603,968 active members*
1,515 visitors online*
Page 1 of 2 12
Results 1 to 20 of 21
Hybrid View
pjohnsonj Saturn 4x4 plasma 04-05-2017, 03:45 AM
MajorTendonitis Re: Saturn 4x4 plasma 04-05-2017, 04:15 AM
pjohnsonj Re: Saturn 4x4 plasma 04-16-2017, 04:19 PM
beltramidave Re: Saturn 4x4 plasma 04-16-2017, 04:37 PM
difalkner Re: Saturn 4x4 plasma 04-17-2017, 01:27 PM
difalkner Re: Saturn 4x4 plasma 04-05-2017, 12:47 PM
pjohnsonj Re: Saturn 4x4 plasma 04-05-2017, 11:38 PM
pjohnsonj Re: Saturn 4x4 plasma 04-16-2017, 04:54 PM
cobra514 Re: Saturn 4x4 plasma 04-17-2017, 02:56 PM
difalkner Re: Saturn 4x4 plasma 04-06-2017, 02:51 AM
MajorTendonitis Re: Saturn 4x4 plasma 04-06-2017, 03:58 AM
pjohnsonj Re: Saturn 4x4 plasma 04-06-2017, 11:25 PM
pjohnsonj Re: Saturn 4x4 plasma 04-20-2017, 03:01 AM
cobra514 Re: Saturn 4x4 plasma 04-20-2017, 03:37 AM
pjohnsonj Re: Saturn 4x4 plasma 04-23-2017, 03:56 PM
difalkner Re: Saturn 4x4 plasma 04-07-2017, 02:04 AM
pjohnsonj Re: Saturn 4x4 plasma 04-15-2017, 04:13 PM
cobra514 Re: Saturn 4x4 plasma 04-15-2017, 05:45 PM
beltramidave Re: Saturn 4x4 plasma 04-16-2017, 12:34 AM
MajorTendonitis Re: Saturn 4x4 plasma 04-16-2017, 01:46 AM
coherent Re: Saturn 4x4 plasma 04-16-2017, 03:22 PM
    Feb 2009
    13
    Saturn 4x4 plasma
    Going to this in reverse a bit,will post build pictures/comments soon. Here is a picture of the semi completed Saturn Plasma.
    Phil
    Ohio
    Attachment 357544
    Mar 2017
    164
    I want to purchace a 4/4 Saturn from FLA soon . Never thought of it as a CNC plasma cutter , very neat
    Feb 2009
    13
    energy chain. Again stock one functions fine. The CNCRP ones only takes a quick twist with a screw driver and they pop up(hinged on opposite side), quicker and easier. I will be adding stuff down the road and wanted to make it easier to get it and out. I also went one size up in width.
    Attachment 359070
    On the Fineline ones you have to use a small screw driver at very specific places. If you don't follow the proper procedure they will break. Make sure you follow this video.
    https://youtu.be/NcQP_hFbgbQ
    Using a Hypertherm 45xp, feed speeds depending on steel thickness 15 to 320 in/min.
    Using Candcnc.com controller with THC. Went with the Linux version using a modified version of Linuxcnc called Commandcnc(from Candcnc). Using sheetcam as well. Sharing tips would be great!
    Would love to see pictures of the new steel gantry.
    Mores pics
    Computer stand. Had this laying around, not sure if I'll keep it, but for now it works.
    Attachment 359074
    Attachment 359076Attachment 359078Attachment 359080
    test cuts
    Attachment 359082Attachment 359084Attachment 359086
    Mar 2012
    103
    Here are a couple of pics of my Saturn with the steel gantry.
    Dave
    Nov 2014
    708
    Quote Originally Posted by beltramidave View Post
    Dave
    That just looks awesome!
    David
    David
    Romans 3:23
    Etsy shop opened 12/1/17 - CurlyWoodShop
    Nov 2014
    708
    That's a nice looking setup! The stand looks pretty sturdy, too. Did you build that?
    David
    David
    Romans 3:23
    Feb 2009
    13
    Feb 2009
    13
    I like the steel gantry a lot. The Saturn for a plasma table is a bit over kill, since your only moving a torch head around and not pushing/cutting material like a router. I have a router that I built several years ago and used 8020 for the base. Too much movement and vibration. Should have welded up a steel base from start. the cheapest way to help with vibration is mass. I would weld up a base full of heavy steel and cross bracing....
