTER for $264 with both?
    Where can you get the hitachi vfd?
    Mar 2003
    35538
    The shipping is $135. Again, most people don't redcommend the Chinese VFD, as they go bad quite often.
    Gerry
    Mar 2012
    68
    Ok lets just say I was to go with a chinese spindle and a Hitachi vfd. Thats looking about $100-$200 more the the router setup.
    Question is how much better would the spindle setup be? I just don't want to go the router way and then replace it with a spindle later.
    Dec 2007
    379
    I don't have any experience with a super PID and router setup, but I found the 2.2KW spindle to be a significant improvement over a router alone. If the 1.5KW came with and ER20 collet I would have gotten that, because at around $220, its disposable after making the investment in a quality VFD.
    Feb 2012
    Those water spindles,they also do an air cooled one which will then mean you don't have to
    buy the coolant pump and line.
    Mar 2003
    35538
    The air cooled ones with shaft mounted fans can be extremely loud at high rpm's.
    Gerry
    Feb 2009
    1290
    Here is a thought, I read in one of Gerry's posts that he has been using the Porter Cable 690 at his place of work for quite a long time (number of years) they have been very reliable. There is a video on you-tube which shows how to change the bearings which do not cost all that much. I like the idea of the PC690 having a RPM curve of 5K to Max 23K or so (With S-PID), I’m not sure if the Chi spindles will do the low end range. I was even thinking of purchasing a spare PC690 and spare set of bearings so when the eventual failure occurs, I can swap out the routers and carry on with the job while replacing the bearings in the original router. Down time would be at a minimum and the cost would be about the same as the Chi spindle + VFD setup + shipping.
    The drawback of the PC690 can be the loudness, they scream at max RPM while I have heard the Chi water cooled spindles are very quiet.
    Just a thought…
    Thank You.
    Mar 2011
    584
    A router mount from K2 cnc is only about $55.
    I chose the Router & super PID route only for the $ issue. No regrets Its working great! :banana: If it was the same price i would go for the spindle & hitachi vfd.
    Mar 2012
    68
    If I go with the super pid and the router wouldn't I have to do something to it to disable the the speed control in it? If so this would void the warranty right?
    Aug 2008
    142
    If you go with the hitachi the heck with the warranty. You can get all of the bearings from NAPA. The routers are easy to rebuild. Removing the speed control would void the warranty.
    Mar 2011
    584
    Quote Originally Posted by allengambrell View Post
    Yea but does a china spindle have a warranty? As said there is something about being able to run down to your local hardware store and pick up a new router if the one you were using ever died.
    Mar 2003
    35538
    Quote Originally Posted by vtx1029 View Post
    Some supposedly have 2 year warranties. But shipping to China and back is probably well over $100?
    Gerry
    Dec 2007
    379
    If someone has experience with both a spindle and a router with PID please state your experience.
    Apr 2012
    I also have the same question." Is the chinese spindle a better option than going with a router for a cnc machine"? Noise? runout? spindle quality? long run times? ect.
  1. Mini Mill X2 Spindle Head + VFD + Chinese Spindle= custom!
    By diyengineer in forum Uncategorised MetalWorking Machines
    Last Post: 12-26-2016, 10:04 PM
  2. Chinese Router Spindle Bearings
    By wizzardworks in forum Chinese Machines
    Last Post: 04-24-2014, 06:26 AM
  3. Chinese CNC Router
    By jchkramer in forum Chinese Machines
    Last Post: 10-23-2012, 07:47 PM
  4. Chinese CNC router
    By eadya in forum CNC Wood Router Project Log
    Last Post: 12-21-2011, 09:37 AM
  5. Different chinese cnc router~
    By limacrouter in forum News Announcements
    Last Post: 03-29-2010, 12:40 PM
