603,392 active members*
3,538 visitors online*
Results 1 to 6 of 6
    Oct 2024
    14
    Saving an xy zero?
    Resetting my zero for x and y is a bit of a pain. Is there a way to save the xy zero between jobs.? I
    Re: Saving an xy zero?
    you can add a g10 to your programs if your parts are being located in the same previous positions between jobs
    Apr 2004
    5948
    If your machine has home switches, you can record the offsets from the home position and go back to them next time.
    Andrew Werby
    Website
    Sep 2012
    230
    Quote Originally Posted by Rmess43 View Post
    Which model Techno do you have?
    Eric Feldman - Design Engineer, Programmer
    Armor CNC - http://www.armorcnc.com Support hours: 7am thru 10pm EST, 7 days a week
    Oct 2024
    14
    It’s an LC4896 model. Recording the offsets from home is a good idea.
    Sep 2012
    230
    Home the machine.
    Set your Xyz zeroes wherever you want them.
    Click setup, offsets.
    Store current origin button.
    Pick a slot # to use.
    To retrieve an origin:
    Home the machine
    Double click in the use column to put an x there to select it.
    Click use at the bottom of the screen.
    Say ok
    All set!
    Regards
    Eric
    Www.armorcnc.com
    Eric at Armor CNC . Com
    Full support of the original USA made Techno machines from 2013 and older. 7 days a week. Free support, all parts in stock, all repairs and upgrades.
  1. Saving Sttings
    By jonathanrayce in forum Haas Mills
    Last Post: 11-03-2014, 05:33 PM
  2. Saving a file
    By bjm323 in forum Mastercam
    Last Post: 11-23-2008, 06:22 PM
  3. saving tools
    By delhierro in forum Safety Zone
    Last Post: 04-26-2008, 11:18 AM
  4. Saving the Changes,
    By CharlieM in forum Uncategorised CAM Discussion
    Last Post: 01-11-2006, 08:24 PM
