Machine will send program to pc but pc to cnc loads from pc but cnc keeps flashing loading.... Takisawa MAC2 mill with Fanuc 10M. Tera Term download software. Help.....
If this means that when your NC receives a program, it loads the program fine but the LOAD message on the screen never disappears. Then the problem is that it never receives the end of record wich generally uses the % simbol, try writing this symbol at the end of the program, also you can press RESET to erase the LOAD and all will be OK.
If the problem is diferent maybe you can explain so I can try to help you.
GP.
I have just the opposite problem with a 10tf. can send to control but can't receive from control w/ tereterm. control keeps flashing "punch" but no data is sent to pc.
