587,104 active members*
4,229 visitors online*
    Mar 2011
    24
    saving to a dwg.
    I have vectorized a jpeg file in bobart. I want to save it in a dwg. or dxf so I can load it into my autocad where I am more proficient at the editing and then bring it back into bobart to run the gcode. I am able to save it as a dxf or dwg in bobcad but when I go to my autocad to open that file it does not show up in the bobcad directory. Where is it? I have even tried to drag and drop into Autocad with no success. Why have a way to save the file in dwg or dxf if it cannot be opened in Autocad? Please help.
    Feb 2009
    214
    I just did a test that worked.
    I imported a jpg, vectorized it, saved as a dwg, then in autocad 2004 I opened the dwg.
    If the file name does not show up in the folder where you saved it when you use the open command in Autocad, either the file is in another location, or when you are saving you are not getting the right file extension somehow.
    David L. Aery
    www.hooksolutions.com
  1. saving toolpath
    By qnet2 in forum Mastercam
    Last Post: 02-22-2011, 07:21 PM
  2. saving program
    By matchy in forum Haas Mills
    Last Post: 04-02-2010, 10:11 PM
  3. Saving a set of operations
    By John@CRDM in forum Mastercam
    Last Post: 02-05-2010, 03:18 PM
  4. saving files with a DWG or DXF
    By casta-baga in forum Mastercam
    Last Post: 08-07-2008, 04:02 AM
  5. Saving the Changes,
    By CharlieM in forum Uncategorised CAM Discussion
    Last Post: 01-11-2006, 08:24 PM
