603,970 active members*
2,035 visitors online*
Results 1 to 6 of 6
    Screen replacement
    We have 4 Agie wire cuts and the screens are getting less bright as they age. Has anyone found replacements, or made them run LCD screens?
    Dec 2010
    13
    There are replacement monitors available, here: Replacement monitors Agie for example but they are quite expensive. I have been trying to replace the CRT on my old AC100 with an standard monitor of some kind but this far without success... The AGIEMATIC C control, wich I have, used a TTL signal with 19,2 KHZ horizontal and 55,7HZ vertical sync.
    Hard to find, believe me...
    /Rikard
    Aug 2005
    48
    I have just eliminated my CRT problems on Fanucs. I have a LCD Flat screen replacement that slides right in. I bet I can match one for that Agie. And cheaper than the CRT replacement. What is the model of the CRT? How big screen? Is it color or mono?
    Later Jim
    Dec 2010
    13
    I'ts 14" colour. I tried one of these:Video Converters - CGA/EGA/YUV to VGA Arcade HD-Converter PCB (GBS-8220) - JAMMABOARDS.COM - JAMMA Coin-Op Arcade Game Parts - CGA/EGA/YUV to VGA Arcade Converter PCB (GBS-8220) but with no luck. Take a look at the attached picture, thos is the best spec I found on AGIE's original monitors.
    Attached Files Attached Files
    Thanks for this, I will post any success we have.
    Merry Holiday break, what ever it entails, Colin
    Screen Replacement
    Quote Originally Posted by EDM_Fixer View Post
    Later Jim
    Hi Jim
    It's colour, but is only writing, so not important.
    Its a Matsu****a 370MYB22N if that means anything.
    14" diagonal.
    Colin
  1. New Screen set for my touch screen
    By Scott_M in forum Tormach Personal CNC Mill
    Last Post: 08-17-2010, 01:37 PM
  2. Homemade Screen Printer/Silk Screen
    By Sbthomas13 in forum Machine Created Art
    Last Post: 02-14-2009, 01:35 AM
  3. Replies: 6
    Last Post: 07-13-2008, 11:28 PM
  4. EZ-Track Mills LCD Screen Replacement Kits
    By RADAPG1 in forum News Announcements
    Last Post: 03-20-2008, 03:51 AM
