603,409 active members*
3,366 visitors online*
    Jun 2024
    9
    rusting issue
    we recently bought new cabinets for out tool holders, its a tall narrow drawer that pulls out and has shelves for the holders
    Our ISO20 holders seem to rusting up like crazy all other holders are fine with maybe a small spot occasionally
    Any idea possible cause or remedy
    we use water soluble coolant with a refract of 3.6-6.3
    thanks
    Re: rusting issue
    What are the recommended refractometer level from the manufacturer ? They vary from one company to the next and your concentration levels may be too low .
    Are the holders being cleaned after being removed from the machine , if so with what . If they aren't being hand cleaned after use then there should be enough of a protective film left over from the coolant to protect the holders . Coolants usually have rust inhibitors and some are better than others . If the coolant isn't protecting the equipment then I'd suggest finding a better coolant
    Also - where where the rusting holders manufactured . If they are lower cost holders (chinese) then the metals they are made from may be of low quality
    Dec 2008
    3211
    Re: rusting issue
    A refract of 3.6 is too low for ferric materials. Check the manufacturers specifications for machining and material types
    Alum machining requires a higher concentration than a steel.
    If your cabinet is kept closed, I'd suggest some bags of silica gel to absorb moisture. But you should at least wipe the tapers before storing.
  1. Rusting issues
    By BRAIN-HURTS in forum EDM Discussion General Topics
    Last Post: 07-21-2020, 07:55 AM
  2. 17-4 stainless rusting problem need help
    By skipperspride in forum MetalWork Discussion
    Last Post: 06-10-2010, 02:22 AM
  3. How do you stop your tooling from rusting?
    By KyleH2 in forum MetalWork Discussion
    Last Post: 06-12-2008, 12:09 PM
  4. Rusting on my table
    By chase78 in forum Benchtop Machines
    Last Post: 05-05-2007, 07:22 PM
  5. water bath preventing from rusting?
    By DanOSB in forum Waterjet General Topics
    Last Post: 09-25-2006, 02:14 PM
