603,979 active members*
1,382 visitors online*
Results 1 to 4 of 4
    Jun 2006
    87
    Rs232 Problems
    Got A New Vf2 ... I Can Not Get It To Take Progs. From My Computer ( Using Cimcom ... Same Software I Use On All My Other Machines ) Can Someone Please Help Me... Maybe Even Just Go Thru The Process For Me ... I May Be Leaving Out A Step Or Something
    Apr 2006
    97
    have you checked the board rate is set the same as the computer
    Mar 2005
    1498
    070507-1624 EST USA
    j-radkemachine:
    You have to provide far more information.
    What machines can you communicated to at the present?
    What are your settings at the computer, the working CNCs, and the HAAS --- baud rate, stop bits, parity, handshake mode, cable length?
    What are the pin connections at both ends of your HAAS and other cables?
    What is the year of manufacture of the HAAS?
    Does either direction of transfer with HAAS work?
    After you initiate RECV at the HAAS what message does HAAS display and does it change after you start sending a program? Do you get an error message or flashing red beacon?
    Will a simple program like the following load?
    O3030
    (test)
    M30
    Jun 2006
    87
    Thanks Daleman... That Was Part Of It.... Duh.. Didnt Even Check It
  1. Boss nine rs232 problems
    By Plateroom in forum Bridgeport / Hardinge Mills
    Last Post: 09-20-2008, 11:29 AM
  2. Fanuc OM-D Rs232 problems
    By SpringKing in forum Fanuc
    Last Post: 09-13-2007, 10:18 PM
  3. 3T model F rs232 problems
    By Jerrytool in forum Fanuc
    Last Post: 02-08-2007, 06:53 AM
  4. Fanuc RS232 problems
    By wsuwrhr in forum DNC Problems and Solutions
    Last Post: 09-04-2006, 07:25 PM
  5. Problems you have or had with RS232?
    By gar in forum Polls
    Last Post: 12-22-2005, 05:21 PM
