587,672 active members*
3,166 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > News Announcements > SANYO--Electronic Component--updated stepper motor driver IC
Results 1 to 4 of 4
    Nov 2011
    In view of the problem from the stepper motor controller users usually encounter and the reports from the semiconductor ic markets, for example, noise come from the driving, reset zero function, board toast the board ect. We recently have lauched two powerful with high quality, market-focused ic products THB6128,THB7128 and THB8128, now are winning good reputation worldwide and have huge market.
    THB6128
    *1 channel PWM current control stepping motor driver
    *BiCDMOS process IC
    *Output on-resistance ( High side 0.3 Ω, Low side 0.25 Ω, Total 0.55 Ω; Ta = 25°C, Io = 2.0 A)
    *2, 1-2, W1-2, 2W1-2, 4W1-2, 8W1-2, 16W1-2, 32W1-2 phase excitation are selectable
    *Advance the excitation step with the only step signal input
    *Available forward reverse control
    *Iomax=2.2A
    *Over current protection circuit
    *Thermal shutdown circuit
    *Input pull down resistance
    *With reset pin and enable pin
    *Operating temperature(Topg): -20 to 85 ° C
    *Storage temperature(Tstg): -55 to +150 ° C
    *Package: MFP30KR
    *Dimentions: 1.52*0.79*0.025cm
    *Weight: 0.6g
    THB7128
    *PWM current control stepping motor driver
    *Output on-resistance (High side 0.3ohm, Low side 0.25ohm, Total 0.55ohm; Ta = 25℃, Io = 2.5A)
    *VMmax=40V(DC),Iopmax=3.3A
    *With built-in automatic half current maintenance energizing function
    *Operating temperature(Topg): -20 to 105 ° C
    *Storage temperature (Tstg): -40 to +125 ° C
    *Package: HZIP25
    *Dimentions: 2.92*1.29*0.45cm
    THB8128
    *BiCDMOS process IC
    *Output on-resistance( High side 0.25 Ω, Low side 0.15 Ω, Total 0.40 Ω; Ta = 25°C, Io = 4.0 A)
    *Selectable phase drive (1/2, 1/8, 1/16,1/32, 1/64,1/128, 1/10,1/20step)
    *Iomax =4.3A
    *Operating temperature(Topg): -30 to 85 ° C
    *Storage temperature (Tstg): -55 to +150 ° C
    *Package: HZIP25
    If you are interested in these chips,I can show you more information.
    Please don't hesitate to contact me.
    Attached Files Attached Files
    Nov 2011
    You can find the announcement from the attachement about THB series chip by SANYO Semiconductor Co.Ltd.
    Attached Thumbnails Attached Thumbnails Anoncement about THB series chips by SANYO semiconductor(H.K.) Co.,Ltd.jpg
    Nov 2011
    Hello all the friends,
    If you are interested in these chips,please send message to me.I'll try my best to help you.Even though you just want to disscuss them.
    Best regards,
    Jerry
    THB8128 is VL8727
    THB8128 SANYO Semiconductor is the part number has been shipped to China for a specific company.
    Item is formal LV8727.
    THB6128 is the difference between the package of LV8729V.
    I contact SANYO Semiconductor.
    LV8727 is very good.
    Quote Originally Posted by Jerry888 View Post
    THB6128
    *BiCDMOS process IC
    *Iomax=2.2A
    *Package: MFP30KR
    *Weight: 0.6g
    THB7128
    *Package: HZIP25
    THB8128
    *BiCDMOS process IC
    *Iomax =4.3A
    *Package: HZIP25
  1. Looking for Sanyo Servo Motor # CN-800T-21(for OKUMA) & Electronic Parts
    By usedcncmt in forum Want To Buy...Need help!
    Last Post: 10-14-2010, 07:48 AM
  2. Replies: 2
    Last Post: 08-19-2008, 02:44 PM
  3. PCB,IC and Electronic component from china
    By itbaba in forum CNC Machine Related Electronics
    Last Post: 01-10-2008, 03:40 PM
  4. vexta stepper motor and electronic utopia driver
    By DanOSB in forum Stepper Motors / Drives
    Last Post: 10-10-2005, 01:13 PM
  5. Electronic Component Explanation
    By DragnsBane in forum CNC Machine Related Electronics
    Last Post: 11-02-2004, 04:38 PM
