603,936 active members*
3,741 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Seig X1 mill - Initial Conversion Design - pdfs
Results 1 to 5 of 5
    Mar 2007
    30
    Hi all,
    I think I've got the preliminary mechanical design complete for converting
    my X1 Micro Mill. Attached are some pdfs of the 3d model.
    I'm using NEMA 23 steppers. A 5/8" rolled ballscrew for the Z axis and
    the existing lead screws/nuts for the X & Y axis.
    Should be ready to start cutting metal soon....
    Jeff
    Attached Files Attached Files
    Jan 2005
    224
    The PDFs look good.
    Please post status and pictures as you progress with it.
    Pres - fellow X1 (w/LMS table extensions) user.
    Mar 2007
    30
    Thanks Pres......I'll keep u updated....
    Jeff
    Apr 2007
    Cool ball screw supplier
    Hi, im also converting a re-branded x1 but have trouble with all axis (mostly near the ends of the screws), may need a counter-weight for the Z axis. Where did you get your ball screw and was it expensive?
    Im in England so if you know of a more local supplier that would be good.
    Cheers
    Shaun
    Jul 2007
    212
    Shaun,
    You may want to try sending him an IM or e-mail, as his last post in this thread was almost 2 years ago. ;-)
    -Caleb105-
  1. Taig/Seig Mill physical size
    By praetor in forum Uncategorised MetalWorking Machines
    Last Post: 04-05-2007, 03:58 PM
  2. Confused - G81 & initial plane
    By mbam in forum Fadal
    Last Post: 03-23-2007, 04:52 AM
  3. Converting PDFs to DXF And so on
    By planekrazie in forum Machine Created Art
    Last Post: 01-27-2007, 05:02 AM
  4. mill comparison help seig x2 vs sherline
    By daedalus in forum Benchtop Machines
    Last Post: 09-27-2005, 07:28 PM
  5. Mazatrol M-1 - Initial procedure
    By lecamtu in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-23-2005, 04:22 PM
