603,316 active members*
2,227 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Running stepper motor wire with router wire?
    Jan 2010
    76
    In building my router (see below link), i have thusfar not properly mounted my router's power wire, and i was considering running it with the stepper motor wire (actually having the stepper motor wire wrapped around the thicker router wire in a loose spiral).
    Has anyone had experience with this or had issues with the flux field generated by the router's wire inducing currents in the stepper wire???
    Thanks,
    http://www.cnczone.com/forums/showthread.php?t=98950
    Jun 2007
    3738
    No problem (IMHO)
    The stepper wire may help more interference to the outside world via tha mains cable but should be of no detriment to normal operation.
    Super X3. 3600rpm. Sheridan 6"x24" Lathe + more. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
    May 2009
    264
    Should not be an issue. The only area of wiring that can cause you headaches from crosstalk will be the home and limit switches. I've never encountered this either and I an my power, stepper, and limit switch wires bundled all together. My limit switch wires were simple speaker wire...still no issues.
  1. 8 wire stepper motor help
    By woodturn in forum Gecko Drives
    Last Post: 03-30-2011, 11:30 AM
  2. Stepper Motor Wire
    By AlbertaClipper in forum Canadian Club House
    Last Post: 12-23-2009, 03:00 AM
  3. 8 Wire Stepper motor
    By freckel_boy in forum Stepper Motors / Drives
    Last Post: 10-11-2009, 11:35 PM
  4. How to wire an 8 wire stepper motor
    By technosteve in forum DIY CNC Router Table Machines
    Last Post: 01-17-2009, 12:01 AM
  5. Stepper motor 8 wire
    By debutpic in forum Stepper Motors / Drives
    Last Post: 09-02-2006, 01:34 PM
