Hi All, (this is my first post in many years here, I had to create a new account)
I am presently in need of raising some funds for projects, so I have had to bite the bullet and am now making this beautiful piece of equipment available. I had been keeping it to use as part of a DIY CNC machine project, but I really need to raise the cash so it has to go.
This is a very high-end quality industrial "Panel PC" normally used for HMI or SCADA applications of control systems - it's an all-in-one touchscreen and PC unit, designed to fit in a rectangular hole in a control panel. It's very rugged, tough, and built to last. The front bezel is an aluminium casting, with galvanised steel enclosures to the rear.
It's in almost-unused like-new condition, and dates roughly from 2014/2015 ish. It has only seen some light lab/demo use. It was built with Windows XP (even though W7 was released by then) due to requirements of the software it was to be used with. It still has Windows XP Professional SP2 installed as can be seen in the images.
On the front it has a waterproof cover containing a USB socket to the bottom left corner of the screen. There are also Power and Temperature indicator LEDs. To the rear is an enclosure containing the computer elements, including a DVD writer, two Ethernet Network ports, four rear USB ports, Profibus port, RS232 serial port, and also additional DVI monitor port (Unsure if this is to support multiple displays or is an alternative to the main display), and Phoenix Contact connector for 24V DC power supply (connector included), plus two PCI slots. (24V power supply not included, I am using my own test power supply unit in these images).
I have tested it as far as can be seen in the images, the touchscreen works well, It boots, programs run, shuts down all as expected. I have also tested it with a USB mouse too which works fine, a USB keyboard can also be plugged in.
Spec from the label:
Panel 19" T 677/877
Mainboard CV4 with Profibus
Core 2 duo T7400 2.16 GHz 4 MB L2 (dual core)
Busboard 2 PCI Slot
2048 MByte DDR2 667 SODIMM
160 GB HDD SATA + DVD-Writer
Windows XP Prof. MUI SP2 / 677B
It also includes all of the brackets to mount it through a panel cutout.. the bezel has a rubber seal on the rear face which would abut to the front of the panel around the cutout, making a water-tight seal; at the rear the included brackets clip to the sides of the monitor housing and screws press against the inside of the panel, mounting it in place.
Due to it's ruggedness it is quite heavy. I am happy for local collection from South Leicestershire, UK, forum courier service, or to weigh it and organise a courier at buyers cost (and risk). I will be visiting Bristol by car in the coming couple of weeks so would be more than happy to bring it down with me to Bristol, or to meet somewhere en-route.
I am asking £100 for it which compares to sale prices of similar units on other sites, Payment please PayPal only. Please PM for details, first come first served, no hat. It will be marked as sold when payment is sent.
I'm open to questions about it, please drop me a line.
Please note, this is also listed on another forum.
Many thanks, Scott
