586,032 active members*
2,993 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Sanity check: CNC mill with DRO.
    Sep 2015
    15
    Hi all:
    About a year ago I purchased a PM-728-VT Ultra precision mill. I also installed a DRO
    so I could do some work while I collected all the CNC items for it.
    I installed a Centroid Acorn system with Clearpath servos
    and have it running. I highly recommend this system.
    My question is, should I keep the DRO? it's allways
    1 or 2 thou off from the CNC display. But it does give me
    an idea if everything is working ok. It is a cheap Chinese DRO
    I may be able to calibrate to the CNC. I may give it a try.
    Anyone have set up like this??
    Any advice appreciated.
    RonL
    Jan 2008
    1529
    Re: Sanity check: CNC mill with DRO.
    What do you mean by 1 - 2 thou off?
    Difference in travel measured? Over what distance?
    You won't do any harm by having a DRO sitting there. Not sure it does you much good though.
    Sep 2015
    15
    Sorry, 1 to 2 thou off over 10"
  1. 4x8ft CNC router - steppers, drives and sanity check
    By spiral72 in forum Stepper Motors / Drives
    Last Post: 11-25-2015, 12:03 AM
  2. Need a Sanity Check
    By xTourniquet in forum USA Club House
    Last Post: 08-14-2014, 08:34 AM
  3. Sanity check design please...
    By Rarius in forum DIY CNC Router Table Machines
    Last Post: 03-12-2009, 01:50 PM
  4. Newbie sanity check
    By mmm in forum DIY CNC Router Table Machines
    Last Post: 11-10-2008, 05:34 PM
