588,174 active members*
4,749 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Sargon DRO & Mitutoyo AT715-750 Scale
Results 1 to 4 of 4
    Apr 2008
    196
    I need to locat a 15 pin femal to 25 pin male adapter to connect a Mitutoyo AT715-750 scale to a Sargon Prospector DRO. The original glass scale crapped out & I got this magnetic Mitutoyo to replace it with. Also if someone could help with a pinout I could possibly make my own adapter.
    Nov 2005
    36
    Quote Originally Posted by ynnek View Post
    Hello,
    Sorry but the scale you have is not compatible with the display you have.
    The Sargon display needs a +5 volt TTL square wave (single track) input from the scale.
    The Mitutoyo scale you have has a output of 2Vpp sine wave - Electromagnetic induction system (3 tracks, absolute AOS).
    Regards,
    Tim Barnard
    LMSC
    877-376-4373
    www.sargon-dro.com
    Apr 2008
    196
    Thanks for your input
    Quote Originally Posted by LMSC View Post
    Hello,
    Regards,
    Tim Barnard
    LMSC
    877-376-4373
    www.sargon-dro.com
    do you carry the scale I need, or would it be better to by a new system? The date on the read out is 11/98. Seems to be a bit old.
    Nov 2005
    36
    Yes we carry replacement scales. I don't see a reason to replace everything unless your not happy with the rest of the system.
    Regards,
    Tim Barnard
    LMSC
    877-376-4373
    www.sargon-dro.net
  1. mitutoyo linear scale pinout
    By pham1129 in forum Bridgeport / Hardinge Mills
    Last Post: 04-21-2021, 12:31 PM
  2. Looking for Sargon digital readout manuals
    By LMSC in forum Want To Buy...Need help!
    Last Post: 01-27-2009, 11:43 PM
  3. mitutoyo linear scale cable pinout
    By pham1129 in forum Uncategorised MetalWorking Machines
    Last Post: 12-08-2008, 02:25 PM
  4. Need to make scale tire mold for 1/6 scale car
    By thuffner3 in forum Moldmaking
    Last Post: 04-29-2008, 06:57 AM
  5. Mitutoyo DRO for CNC
    By CaptnVideo in forum Gecko Drives
    Last Post: 04-08-2005, 06:03 PM
