I'm having a problem where I'm cutting some parts out of a sheet of aluminum, the center of the bit gets to about the the edge of the sheet, then it will lift up move to a new spot and start cutting again. Its like it wont move past 0 on the x and y coordinates while running the g-code. I thought it was something I did wrong in Aspire, but the preview shows the bit cutting all the way around my parts. I never had the problem before it just started happing, so I'm wondering is there a setting in Mach 3 that will cause this? I would think maybe soft limits but I dont have them on, and that should only happen for machine coordinates and not part coordinates?
