587,997 active members*
2,187 visitors online*
    Jul 2010
    Routing PP Sheet
    Hello,
    I've recently been tasked with cutting polypropylene sheet on a CNC router. I'm using a 3/8" 2-flute upcut spiral at 16000 RPM and 300 IPM. The problem I'm having is in 3/4" thick material where I'm taking 1/4" passes and the chips are getting stuck in the groove left behind the tool path. This only happens on the 2nd and 3rd passes. When I say stuck I mean really stuck. High pressure air sometimes does not work to eject the chips. The stuck chips are being re-cut by the tool and causing a poor finish. I cut 3/4" thick polyethylene and even 1/2" thick polypropylene without this issue. Any advice is appreciated. Thanks in advance.
    Apr 2007
    777
    Compressed air to blow the chips out and cool the tool would be my first guess. My second would be that your spindle speed is too high. I haven't ever done this task myself however so hopefully someone with more experience will comment.
    Mar 2003
    35538
    Cut your spindle speed to 10,000 - 12,000, or increase your feedrate.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
  1. Routing Aluminium sheet
    By kong in forum DIY CNC Router Table Machines
    Last Post: 05-06-2016, 08:44 AM
  2. CNC Routing?
    By slamman in forum WoodWorking Topics
    Last Post: 05-11-2010, 06:55 PM
  3. Routing 1/32 thick sheet metal
    By dbtoutfit in forum DIY CNC Router Table Machines
    Last Post: 08-09-2007, 08:10 AM
  4. RFG - FOAM SHEET ROUTING in MELB AUSTRALIA
    By clp in forum Employment Opportunity
    Last Post: 10-26-2006, 05:33 PM
  5. Routing Alu sheet
    By ScuD in forum DIY CNC Router Table Machines
    Last Post: 09-26-2005, 01:17 PM
