587,202 active members*
3,004 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Sanyo E681000c30 encoder, does it need pull up resistors or something ?
Results 1 to 10 of 10
    Dec 2005
    313
    Hi..
    I have a Sanyo E681000C30 1000 line encoder.
    It works on 5 volt.
    Came with a Super U Sanyo Denki U718-012E 18 servo motor.
    On the encoder there is a table which shows which color lead is what channel.
    This is all clear.
    But does the outputs need a pull up resistor ?
    Or something else ?
    To what type of input should these encoder outputs be connected ?
    Thank you :-)
    Sep 2006
    177
    those encoder lines are usually connected to a motor drive and used as feedback to read the motor position.
    Jun 2003
    866
    there are some encoders that do require a pullup, but they are rare. If you are having trouble reading it, it seems more likely that it's an absolute encoder, but this is a random observation on my part. Do you have a link to a manual?
    Dec 2003
    24223
    Many of the small Sanyo-Denki motors that I have come across are single ended - open collector, but it should be easy to determine with power applied and a meter test, if the results are a bit vague, then try a 1k resistor to +v and repeat the test.
    If they are differential, there is a good chance they are not open collector.
    Al.
    Albert E.
    Dec 2005
    313
    I have tried the encoder.
    Without a pull up resistor it gives a nice square wave.
    May 2003
    96
    Quote Originally Posted by vroemm View Post
    Hi vroemm,
    would you mind sharing termination and relevant data information on how you connected your encoder. I've got 4 of them which I wish to utilise for my next cnc.
    Thanks marting
    Martin G
    Dec 2005
    313
    Quote Originally Posted by marting View Post
    Hi vroemm,
    It has been 3 years ago.
    And it was only a experimental setup.
    I do not have the data you asked anymore.
    Sorry
    Vroemm.
    Sep 2010
    1765
    therefore 100% it does NOT need pull ups resistors.
    Dec 2005
    313
    Quote Originally Posted by mike_Kilroy View Post
    Or perhaps i made a mistake.
    Vroemm
    Sep 2010
    1765
    if u looked at the outputs with a scope, and the voltages were greater than about 2.5v on hi and close to 0v on low of square wave, then i dont think u made a mistake; if it was open collector u would not get a square wave output of these voltages.
  1. interact 4 pull stud/retention knob style?
    By camarogod98 in forum Bridgeport / Hardinge Mills
    Last Post: 04-19-2017, 05:12 PM
  2. pull studs
    By najnielkp in forum Uncategorised MetalWorking Machines
    Last Post: 06-12-2009, 02:42 AM
  3. Sensing Resistors vs Current limiting Resistors
    By whitney in forum Hobbycnc (Products)
    Last Post: 11-06-2006, 06:29 AM
  4. "pull up" resistors ?
    By boyvox in forum CNC Machine Related Electronics
    Last Post: 06-22-2006, 03:56 PM
  5. getting ready to pull my hair out!!!
    By bherr in forum Shopmaster/Shoptask
    Last Post: 05-21-2006, 02:16 PM
