588,563 active members*
4,792 visitors online*
IndustryArena Forum > Community Club House > Salvagnini or Trumpf programmers
Results 1 to 18 of 18
    Post Salvagnini or Trumpf programmers
    Would any Salvagnini S4 / P4 or Trumpf programmers have any interest in sharing information about these machines? I thought it may be handy to compile a list of e-mails and who has what machine to possibly ask for help or tips to make our job easer.
    Currently I program the following:
    Salvagnini S4 (SDE)
    Salvagnini S4 (SDEX)
    Two Salvagnini P4’s
    Trumpf 600 L
    Trumpf 500
    Trumpf 200
    I also have a good understanding of the Trumpf 2020 and Trumpf 5000.
    You can review my home page for other machines.
    Independent CNC Programmer
    www.ctcn.net/~3kings/
    Post Other Machines / Software
    I now have more machines / software that can be added to my list.
    Machines:
    Trumpf 2030 (this should cover most of the Trumpf’s laser flatbed machines)
    Trumpf 260
    Finn-Power Shear Genius
    Software:
    NC Express (Finn-Power)
    Metal Studio (Salvagnini)
    MetalNest (Salvagnini)
    Oct 2008
    3
    Hi there,
    Currently i Program Amada Astro and Standard PressBrakes using AstroCam and BendCam. And i also program Salvagnini P4 stanard programming and ABS programming.
    If you need and info please drop me a email.
    Question Salvagnini P4
    Thanks!
    Are you using the Salvagnini software to generate your P4 programs or do you write them by hand?
    www.independentcnc.com
    My mission is to share CNC programming innovations for a lifetime.
    Oct 2008
    3
    Salvagnini Programming
    I produce all the programs by hand as the Salvagnini Software is very limited to what it can do and they told us not to waste our money on it. As i work for a subcontract manufacturing unit we don't no what work is new work is coming so we have to be very flexible with our machines.
    I also use ABS programming a lot to produce special bending profiles which normal cannot be made on the Salvagnini.
    Post Salvagnini P4
    The software I use is really good for getting the reference line correct and setting up the correct format for the bend lines. I can also generate a graphic view with the code to aid the operators.(see link below) All the fine-tuning is made at the machine.
    I agree Salvagnini software is hard to justify.
    http://www.ctcn.net/~3kings/SampleP4...1_image001.png
    Oct 2008
    3
    Salvagnini P4
    I see what you mean now with the software.
    But to be honest we have dxf files for all of our parts that we manufacture, so i can sit a home and write a program in note pad and load them straight on the machine and it will be right 1st time. I have done hundreds of different profiles, electrical box's, cabinets using standard bending, box fold bending , radius bending, with and without option-p. I develop new designs for all different sectors of the market. We have made parts on our P4 that Salvagnini Austria don't think can be made on it. So sometimes you mind can produce thing's software will not even think about. Also i find it great fun to come up with new bending profiles, which we offer to our customers to use of there products.
    I don't no if you are aware but there is a new software release going out to certain customers who have had problems with the life of the bending tools, this has a extra bending mode, MODE 2 which will become the standard bending mode not MODE 1.
    We have been told it will help the life of the bending tools. We have had all our bending tools replaced 3 times in the past two and half years. And every six months upper and lower bending blades are shimmed to get the radius correct in the center area of the machine about 1 meter long.
    We run our machine 24hrs a day 7 days a week, we have produced over million components on the machine so far averaging around 7000 per week. And our average batch size is only about 50 parts.
    Do you have a problems with life of bending blades on your machine?
    Best Regards
    David
    Salvagnini P4
    The main reason I have set up software to write the code for the P4 is to eliminate the human error. They are an easy program to write, however, if a wrong number is typed in there is a chance of damaging the machine.
    We run 16 and 14 gauge cold rolled and have only replaced our blades once in the last 8 years. We also run 24/7.
    Thanks for the information I will check into the MODE 1 and MODE 2.
    Nov 2008
    Salvagnini P4
    I do the programming for the Salvagnini P4 and S4.
    We also run 24/7 for the past 5 years and just starting to notice wear on the blankholder; not the upper or lower bending blades.
    The laser we are still working the bugs out we just got it about 4 months ago.
    I also write the programs for 28 Amada's in our facility.
