603,935 active members*
3,177 visitors online*
IndustryArena Forum > CNC Electronics > Rutex Products > Servo Drives > Rutex configuration for Mach2
Results 1 to 5 of 5
    May 2004
    5
    Exclamation Rutex configuration for Mach2
    Hello!!
    Does everyone can help me as to set R90H rutex servo drives with Mach 2?
    I wondering on which pin of DB25 parallel port goes the encoder chanel A and Chanel B. My system include 3 axis XYZ of R90H servo drive, a R990 MB and a R90IO.
    Left
    Aug 2004
    244
    Your encoders connect to ch a and b of the rutex cards. The db 25 provides the step and direction signals for the rutex drives. The drive reads the encoders and positions the servos. Mach 2 has no direct connection to the encoders in this set up.
    Everything in moderation, including moderation.
    Jun 2004
    258
    Left...
    On your R90H drives (3) you have a DB9 connection. This is your encoder connection. Depending on your encoders you most probably only need 7 pins.. 2 for + & -, 2 for each channel(a & b) and one for the shield. Have you downloaded the PDF for the drive from www.Rutex.com . The PDF explains if fairly well... I am just hooking up my encoders today.
    It may be wise to run seperate wires for the power (+ & -) and the channels to minimise any electricial interference.
    cheers
    Frans
    May 2004
    5
    Rutex and Mach2 conf.
    Many thanks Frans
    I am a new user of Rutex boards and Mach2 .
    I am a little confused because Mach 2 need to be configured for the ports and pins and as it sais for the encoders too. Are you a Mach 2 user too?
    I would be much appreciated if you could help me on the Mach2 confnigurationn for the rutex drives
    Regards
    Left
    Feb 2004
    38
    i think? you need to reverse your STEP AND DIRECTION settings in mach 2 ports and pins
    instead of port 1 step2
    dir3
    step4
    dir5
    it should be?? port 1 or whatever port your using step3
    dir2
    step5
    dir4
    check out page 2 on the rutex r990mb pdf on there site www.rutex.com
    im a noob here so i could be wrong but hope this helps
    good luck
    roonster
  1. 2000 series Rutex drives
    By rutexus in forum Servo Drives
    Last Post: 04-03-2007, 10:00 PM
  2. Mach2 configuration for Rutex R90H
    By Left in forum Mach Software (ArtSoft software)
    Last Post: 01-20-2005, 10:24 PM
  3. Gecko vs Rutex
    By samualt in forum Gecko Drives
    Last Post: 10-21-2004, 07:48 AM
  4. Rutex Drives
    By mikburts in forum Servo Drives
    Last Post: 04-10-2004, 01:16 PM
  5. Mach2 and Rutex
    By ynneb in forum Mach Software (ArtSoft software)
    Last Post: 03-31-2004, 09:37 PM
