Will a standard db9 to db15 cable work for serial communications between a laptop and an allen bradley 9/series? Or would I need a custom cable?
This doesn't sound like a standard cable. You can configure a custom serial cable here:
http://www.showmecustomcables.com
You would not use the 15pin port on this machine for RS232 communication. The machine will have typically a DB9 but on some models of the 9 series they have used DB25 as well. If you need help with clarification on wiring, give me a call - We have the wiring info as well as some manuals I can provide to you.
Greg Mercurio -Shop Floor Automations
www.shopfloorautomations.com /619-461-4000
check this link
http://www.kfasllc.com/rs232_setup.htm
