603,546 active members*
3,949 visitors online*
IndustryArena Forum > Tools / Tooling Technology > Calibration / Measurement > Scraping a cube how to indicate surface flatness and parallelism in 3 planes?
    Jan 2012
    17
    Hello,
    Cube size 45x45x20mm
    Precision needed 0.01mm
    I have surface plate 15x15cm
    Dial indicator Mitutoyo 513-401 dial test indicator.
    What other tools do I need for this ? How to setups for this to work?
    Nov 2013
    5406
    Re: Scraping a cube how to indicate surface flatness and parallelism in 3 planes?
    I suspect you'll need a precision granite square.
    You can use a surface plate and indicator to get two surfaces parallel to each other, but you'll need a reference square to get a surface square to your pair of parallel faces.
    I bought a small square from Precision Granite in California, 6" x 6" x 4.5" AA. Its good.........I wish I could afford a much bigger master square....but I had to settle with this one.
    https://www.precisiongraniteusa.com/products
    Craig
    Jul 2018
    6839
    Hui Smile - You will find clues in here. Peter
    https://pearl-hifi.com/06_Lit_Archiv...l_Accuracy.pdf
  1. Checking flatness on surface plate
    By toadontheroad in forum Calibration / Measurement
    Last Post: 11-13-2013, 10:28 PM
  2. Cut with Surface between two planes
    By CAD2013 in forum Solidworks
    Last Post: 07-16-2012, 07:43 PM
  3. measure the flatness of a flat surface
    By faltklo in forum HEIDENHAIN -> GENERIC
    Last Post: 04-04-2012, 05:12 PM
