Selecting CNC Router Bits
I have recently finished my CNC Router Parts 4896 Router and looking for some router bits. I am using a Porter Cable 7518 Router as my spindle (3.25 hp, variable speed) and will be routing melamine and plywood for cabinet parts.
What type bits will minimize chipping on the melamine and tearout on crosscuts for the plywood? I hear alot about compression bits, but I am under the impression that you need to cut the sheed in 1 pass for them to do any good. Is this correct. Obviously upcut and downcut will leave 1 surface good and potentially 1 bad.
Looking to feed around 300 ipm at around a 1/4" DOC based on trials with the machine capabilities so far. This is a hobbiest environment so no $200 bits in the budget.
Dan
Check out what I am working on at www.routerbitz.com!