    Feb 2017
    21
    Quote Originally Posted by pjohnsonj View Post
    Would your opinion be that 3/16" wall box channel would be good for the base? Maybe even get away with 1/8" wall? I have some 1/4" wall laying around....but that seems like overkill.
    Nov 2014
    708
    Let me rephrase - that is a SERIOUSLY nice and sturdy stand!!
    David
    David
    Romans 3:23
    Mar 2017
    164
    Quote Originally Posted by difalkner View Post
    David
    + 1 . I really need to learn how to weld . Bought one , just haven't used it yet
    Feb 2009
    13
    Thanks for the positive feedback. Here are more photos.
    Attachment 357832Attachment 357834Attachment 357852Attachment 357838
    55 gallon drum in this photo is for water storage for the water table. I did not want the water standing in the tray all the time. Water drains in the drum when not in use. All it takes is 5psi of air pressure to push the water back into tray.
    Attachment 357840
    Attachment 357842Attachment 357844
    water table
    Attachment 357848Attachment 357850Attachment 357846
    Feb 2009
    13
    Is it for a router or a plasma?
    Feb 2017
    21
    Router...for non-ferrous metals.
    Feb 2009
    13
    Quote Originally Posted by cobra514 View Post
    I wouldn't hessitate to use the 1/4". You want as little vibration as possibly when cutting aluminum etc. That weight/mass will absorb that. Don't set the machine on leveling castors. I used them on the my plasma but would not on a router. Here are some pics of the bottom of a base i am going to replace my 8020 base with(cnc router). Its 1/4" walled 2.5 x 2.5. Castor use is only for moving cnc.
    Attachment 359806Attachment 359808Attachment 359810
    Nov 2014
    708
    That's pretty slick looking - very well done! What will you be cutting (primarily)?
    David
    David
    Romans 3:23
  17. #17
    Feb 2009
    13
    I will be cutting anything from decorative/art pieces to misc brackets/parts. More pics...
    floating head on z with magnetic breakaway torch mount
    Attachment 358864Attachment 358866Attachment 358868Attachment 358870Attachment 358872
    My Z mount had same issue as some of the others with needing spacers. I took advantage of it and made a support shelf.
    Attachment 358874Attachment 358876Attachment 358872
    I took some regular 8020 end caps and milled holes in them to cover gantry ends
    Attachment 358880Attachment 358882
    I replaced the energy chains with CNCRP ones. the ones that the Saturn came with drove me nuts, although they function fine. I made brackets for the ends of the new energy chains instead of threaded rod. Also drilled a big hole with a rubber grommet for wires.
    Attachment 358884Attachment 358886Attachment 358888Attachment 358890Attachment 358892Attachment 358894Attachment 358896Attachment 358898
  18. #18
    Feb 2017
    21
    That is great work. Hats off to you.
    Those gantry ends are a nice touch. Actually, looking at it, one would just assume the Saturn comes with those.
    Modifications/upgrades that look "stock" are the best. They don't have to be expensive or complicated to be impressive.
    Can you explain what your primary issue was with the stock energy chain?
  19. #19
    Mar 2012
    103
    Thanks for all the pictures, looks great! I think I may have gotten the first Saturn with the steel beam gantry. Kind of missed not being able to run cables through it.
    What kind of speeds do you need for plasma cutting?
    Dave
  20. #20
    Mar 2017
    164
    Phil , you certainly have some skills there . The type I'd like to have. Really liking how you welded the frame , and those end caps are sure a nice touch
Page 1 of 2 12
  1. Saturn 4x2
    By coherent in forum FineLine Automation
    Last Post: 03-15-2018, 11:51 PM
  2. 2nd Build (first) - Saturn CNC 2'x4'
    By difalkner in forum FineLine Automation
    Last Post: 11-11-2017, 12:56 AM
  3. Saturn 4x4
    By GoFigure in forum FineLine Automation
    Last Post: 04-03-2017, 04:36 AM
  4. Saturn 4 X 4 build
    By sybilsurf in forum FineLine Automation
    Last Post: 03-19-2017, 01:47 AM
  5. Monsters Machine - Saturn 4X4
    By MonsterRobotics in forum FineLine Automation
    Last Post: 01-26-2017, 12:18 AM
