603,800 active members*
3,733 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Scrap value quesiton, chips vs chunks. Coolant mixed with chips?
Results 1 to 6 of 6
    Jan 2012
    113
    I had a couple questions about making the most out of scrap 6061 aluminum.
    1. Lets say I need to cut a 3" hole in the aluminum with a 1/2" endmill. Would it be more practical to machine a circle so I am left with a cylinder of material dropping out or should I just shave the hole inside of the circle leaving it all as chips?
    2. When getting rid of the chips, does coolant mixed in with them drop the value? What do people usually do when coolant is in the mix?
    Oct 2013
    4
    Once the slug (cylinder of material) becomes free, it can wedge in the hole & break/chip the endmill. It is better to mill the hole to the desired diameter to prevent this from happening. Lastly, it will not affect the value of the chips as long as the majority of coolant has been drained.
    Jan 2012
    113
    Understand, the machining has to be done on both sides, would probably machine 75% of it on one side then flip it over to machine the other side. If I shave off 1/2" out of the inside circle and then mill around the edges of the circle from .5" to say 3" then flip it over and do the other 1" , will the newly formed cylinder just drop 1/2" onto the worktable and stay there as a shiny new cylinder to resell at full non scrap value or would it likely vibrate and cause issues?
    Mar 2012
    52
    so you are going to extra trouble, an risk jamming slug which could break your cutter , just so you can get an extra few cents for the slug in swarf value ?????WTF
    Jan 2006
    2985
    Quote Originally Posted by trialanderror View Post
    At some point, your scrap may have actual value (maybe a 16" ring from2" MIC6 or something). Anything smallish should be turned into chips. You are risking the part you are cutting, a $30 endmill and your time to dig out the slug, replace the endmill, etc. for a little tiny chunk of metal. It WILL bite you.
    Oct 2005
    328
    I've done almost that, except I left 3 tabs and broke the piece out afterward. I didn't do it for scrap value, though. I saved the slug for future projects.
    Dave
  1. My encloser chips & coolant will never get away!
    By TT350 in forum Tormach Personal CNC Mill
    Last Post: 11-20-2009, 08:01 PM
  2. Replies: 8
    Last Post: 09-09-2009, 02:37 PM
  3. chips in coolant sump
    By gromit68 in forum Haas Mills
    Last Post: 06-26-2008, 02:28 PM
  4. Replies: 17
    Last Post: 01-25-2008, 11:42 PM
  5. Cook your chips to make more chips :)
    By ToMMY2ooo in forum Bending, Forging, Extrusion...
    Last Post: 09-07-2004, 07:38 PM
