603,958 active members*
2,027 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Sequence Restart question
Results 1 to 11 of 11
    Mar 2005
    110
    I'm not sure where to post this question so I'll post it here since I'm most familiar with Okuma Lathes. I've been sequence restarting Okumas for 30 years so that's not my problem.
    Recently I bought a Dainichi with a Fanuc 6T and I use G71 for lap programming and G70 for the finishing cycle. My question is how do I pick up the finishing pass for a rerun? Thanks.
    Jul 2010
    287
    You sell it, buy an Okuma, reprogram the part for OSP, then run it in there.
    But seriously, it has to do with you running in dry run and turning it off when you're ready to continue I believe. But you'd be better off looking on a different forum. Even a mori or clausing forum maybe.
    Mar 2005
    110
    That's what I ended up doing. Ran in dry run mode to the finish pass. Thought there might be a different way.
    BTW I do have about a dozen Okuma lathes including 3 LC-40"s. But this Dainichi has a 21 inch Kitagawa chuck, 60 inch between centers and does bigger work. Even dry running it takes a very long time to get to the finish pass.
    Thanks for your response.
    Aug 2011
    2517
    nar that's the wrong way to do it.
    put single block on. In MEMORY run the program to where the tool is positioned before the G71 line, switch to EDIT and cursor to the G70 line. Put back to MEMORY, single block off and press start. that works on every Fanuc control I've ever seen from 6T to latest 32i
    Mar 2005
    110
    Thanks guys. I tried it this morning and all is good. I had looked through all the manuals but could not find anything.
    Aug 2011
    2517
    its not in the manual. it's a secret ;-)
    actually they would never tell you that because it requires knowledge of the program and what it does and since every program is different they can not cover all bases. if someone were to carelessly skip over program lines without knowledge of what they are doing it would present a crash situation.
    Oct 2010
    134
    You can try this program format also,
    and when you want to finish only, you push the "block delete" button.
    I don't have my program in front of me, but it should look like this:
    0010
    Header.......
    Tool, rpm, coolant
    G0 X Z (approch)
    \G71 P100 Q200 etc......
    P100 shape.......
    shape ..............
    Q200 shape end
    \G70 P100 Q200 etc....
    go home
    M02
    Mar 2005
    110
    Thanks Tancuda. Looks like that would work. Am I correct in saying that in line P100 I would put the finishing speed and feed? But what if I want to use a DNMG instead of a CNMG for finishing?
    Aug 2011
    2517
    that example is for 1 tool. yes you can add a finishing speed to the first P100 line.
    if you want a different tool for finishing add another process and just give it the G70
    like this.....
    N1 G50 S1000
    G0 T0101
    G96 S.... M3
    G0 X.... Z....
    P100 shape.......
    Q200 shape end
    go home
    T0100
    M01
    N2 G50 S1000
    G0 T0202
    G96 S.... M3
    G0 X.... Z......
    go home
    T0200 M5
    M02
    if you want to run the finish cut go to edit, cursor to N2, switch to memory and press start.
    Oct 2010
    134
    Sorry for the delay Stude8,
    fordav11 is correct, my program are for a large vertical lathe with one big part at a time, so I don't mind
    changing the tool number, and cycle start every time, but for small machine with lot's of parts, fordav11's method is good.
    Mar 2005
    110
    Thanks all! I understand and now will save lots of air cutting time.
  1. FLA 2x4 Machine - Build Sequence Question
    By adt2 in forum DIY CNC Router Table Machines
    Last Post: 07-21-2011, 01:11 PM
  2. Replies: 6
    Last Post: 02-10-2011, 07:06 AM
  3. Restart sequence in U-10
    By edufer1 in forum Okuma
    Last Post: 11-25-2010, 02:31 AM
  4. cut sequence
    By camtd in forum Surfcam
    Last Post: 06-13-2006, 05:26 PM
  5. Sequence #'s
    By Mountainwildman in forum Post Processors for MC
    Last Post: 04-02-2006, 05:25 PM
