603,316 active members*
2,489 visitors online*
IndustryArena Forum > CNC Electronics > Rutex Products > Servo Drives > Rutex drivers used For CNC milling
Results 1 to 9 of 9
    May 2003
    96
    Hi there!
    I am currently building my own CNC machine and will be using Rutex drivers. Although I have made a considerable amount of research in general and also designs, I would highly appreciate information as regards to results and how these drives perform.
    Martin G
    Martin G
    Mar 2003
    2139
    I am not familliar with those drivers. They look good though.
    www.rutex.com
    I believe routerman has used them. See this thread. http://www.cnczone.com/showthread.ph...ighlight=rutex
    Eric
    I wish it wouldn't crash.
    Mar 2003
    2139
    Actually looking at the web page I like the 200 volt version of the R996 Servo Motor Drive. 6 amps at 200 volts. The gecko's I was going to use are 80 volts 7 amps. My motors are 110 volts 1.1 amps. These might be more suitable.
    I too would be interested in what others think or these.
    Eric
    May 2003
    96
    Hi Eric,
    Thanks for the tip! I'l get in touch with routerman to see how they worked for him. I'l also be keeping you guys updated of my small and slow progressions in the future, as I only work a few hours here and there.
    Rgds
    Martin
    Martin G
    Mar 2003
    93
    THe Rutex drives worked great. Very reliable and easy to tune.
    Aug 2003
    329
    8020
    Balsaman,
    I tried responding to your add for the 8020. I am willing to drive to Canada to get them. I live near Syracuse, How far are you from Kingston?
    Bill
    Mar 2004
    1661
    I am running Rutex products, very satisfied.
    (I just had to delete a spam, so I posted too - even though the thread is from the stone age )
    Oct 2005
    80
    Feedback on Rutex Drives
    I used 3) R2020 drived for my CNC mill conversion; they worked fine. One of the drives I got never worked correctly even right out of the box , but it was taken care of by the US distributor who is good to work with. They do have a nice tuning program.
    I do have a couple of complaints about them though:
    -The mechanical design of the drives is not the greatest (use of nuts vs screws for mounting that are very difiicult to access)
    -Difficult to connect and disconnect the power wires due to limited access, and use of nuts.
    -Design is too compact overall; tired to crunch everything into too small of a package.
    -No way to reset errors without shutting off power to the logic circuitry.
    -Intermittent supply of new/replacement boards; sometimes takes a while to get them.
    I am going to try different drives for my lathe conversion. I'll see if I like them better.
    -Brian
    Nov 2009
    I want to purchase 510B from RUTEX please help me that how could I go for it
  1. Why would this machine be bad for milling?
    By jevs in forum Knee Vertical Mills
    Last Post: 06-17-2005, 04:49 AM
  2. Worth a Thousand Words
    By Chunky in forum CNC Machine Related Electronics
    Last Post: 05-29-2005, 10:18 PM
  3. I recommend Rutex drivers.
    By ynneb in forum Servo Drives
    Last Post: 02-02-2005, 04:36 PM
  4. Replies: 11
    Last Post: 11-15-2004, 11:48 PM
  5. Gecko vs Rutex
    By samualt in forum Gecko Drives
    Last Post: 10-21-2004, 07:48 AM
