603,795 active members*
2,898 visitors online*
Results 1 to 4 of 4
    Mar 2009
    291
    serial numbers
    Hi i have a part that needs to have serial numbers ingraved on them.I have a fanuc 21i control.How do i go about programing that?I would like it to be a sub program so i could use it on many part numbers.Mabie call it up with a g code and enter a x y z start point a z depth and height of number?
    Feb 2006
    992
    post your pix on here we can mipulate the program, since we don't know what it look like. It's seem this same subject post on here once every month.
    The best way to learn is trial error.
    Aug 2009
    684
    Engraving
    Doesn't 21i have Engraving Cycle (G1025 I think)?
    DP
    Nov 2006
    418
    I think it was Al_the_Man that posted a link to CNC Concepts the other day, and they have a set of macro's available for free download.
    Go to:http://www.cncci.com/resources/tips/engrave.htm
    You could use these as a basis to build the few needed to complete the set with numbers.
  1. serial numbers
    By 1234567 in forum Fanuc
    Last Post: 02-13-2010, 12:03 PM
  2. engraving serial numbers
    By mls in forum Haas Mills
    Last Post: 09-18-2009, 02:22 AM
  3. macro to engrave serial numbers
    By nmn in forum Parametric Programing
    Last Post: 05-29-2009, 03:33 AM
  4. Engraving Serial Numbers
    By drk in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 07-01-2007, 03:26 PM
  5. Posting sequentiol serial numbers
    By NateG in forum Engraving Machines
    Last Post: 06-22-2007, 12:09 PM
