603,850 active members*
5,694 visitors online*
Results 1 to 5 of 5
    Oct 2007
    1072
    running mach3
    I tried running mach 3 with a notebook that has a lpt port configured the same as a desktop computer i was using.
    The cnc went crazy ,sounded like the bearing and gears were not meshing properly ,manufacturer says laptops and mach 3 don't get along very good ,the lpt port on the laptop can be used but has to be set up ,anyone have experience with this
    woodman
    Aug 2004
    3215
    If I use my laptop to a driver board what does not require a BOB it does not work, if i use it with an iso. bob with its own 5v PSU it works fine. What Drivers are you useing and if so what BOB?
    Joe
    Oct 2007
    1072
    mach 3 and notebook
    not sure what you mean about drivers there are no drivers for an lpt port ,i just replaced the dsesktop with a notebook same mach3 settings and it works fine testing with the arrow keys but when i run gcode the machine goes crazy and there are no settings to change.
    Its almost as if the notebook does not send a continuous signal,tried the bi direction and 2 other settings
    Other people are reporting the same problem and my notebook is older as new ones don't have a lpt port
    Aug 2004
    3215
    Motor Drivers, not driver for lpt port that is built into windows.
    the problem is the 3.5v from the printer port on the laptop, the bob card will up this to the required 5v and improve signal strength. this was the case on mine and I run my CNC 4x4 Hybrid with a Toshiba laptop now.
    Joe
    Mar 2003
    35494
    It could be lots of things. Mach3 won't run on a lot of notebooks, and for some, you may need to disable a lot of things to get it to work properly. It varies from laptop to laptop. It could also just be as Joe said, 3.3V ports.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
  1. Running flood coolant from Mach3
    By BrassBuilder in forum Benchtop Machines
    Last Post: 02-13-2008, 06:50 AM
  2. Running Mach3 for laser cutting questions
    By cncadmin in forum Mach Plasma / Laser
    Last Post: 09-15-2007, 04:34 AM
  3. Laptops Running Mach3?
    By Fred Kelly in forum Shopmaster/Shoptask
    Last Post: 09-10-2007, 02:07 PM
  4. Anyone running Mach3 with a DynaCNC table top?
    By CrashMasterKev in forum Machines running Mach Software
    Last Post: 11-22-2006, 03:36 AM
  5. Mach3 running the new G203 Vampire drivers
    By Dan Mauch in forum Gecko Drives
    Last Post: 11-15-2006, 08:00 PM
