588,136 active members*
5,715 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Selecting Start Point for Plunge Roughing - V28
Results 1 to 8 of 8
    Nov 2013
    29
    Iam doing some experimenting with plunge roughing in V28 and cant seem to modify the start point of the cutter. As you know, most plunge cutters arent center cutting, so I cant just slam the tool into the material.
    Any help is appreciated.
    -Geoff
    -Geoff Warner
    VegasCarts.com & myVegasCarts.com
    Re: Selecting Start Point for Plunge Roughing - V28
    Can you use Spiral or Ramp lead in rather than plunging?
    Dec 2015
    7
    hi
    in my experience spiral and compression cutters are noyt designed to plunge but ok to ramp in and out with a lead in and out.
    I have been cncing wood for a number of years now and i always use a standard 2 flute cutter to plunge for a pocket cycle then come in with spiral cuttter to finish it off.
    When roughing a componanant out i always leave .25mm on stock then come in and do a final pass,I hope this helps you
    Nov 2013
    29
    I'm using an MFH Raptor High Feed Mill which is specifically designed to plunge. Look up some videos on YouTube regarding plunge milling....its one of the fastest ways to rough material.
    You've both now been enlightened!
    Quote Originally Posted by newbie1968 View Post
    hi
    -Geoff Warner
    Quote Originally Posted by geoffw View Post
    Not by your first post where you didn't bother to mention that though! ;-)
    -Geoff
    It's easy to be smart about information you don't furnish to those you are expecting to help, why say you can't when you subsequently state you are using a tool which specifically can? Now you too have been enlightened! :P
    Dec 2008
    4548
    The plunge roughing feature is a raster, simple planar strategy. Your control is a directional control called setting the lace angle, which will determine in which direction it rasters....
    But a plunge rough is a plunge! there is no concern for plunging a tool into material in a plunge rough? What's the point!
    You can set a peck amount.....
    If you cant have the surface extended to then use a boundary to control where the first plunge occurs,(The first plunge becomes the full bit) you will need to add an operation to that area to remove the material another way....
    Dec 2008
    4548
    You can add a planar surface to the geometry selection to extend the plunge out of the boundary half the tool distance (since it computes at tip)... That will allow the plunge to "nibble" into the rough....
    Apr 2009
    3376
    WOW,,,,I have been doing 4140 all wrong
  1. Selecting start point for 2D pocket - V25
    By TonyW in forum BobCad-Cam
    Last Post: 07-08-2013, 08:31 PM
  2. Plunge Roughing in VM
    By bruce34rr in forum Visual Mill
    Last Post: 03-16-2012, 06:10 AM
  3. plunge roughing
    By conklin36 in forum EdgeCam
    Last Post: 05-15-2010, 02:09 PM
  4. Chaining from specific start point for plunge
    By jrrhotrod in forum Mastercam
    Last Post: 04-19-2008, 07:46 PM
  5. Plunge roughing?
    By RdHawg in forum Hypermill
    Last Post: 01-04-2007, 12:42 AM
