587,753 active members*
2,906 visitors online*
IndustryArena Forum > Community Club House > Environmental / Alternate Energy > Series KPH transformer oil regeneration device
    Apr 2013
    Post Series KPH transformer oil regeneration device
    Application:
    Series KPH transformer oil regeneration device use of a special active clay for purifying and regenerating the unqualified transformer oil, switch oil, mutual inductor, it also can be used as absorption unit for treating low viscosity lube oils. Series KPH can remove acid, free carbon, oxides, pigment and particles, it dose not affect insulating oil ingredients and anti-oxidation. Restoring oil dielectric strength, the treated oil is limpidity. It can save 90% cost than replacing of new oil.
    KPH is mainly to regenerate the old insulating oil, it remove acid, sludge, oxidation and various of resultant, the treated oil is limpidity and clarity color. After the regenerating process, we suggest to use the vacuum insulating oil purifier to purify regenerated oil, remove the trace water, gas, and tiny particles. Getting more higher dielectric strength.
    Regeneration Machine Features:
    1.Use of special chemicals to eliminate oil-ion’s charge polarity, collecting oil-ions and separating out them, removing colloid, asphalt and other chemical compounds.
    2.Gas treatment device combined with air filter and vacuum degassing, dewatering to remove the odor and water.
    3.Closed type filtering system use stainless steel mesh, reliable, no pollution. Two filtering units can realize continuous production.
    4.Vacuum degassing, dewatering, removing particles make sure effectively improve oil properties, restoring oil performance.
    5.Efficient electric heating system, heating uniformity, less power consumption, safe, and reliable.
    6.Compact structure, reasonable layout, small space applied, large output.
    7.Imported Germany electric parts (such as SIEMENS, SCHNEIDER), good performance, safe and reliable.
    Dec 2013
    35
    You have shared a very good information about the oil regeneration device, it really raise our eyes about this device.
    __________
    Tarpomatic.net
  1. Replies: 2
    Last Post: 06-27-2008, 12:52 AM
  2. Bridgeport Series 2 Interact 2 Transformer
    By rrossey in forum Bridgeport / Hardinge Mills
    Last Post: 01-23-2007, 02:09 PM
  3. NSH VFD transformer Oil Regeneration plant
    By sinonsh22 in forum News Announcements
    Last Post: 11-06-2006, 07:56 AM
  4. Sino-nsh transformer oil regeneration
    By sinonsh22 in forum Mechanical Calculations/Engineering Design
    Last Post: 10-13-2006, 07:06 AM
