603,936 active members*
3,921 visitors online*
Results 1 to 6 of 6
    Nov 2013
    45
    Segmented Corners
    Hello,
    I have a minor problem when cornering on my mill. Sometimes depending on the corner radius and speed (.25 radius at 15 IPM) I get segmented corners instead of being smooth.You can feel the servo making jerky moves on these corners. I am using KMCNC and have played with the trajectory settings but maybe I have missed the correct combination or setting altogether. I have considered that this may be a servo tuning issue as well but jogging seems to be smooth and trouble free. Anyone have any advice on this?
    Thanks.
    May 2006
    4091
    Re: Segmented Corners
    Hi Epiphany
    What is the GCode doing? A G2/G3 Arc? Or line segments? Can you see segments in the GCode Viewer? (You will need to run not simulate). What are your TP Settings?
    Regards
    TK
    http://dynomotion.com
    Nov 2013
    45
    Tom,
    Thanks for the reply.
    The G code viewer does not show segments. (I ran the machine with no tool to verify)
    Break Angle- 5
    Look Ahead- .5
    Collinear Tolerance- .001
    Corner Tolerance- .0001
    Facet Angle- 5
    Here is snippet of the code I am running.
    (PROGRAM NAME - TOP BRACKET.NC)
    (POST -AAA_Tree)
    (DATE - TUE. 04/01/2014)
    (TIME - 01:23PM)
    N01 G20 G40 G49 G80 G90 G59.3
    N02 G0 G90 G53 Z0.
    (JOB 1 PROFILE)
    (SLOT)
    N03 M01 ( T1 M6)
    N04 S2200 M03
    N05 G00 G90 G54 X-3.1425 Y-3.376
    N06 G43 H1 Z.1
    N07 G01 Z-.1 F10.
    N08 Y-3.126 F16.
    N09 G17 G02 X-3.5185 Y-2.75 I0. J.376 F11.2
    N10 G01 Y-2.36 F16.
    N11 G02 X-3.1425 Y-1.984 I.376 J0. F11.2 *Segmenting seems to be the worst here
    N12 G01 X-2.9967 F16.
    N13 G02 X-2.9242 Y-1.9911 I0. J-.376 F11.2
    N14 G03 X-2.8425 Y-1.999 I.0817 J.416
    N15 G01 X-2.1875 F16.
    N16 G03 X-2.1875 Y-1.001 I0. J.499 F11.2
    N17 G01 X-2.8425 F16.
    N18 G03 X-2.9242 Y-1.0089 I0. J-.424 F11.2
    N19 G02 X-2.9967 Y-1.016 I-.0725 J.369
    N20 G01 X-3.1425 F16.
    N21 G02 X-3.5185 Y-.64 I0. J.376 F11.2
    N22 G01 Y-.25 F16.
    N23 G02 X-3.1425 Y.126 I.376 J0. F11.2 *And here
    N24 G01 Y.376 F16.
    N25 G00 Z.1
    Thanks for the support.
    May 2006
    4091
    Hi Epiphany,
    What Version are you running? Are you selecting "Arcs to Segments" ?
    Try Setting:
    Collinear Tolerance- .0001
    Facet Angle- 1
    Regards
    TK
    Nov 2013
    45
    Tom,
    Sorry been out of town.
    4.31s
    No, this is not selected.
    Try Setting:
    Facet Angle- 1
    This worked fantastic. Thanks so much.
    This machine is so much more user friendly now its amazing and now has rigid tapping to boot. Great product and support.
    Getting ready to start the next machine. Mori Seiki SL1 lathe. What is the current status of the single point threading, is the canned cycle supported or will this have to be done in C?
    May 2006
    4091
    Single Point Threading with KMotionCNC
    Hi Epiphany,
    KMotionCNC Version 4.32a supports G32 for single point Threading. You shouldn't need any C Programming. But not yet G76.
    please see this post.
    Leo made a video. See:
    More work is needed to make KMotionCNC more Lathe friendly. But the basic functionality is working.
    Regards
    TK
  1. Segmented linear moves for arcs?
    By Spencer myers in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 12-20-2016, 03:23 PM
  2. Bad corners
    By Pysiek in forum PhotoVCarve and VCarve Pro
    Last Post: 12-19-2013, 04:40 PM
  3. Mini-Mill Segmented Tool Disk Upgrade CAT40 10-Tool
    By C.M.I. in forum News Announcements
    Last Post: 12-17-2009, 07:36 PM
  4. New actuators based on the segmented spindle
    By kataka1 in forum News Announcements
    Last Post: 06-16-2008, 12:18 PM
  5. Segmented motion?
    By Guy Smiley in forum Machines running Mach Software
    Last Post: 02-07-2006, 01:05 PM
