We have inherited a 'pot' status message on our Y axis servopack.
We have rebooted the machine several times, manually repositioned the axis, still an error.
What is this error telling me. Can it be reset.
POT = positive over travel on Y. If repositioning the axis manually off of the switch does not help, check to see if the switch is stuck. There should be several switches on the one unit (positive over travel, negative overtravel, & homing) Make sure you are checking the right switch. You should be able to tell by lining it up with the ramp associatted with Y+ travel.
Mark T
CNC Custom Services - CNC Service, CNC Support, CNC Training for the CNC Woodworking Industry focused on CNC Routers and CNC Point-to-Point Machines.