    Nov 2008
    I was hoping if someone can please tell me if there is better software out for the Salvagnini P4 panel bender?
    Also if someone could tell me what ABS programming is.
    Thank you
    Post Salvagnini P4 software
    I have customized WE-CIM to generate Salvagnini P4 programs for my current employer and one of my customers. Attached is a sample of what I have done. If you are comparing it to the Salvagnini programming software it may not be better just easer to use.
    http://www.independentcnc.com/
    Feb 2009
    Talking Love our Salvagnini's
    I currently program 3 P4's and and one of them is the new X machine. We also have a Roboformer and 3 S4's, one of those is the new X machine also. Every thing that we do is with the Salvagnini software and it has been wonderfull. I use CamBend software on a daily basis and it works very well for me. Yes there are a few things that the software can not do but Salvagnini is constantly updating the software and it gets better and more versitile every few months.
    As for updating the P4's from Mode 1 to Mode 2 bending it is not possible, we already asked. The new Mode 2 is only on the newest X generation machines and it consists of completly new bending formulas for the machine from what I understand.
    I also do a significant amount of ABS programming and theraly enjoy it. ABS is point by point positioning of the bending blades and tooling for bending profiles that are not achievable with standard programming. When we got our first P4, Salvagnini would not enable the ABS untill we had the machine for about a year. Somthing to do with geting to know th equipment before letting me program this way. I can understand why because I've put the upper bending blade on the upper slope of the tooling and left marks on the tooling from it. Luckaly nothing got damaged.
    Independent CNC, the example of the WI-CIM doesn't tell me a whole lot. It's a nice graphical but how does it work? Does it write the program for you or just the DIM and REF lines?
    Post WE-CIM programming a Salvagnini P4
    Machining Yeti,
    To program the Salvagnini P4 in WE-CIM you place the reference stops on the GUI then fill out a menu for the finished size of the part with the bend lengths and angles for each side. The program is generated complete including special variables that can be customized to always be out put or selected as needed. The software is a cheaper solution for generating code and it allows me to customize in my time.
    If you are only dealing with Salvagnini machines their software is the best way to go. I am dealing with many different punch/laser/plasma/form machines and I would rather have a one CAM package solution.
    Jun 2011
    7
    Good morning, Independent CNC,
    My name is John, from New york. I have read your post about Salvagnini programming and the software you use for programming. At work they have a: Salvagnini P 4 M_330_1497 ABA. CUT.PCD.RIP, you think you can share some information with me about the software you use, how can i learn to program and get the software. Thank you very much in advance.
    Regards.
    john.
    Jun 2011
    7
    GOOD MORNING DAVID RUTTER...
    I AM JOHN FROM NEW YORK, AND I AM LOOKING FOR INFORMATION HOW TO PROGRAM A SALVAGNINI P4. DO YOU USE A SOFTWARE TO GENERATE THE CODE, HOW CAN I LEARN TO PROGRAM THIS MACHINES AND WRITE THE CODE. I REALLY APPRECIATE ANY INFORMATION YOU WOULD LIKE TO SHARE WITH ME.
    THANK YOU VERY MUCH IN ADVANCE.
    REGARDS.
    JOHN.
    John, you should be able to get a PDF manual from Salvagnini for that machine to help you understand the code. If you get stuck you can e-mail me and I will try to help you out.
  17. #17
    Jun 2011
    7
    Good afternoon, Independent CNC,
    Do you think you can share information with me for the ABS programming on a Salvagnini, something you may have to read on or if you know where I can get a book.
    I am learning how to program a P4, on my own.
    Thank you in advance for your assistance.
    Regards.
    John
  18. #18
    Sep 2013
    8
  1. G-code for Trumpf turret punch
    By Sparkman Stan in forum G-Code Programing
    Last Post: 02-27-2016, 06:29 AM
  2. You own a Trumpf L3050???
    By tikrik in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-20-2008, 08:05 PM
  3. Automation Specialist Wanted - Salvagnini - Chicago Area
    By pspiech in forum Employment Opportunity
    Last Post: 12-06-2006, 08:06 PM
  4. Looking for (3) CNC Setup/Programmers
    By wakates in forum Employment Opportunity
    Last Post: 03-16-2005, 09:57 PM
