603,853 active members*
2,839 visitors online*
Results 1 to 5 of 5
    Dec 2006
    35
    rs232 port on M1
    Does anyone know the purpose of the rs232 port located on the fx01 board?
    Dec 2003
    24260
    One purpose of the RS232 port SCN1 on the FX701 board on the M2 is to use a laptop to clear memory.
    Not sure it it is the same purpose on an M1?
    Al.
    Albert E.
    Dec 2007
    300
    Just wondering what type of laptop they would have used in 1981 when the M1 was introduced? The CMT port used the casette deck and the other RS232 ports were Mitsubishi diagnostic ports as I remember. But of course I could be wrong. Clearing the memory to reinitialize the control was done with dip switches according to my M2 restart procedure.
    Dec 2003
    24260
    All I know is I have a Mitsubishi service bulletin that outlines the procedure using Hyperterminal or any modem program.
    I had a problem where the memory would not initialize using the normal method and this was a last resort procedure.
    Al.
    Albert E.
    Oct 2007
    53
    Does any one has used drip feed mode on Mazak M-1 Control ?
    If yes, what are the settings ?
  1. program input/output with RS232 port on Mitsubishi 50L
    By Chuck Reamer in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-21-2013, 08:56 AM
  2. test plug rs232 port not respond
    By joseponzo in forum Fadal
    Last Post: 10-16-2007, 07:23 PM
  3. PC to RS232 port software
    By Independent CNC in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-15-2007, 09:18 PM
  4. rs232\serial port (Voltage)
    By j m in forum Computers / Desktops / Networking
    Last Post: 08-05-2005, 01:43 PM
  5. How to drip link from pc to RS232 port
    By jamie in forum CNC Machine Related Electronics
    Last Post: 02-12-2005, 05:54 AM
