587,129 active members*
3,093 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Sanyo Denki stepper motot driver failed
Results 1 to 19 of 19
    Dec 2011
    Hi everybody,
    I bought 3 Sanyo Denki (103H7126-1740) stepper motors to build a CNC but I got some problems with drivers, I tried the L297+L298 stepper driver but the L298 gets hot after a while and burn out, then I tried the L297+ 2XL6230 which turn off once hot, I also tried PIC microcontroller + Mosfets (TIP161&TIP145) but the mosfets burn out after few minutes. I'm trying to make them work fine months ago with no result.
    The motors scpecifications are:
    - Bipolar
    - Current: 4 A
    - Grade: 1.8 ° + / - 0.09 °
    - Holding torque: 165 Ncm
    - Resistance: 0.48 Ohms
    - Inductance: 2.2 mH
    - inertia: 360 Kgm ² x 10 -7
    - Theoretical acceleration: 45,800 rad x sec -2
    - Constant voltage: 31 V / krpm
    - Weight: 1 Kg
    Help me pleaaaaaaaaaaaase :'(, thank you verry much.
    Jan 2005
    364
    The DIY open source THB6064 is a perfect candidate for a 4Amp and 2.2mH motor.
    http://users.skynet.be/ldt/CNC%20ele...THB6064AH.html
    or
    THB6064 MassMind Stepper Motor Driver Kit
    Dec 2011
    Thank you so much Lucas for your reply but I didn't find the THB6064AH chip in the store.
    Jan 2005
    364
    Almost everybody uses full partkits, some only a PCB and chip.
    I can supply the chip only, please send a PM if you need some.
    Dec 2011
    Please guys any suggestions, please help meeeeee :'(.
    Jan 2005
    1695
    What is your objective?
    Dec 2011
    Quote Originally Posted by H500 View Post
    Hi, I need to drive those steppers, I need them to work good
    Dec 2008
    239
    Jan 2005
    1695
    Quote Originally Posted by scalance View Post
    The link does not show a motor.
    Jan 2005
    364
    @H500:
    That link is automatically created by CNCzone to one of their sponsers for additional income, it's not a link to his steppers, the spec's are in the first post. I have been confused by this for a while also, you can turn most of these auto-created-links off in the user control panel.
    @scalance:
    Your first post showed that you are a DIY guy, that's why I linked to a DIY solution wich is a good drive for these motors.
    There are other drives: Gecko G540, Leadshine... but these aren't cheap.
    Dec 2011
    Quote Originally Posted by lucas View Post
    @H500:
    @scalance:
    Thanks Lucas, but as you said those drivers aren't cheap and I like to make myself things so I undertand how they work exactly
    Dec 2011
    Quote Originally Posted by yours_prabhat View Post
    I looked for the THB6064AH but didn't find them in the store
    Jan 2005
    364
    On that page there's : 416073 Replacement THB6064AH chip.
    Click on that and there it is: 6064 Stepper Motor Driver (CHIP ONLY!)
    A few posts back you said the same, I then replied:
    "I can supply the chip only, please send a PM if you need some. "
    What more do you need?
    Dec 2011
    Yes bro I apreciate your help thank you verry much but am from morocco so how can you supply the chip for me , it's an other problem , well going to see if I can the replacement but am sure I will not find it cause they sell anly chips that are usually in use.
    Thk you bro so much.
    Am looking to parallel 3XL298 or 3XL6203, anybody has an idea if it will work?
    Jan 2005
    1695
    Where do you buy your components from?
    Dec 2011
    From the store
  17. #17
    Jan 2005
    1695
    So Morocco only have 1 store and no postal service? =)
    Why not order parts online?
  18. #18
    Dec 2011
    we have lots of stors but they supply only parts that usually used for reprations.
    We can't order parts online cause paypal and things like that doesn't work here, don't as me why cause I dunno .
  19. #19
    Jan 2005
    364
    International banktransfer should work, easy with IBAN account numbers.
  1. sanyo denki san driver pd12-3005B
    By princeviju in forum Open Source Controller Boards
    Last Post: 12-01-2009, 04:19 PM
  2. Sanyo Denki PM Driver
    By Florin in forum Stepper Motors / Drives
    Last Post: 06-25-2009, 02:21 AM
  3. Need help with Sanyo Denki stepper
    By vova in forum Stepper Motors / Drives
    Last Post: 05-20-2008, 05:16 PM
  4. Sanyo- Denki Step Syn motors need some help on driver for
    By rollin_ballz1 in forum DIY CNC Router Table Machines
    Last Post: 03-07-2006, 03:21 PM
  5. Sanyo denki stepper motor
    By kheri in forum Stepper Motors / Drives
    Last Post: 04-23-2005, 07:08 AM
