587,753 active members*
3,033 visitors online*
IndustryArena Forum > CAM Software > Visual Mill > Saving cutting tools in library. Can someone help please.
    Nov 2011
    5
    I have been trying to save cutting tools with correct speeds and feeds etc.
    Every time I do this it has not saved it in the library and will go back to the defaut tools.
    Its ok while using it and changing settings, but cant save any changes.
    Sep 2009
    38
    I had the same prob. I did two things: 1) Save your library as a vkb file. 2) edit speeds and feeds in the tool library vs. in an operation. For some reason it doesn't transfer to the library during a save if you only put the speeds/feeds in an operation.
    May 2010
    30
    I found that when you are adding tools, you can save the tool library but not save it through the Knowledge Base directly or it doesn't work. So save the tool to the library or a desktop folder, then load the tool library and drag the tools over you wish to use. BTW, Udi (pronounced ooh day) is awesome. Provides excellent support and seems to know everything in and out. Great program just limited tutorials to get advanced things going.
    I bought a 5 hour training block and taught me the basics.
  1. Saving Tools
    By glorious in forum Mastercam
    Last Post: 05-30-2012, 02:55 AM
  2. Mastercam tools library
    By basim in forum Post Processors for MC
    Last Post: 12-14-2009, 12:15 AM
  3. saving tools
    By delhierro in forum Safety Zone
    Last Post: 04-26-2008, 11:18 AM
  4. How to get more tools in the tool library?
    By clint_so in forum Mastercam
    Last Post: 07-24-2007, 04:55 PM
  5. library of wood tools
    By MikeA in forum Mastercam
    Last Post: 04-23-2004, 10:47 PM
