588,567 active members*
5,078 visitors online*
Results 1 to 4 of 4
    Mar 2008
    31
    Series 0 control
    How can I turn on the servo diag page. It is on the soft key menu with parameter and diagnostics. The one that shows the load and percent of current of the specific axis and the axis parameters.
    We have other machines with same control that has this function turned on, and this one does not. Is it a parameter or a option??
    Thanks in advance...
    Jan 2006
    59
    Talking
    On the Fanuc 0 the parameter # is 389 bit 0. Change it from 1 to 0 (need to have PWE on). I don't remember if you need to power down and back up again though.
    Once you have this enabled BE CAREFUL. Parameters in this screen can be changed WITHOUT PWE enabled (on). I just had a customer accidentally change one!
    RRL
    Mar 2008
    31
    I tried it and they are already set to 0. This is a 0-tt control...on a Saginaw twin vertical lathe. The screen should show sv-prm for the soft button, but doesn't. Anything other than parameter 389??
    Jan 2006
    59
    If this is a "TT" you will need to do both sides Right and Left.
    RRL
  1. Series II BOSS 6 Control panel issue
    By btcoutermash in forum Bridgeport / Hardinge Mills
    Last Post: 04-05-2008, 11:56 PM
  2. Help with BP series I with BOSS 4 control
    By rhemp in forum Bridgeport / Hardinge Mills
    Last Post: 08-07-2007, 04:37 PM
  3. Series 2 r2e3 control retrofit
    By cut more in forum Bridgeport / Hardinge Mills
    Last Post: 05-09-2007, 03:09 PM
  4. acramatic series 5 control
    By PETE1968 in forum Uncategorised MetalWorking Machines
    Last Post: 04-04-2007, 06:59 PM
  5. BP Series 1 CNC conversion to new control
    By ps2727 in forum Bridgeport / Hardinge Mills
    Last Post: 06-29-2005, 09:09 PM
