586,035 active members*
3,712 visitors online*
    Aug 2009
    119
    Router vs Mill conguration?
    Can Mach3 be configured in a conventional router style, with the x axis forward and back, and the y axis side to side?
    I can get the machine to move and jog correctly with the arrow keys by switching the output pins or switching the motor connectors in the drivers, but the sceenset DRO display is still wrong.
    Alternately, can the outputs from the arrow keys themselves be switched in the computer?
    Mar 2003
    35538
    Re: Router vs Mill conguration?
    To me, a conventional router has the X move from left to right.
    No, you can't change the coordinate system in Mach3. X is always left to right. But you can change the hotkeys for jogging with Config > Hotkeys.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Aug 2009
    119
    Thanks Ger, that worked great!
    But.... the motion in the table display screen is still reversed :-(
    I'm just going to bite the bullet, retrain my brain, and go with the mill convention, there more important battles to fight, Unless theres a way to change the display screen direction?
  1. Router vs. mill
    By Ugilten in forum DIY CNC Router Table Machines
    Last Post: 08-10-2016, 12:01 PM
  2. Our first cnc router (or a mill if you say)
    By mitis in forum Uncategorised MetalWorking Machines
    Last Post: 09-27-2014, 07:04 PM
  3. CNC Mill or CNC Router?
    By spacifique1 in forum Australia, New Zealand Club House
    Last Post: 03-16-2007, 05:59 AM
  4. Router or Mill?
    By UKRobotics in forum Uncategorised MetalWorking Machines
    Last Post: 04-04-2004, 06:45 AM
