Re: segment to short
Klm123
The message (rapid plane Z is same as R value) is letting you know the rapid move G00 Z0.1 is the same as the R0.1 value in the G83 canned cycle on the line before. Z would not move. It's only a message. The message has been removed many years ago in CNC Lite. Your system is 9 1/2 years old.
No need for this line G00 Z0.1
The R0.1 (rapid clearance plane) in the G83 canned cycle rapids to the same place.
You may either delete this line or else use a slightly higher Z to rapid too to be safe.
Tech Support
CamSoft Corp.
[email protected]
PH 951-674-8100
Fax 951-674-3110
PC Based CNC Controller For The Machine Tool CNC Retrofit And CNC Controller OEM Market
