I have an old fanuc servo I would like to use but need to find an appropriate servo amp, motor is:
40S/2000
A06B-0583-B065#7000
Searching the forum I found some fanuc data sheets which say the motor has a high resolution pulse coder 25000p/r but for the high resolution models it does not say whether it is absolute or incremental. Also is the encoder a standard quadrature or fanuc proprietary? Either way where could I find pinouts for it?
Matching it to the 'original' fanuc amp would be an option but I am not sure how.
Are there any model number references for fanuc servo amps like for the motors?
I plan on using Mesa cards and EMC to drive it, the final card will depend on if I can find an analog or pwm amp.
Thanks.
